[cgma-dev] r2248 - in cgm/trunk: geom/virtual init
kraftche at mcs.anl.gov
Fri Nov 14 12:29:19 CST 2008
Author: kraftche
Date: 2008-11-14 12:29:19 -0600 (Fri, 14 Nov 2008)
New Revision: 2248
Modified:
cgm/trunk/geom/virtual/VirtualQueryEngine.cpp
cgm/trunk/init/InitCGMA.cpp
Log:
Fix issues initializing cubit-based CGMA:
o Fix segfault trying to set default engine to ACIS
o Make VG initialization compatible with Cubit
Modified: cgm/trunk/geom/virtual/VirtualQueryEngine.cpp
--- cgm/trunk/geom/virtual/VirtualQueryEngine.cpp 2008-11-14 18:27:21 UTC (rev 2247)
+++ cgm/trunk/geom/virtual/VirtualQueryEngine.cpp 2008-11-14 18:29:19 UTC (rev 2248)
@@ -640,7 +640,6 @@
//GeometryQueryTool::instance()->set_default_engine(this);
CompositeEngine::instance();
PartitionEngine::instance();
- register_attributes();
Modified: cgm/trunk/init/InitCGMA.cpp
--- cgm/trunk/init/InitCGMA.cpp 2008-11-14 18:27:21 UTC (rev 2247)
+++ cgm/trunk/init/InitCGMA.cpp 2008-11-14 18:29:19 UTC (rev 2248)
@@ -54,23 +54,25 @@
CGMApp::instance()->startup( 0, NULL );
GeometryModifyEngine* default_engine = 0;
+ bool ignore_default = false;
-#if defined(CUBIT_CGM) || defined(HAVE_ACIS)
- GeometryModifyEngine* acis_engine_ptr;
- #ifdef CUBIT_CGM
- if (!AcisQueryEngine::instance_)
- AcisQueryEngine::instance_ = new (reinterpret_cast<AcisQueryEngine*>(new dummym)) AcisQueryEngine;
- if (!AcisModifyEngine::instance_)
- AcisModifyEngine::instance_ = new (reinterpret_cast<AcisModifyEngine*>(new dummym)) AcisModifyEngine;
- acis_engine_ptr = reinterpret_cast<GeometryModifyEngine*>
- (AcisModifyEngine::instance_);
- #else
- AcisQueryEngine::instance();
- AcisModifyEngine::instance();
- acis_engine_ptr = AcisModifyEngine::instance();
- #endif
+#ifdef CUBIT_CGM
+ if (!AcisQueryEngine::instance_)
+ AcisQueryEngine::instance_ = new (reinterpret_cast<AcisQueryEngine*>(new dummym)) AcisQueryEngine;
+ if (!AcisModifyEngine::instance_)
+ AcisModifyEngine::instance_ = new (reinterpret_cast<AcisModifyEngine*>(new dummym)) AcisModifyEngine;
if (default_engine_name && streq_nocase("ACIS",default_engine_name))
- default_engine = acis_engine_ptr;
+ ignore_default = true; // We cannot set the default engine correctly
+ // because we cannot safely cast to GeometryModifyEngine
+ // without the complete definition of AcisModifyEngine.
+ // But it shouldn't matter, as ACIS is the default for
+ // Cubit anyway.
+#elif defined(HAVE_ACIS)
+ AcisQueryEngine::instance();
+ AcisModifyEngine::instance();
+ acis_engine_ptr = AcisModifyEngine::instance();
+ if (default_engine_name && streq_nocase("ACIS",default_engine_name))
+ default_engine = AcisModifyEngine::instance();
#endif
#ifdef HAVE_OCC
@@ -82,12 +84,12 @@
FacetQueryEngine::instance();
FacetModifyEngine::instance();
- VirtualQueryEngine::instance();
+ VirtualQueryEngine::instance()->register_attributes();
if (default_engine_name && streq_nocase("FACET",default_engine_name))
default_engine = FacetModifyEngine::instance();
- if(default_engine_name) {
+ if(default_engine_name && !ignore_default) {
if (!default_engine) {
PRINT_ERROR("Invalid or unsupported engine: '%s'\n", default_engine_name);
return CUBIT_FAILURE;
More information about the cgma-dev
