[cgma-dev] r2276 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov janehu at mcs.anl.gov
Thu Nov 20 15:17:58 CST 2008
Author: janehu
Date: 2008-11-20 15:17:58 -0600 (Thu, 20 Nov 2008)
New Revision: 2276
Modified:
   cgm/trunk/geom/OCC/OCCDrawTool.cpp
   cgm/trunk/geom/OCC/OCCQueryEngine.cpp
   cgm/trunk/geom/OCC/OCCQueryEngine.hpp
Log:
Partial fix for user reported error in OCCDrawTool, and some minor changes.
Modified: cgm/trunk/geom/OCC/OCCDrawTool.cpp
--- cgm/trunk/geom/OCC/OCCDrawTool.cpp	2008-11-19 19:06:22 UTC (rev 2275)
+++ cgm/trunk/geom/OCC/OCCDrawTool.cpp	2008-11-20 21:17:58 UTC (rev 2276)
@@ -70,7 +70,7 @@
     for (ii=1; ii<=M.Extent(); ii++)
           TopologyBridge *face = OCCQueryEngine::instance()->occ_to_cgm(M(ii));
-          OCCSurface *occ_face = CAST_TO(occ_face, OCCSurface);
+          OCCSurface *occ_face = CAST_TO(face, OCCSurface);
           Face_list.append_unique(occ_face->get_TopoDS_Face());
     int i;
@@ -181,6 +181,9 @@
   GMem g_mem;
   int num_points;
   OCCQueryEngine *OQE = OCCQueryEngine::instance();
+  double tol = OQE->get_sme_resabs_tolerance();
+  if (curve->get_arc_length() < tol)
+    return CUBIT_SUCCESS;
   // get the graphics
   CubitStatus stat;
   stat = OQE->get_graphics( curve, num_points, &g_mem );
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2008-11-19 19:06:22 UTC (rev 2275)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2008-11-20 21:17:58 UTC (rev 2276)
@@ -31,8 +31,11 @@
 #include "Poly_Triangle.hxx"
 #include "BRepAlgoAPI_BooleanOperation.hxx"
 #include "Handle_Poly_Triangulation.hxx"
+#include "BRepAdaptor_Curve.hxx"
+#include "BndLib_Add3dCurve.hxx"
 #include "Poly_Polygon3D.hxx"
 #include "Handle_Poly_Polygon3D.hxx"
+#include "BRepMesh_FastDiscret.hxx"
 #include "OCCQueryEngine.hpp"
 #include "OCCModifyEngine.hpp"
 #include "Poly_Triangulation.hxx"
@@ -269,15 +272,32 @@
   TopLoc_Location L;
   Handle_Poly_Triangulation facets = BRep_Tool::Triangulation(*Topo_Face, L);
+  if(facets.IsNull())
+    //do triangulation
+    double deflection = 0.01;
+    double angle  = 0.5;
+    BRepAdaptor_Surface asurface(*Topo_Face);
+    Bnd_Box aBox;
+    BndLib_AddSurface::Add(asurface, Precision::Approximation(), aBox);
+    BRepMesh_FastDiscret *myMesh =
+    new BRepMesh_FastDiscret(deflection, *Topo_Face, aBox, angle, Standard_True, Standard_True);
+    if (myMesh != NULL) delete myMesh;
+    facets = BRep_Tool::Triangulation(*Topo_Face, L);
+      PRINT_ERROR("Can't get triangulation representation for this surface.\n");
+      return CUBIT_FAILURE;
   //if necessary, the face tolerance can be returned. now, no use.
   //double tol = BRep_Tool::Tolerance(*Topo_Face);
   number_points = facets->NbNodes();
   number_triangles = facets->NbTriangles();
-  assert(number_points == 3 * number_triangles);
   number_facets = 4 * number_triangles;
-  Poly_Array1OfTriangle triangles(0, number_facets-1);
+  Poly_Array1OfTriangle triangles(0, number_triangles-1);
   triangles.Assign( facets->Triangles() );
   int *facetList =  new int[number_facets];
   //needs to test that N1, N2, N3 index are starting from 0 to number_points-1
@@ -337,20 +357,28 @@
   if (!Topo_Edge)
-  TopLoc_Location L;
-  Handle_Poly_Polygon3D facets = BRep_Tool::Polygon3D(*Topo_Edge, L);
+  BRepAdaptor_Curve acurve(*Topo_Edge);
+  Bnd_Box aBox;
+  BndLib_Add3dCurve::Add(acurve, Precision::Approximation(), aBox);
+  new BRepMesh_FastDiscret(deflection, *Topo_Edge, aBox, angle, Standard_True, Standard_True);
+  if (myMesh == NULL)
+    PRINT_ERROR("Can't get triangulation representation for this curve.\n");
+  num_points = myMesh->NbVertices();
-  num_points = facets->NbNodes();
-  TColgp_Array1OfPnt points(0, num_points-1);
-  points.Assign(facets->Nodes());
   //! Note: If the polygon is closed, the point of closure is
   //! repeated at the end of its table of nodes. Thus, on a closed
   //! triangle the function NbNodes returns 4.
   GPoint *gPnts= new GPoint[num_points];
-  for (int i = 0; i < num_points ; i ++)
+  for (int i = 1; i <= num_points ; i ++)
-      gp_Pnt gp_pnt = points.Value(i);
+      gp_Pnt gp_pnt = myMesh->Pnt(i);
       GPoint gPnt;
       gPnt.x = gp_pnt.X();
       gPnt.y = gp_pnt.Y();
@@ -359,6 +387,7 @@
   gMem->replace_point_list( gPnts, num_points, num_points );
+  delete myMesh;
@@ -1871,7 +1900,7 @@
 // Creation Date : 12/12/07
 CubitStatus
-OCCQueryEngine::unhook_CoFaces_from_OCC( DLIList<OCCCoFace*> cofaces) const
+OCCQueryEngine::unhook_CoFaces_from_OCC( DLIList<OCCCoFace*>& cofaces) const
   int size = cofaces.size();
   while(size > 0)
@@ -2051,7 +2080,7 @@
 CubitStatus
-OCCQueryEngine::unhook_CoEdges_from_OCC( DLIList<OCCCoEdge*> coedges) const
+OCCQueryEngine::unhook_CoEdges_from_OCC( DLIList<OCCCoEdge*>& coedges) const
   int size = coedges.size();
   while(size > 0)
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.hpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.hpp	2008-11-19 19:06:22 UTC (rev 2275)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.hpp	2008-11-20 21:17:58 UTC (rev 2276)
@@ -274,8 +274,8 @@
   CubitStatus unhook_Lump_from_OCC( Lump* lump ) const;
   CubitStatus unhook_ShellSM_from_OCC( ShellSM* shell ) const;
-  CubitStatus unhook_CoEdges_from_OCC( DLIList<OCCCoEdge*> coedges) const;
-  CubitStatus unhook_CoFaces_from_OCC( DLIList<OCCCoFace*> cofaces) const;
+  CubitStatus unhook_CoEdges_from_OCC( DLIList<OCCCoEdge*>& coedges) const;
+  CubitStatus unhook_CoFaces_from_OCC( DLIList<OCCCoFace*>& cofaces) const;
   CubitStatus unhook_LoopSM_from_OCC( LoopSM* loopsm) const;
   CubitStatus delete_loop( LoopSM* loopsm)const;
   void unhook_cofaces_of_a_surface(OCCSurface* surface)const;
More information about the cgma-dev mailing list
