[cgma-dev] r2212 - cgm/trunk/itaps
Tim Tautges tautges at mcs.anl.gov
Wed Nov 5 12:32:47 CST 2008
Can you have both these engines?
- tim
kraftche at mcs.anl.gov wrote:
> Author: kraftche
> Date: 2008-11-05 12:24:06 -0600 (Wed, 05 Nov 2008)
> New Revision: 2212
> Modified:
>    cgm/trunk/itaps/iGeom_CGMA.cc
> Log:
> Allow 'engine=ACIS' or 'engine=OCC' in iGeom_newGeom options
> Modified: cgm/trunk/itaps/iGeom_CGMA.cc
> --- cgm/trunk/itaps/iGeom_CGMA.cc	2008-11-05 18:19:29 UTC (rev 2211)
> +++ cgm/trunk/itaps/iGeom_CGMA.cc	2008-11-05 18:24:06 UTC (rev 2212)
> @@ -228,7 +228,7 @@
>    iGeom_getLastError( *err, descr, descr_len );
> -void iGeom_newGeom( const char* ,
> +void iGeom_newGeom( const char* options,
>                      iGeom_Instance* instance_out,
>                      int* err,
>                      const int options_size)
> @@ -239,16 +239,29 @@
>    CubitStatus status = InitCGMA::initialize_cgma();
>    if (CUBIT_SUCCESS != status) RETURN(iBase_FAILURE);
> +    // scan options for engine to use
> +  std::string engine;
> +  if (options && options_size) {
> +    char* opt = (char*)malloc( options_size + 1 );
> +    memcpy(opt, options, options_size);
> +    opt[options_size] = '\0';
> +    const char delim[] = { opt[0], '\0' };
> +    for (char* s = strtok(opt+1, delim); s; s = strtok(0,delim)) {
> +      char* v = strchr( s, '=' );
> +      if (v) {
> +        *v = '\0';
> +        ++v;
> +      if (!strcmp(s,"engine")) {
> +        engine = std::string(v);
> +        break;
> +    free(opt);
> +  InitCGMA::initialize_engine(engine.empty() ? 0 : engine.c_str());
> -#ifdef HAVE_ACIS
> -  status = InitCGMA::initialize_engine("ACIS");
> -  if (CUBIT_SUCCESS != status) RETURN(iBase_FAILURE);
> -#endif
> -#ifdef HAVE_OCC
> -  InitCGMA::initialize_engine("OCC");
> -#endif
>  // sometimes can't have following, depending on CGM version
>    // CGMApp::instance()->attrib_manager()->silent_flag(true);
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the cgma-dev mailing list
