[cgma-dev] r2247 - cgm/trunk/test
kraftche at mcs.anl.gov
Fri Nov 14 12:27:21 CST 2008
Author: kraftche
Date: 2008-11-14 12:27:21 -0600 (Fri, 14 Nov 2008)
New Revision: 2247
Modified:
cgm/trunk/test/Makefile.am
Log:
fix link flags for tests, and run webcut test for cubit-based build
Modified: cgm/trunk/test/Makefile.am
--- cgm/trunk/test/Makefile.am 2008-11-14 18:12:43 UTC (rev 2246)
+++ cgm/trunk/test/Makefile.am 2008-11-14 18:27:21 UTC (rev 2247)
@@ -12,21 +12,24 @@
-I$(srcdir) \
$(OCC_INC_FLAG)
-LINK_FLAGS =
TESTS = sheet
if build_ACIS
TESTS += webcut hollow_acis
- LINK_FLAGS += -R$(ACIS_LIB_DIR)
+else
+if WITH_CUBIT
+ TESTS += webcut
endif
+endif
if build_OCC
TESTS += modify makept r_w test_occ
- LINK_FLAGS += -R$(OCC_LIB_DIR)
endif
AM_CPPFLAGS =
AM_CPPFLAGS += -DSRCDIR=@srcdir@ $(HAVE_ACIS_DEF) $(HAVE_OCC_DEF)
check_PROGRAMS = $(TESTS)
+LINK_FLAGS = $(CGM_EXT_LDFLAGS) $(CGM_EXT_LTFLAGS)
webcut_SOURCES = webcut.cpp
hollow_acis_SOURCES = hollow_acis.cpp
makept_SOURCES = makept.cpp
More information about the cgma-dev
