[cgma-dev] r2276 - cgm/trunk/geom/OCC
Tim Tautges tautges at mcs.anl.gov
Thu Nov 20 15:21:36 CST 2008
Jane,
   Good job, this sort of support is very important to the "big picture".
- tim
janehu at mcs.anl.gov wrote:
> Author: janehu
> Date: 2008-11-20 15:17:58 -0600 (Thu, 20 Nov 2008)
> New Revision: 2276
> Modified:
>    cgm/trunk/geom/OCC/OCCDrawTool.cpp
>    cgm/trunk/geom/OCC/OCCQueryEngine.cpp
>    cgm/trunk/geom/OCC/OCCQueryEngine.hpp
> Log:
> Partial fix for user reported error in OCCDrawTool, and some minor changes.
> Modified: cgm/trunk/geom/OCC/OCCDrawTool.cpp
> --- cgm/trunk/geom/OCC/OCCDrawTool.cpp	2008-11-19 19:06:22 UTC (rev 2275)
> +++ cgm/trunk/geom/OCC/OCCDrawTool.cpp	2008-11-20 21:17:58 UTC (rev 2276)
> @@ -70,7 +70,7 @@
>      for (ii=1; ii<=M.Extent(); ii++)
>            TopologyBridge *face = OCCQueryEngine::instance()->occ_to_cgm(M(ii));
> -          OCCSurface *occ_face = CAST_TO(occ_face, OCCSurface);
> +          OCCSurface *occ_face = CAST_TO(face, OCCSurface);
>            Face_list.append_unique(occ_face->get_TopoDS_Face());
>      int i;
> @@ -181,6 +181,9 @@
>    GMem g_mem;
>    int num_points;
>    OCCQueryEngine *OQE = OCCQueryEngine::instance();
> +  double tol = OQE->get_sme_resabs_tolerance();
> +  if (curve->get_arc_length() < tol)
> +    return CUBIT_SUCCESS;
>    // get the graphics
>    CubitStatus stat;
>    stat = OQE->get_graphics( curve, num_points, &g_mem );
> Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
> --- cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2008-11-19 19:06:22 UTC (rev 2275)
> +++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2008-11-20 21:17:58 UTC (rev 2276)
> @@ -31,8 +31,11 @@
>  #include "Poly_Triangle.hxx"
>  #include "BRepAlgoAPI_BooleanOperation.hxx"
>  #include "Handle_Poly_Triangulation.hxx"
> +#include "BRepAdaptor_Curve.hxx"
> +#include "BndLib_Add3dCurve.hxx"
>  #include "Poly_Polygon3D.hxx"
>  #include "Handle_Poly_Polygon3D.hxx"
> +#include "BRepMesh_FastDiscret.hxx"
>  #include "OCCQueryEngine.hpp"
>  #include "OCCModifyEngine.hpp"
>  #include "Poly_Triangulation.hxx"
> @@ -269,15 +272,32 @@
>    TopLoc_Location L;
>    Handle_Poly_Triangulation facets = BRep_Tool::Triangulation(*Topo_Face, L);
> +  if(facets.IsNull())
> +    //do triangulation
> +    double deflection = 0.01;
> +    double angle  = 0.5;
> +    BRepAdaptor_Surface asurface(*Topo_Face);
> +    Bnd_Box aBox;
> +    BndLib_AddSurface::Add(asurface, Precision::Approximation(), aBox);
> +    BRepMesh_FastDiscret *myMesh =
> +    new BRepMesh_FastDiscret(deflection, *Topo_Face, aBox, angle, Standard_True, Standard_True);
> +    if (myMesh != NULL) delete myMesh;
> +    facets = BRep_Tool::Triangulation(*Topo_Face, L);
> +      PRINT_ERROR("Can't get triangulation representation for this surface.\n");
> +      return CUBIT_FAILURE;
>    //if necessary, the face tolerance can be returned. now, no use.
>    //double tol = BRep_Tool::Tolerance(*Topo_Face);
>    number_points = facets->NbNodes();
>    number_triangles = facets->NbTriangles();
> -  assert(number_points == 3 * number_triangles);
>    number_facets = 4 * number_triangles;
> -  Poly_Array1OfTriangle triangles(0, number_facets-1);
> +  Poly_Array1OfTriangle triangles(0, number_triangles-1);
>    triangles.Assign( facets->Triangles() );
>    int *facetList =  new int[number_facets];
>    //needs to test that N1, N2, N3 index are starting from 0 to number_points-1
> @@ -337,20 +357,28 @@
>    if (!Topo_Edge)
> -  TopLoc_Location L;
> -  Handle_Poly_Polygon3D facets = BRep_Tool::Polygon3D(*Topo_Edge, L);
> +  BRepAdaptor_Curve acurve(*Topo_Edge);
> +  Bnd_Box aBox;
> +  BndLib_Add3dCurve::Add(acurve, Precision::Approximation(), aBox);
> +  new BRepMesh_FastDiscret(deflection, *Topo_Edge, aBox, angle, Standard_True, Standard_True);
> +  if (myMesh == NULL)
> +    PRINT_ERROR("Can't get triangulation representation for this curve.\n");
> +  num_points = myMesh->NbVertices();
> -  num_points = facets->NbNodes();
> -  TColgp_Array1OfPnt points(0, num_points-1);
> -  points.Assign(facets->Nodes());
>    //! Note: If the polygon is closed, the point of closure is
>    //! repeated at the end of its table of nodes. Thus, on a closed
>    //! triangle the function NbNodes returns 4.
>    GPoint *gPnts= new GPoint[num_points];
> -  for (int i = 0; i < num_points ; i ++)
> +  for (int i = 1; i <= num_points ; i ++)
> -      gp_Pnt gp_pnt = points.Value(i);
> +      gp_Pnt gp_pnt = myMesh->Pnt(i);
>        GPoint gPnt;
>        gPnt.x = gp_pnt.X();
>        gPnt.y = gp_pnt.Y();
> @@ -359,6 +387,7 @@
>    gMem->replace_point_list( gPnts, num_points, num_points );
> +  delete myMesh;
> @@ -1871,7 +1900,7 @@
>  // Creation Date : 12/12/07
>  CubitStatus
> -OCCQueryEngine::unhook_CoFaces_from_OCC( DLIList<OCCCoFace*> cofaces) const
> +OCCQueryEngine::unhook_CoFaces_from_OCC( DLIList<OCCCoFace*>& cofaces) const
>    int size = cofaces.size();
>    while(size > 0)
> @@ -2051,7 +2080,7 @@
>  CubitStatus
> -OCCQueryEngine::unhook_CoEdges_from_OCC( DLIList<OCCCoEdge*> coedges) const
> +OCCQueryEngine::unhook_CoEdges_from_OCC( DLIList<OCCCoEdge*>& coedges) const
>    int size = coedges.size();
>    while(size > 0)
> Modified: cgm/trunk/geom/OCC/OCCQueryEngine.hpp
> --- cgm/trunk/geom/OCC/OCCQueryEngine.hpp	2008-11-19 19:06:22 UTC (rev 2275)
> +++ cgm/trunk/geom/OCC/OCCQueryEngine.hpp	2008-11-20 21:17:58 UTC (rev 2276)
> @@ -274,8 +274,8 @@
>    CubitStatus unhook_Lump_from_OCC( Lump* lump ) const;
>    CubitStatus unhook_ShellSM_from_OCC( ShellSM* shell ) const;
> -  CubitStatus unhook_CoEdges_from_OCC( DLIList<OCCCoEdge*> coedges) const;
> -  CubitStatus unhook_CoFaces_from_OCC( DLIList<OCCCoFace*> cofaces) const;
> +  CubitStatus unhook_CoEdges_from_OCC( DLIList<OCCCoEdge*>& coedges) const;
> +  CubitStatus unhook_CoFaces_from_OCC( DLIList<OCCCoFace*>& cofaces) const;
>    CubitStatus unhook_LoopSM_from_OCC( LoopSM* loopsm) const;
>    CubitStatus delete_loop( LoopSM* loopsm)const;
>    void unhook_cofaces_of_a_surface(OCCSurface* surface)const;
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the cgma-dev mailing list
