[cgma-dev] CGMA check for *64* failed.
Nightly Test
kraftche at cae.wisc.edu
Sun Nov 2 02:04:41 CST 2008
/bin/sh ./config.status --recheck
running CONFIG_SHELL=/bin/sh /bin/sh ../trunk/configure --enable-debug --enable-release --with-acis=/opt/acis16.7 --with-occ=/opt/OpenCascade6.3 --no-create --no-recursion
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking target system type... x86_64-unknown-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for style of include used by make... GNU
checking for cc... cc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether cc accepts -g... yes
checking for cc option to accept ISO C89... none needed
checking dependency style of cc... gcc3
checking how to run the C preprocessor... cc -E
checking for CC... no
checking for aCC... no
checking for cxx... no
checking for xlC_r... no
checking for xlC... no
checking for c++... c++
checking whether we are using the GNU C++ compiler... yes
checking whether c++ accepts -g... yes
checking dependency style of c++... gcc3
checking how to run the C++ preprocessor... c++ -E
checking for gfortran... gfortran
checking whether we are using the GNU Fortran compiler... yes
checking whether gfortran accepts -g... yes
checking whether we are using the GNU Fortran 77 compiler... yes
checking for known C compilers... GNU
checking for known compiler/OS combinations... GNU:x86_64
checking for known c++ compilers... GNU
checking whether we are using the GNU Fortran compiler... (cached) yes
checking whether gfortran accepts -g... (cached) yes
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ld used by cc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognize dependent libraries... pass_all
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking the maximum length of command line arguments... 98304
checking command to parse /usr/bin/nm -B output from cc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if cc supports -fno-rtti -fno-exceptions... no
checking for cc option to produce PIC... -fPIC
checking if cc PIC flag -fPIC works... yes
checking if cc static flag -static works... yes
checking if cc supports -c -o file.o... yes
checking whether the cc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... no
checking whether to build static libraries... yes
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by c++... /usr/bin/ld -m elf_x86_64
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
checking whether the c++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for c++ option to produce PIC... -fPIC
checking if c++ PIC flag -fPIC works... yes
checking if c++ static flag -static works... yes
checking if c++ supports -c -o file.o... yes
(cached) (cached) checking how to hardcode library paths into programs... immediate
appending configuration tag "F77" to libtool
checking for gfortran option to produce PIC... -fPIC
checking if gfortran PIC flag -fPIC works... yes
checking if gfortran static flag -static works... yes
checking if gfortran supports -c -o file.o... yes
checking whether the gfortran linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether byte ordering is bigendian... no
checking how to get verbose linking output from gfortran... -v
checking for Fortran libraries of gfortran... -L/usr/lib/gcc/x86_64-linux-gnu/4.3.2 -L/usr/lib/gcc/x86_64-linux-gnu/4.3.2/../../../../lib -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.3.2/../../.. -lgfortranbegin -lgfortran -lm
checking for dummy main to link with Fortran libraries... none
checking for Fortran name-mangling scheme... lower case, underscore, no extra underscore
checking for C++-standard library in std:: namespace... yes
checking for C++-standard I/O in std:: namespace... yes
checking if C++ template definitions should be included... yes
checking for ../trunk/geom/ACIS/AcisQueryEngine.hpp... yes
checking for /opt/acis16.7/include/acis.hxx... yes
checking ACIS version of /opt/acis16.7/bin/linux_amd_64_so ... 1607
checking ACIS platform name... linux
checking for main in -lxstep... no
checking for main in -lxiges... no
checking new.h usability... no
checking new.h presence... no
checking for new.h... no
checking for 'include' subdir of /opt/OpenCascade6.3... inc
checking for 'lib' subdir of /opt/OpenCascade6.3... lib
checking if platform is 64-bit (-D_OCC64)... yes
checking iostream usability... yes
checking iostream presence... yes
checking for iostream... yes
checking iostream.h usability... no
checking iostream.h presence... no
checking for iostream.h... no
checking iomanip usability... yes
checking iomanip presence... yes
checking for iomanip... yes
checking iomanip.h usability... no
checking iomanip.h presence... no
checking for iomanip.h... no
checking fstream usability... yes
checking fstream presence... yes
checking for fstream... yes
checking fstream.h usability... no
checking fstream.h presence... no
checking for fstream.h... no
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking Standard_Version.hxx usability... yes
checking Standard_Version.hxx presence... yes
checking for Standard_Version.hxx... yes
checking for create_mailbox in -lTKernel... no
checking for create_mailbox in -lTKernel... yes
CXXFLAGS = -Wall -pipe -pedantic -g
configure: creating ./config.status
config.status: creating Makefile
config.status: creating util/Makefile
config.status: creating geom/Makefile
config.status: creating geom/ACIS/Makefile
config.status: creating geom/Cholla/Makefile
config.status: creating geom/facet/Makefile
config.status: creating geom/facetbool/Makefile
config.status: creating geom/OCC/Makefile
config.status: creating geom/parallel/Makefile
config.status: creating geom/virtual/Makefile
config.status: creating init/Makefile
config.status: creating cgm.make
config.status: creating itaps/Makefile
config.status: creating itaps/iGeom-Defs.inc
config.status: creating itaps/SIDL/Makefile
config.status: creating test/Makefile
config.status: creating cgm_apps/Makefile
config.status: creating cgm_apps/examples/Makefile
config.status: creating cgm_apps/examples/driverc++/Makefile
config.status: creating cgm_apps/examples/facetdriver/Makefile
config.status: creating config.h
config.status: config.h is unchanged
config.status: creating itaps/iBase_FCDefs.h
config.status: itaps/iBase_FCDefs.h is unchanged
config.status: executing depfiles commands
make all-recursive
make[1]: Entering directory `/home/jason/cgm/test/64'
Making all in util
make[2]: Entering directory `/home/jason/cgm/test/64/util'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/home/jason/cgm/test/64/util'
Making all in geom
make[2]: Entering directory `/home/jason/cgm/test/64/geom'
Making all in .
make[3]: Entering directory `/home/jason/cgm/test/64/geom'
make[3]: Nothing to be done for `all-am'.
make[3]: Leaving directory `/home/jason/cgm/test/64/geom'
Making all in Cholla
make[3]: Entering directory `/home/jason/cgm/test/64/geom/Cholla'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/home/jason/cgm/test/64/geom/Cholla'
Making all in facetbool
make[3]: Entering directory `/home/jason/cgm/test/64/geom/facetbool'
make[3]: Leaving directory `/home/jason/cgm/test/64/geom/facetbool'
Making all in facet
make[3]: Entering directory `/home/jason/cgm/test/64/geom/facet'
make[3]: Leaving directory `/home/jason/cgm/test/64/geom/facet'
Making all in virtual
make[3]: Entering directory `/home/jason/cgm/test/64/geom/virtual'
make[3]: Leaving directory `/home/jason/cgm/test/64/geom/virtual'
Making all in ACIS
make[3]: Entering directory `/home/jason/cgm/test/64/geom/ACIS'
make[3]: Leaving directory `/home/jason/cgm/test/64/geom/ACIS'
Making all in OCC
make[3]: Entering directory `/home/jason/cgm/test/64/geom/OCC'
make[3]: Leaving directory `/home/jason/cgm/test/64/geom/OCC'
make[2]: Leaving directory `/home/jason/cgm/test/64/geom'
Making all in init
make[2]: Entering directory `/home/jason/cgm/test/64/init'
make[2]: Leaving directory `/home/jason/cgm/test/64/init'
Making all in .
make[2]: Entering directory `/home/jason/cgm/test/64'
make[2]: Leaving directory `/home/jason/cgm/test/64'
Making all in itaps
make[2]: Entering directory `/home/jason/cgm/test/64/itaps'
make all-recursive
make[3]: Entering directory `/home/jason/cgm/test/64/itaps'
Making all in .
make[4]: Entering directory `/home/jason/cgm/test/64/itaps'
make[4]: Leaving directory `/home/jason/cgm/test/64/itaps'
make[3]: Leaving directory `/home/jason/cgm/test/64/itaps'
make[2]: Leaving directory `/home/jason/cgm/test/64/itaps'
Making all in test
make[2]: Entering directory `/home/jason/cgm/test/64/test'
make[2]: Leaving directory `/home/jason/cgm/test/64/test'
Making all in cgm_apps
make[2]: Entering directory `/home/jason/cgm/test/64/cgm_apps'
Making all in examples
make[3]: Entering directory `/home/jason/cgm/test/64/cgm_apps/examples'
Making all in driverc++
make[4]: Entering directory `/home/jason/cgm/test/64/cgm_apps/examples/driverc++'
make[4]: Nothing to be done for `all'.
make[4]: Leaving directory `/home/jason/cgm/test/64/cgm_apps/examples/driverc++'
Making all in facetdriver
make[4]: Entering directory `/home/jason/cgm/test/64/cgm_apps/examples/facetdriver'
make[4]: Leaving directory `/home/jason/cgm/test/64/cgm_apps/examples/facetdriver'
make[4]: Entering directory `/home/jason/cgm/test/64/cgm_apps/examples'
make[4]: Nothing to be done for `all-am'.
make[4]: Leaving directory `/home/jason/cgm/test/64/cgm_apps/examples'
make[3]: Leaving directory `/home/jason/cgm/test/64/cgm_apps/examples'
make[3]: Entering directory `/home/jason/cgm/test/64/cgm_apps'
make[3]: Leaving directory `/home/jason/cgm/test/64/cgm_apps'
make[2]: Leaving directory `/home/jason/cgm/test/64/cgm_apps'
make[1]: Leaving directory `/home/jason/cgm/test/64'
Making check in util
make[1]: Entering directory `/home/jason/cgm/test/64/util'
make[1]: Nothing to be done for `check'.
make[1]: Leaving directory `/home/jason/cgm/test/64/util'
Making check in geom
make[1]: Entering directory `/home/jason/cgm/test/64/geom'
Making check in .
make[2]: Nothing to be done for `check-am'.
Making check in Cholla
make[2]: Entering directory `/home/jason/cgm/test/64/geom/Cholla'
make[2]: Nothing to be done for `check'.
make[2]: Leaving directory `/home/jason/cgm/test/64/geom/Cholla'
Making check in facetbool
make[2]: Entering directory `/home/jason/cgm/test/64/geom/facetbool'
make[2]: Leaving directory `/home/jason/cgm/test/64/geom/facetbool'
make[2]: Entering directory `/home/jason/cgm/test/64/geom/facet'
make[2]: Leaving directory `/home/jason/cgm/test/64/geom/facet'
Making check in virtual
make[2]: Entering directory `/home/jason/cgm/test/64/geom/virtual'
make[2]: Leaving directory `/home/jason/cgm/test/64/geom/virtual'
Making check in ACIS
make[2]: Entering directory `/home/jason/cgm/test/64/geom/ACIS'
make[2]: Leaving directory `/home/jason/cgm/test/64/geom/ACIS'
Making check in OCC
make[2]: Entering directory `/home/jason/cgm/test/64/geom/OCC'
make[2]: Leaving directory `/home/jason/cgm/test/64/geom/OCC'
make[1]: Leaving directory `/home/jason/cgm/test/64/geom'
Making check in init
make[1]: Entering directory `/home/jason/cgm/test/64/init'
make[1]: Leaving directory `/home/jason/cgm/test/64/init'
Making check in .
Making check in itaps
make[1]: Entering directory `/home/jason/cgm/test/64/itaps'
Making check in .
make testgeom
c++ -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS -I. -I../../trunk/itaps -I.. -I../../trunk/util -I../../trunk/geom -I../../trunk/init -I../../trunk/geom/ACIS -I. -isystem /opt/acis16.7/include -DSRCDIR=../../trunk/itaps -isystem /opt/acis16.7/include -Wall -pipe -pedantic -g -MT testgeom-testgeom.o -MD -MP -MF .deps/testgeom-testgeom.Tpo -c -o testgeom-testgeom.o `test -f 'testgeom.cc' || echo '../../trunk/itaps/'`testgeom.cc
mv -f .deps/testgeom-testgeom.Tpo .deps/testgeom-testgeom.Po
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -o testgeom testgeom-testgeom.o libiGeom.la -lm
c++ -Wall -pipe -pedantic -g -o testgeom testgeom-testgeom.o ./.libs/libiGeom.a /home/jason/cgm/test/64/.libs/libcgm.a -L/opt/acis16.7/bin/linux_amd_64_so -lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase -L/opt/OpenCascade6.3/lib /opt/OpenCascade6.3//lib/libTKFeat.so /opt/OpenCascade6.3//lib/libTKHLR.so /opt/OpenCascade6.3//lib/libTKIGES.so /opt/OpenCascade6.3//lib/libTKOffset.so /opt/OpenCascade6.3//lib/libTKFillet.so /opt/OpenCascade6.3//lib/libTKBool.so /opt/OpenCascade6.3//lib/libTKBO.so /opt/OpenCascade6.3//lib/libTKPrim.so /opt/OpenCascade6.3//lib/libTKSTEP.so /opt/OpenCascade6.3//lib/libTKSTEPAttr.so /opt/OpenCascade6.3//lib/libTKSTEP209.so /opt/OpenCascade6.3//lib/libTKSTEPBase.so /opt/OpenCascade6.3//lib/libTKSTL.so /opt/OpenCascade6.3//lib/libTKMesh.so /opt/OpenCascade6.3//lib/libTKXSBase.so /opt/OpenCascade6.3//lib/libTKShHealing.so /opt/OpenCascade6.3//lib/libTKLCAF.so /opt/OpenCascade6.3//lib/libTKCDF.so /opt/OpenCascade6.3//lib/libTKT!
opAlgo.so /opt/OpenCascade6.3//lib/libTKGeomAlgo.so /opt/OpenCascade6.3//lib/libTKBRep.so /opt/OpenCascade6.3//lib/libTKGeomBase.so /opt/OpenCascade6.3//lib/libTKG3d.so /opt/OpenCascade6.3//lib/libTKG2d.so /opt/OpenCascade6.3//lib/libTKMath.so /opt/OpenCascade6.3//lib/libTKernel.so -lpthread -ldl -lm -Wl,--rpath -Wl,/opt/OpenCascade6.3//lib -Wl,--rpath -Wl,/opt/OpenCascade6.3//lib
./.libs/libiGeom.a(iGeom_CGMA.o): In function `iGeom_load_cub_geometry':
/home/jason/cgm/test/64/itaps/../../trunk/itaps/iGeom_CGMA.cc:5853: warning: the use of `tmpnam' is dangerous, better use `mkstemp'
/usr/bin/ld: warning: libstdc++.so.5, needed by /opt/acis16.7/bin/linux_amd_64_so/libSpaAVis.so, may conflict with libstdc++.so.6
make check-TESTS
./testgeom: error while loading shared libraries: libSpaAVis.so: cannot open shared object file: No such file or directory
PASS: testgeom
All 1 tests passed
make[1]: Leaving directory `/home/jason/cgm/test/64/itaps'
Making check in test
make[1]: Entering directory `/home/jason/cgm/test/64/test'
make sheet webcut hollow_acis modify makept r_w test_occ
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_ACIS -I. -I../../trunk/test -I.. -I../itaps -I../../trunk/geom -I../../trunk/util -I../../trunk/init -I../../trunk/geom/ACIS -I../../trunk/geom/virtual -I../../trunk/geom/facet -I../../trunk/geom/Cholla -I../../trunk/geom/OCC -I../../trunk/test -I/opt/OpenCascade6.3/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DSRCDIR=../../trunk/test -DHAVE_ACIS -DHAVE_OCC -isystem /opt/acis16.7/include -Wall -pipe -pedantic -g -MT sheet.o -MD -MP -MF .deps/sheet.Tpo -c -o sheet.o ../../trunk/test/sheet.cpp
../../trunk/test/sheet.cpp: In function âint main(int, char**)â:
../../trunk/test/sheet.cpp:39: warning: unused variable âgqe_listâ
mv -f .deps/sheet.Tpo .deps/sheet.Po
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -R/opt/acis16.7/bin/linux_amd_64_so -R/opt/OpenCascade6.3/lib -o sheet sheet.o ../libcgm.la -lm
mkdir .libs
c++ -Wall -pipe -pedantic -g -o sheet sheet.o ../.libs/libcgm.a -L/opt/acis16.7/bin/linux_amd_64_so -lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase -L/opt/OpenCascade6.3/lib /opt/OpenCascade6.3//lib/libTKFeat.so /opt/OpenCascade6.3//lib/libTKHLR.so /opt/OpenCascade6.3//lib/libTKIGES.so /opt/OpenCascade6.3//lib/libTKOffset.so /opt/OpenCascade6.3//lib/libTKFillet.so /opt/OpenCascade6.3//lib/libTKBool.so /opt/OpenCascade6.3//lib/libTKBO.so /opt/OpenCascade6.3//lib/libTKPrim.so /opt/OpenCascade6.3//lib/libTKSTEP.so /opt/OpenCascade6.3//lib/libTKSTEPAttr.so /opt/OpenCascade6.3//lib/libTKSTEP209.so /opt/OpenCascade6.3//lib/libTKSTEPBase.so /opt/OpenCascade6.3//lib/libTKSTL.so /opt/OpenCascade6.3//lib/libTKMesh.so /opt/OpenCascade6.3//lib/libTKXSBase.so /opt/OpenCascade6.3//lib/libTKShHealing.so /opt/OpenCascade6.3//lib/libTKLCAF.so /opt/OpenCascade6.3//lib/libTKCDF.so /opt/OpenCascade6.3//lib/libTKTopAlgo.so /opt/OpenCascade6.3//lib/libTKGeomAlgo.so /op!
t/OpenCascade6.3//lib/libTKBRep.so /opt/OpenCascade6.3//lib/libTKGeomBase.so /opt/OpenCascade6.3//lib/libTKG3d.so /opt/OpenCascade6.3//lib/libTKG2d.so /opt/OpenCascade6.3//lib/libTKMath.so /opt/OpenCascade6.3//lib/libTKernel.so -lpthread -ldl -lm -Wl,--rpath -Wl,/opt/OpenCascade6.3//lib -Wl,--rpath -Wl,/opt/OpenCascade6.3//lib -Wl,--rpath -Wl,/opt/acis16.7/bin/linux_amd_64_so -Wl,--rpath -Wl,/opt/OpenCascade6.3/lib
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_ACIS -I. -I../../trunk/test -I.. -I../itaps -I../../trunk/geom -I../../trunk/util -I../../trunk/init -I../../trunk/geom/ACIS -I../../trunk/geom/virtual -I../../trunk/geom/facet -I../../trunk/geom/Cholla -I../../trunk/geom/OCC -I../../trunk/test -I/opt/OpenCascade6.3/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DSRCDIR=../../trunk/test -DHAVE_ACIS -DHAVE_OCC -isystem /opt/acis16.7/include -Wall -pipe -pedantic -g -MT webcut.o -MD -MP -MF .deps/webcut.Tpo -c -o webcut.o ../../trunk/test/webcut.cpp
../../trunk/test/webcut.cpp: In function âint main(int, char**)â:
../../trunk/test/webcut.cpp:67: warning: unused variable âgtiâ
../../trunk/test/webcut.cpp: In function âCubitStatus read_geometry(int, char**)â:
../../trunk/test/webcut.cpp:118: warning: unused variable âfile_ptrâ
../../trunk/test/webcut.cpp: In function âCubitStatus webcut_with_brick()â:
../../trunk/test/webcut.cpp:139: warning: deprecated conversion from string constant to âchar*â
../../trunk/test/webcut.cpp: In function âCubitStatus webcut_with_cylinder()â:
../../trunk/test/webcut.cpp:194: warning: deprecated conversion from string constant to âchar*â
../../trunk/test/webcut.cpp: In function âCubitStatus webcut_with_planar_sheet()â:
../../trunk/test/webcut.cpp:245: warning: deprecated conversion from string constant to âchar*â
../../trunk/test/webcut.cpp: In function âCubitStatus webcut_with_sweep_curves_rotated()â:
../../trunk/test/webcut.cpp:299: warning: deprecated conversion from string constant to âchar*â
../../trunk/test/webcut.cpp: In function âCubitStatus webcut_with_sweep_curves()â:
../../trunk/test/webcut.cpp:365: warning: deprecated conversion from string constant to âchar*â
../../trunk/test/webcut.cpp: In function âCubitStatus webcut_with_sweep_along_curve()â:
../../trunk/test/webcut.cpp:425: warning: deprecated conversion from string constant to âchar*â
../../trunk/test/webcut.cpp: In function âCubitStatus webcut_with_curve_loop()â:
../../trunk/test/webcut.cpp:496: warning: deprecated conversion from string constant to âchar*â
../../trunk/test/webcut.cpp: In function âCubitStatus webcut_with_extended_surf()â:
../../trunk/test/webcut.cpp:553: warning: deprecated conversion from string constant to âchar*â
../../trunk/test/webcut.cpp: In function âCubitStatus webcut_with_sweep_surfaces_rotated()â:
../../trunk/test/webcut.cpp:600: warning: deprecated conversion from string constant to âchar*â
../../trunk/test/webcut.cpp: In function âCubitStatus webcut_with_sweep_surfaces()â:
../../trunk/test/webcut.cpp:651: warning: deprecated conversion from string constant to âchar*â
../../trunk/test/webcut.cpp: In function âCubitStatus webcut_with_sweep_surfaces_along_curve()â:
../../trunk/test/webcut.cpp:701: warning: deprecated conversion from string constant to âchar*â
../../trunk/test/webcut.cpp: In function âCubitStatus webcut_with_sweep_surfaces_perp()â:
../../trunk/test/webcut.cpp:761: warning: deprecated conversion from string constant to âchar*â
mv -f .deps/webcut.Tpo .deps/webcut.Po
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -R/opt/acis16.7/bin/linux_amd_64_so -R/opt/OpenCascade6.3/lib -o webcut webcut.o ../libcgm.la -lm
c++ -Wall -pipe -pedantic -g -o webcut webcut.o ../.libs/libcgm.a -L/opt/acis16.7/bin/linux_amd_64_so -lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase -L/opt/OpenCascade6.3/lib /opt/OpenCascade6.3//lib/libTKFeat.so /opt/OpenCascade6.3//lib/libTKHLR.so /opt/OpenCascade6.3//lib/libTKIGES.so /opt/OpenCascade6.3//lib/libTKOffset.so /opt/OpenCascade6.3//lib/libTKFillet.so /opt/OpenCascade6.3//lib/libTKBool.so /opt/OpenCascade6.3//lib/libTKBO.so /opt/OpenCascade6.3//lib/libTKPrim.so /opt/OpenCascade6.3//lib/libTKSTEP.so /opt/OpenCascade6.3//lib/libTKSTEPAttr.so /opt/OpenCascade6.3//lib/libTKSTEP209.so /opt/OpenCascade6.3//lib/libTKSTEPBase.so /opt/OpenCascade6.3//lib/libTKSTL.so /opt/OpenCascade6.3//lib/libTKMesh.so /opt/OpenCascade6.3//lib/libTKXSBase.so /opt/OpenCascade6.3//lib/libTKShHealing.so /opt/OpenCascade6.3//lib/libTKLCAF.so /opt/OpenCascade6.3//lib/libTKCDF.so /opt/OpenCascade6.3//lib/libTKTopAlgo.so /opt/OpenCascade6.3//lib/libTKGeomAlgo.so /!
opt/OpenCascade6.3//lib/libTKBRep.so /opt/OpenCascade6.3//lib/libTKGeomBase.so /opt/OpenCascade6.3//lib/libTKG3d.so /opt/OpenCascade6.3//lib/libTKG2d.so /opt/OpenCascade6.3//lib/libTKMath.so /opt/OpenCascade6.3//lib/libTKernel.so -lpthread -ldl -lm -Wl,--rpath -Wl,/opt/OpenCascade6.3//lib -Wl,--rpath -Wl,/opt/OpenCascade6.3//lib -Wl,--rpath -Wl,/opt/acis16.7/bin/linux_amd_64_so -Wl,--rpath -Wl,/opt/OpenCascade6.3/lib
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_ACIS -I. -I../../trunk/test -I.. -I../itaps -I../../trunk/geom -I../../trunk/util -I../../trunk/init -I../../trunk/geom/ACIS -I../../trunk/geom/virtual -I../../trunk/geom/facet -I../../trunk/geom/Cholla -I../../trunk/geom/OCC -I../../trunk/test -I/opt/OpenCascade6.3/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DSRCDIR=../../trunk/test -DHAVE_ACIS -DHAVE_OCC -isystem /opt/acis16.7/include -Wall -pipe -pedantic -g -MT hollow_acis.o -MD -MP -MF .deps/hollow_acis.Tpo -c -o hollow_acis.o ../../trunk/test/hollow_acis.cpp
../../trunk/test/hollow_acis.cpp: In function âint main(int, char**)â:
../../trunk/test/hollow_acis.cpp:56: warning: unused variable âgtiâ
../../trunk/test/hollow_acis.cpp: In function âCubitStatus read_geometry(int, char**)â:
../../trunk/test/hollow_acis.cpp:96: warning: unused variable âfile_ptrâ
../../trunk/test/hollow_acis.cpp: In function âCubitStatus hollow()â:
../../trunk/test/hollow_acis.cpp:117: warning: deprecated conversion from string constant to âchar*â
../../trunk/test/hollow_acis.cpp:147: warning: unused variable âstatâ
mv -f .deps/hollow_acis.Tpo .deps/hollow_acis.Po
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -R/opt/acis16.7/bin/linux_amd_64_so -R/opt/OpenCascade6.3/lib -o hollow_acis hollow_acis.o ../libcgm.la -lm
c++ -Wall -pipe -pedantic -g -o hollow_acis hollow_acis.o ../.libs/libcgm.a -L/opt/acis16.7/bin/linux_amd_64_so -lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase -L/opt/OpenCascade6.3/lib /opt/OpenCascade6.3//lib/libTKFeat.so /opt/OpenCascade6.3//lib/libTKHLR.so /opt/OpenCascade6.3//lib/libTKIGES.so /opt/OpenCascade6.3//lib/libTKOffset.so /opt/OpenCascade6.3//lib/libTKFillet.so /opt/OpenCascade6.3//lib/libTKBool.so /opt/OpenCascade6.3//lib/libTKBO.so /opt/OpenCascade6.3//lib/libTKPrim.so /opt/OpenCascade6.3//lib/libTKSTEP.so /opt/OpenCascade6.3//lib/libTKSTEPAttr.so /opt/OpenCascade6.3//lib/libTKSTEP209.so /opt/OpenCascade6.3//lib/libTKSTEPBase.so /opt/OpenCascade6.3//lib/libTKSTL.so /opt/OpenCascade6.3//lib/libTKMesh.so /opt/OpenCascade6.3//lib/libTKXSBase.so /opt/OpenCascade6.3//lib/libTKShHealing.so /opt/OpenCascade6.3//lib/libTKLCAF.so /opt/OpenCascade6.3//lib/libTKCDF.so /opt/OpenCascade6.3//lib/libTKTopAlgo.so /opt/OpenCascade6.3//lib/libTKGeo!
mAlgo.so /opt/OpenCascade6.3//lib/libTKBRep.so /opt/OpenCascade6.3//lib/libTKGeomBase.so /opt/OpenCascade6.3//lib/libTKG3d.so /opt/OpenCascade6.3//lib/libTKG2d.so /opt/OpenCascade6.3//lib/libTKMath.so /opt/OpenCascade6.3//lib/libTKernel.so -lpthread -ldl -lm -Wl,--rpath -Wl,/opt/OpenCascade6.3//lib -Wl,--rpath -Wl,/opt/OpenCascade6.3//lib -Wl,--rpath -Wl,/opt/acis16.7/bin/linux_amd_64_so -Wl,--rpath -Wl,/opt/OpenCascade6.3/lib
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_ACIS -I. -I../../trunk/test -I.. -I../itaps -I../../trunk/geom -I../../trunk/util -I../../trunk/init -I../../trunk/geom/ACIS -I../../trunk/geom/virtual -I../../trunk/geom/facet -I../../trunk/geom/Cholla -I../../trunk/geom/OCC -I../../trunk/test -I/opt/OpenCascade6.3/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DSRCDIR=../../trunk/test -DHAVE_ACIS -DHAVE_OCC -isystem /opt/acis16.7/include -Wall -pipe -pedantic -g -MT modify.o -MD -MP -MF .deps/modify.Tpo -c -o modify.o ../../trunk/test/modify.cpp
../../trunk/test/modify.cpp: In function âCubitStatus make_Point()â:
../../trunk/test/modify.cpp:208: warning: deprecated conversion from string constant to âchar*â
../../trunk/test/modify.cpp:119: warning: unused variable ârefâ
../../trunk/test/modify.cpp:179: warning: unused variable âgmeâ
../../trunk/test/modify.cpp:180: warning: unused variable âstitched_bodyâ
../../trunk/test/modify.cpp:519: warning: unused variable âocc_bodiesâ
../../trunk/test/modify.cpp:734: warning: unused variable ârotate_face2â
mv -f .deps/modify.Tpo .deps/modify.Po
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -R/opt/acis16.7/bin/linux_amd_64_so -R/opt/OpenCascade6.3/lib -o modify modify.o ../libcgm.la -lm
c++ -Wall -pipe -pedantic -g -o modify modify.o ../.libs/libcgm.a -L/opt/acis16.7/bin/linux_amd_64_so -lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase -L/opt/OpenCascade6.3/lib /opt/OpenCascade6.3//lib/libTKFeat.so /opt/OpenCascade6.3//lib/libTKHLR.so /opt/OpenCascade6.3//lib/libTKIGES.so /opt/OpenCascade6.3//lib/libTKOffset.so /opt/OpenCascade6.3//lib/libTKFillet.so /opt/OpenCascade6.3//lib/libTKBool.so /opt/OpenCascade6.3//lib/libTKBO.so /opt/OpenCascade6.3//lib/libTKPrim.so /opt/OpenCascade6.3//lib/libTKSTEP.so /opt/OpenCascade6.3//lib/libTKSTEPAttr.so /opt/OpenCascade6.3//lib/libTKSTEP209.so /opt/OpenCascade6.3//lib/libTKSTEPBase.so /opt/OpenCascade6.3//lib/libTKSTL.so /opt/OpenCascade6.3//lib/libTKMesh.so /opt/OpenCascade6.3//lib/libTKXSBase.so /opt/OpenCascade6.3//lib/libTKShHealing.so /opt/OpenCascade6.3//lib/libTKLCAF.so /opt/OpenCascade6.3//lib/libTKCDF.so /opt/OpenCascade6.3//lib/libTKTopAlgo.so /opt/OpenCascade6.3//lib/libTKGeomAlgo.so /!
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_ACIS -I. -I../../trunk/test -I.. -I../itaps -I../../trunk/geom -I../../trunk/util -I../../trunk/init -I../../trunk/geom/ACIS -I../../trunk/geom/virtual -I../../trunk/geom/facet -I../../trunk/geom/Cholla -I../../trunk/geom/OCC -I../../trunk/test -I/opt/OpenCascade6.3/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DSRCDIR=../../trunk/test -DHAVE_ACIS -DHAVE_OCC -isystem /opt/acis16.7/include -Wall -pipe -pedantic -g -MT makept.o -MD -MP -MF .deps/makept.Tpo -c -o makept.o ../../trunk/test/makept.cpp
../../trunk/test/makept.cpp: In function âCubitStatus make_Point()â:
../../trunk/test/makept.cpp:118: warning: deprecated conversion from string constant to âchar*â
../../trunk/test/makept.cpp:122: warning: deprecated conversion from string constant to âchar*â
../../trunk/test/makept.cpp:126: warning: deprecated conversion from string constant to âchar*â
../../trunk/test/makept.cpp:266: warning: unused variable âdâ
../../trunk/test/makept.cpp:183: warning: unused variable âis_equalâ
../../trunk/test/makept.cpp:271: warning: unused variable ânew_face2â
../../trunk/test/makept.cpp:312: warning: unused variable âareaâ
../../trunk/test/makept.cpp:351: warning: unused variable âpc2â
../../trunk/test/makept.cpp:355: warning: unused variable ânum_loopsâ
../../trunk/test/makept.cpp:360: warning: unused variable âangleâ
mv -f .deps/makept.Tpo .deps/makept.Po
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -R/opt/acis16.7/bin/linux_amd_64_so -R/opt/OpenCascade6.3/lib -o makept makept.o ../libcgm.la -lm
c++ -Wall -pipe -pedantic -g -o makept makept.o ../.libs/libcgm.a -L/opt/acis16.7/bin/linux_amd_64_so -lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase -L/opt/OpenCascade6.3/lib /opt/OpenCascade6.3//lib/libTKFeat.so /opt/OpenCascade6.3//lib/libTKHLR.so /opt/OpenCascade6.3//lib/libTKIGES.so /opt/OpenCascade6.3//lib/libTKOffset.so /opt/OpenCascade6.3//lib/libTKFillet.so /opt/OpenCascade6.3//lib/libTKBool.so /opt/OpenCascade6.3//lib/libTKBO.so /opt/OpenCascade6.3//lib/libTKPrim.so /opt/OpenCascade6.3//lib/libTKSTEP.so /opt/OpenCascade6.3//lib/libTKSTEPAttr.so /opt/OpenCascade6.3//lib/libTKSTEP209.so /opt/OpenCascade6.3//lib/libTKSTEPBase.so /opt/OpenCascade6.3//lib/libTKSTL.so /opt/OpenCascade6.3//lib/libTKMesh.so /opt/OpenCascade6.3//lib/libTKXSBase.so /opt/OpenCascade6.3//lib/libTKShHealing.so /opt/OpenCascade6.3//lib/libTKLCAF.so /opt/OpenCascade6.3//lib/libTKCDF.so /opt/OpenCascade6.3//lib/libTKTopAlgo.so /opt/OpenCascade6.3//lib/libTKGeomAlgo.so /!
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_ACIS -I. -I../../trunk/test -I.. -I../itaps -I../../trunk/geom -I../../trunk/util -I../../trunk/init -I../../trunk/geom/ACIS -I../../trunk/geom/virtual -I../../trunk/geom/facet -I../../trunk/geom/Cholla -I../../trunk/geom/OCC -I../../trunk/test -I/opt/OpenCascade6.3/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DSRCDIR=../../trunk/test -DHAVE_ACIS -DHAVE_OCC -isystem /opt/acis16.7/include -Wall -pipe -pedantic -g -MT r_w.o -MD -MP -MF .deps/r_w.Tpo -c -o r_w.o ../../trunk/test/r_w.cpp
../../trunk/test/r_w.cpp: In function âCubitStatus make_Point()â:
../../trunk/test/r_w.cpp:128: warning: deprecated conversion from string constant to âchar*â
../../trunk/test/r_w.cpp:155: warning: deprecated conversion from string constant to âchar*â
../../trunk/test/r_w.cpp:200: warning: deprecated conversion from string constant to âchar*â
../../trunk/test/r_w.cpp:226: warning: deprecated conversion from string constant to âchar*â
../../trunk/test/r_w.cpp:256: warning: deprecated conversion from string constant to âchar*â
../../trunk/test/r_w.cpp:282: warning: deprecated conversion from string constant to âchar*â
../../trunk/test/r_w.cpp:177: warning: unused variable âdâ
../../trunk/test/r_w.cpp:179: warning: unused variable ânâ
mv -f .deps/r_w.Tpo .deps/r_w.Po
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -R/opt/acis16.7/bin/linux_amd_64_so -R/opt/OpenCascade6.3/lib -o r_w r_w.o ../libcgm.la -lm
c++ -Wall -pipe -pedantic -g -o r_w r_w.o ../.libs/libcgm.a -L/opt/acis16.7/bin/linux_amd_64_so -lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase -L/opt/OpenCascade6.3/lib /opt/OpenCascade6.3//lib/libTKFeat.so /opt/OpenCascade6.3//lib/libTKHLR.so /opt/OpenCascade6.3//lib/libTKIGES.so /opt/OpenCascade6.3//lib/libTKOffset.so /opt/OpenCascade6.3//lib/libTKFillet.so /opt/OpenCascade6.3//lib/libTKBool.so /opt/OpenCascade6.3//lib/libTKBO.so /opt/OpenCascade6.3//lib/libTKPrim.so /opt/OpenCascade6.3//lib/libTKSTEP.so /opt/OpenCascade6.3//lib/libTKSTEPAttr.so /opt/OpenCascade6.3//lib/libTKSTEP209.so /opt/OpenCascade6.3//lib/libTKSTEPBase.so /opt/OpenCascade6.3//lib/libTKSTL.so /opt/OpenCascade6.3//lib/libTKMesh.so /opt/OpenCascade6.3//lib/libTKXSBase.so /opt/OpenCascade6.3//lib/libTKShHealing.so /opt/OpenCascade6.3//lib/libTKLCAF.so /opt/OpenCascade6.3//lib/libTKCDF.so /opt/OpenCascade6.3//lib/libTKTopAlgo.so /opt/OpenCascade6.3//lib/libTKGeomAlgo.so /opt/Op!
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_ACIS -I. -I../../trunk/test -I.. -I../itaps -I../../trunk/geom -I../../trunk/util -I../../trunk/init -I../../trunk/geom/ACIS -I../../trunk/geom/virtual -I../../trunk/geom/facet -I../../trunk/geom/Cholla -I../../trunk/geom/OCC -I../../trunk/test -I/opt/OpenCascade6.3/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DSRCDIR=../../trunk/test -DHAVE_ACIS -DHAVE_OCC -isystem /opt/acis16.7/include -Wall -pipe -pedantic -g -MT test_occ.o -MD -MP -MF .deps/test_occ.Tpo -c -o test_occ.o ../../trunk/test/test_occ.cpp
../../trunk/test/test_occ.cpp: In function âint main(int, char**)â:
../../trunk/test/test_occ.cpp:39: warning: unused variable âgmtiâ
mv -f .deps/test_occ.Tpo .deps/test_occ.Po
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -o test_occ test_occ.o ../libcgm.la -lm
c++ -Wall -pipe -pedantic -g -o test_occ test_occ.o ../.libs/libcgm.a -L/opt/acis16.7/bin/linux_amd_64_so -lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase -L/opt/OpenCascade6.3/lib /opt/OpenCascade6.3//lib/libTKFeat.so /opt/OpenCascade6.3//lib/libTKHLR.so /opt/OpenCascade6.3//lib/libTKIGES.so /opt/OpenCascade6.3//lib/libTKOffset.so /opt/OpenCascade6.3//lib/libTKFillet.so /opt/OpenCascade6.3//lib/libTKBool.so /opt/OpenCascade6.3//lib/libTKBO.so /opt/OpenCascade6.3//lib/libTKPrim.so /opt/OpenCascade6.3//lib/libTKSTEP.so /opt/OpenCascade6.3//lib/libTKSTEPAttr.so /opt/OpenCascade6.3//lib/libTKSTEP209.so /opt/OpenCascade6.3//lib/libTKSTEPBase.so /opt/OpenCascade6.3//lib/libTKSTL.so /opt/OpenCascade6.3//lib/libTKMesh.so /opt/OpenCascade6.3//lib/libTKXSBase.so /opt/OpenCascade6.3//lib/libTKShHealing.so /opt/OpenCascade6.3//lib/libTKLCAF.so /opt/OpenCascade6.3//lib/libTKCDF.so /opt/OpenCascade6.3//lib/libTKTopAlgo.so /opt/OpenCascade6.3//lib/libTKGeomAlgo.!
make check-TESTS
PASS: sheet
Read 1 ACIS Entities from the input file
Constructed 1 Volume: 1
Creating the new (webcut) volumes...
Created volume(s): 2
Updated volume(s): 1
Exported: 2 Volumes
Constructed 1 Volume: 3
Created volume(s): 4
Updated volume(s): 3
Exported: 2 Volumes
Constructed 1 Volume: 5
Created volume(s): 6
Updated volume(s): 5
Exported: 2 Volumes
Read 3 ACIS Entities from the input file
Constructed 1 Volume: 7
Constructed 2 Free Curves: 4457, 4458
Created volume(s): 8
Updated volume(s): 7
CPU time taken to WEBCUT this body: 5.420000 secs
Exported: 2 Volumes
2 Curves
Constructed 1 Volume: 9
Constructed 2 Free Curves: 5296, 5297
Created volume(s): 10
Updated volume(s): 9
Exported: 2 Volumes
2 Curves
Constructed 1 Volume: 11
Constructed 2 Free Curves: 5322, 5323
Created volume(s): 12
Updated volume(s): 11
Exported: 2 Volumes
2 Curves
Read 5 ACIS Entities from the input file
Constructed 1 Volume: 13
Constructed 4 Free Curves: 5348 to 5351
Created volume(s): 14
Updated volume(s): 13
Exported: 2 Volumes
4 Curves
Read 2 ACIS Entities from the input file
Constructed 2 Volumes: 15, 16
Created volume(s): 17
Updated volume(s): 15
Exported: 3 Volumes
Constructed 2 Volumes: 18, 19
Created volume(s): 20
Updated volume(s): 18
Exported: 3 Volumes
Constructed 2 Volumes: 21, 22
Created volume(s): 23
Updated volume(s): 21
Exported: 3 Volumes
Constructed 2 Volumes: 24, 25
Created volume(s): 26
Updated volume(s): 24
Exported: 3 Volumes
Constructed 2 Volumes: 27, 28
Created volume(s): 29
Updated volume(s): 27
Exported: 3 Volumes
PASS: webcut
Destroyed volume(s): 1
PASS: hollow_acis
Modified volume
Created volume(s): 9
Destroyed volume(s): 2 to 7
Exported: 1 OCC Body
Adding solids.
Adding shells.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Constructed 1 Volume: 10
WARNING: WARNING: Edge found with zero arclength
For cones, this may be normal.
Updated volume(s): 19
Destroyed volume(s): 20
Created volume(s): 22, 23
Destroyed volume(s): 19, 21
Total 0 cuts performed, with from_shape having 6 faces.
Total 1 cuts performed, with from_shape having 6 faces.
Total 1 cuts performed, with from_shape having 7 faces.
Total 1 cuts performed, with from_shape having 8 faces.
Updated volume(s): 26
Total 2 cuts performed, with from_shape having 8 faces.
Destroyed volume(s): 25
Modified volume
Total 0 cuts performed, with from_shape having 2 faces.
Updated volume(s): 32
WARNING: Cant make a scar on existing face without splitting it.
Updated volume(s): 33
Created volume(s): 34
WARNING: Surfaces or Shells can't be used to cut a body.
ERROR: Subtract FAILED
Total 4 cuts performed, with from_shape having 10 faces.
Total 3 cuts performed, with from_shape having 9 faces.
Updated volume(s): 35, 36
No projection on the surface.
Total 0 cuts performed, with from_shape having 8 faces.
Removing projected curves
Created volume(s): 39
Updated volume(s): 41
Destroyed volume(s): 40
Destroyed volume(s): 42
The 1 body did not have common part with the tool_body.
Destroyed volume(s): 41, 43
Created volume(s): 46
Destroyed volume(s): 44
Updated volume(s): 45
Created volume(s): 49
Destroyed volume(s): 48
Updated volume(s): 47
Updated volume(s): 51
Destroyed volume(s): 50
Updated volume(s): 53
Destroyed volume(s): 52
Updated volume(s): 54
Destroyed volume(s): 55
Modified volume
Created swept volume 61
Modified volume
Created swept volume 62
Created swept volume 63
Modified volume
Created swept volume 64
ERROR: Only surfaces with no intersection point with the axis can be revolve-swept.
Created swept volume 65
ERROR: Only curves with no intersection point with the axis can be revolve-swept.
Created swept volume 66
Created swept volume 67
Created swept volume 68
Created swept volume 69
ERROR: Sweep along curve itself is not allowed.
Created swept volume 70
Created swept volume 71
ERROR: Errors found during Mergechk session.
PASS: modify
Adding solids.
Adding shells.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding loops.
Adding edges.
Adding vertices.
Adding faces.
Adding loops.
Adding loops.
Adding edges.
Adding vertices.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding solids.
Adding shells.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding loops.
Adding edges.
Adding vertices.
Adding faces.
Adding loops.
Adding loops.
Adding edges.
Adding vertices.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Constructed 1 Volume: 2
Adding solids.
Adding shells.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding solids.
Adding shells.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding edges.
Adding vertices.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding loops.
Adding edges.
Adding vertices.
Adding faces.
Adding loops.
Adding loops.
Adding edges.
Adding vertices.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding loops.
Adding edges.
Adding vertices.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Constructed 2 Volumes: 3, 4
Created volume(s): 5 to 8
Exported: 5 OCC Bodies
3 OCC Points
Exported: 2 OCC Bodies
3 OCC Points
PASS: makept
Adding solids.
Adding shells.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding solids.
Adding shells.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Constructed 2 Volumes: 1, 2
Adding solids.
Adding shells.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding solids.
Adding shells.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Created volume(s): 5, 6
Destroyed volume(s): 3, 4
ERROR: Problems reading geometry file ./unite1.occ.
FAIL: r_w
./test_occ: error while loading shared libraries: libSpaAVis.so: cannot open shared object file: No such file or directory
PASS: test_occ
1 of 7 tests failed
make[2]: *** [check-TESTS] Error 1
make[2]: Leaving directory `/home/jason/cgm/test/64/test'
make[1]: *** [check-am] Error 2
make[1]: Leaving directory `/home/jason/cgm/test/64/test'
make: *** [check-recursive] Error 1
More information about the cgma-dev
