[cgma-dev] r2525 - in cgm/trunk/geom: . ACIS_SRC OCC facet
    janehu at mcs.anl.gov
    Fri Jan  9 14:51:43 CST 2009
Author: janehu
Date: 2009-01-09 14:51:43 -0600 (Fri, 09 Jan 2009)
New Revision: 2525
Modified:
   cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.cpp
   cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.hpp
   cgm/trunk/geom/GeometryModifyEngine.hpp
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
   cgm/trunk/geom/OCC/OCCModifyEngine.hpp
   cgm/trunk/geom/facet/FacetModifyEngine.cpp
   cgm/trunk/geom/facet/FacetModifyEngine.hpp
Log:
Added webcut function to use a tool_body to webcut, since this function is not going to change any memeber of OCCModifyEngine, and the internal operation intersect and subtract are both non-const, change the const signature to non.
Modified: cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.cpp
--- cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.cpp	2009-01-09 19:49:30 UTC (rev 2524)
+++ cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.cpp	2009-01-09 20:51:43 UTC (rev 2525)
@@ -9925,7 +9925,7 @@
 				       DLIList<BodySM*>& webcut_body_list,
 				       BodySM const* tool_body,
 				       DLIList<BodySM*>& results_list,
-				       bool imprint)const
+				       bool imprint)
       // check the tool body if it is made of AcisModifyEngine
       if( !is_modify_engine(tool_body))
Modified: cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.hpp
--- cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.hpp	2009-01-09 19:49:30 UTC (rev 2524)
+++ cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.hpp	2009-01-09 20:51:43 UTC (rev 2525)
@@ -482,7 +482,7 @@
-            bool imprint  = false) const;
+            bool imprint  = false) ;
     //R int
     //R- Number of bodies that were webcut ( >= 0 )
     //I webcut_body_list
Modified: cgm/trunk/geom/GeometryModifyEngine.hpp
--- cgm/trunk/geom/GeometryModifyEngine.hpp	2009-01-09 19:49:30 UTC (rev 2524)
+++ cgm/trunk/geom/GeometryModifyEngine.hpp	2009-01-09 20:51:43 UTC (rev 2525)
@@ -556,7 +556,7 @@
-                    ) const = 0 ;
+                    ) = 0 ;
       //R int
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2009-01-09 19:49:30 UTC (rev 2524)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2009-01-09 20:51:43 UTC (rev 2525)
@@ -1835,13 +1835,15 @@
         stat = CUBIT_FAILURE;
         //Add imprint code here
         if(imprint)
           stat = imprint_toposhapes(from_shape, tool_shape);
-        if(!stat)
-          PRINT_ERROR("Can't do imprint operation on the body. \n");
-          count++;
+          if(!stat)
+            PRINT_ERROR("Can't do imprint operation on the body. \n");
+            count++;
+          continue;
-        continue;
@@ -3389,7 +3391,7 @@
   for (int i = 0; i < shape_list.size(); i++)
     TopoDS_Shape* from_shape = shape_list.get_and_step();
-    //BodySM* from_body = from_bodies.get_and_step();
+    BodySM* from_body = from_bodies.get_and_step();
     BRepAlgoAPI_Common intersector(*from_shape, *tool_shape);
     TopoDS_Shape common_shape = intersector.Shape();
     check_operation(common_shape, from_shape, is_volume[i], has_changed,
@@ -3398,7 +3400,7 @@
     if(from_shape->IsNull())
       PRINT_INFO("The %d body did not have common part with the tool_body.\n", i+1);
-      continue;
+      new_bodies.append(from_body);
     else
       tbs += OCCQueryEngine::instance()->populate_topology_bridge(*from_shape);
@@ -4494,19 +4496,45 @@
-// Function   : webcut
+// Function   : webcuts a list of bodies using another Body as the tool.
 // Member Type: PUBLIC
 // Description:
-// Author     : John Fowler
-// Date       : 10/02
+// Author     : Jane Hu
+// Date       : 01/09
-CubitStatus    OCCModifyEngine::webcut(DLIList<BodySM*>& /*webcut_body_list*/,
-                                 BodySM const* /*tool_body*/,
-                                 DLIList<BodySM*>& /*results_list*/,
-                                 bool /*imprint*/ ) const
+CubitStatus    OCCModifyEngine::webcut(DLIList<BodySM*>& webcut_body_list,
+                                BodySM const* tool_body,
+                                DLIList<BodySM*>& results_list,
+                                bool imprint )
-  PRINT_ERROR("Option not supported for mesh based geometry.\n");
-  return CUBIT_FAILURE;
+  //do intersect and subtract separately and with imprint option and keep_old
+  // is true.
+  //tool_body is a const pointer points to varible BodySM object
+  //here trying to create a non-const pointer points to the same BodySM object.
+  BodySM *body, *body2;
+  body = brick(1,1,1);
+  body2 = body;
+  *body = *tool_body;
+  CubitStatus stat = intersect(body, webcut_body_list, results_list,
+                               CUBIT_TRUE);
+  if(stat)
+    PRINT_ERROR("Failed to webcut the bodies.\n");
+    return CUBIT_FAILURE;
+  DLIList<BodySM*> tool_bodies;
+  tool_bodies.append(body);
+  stat = subtract(tool_bodies, webcut_body_list, results_list, imprint,
+                  CUBIT_TRUE);
+  OCCQueryEngine::instance()->delete_solid_model_entities(body2);
+  return stat;
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.hpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.hpp	2009-01-09 19:49:30 UTC (rev 2524)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.hpp	2009-01-09 20:51:43 UTC (rev 2525)
@@ -317,7 +317,7 @@
   virtual CubitStatus webcut(DLIList<BodySM*>& webcut_body_list,
-    bool imprint = false ) const;
+    bool imprint = false ) ;
   virtual CubitStatus webcut_across_translate( DLIList<BodySM*>& body_list,
     Surface* plane_surf1,
Modified: cgm/trunk/geom/facet/FacetModifyEngine.cpp
--- cgm/trunk/geom/facet/FacetModifyEngine.cpp	2009-01-09 19:49:30 UTC (rev 2524)
+++ cgm/trunk/geom/facet/FacetModifyEngine.cpp	2009-01-09 20:51:43 UTC (rev 2525)
@@ -2007,7 +2007,7 @@
-             bool /*imprint*/ )const
+             bool /*imprint*/ )
Modified: cgm/trunk/geom/facet/FacetModifyEngine.hpp
--- cgm/trunk/geom/facet/FacetModifyEngine.hpp	2009-01-09 19:49:30 UTC (rev 2524)
+++ cgm/trunk/geom/facet/FacetModifyEngine.hpp	2009-01-09 20:51:43 UTC (rev 2525)
@@ -330,7 +330,7 @@
-    bool imprint = false)const;
+    bool imprint = false);
More information about the cgma-dev
