[cgma-dev] r2198 - in cgm/trunk: . cgm_apps/examples/facetdriver init itaps test
tautges at mcs.anl.gov
Mon Nov 3 09:57:27 CST 2008
Author: tautges
Date: 2008-11-03 09:57:27 -0600 (Mon, 03 Nov 2008)
New Revision: 2198
Modified:
cgm/trunk/Makefile.am
cgm/trunk/cgm_apps/examples/facetdriver/Makefile.am
cgm/trunk/configure.in
cgm/trunk/init/InitCGMA.cpp
cgm/trunk/init/Makefile.am
cgm/trunk/itaps/Makefile.am
cgm/trunk/itaps/iGeom_CGMA.cc
cgm/trunk/test/Makefile.am
Log:
- Included several $(HAVE_OCC)'s in DEFS in several subdirs (Jason, shouldn't we just do this at the highest level?)
- changed iGeom init code to check return values and to account for OCC (we should probably remove the OCC and ACIS-specific stuff here and have the default action be to initialize all engines...)
- moved AC_SUBST for CGM_EXT_* to later in the configure, after modification due to OCC stuff
- changed CGM_EXT_LINK to CGM_EXT_LIBS in Makefile.am
Modified: cgm/trunk/Makefile.am
--- cgm/trunk/Makefile.am 2008-11-03 15:36:31 UTC (rev 2197)
+++ cgm/trunk/Makefile.am 2008-11-03 15:57:27 UTC (rev 2198)
@@ -45,11 +45,10 @@
-libcgm_la_LIBADD = init/libcgma_init.la $(CORE_CGM_LIBS) $(CGM_EXT_LINK)
+libcgm_la_LIBADD = init/libcgma_init.la $(CORE_CGM_LIBS) $(CGM_EXT_LIBS) $(CUBIT_FILE)
libcgm_la_SOURCES =
# By default, cmg.make will define these to $(srcdir). We
# want to override that during the INSTALL of the file so
# that the correct values are set (e.g. if someone does
Modified: cgm/trunk/cgm_apps/examples/facetdriver/Makefile.am
--- cgm/trunk/cgm_apps/examples/facetdriver/Makefile.am 2008-11-03 15:36:31 UTC (rev 2197)
+++ cgm/trunk/cgm_apps/examples/facetdriver/Makefile.am 2008-11-03 15:57:27 UTC (rev 2198)
@@ -13,4 +13,4 @@
-I$(top_srcdir)/geom/Cholla \
-I$(top_srcdir)/geom/facet
-LDADD = ../../../libcgm.la
+LDADD = $(top_builddir)/libcgm.la
Modified: cgm/trunk/configure.in
--- cgm/trunk/configure.in 2008-11-03 15:36:31 UTC (rev 2197)
+++ cgm/trunk/configure.in 2008-11-03 15:57:27 UTC (rev 2198)
@@ -61,15 +61,6 @@
AM_CONDITIONAL(INCLUDE_TEMPLATE_DEFS, test x$TEMPLATE_DEFS_INCLUDED != x)
-# Define variables for linking
-AC_SUBST(CGM_EXT_LIBS)
-AC_SUBST(CGM_EXT_LDFLAGS)
-AC_SUBST(CGM_EXT_LTFLAGS)
-AC_SUBST(CGM_EXT_INCLUDE)
# Use Cubit shared libraries
CUBIT_FILE=no
@@ -387,6 +378,14 @@
AC_SUBST(CUBIT_OCC_LIB)
AC_SUBST(HAVE_OCC_DEF)
+# Define variables for linking
+AC_SUBST(CGM_EXT_LIBS)
+AC_SUBST(CGM_EXT_LDFLAGS)
+AC_SUBST(CGM_EXT_LTFLAGS)
+AC_SUBST(CGM_EXT_INCLUDE)
# Allow "if WITH_OCC" in Makefile.am
AM_CONDITIONAL( WITH_OCC, [test "x$occ_DIR" != "xno"] )
Modified: cgm/trunk/init/InitCGMA.cpp
--- cgm/trunk/init/InitCGMA.cpp 2008-11-03 15:36:31 UTC (rev 2197)
+++ cgm/trunk/init/InitCGMA.cpp 2008-11-03 15:57:27 UTC (rev 2198)
@@ -33,7 +33,12 @@
# include "AcisModifyEngine.hpp"
#endif
+#if defined(HAVE_OCC)
+# include "OCCQueryEngine.hpp"
+# include "OCCModifyEngine.hpp"
+#endif
static bool streq_nocase( const char* s, const char* t )
for (; *s; ++s, ++t)
@@ -69,7 +74,12 @@
else if (streq_nocase(name,"VIRTUAL") || streq_nocase(name,"vg")) {
VirtualQueryEngine::instance();
+#ifdef HAVE_OCC
+ else if (streq_nocase(name,"OCC") || streq_nocase(name,"occ")) {
+ OCCQueryEngine::instance();
+ OCCModifyEngine::instance();
+#endif
else if (streq_nocase(name,"facet")) {
FacetQueryEngine::instance();
FacetModifyEngine::instance();
Modified: cgm/trunk/init/Makefile.am
--- cgm/trunk/init/Makefile.am 2008-11-03 15:36:31 UTC (rev 2197)
+++ cgm/trunk/init/Makefile.am 2008-11-03 15:57:27 UTC (rev 2198)
@@ -3,7 +3,7 @@
# Override default defines with the ones we want from the configure script
-DEFS = $(TEMPLATE_DEFS_INCLUDED) $(LITTLE_ENDIAN) $(HAVE_ACIS_DEF) $(CUBIT_CGM)
+DEFS = $(TEMPLATE_DEFS_INCLUDED) $(LITTLE_ENDIAN) $(HAVE_ACIS_DEF) $(HAVE_OCC_DEF) $(CUBIT_CGM)
INCLUDES = -I$(top_srcdir)/geom \
-I$(top_srcdir)/util \
-I$(top_srcdir)/geom/ACIS \
Modified: cgm/trunk/itaps/Makefile.am
--- cgm/trunk/itaps/Makefile.am 2008-11-03 15:36:31 UTC (rev 2197)
+++ cgm/trunk/itaps/Makefile.am 2008-11-03 15:57:27 UTC (rev 2198)
@@ -1,6 +1,6 @@
AUTOMAKE_OPTIONS = foreign
-DEFS = $(TEMPLATE_DEFS_INCLUDED) $(HAVE_ACIS_DEF)
+DEFS = $(TEMPLATE_DEFS_INCLUDED) $(HAVE_ACIS_DEF) $(HAVE_OCC_DEF)
if USE_BABEL
SIDL_DIR = SIDL
Modified: cgm/trunk/itaps/iGeom_CGMA.cc
--- cgm/trunk/itaps/iGeom_CGMA.cc 2008-11-03 15:36:31 UTC (rev 2197)
+++ cgm/trunk/itaps/iGeom_CGMA.cc 2008-11-03 15:57:27 UTC (rev 2198)
@@ -237,9 +237,18 @@
ERROR(iBase_NOT_SUPPORTED, "No options for iGeom factory have been implemented.");
- InitCGMA::initialize_cgma();
- InitCGMA::initialize_engine("ACIS");
+ CubitStatus status = InitCGMA::initialize_cgma();
+ if (CUBIT_SUCCESS != status) RETURN(iBase_FAILURE);
+#ifdef HAVE_ACIS
+ status = InitCGMA::initialize_engine("ACIS");
+#endif
+#ifdef HAVE_OCC
+ InitCGMA::initialize_engine("OCC");
+#endif
// sometimes can't have following, depending on CGM version
// CGMApp::instance()->attrib_manager()->silent_flag(true);
Modified: cgm/trunk/test/Makefile.am
--- cgm/trunk/test/Makefile.am 2008-11-03 15:36:31 UTC (rev 2197)
+++ cgm/trunk/test/Makefile.am 2008-11-03 15:57:27 UTC (rev 2198)
@@ -1,6 +1,6 @@
-I$(top_srcdir)/init \
More information about the cgma-dev
