[cgma-dev] CGM distcheck failed.
Nightly Test
kraftche at cae.wisc.edu
Sun Nov 2 02:00:46 CST 2008
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking target system type... x86_64-unknown-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for style of include used by make... GNU
checking for cc... cc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether cc accepts -g... yes
checking for cc option to accept ISO C89... none needed
checking dependency style of cc... gcc3
checking how to run the C preprocessor... cc -E
checking for CC... no
checking for aCC... no
checking for cxx... no
checking for xlC_r... no
checking for xlC... no
checking for c++... c++
checking whether we are using the GNU C++ compiler... yes
checking whether c++ accepts -g... yes
checking dependency style of c++... gcc3
checking how to run the C++ preprocessor... c++ -E
checking for gfortran... gfortran
checking whether we are using the GNU Fortran compiler... yes
checking whether gfortran accepts -g... yes
checking whether we are using the GNU Fortran 77 compiler... yes
checking for known C compilers... GNU
checking for known compiler/OS combinations... GNU:x86_64
checking for known c++ compilers... GNU
checking whether we are using the GNU Fortran compiler... (cached) yes
checking whether gfortran accepts -g... (cached) yes
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ld used by cc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognize dependent libraries... pass_all
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking the maximum length of command line arguments... 98304
checking command to parse /usr/bin/nm -B output from cc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if cc supports -fno-rtti -fno-exceptions... no
checking for cc option to produce PIC... -fPIC
checking if cc PIC flag -fPIC works... yes
checking if cc static flag -static works... yes
checking if cc supports -c -o file.o... yes
checking whether the cc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... no
checking whether to build static libraries... yes
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by c++... /usr/bin/ld -m elf_x86_64
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
checking whether the c++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for c++ option to produce PIC... -fPIC
checking if c++ PIC flag -fPIC works... yes
checking if c++ static flag -static works... yes
checking if c++ supports -c -o file.o... yes
(cached) (cached) checking how to hardcode library paths into programs... immediate
appending configuration tag "F77" to libtool
checking for gfortran option to produce PIC... -fPIC
checking if gfortran PIC flag -fPIC works... yes
checking if gfortran static flag -static works... yes
checking if gfortran supports -c -o file.o... yes
checking whether the gfortran linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether byte ordering is bigendian... no
checking how to get verbose linking output from gfortran... -v
checking for Fortran libraries of gfortran... -L/usr/lib/gcc/x86_64-linux-gnu/4.3.2 -L/usr/lib/gcc/x86_64-linux-gnu/4.3.2/../../../../lib -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.3.2/../../.. -lgfortranbegin -lgfortran -lm
checking for dummy main to link with Fortran libraries... none
checking for Fortran name-mangling scheme... lower case, underscore, no extra underscore
checking for C++-standard library in std:: namespace... yes
checking for C++-standard I/O in std:: namespace... yes
checking if C++ template definitions should be included... yes
CXXFLAGS = -Wall -pipe -pedantic -O2 -DNDEBUG
configure: creating ./config.status
config.status: creating Makefile
config.status: creating util/Makefile
config.status: creating geom/Makefile
config.status: creating geom/ACIS/Makefile
config.status: creating geom/Cholla/Makefile
config.status: creating geom/facet/Makefile
config.status: creating geom/facetbool/Makefile
config.status: creating geom/OCC/Makefile
config.status: creating geom/parallel/Makefile
config.status: creating geom/virtual/Makefile
config.status: creating init/Makefile
config.status: creating cgm.make
config.status: creating itaps/Makefile
config.status: creating itaps/iGeom-Defs.inc
config.status: creating itaps/SIDL/Makefile
config.status: creating test/Makefile
config.status: creating cgm_apps/Makefile
config.status: creating cgm_apps/examples/Makefile
config.status: creating cgm_apps/examples/driverc++/Makefile
config.status: creating cgm_apps/examples/facetdriver/Makefile
config.status: creating config.h
config.status: creating itaps/iBase_FCDefs.h
config.status: executing depfiles commands
{ test ! -d CGMA-10.2.2 || { find CGMA-10.2.2 -type d ! -perm -200 -exec chmod u+w {} ';' && rm -fr CGMA-10.2.2; }; }
test -d CGMA-10.2.2 || mkdir CGMA-10.2.2
list='util geom init . itaps test cgm_apps'; for subdir in $list; do \
if test "$subdir" = .; then :; else \
test -d "CGMA-10.2.2/$subdir" \
|| /bin/mkdir -p "CGMA-10.2.2/$subdir" \
|| exit 1; \
distdir=`CDPATH="${ZSH_VERSION+.}:" && cd CGMA-10.2.2 && pwd`; \
top_distdir=`CDPATH="${ZSH_VERSION+.}:" && cd CGMA-10.2.2 && pwd`; \
(cd $subdir && \
make \
top_distdir="$top_distdir" \
distdir="$distdir/$subdir" \
am__remove_distdir=: \
am__skip_length_check=: \
distdir) \
|| exit 1; \
fi; \
done
make[1]: Entering directory `/home/jason/cgm/test/dist/util'
make[1]: Leaving directory `/home/jason/cgm/test/dist/util'
make[1]: Entering directory `/home/jason/cgm/test/dist/geom'
list='. Cholla facetbool facet virtual ACIS parallel OCC'; for subdir in $list; do \
test -d "/home/jason/cgm/test/dist/CGMA-10.2.2/geom/$subdir" \
|| /bin/mkdir -p "/home/jason/cgm/test/dist/CGMA-10.2.2/geom/$subdir" \
|| exit 1; \
distdir=`CDPATH="${ZSH_VERSION+.}:" && cd /home/jason/cgm/test/dist/CGMA-10.2.2/geom && pwd`; \
top_distdir=`CDPATH="${ZSH_VERSION+.}:" && cd /home/jason/cgm/test/dist/CGMA-10.2.2 && pwd`; \
(cd $subdir && \
make \
distdir) \
|| exit 1; \
fi; \
done
make[2]: Entering directory `/home/jason/cgm/test/dist/geom/Cholla'
make[2]: Leaving directory `/home/jason/cgm/test/dist/geom/Cholla'
make[2]: Entering directory `/home/jason/cgm/test/dist/geom/facetbool'
make[2]: Leaving directory `/home/jason/cgm/test/dist/geom/facetbool'
make[2]: Entering directory `/home/jason/cgm/test/dist/geom/facet'
make[2]: Leaving directory `/home/jason/cgm/test/dist/geom/facet'
make[2]: Entering directory `/home/jason/cgm/test/dist/geom/virtual'
make[2]: Leaving directory `/home/jason/cgm/test/dist/geom/virtual'
make[2]: Entering directory `/home/jason/cgm/test/dist/geom/ACIS'
make[2]: Leaving directory `/home/jason/cgm/test/dist/geom/ACIS'
make[2]: Entering directory `/home/jason/cgm/test/dist/geom/parallel'
make[2]: Leaving directory `/home/jason/cgm/test/dist/geom/parallel'
make[2]: Entering directory `/home/jason/cgm/test/dist/geom/OCC'
make[2]: Leaving directory `/home/jason/cgm/test/dist/geom/OCC'
make[1]: Leaving directory `/home/jason/cgm/test/dist/geom'
make[1]: Entering directory `/home/jason/cgm/test/dist/init'
make[1]: Leaving directory `/home/jason/cgm/test/dist/init'
make[1]: Entering directory `/home/jason/cgm/test/dist/itaps'
cd ../../trunk && /bin/sh /home/jason/cgm/test/trunk/missing --run autoheader
rm -f stamp-h2
touch ../../trunk/itaps/iBase_FCDefs.h.in
cd .. && /bin/sh ./config.status itaps/iBase_FCDefs.h
config.status: itaps/iBase_FCDefs.h is unchanged
list='. SIDL'; for subdir in $list; do \
test -d "/home/jason/cgm/test/dist/CGMA-10.2.2/itaps/$subdir" \
|| /bin/mkdir -p "/home/jason/cgm/test/dist/CGMA-10.2.2/itaps/$subdir" \
|| exit 1; \
distdir=`CDPATH="${ZSH_VERSION+.}:" && cd /home/jason/cgm/test/dist/CGMA-10.2.2/itaps && pwd`; \
(cd $subdir && \
make \
distdir) \
|| exit 1; \
fi; \
done
make[2]: Entering directory `/home/jason/cgm/test/dist/itaps/SIDL'
make[2]: Leaving directory `/home/jason/cgm/test/dist/itaps/SIDL'
make[1]: Leaving directory `/home/jason/cgm/test/dist/itaps'
make[1]: Entering directory `/home/jason/cgm/test/dist/test'
make[1]: Leaving directory `/home/jason/cgm/test/dist/test'
make[1]: Entering directory `/home/jason/cgm/test/dist/cgm_apps'
list='examples'; for subdir in $list; do \
test -d "/home/jason/cgm/test/dist/CGMA-10.2.2/cgm_apps/$subdir" \
|| /bin/mkdir -p "/home/jason/cgm/test/dist/CGMA-10.2.2/cgm_apps/$subdir" \
|| exit 1; \
distdir=`CDPATH="${ZSH_VERSION+.}:" && cd /home/jason/cgm/test/dist/CGMA-10.2.2/cgm_apps && pwd`; \
(cd $subdir && \
make \
distdir) \
|| exit 1; \
fi; \
done
make[2]: Entering directory `/home/jason/cgm/test/dist/cgm_apps/examples'
list='driverc++ facetdriver'; for subdir in $list; do \
test -d "/home/jason/cgm/test/dist/CGMA-10.2.2/cgm_apps/examples/$subdir" \
|| /bin/mkdir -p "/home/jason/cgm/test/dist/CGMA-10.2.2/cgm_apps/examples/$subdir" \
|| exit 1; \
distdir=`CDPATH="${ZSH_VERSION+.}:" && cd /home/jason/cgm/test/dist/CGMA-10.2.2/cgm_apps/examples && pwd`; \
(cd $subdir && \
make \
distdir) \
|| exit 1; \
fi; \
done
make[3]: Entering directory `/home/jason/cgm/test/dist/cgm_apps/examples/driverc++'
make[3]: Leaving directory `/home/jason/cgm/test/dist/cgm_apps/examples/driverc++'
make[3]: Entering directory `/home/jason/cgm/test/dist/cgm_apps/examples/facetdriver'
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../../trunk/cgm_apps/examples/facetdriver -I../../.. -I../../../itaps -I../../../../trunk/util -I../../../../trunk/geom -I../../../../trunk/geom/Cholla -I../../../../trunk/geom/facet -Wall -pipe -pedantic -O2 -DNDEBUG -MT facets.o -MD -MP -MF .deps/facets.Tpo -c -o facets.o ../../../../trunk/cgm_apps/examples/facetdriver/facets.cpp
mv -f .deps/facets.Tpo .deps/facets.Po
make[3]: *** No rule to make target `../../../libcgm.la', needed by `facets'. Stop.
make[3]: Leaving directory `/home/jason/cgm/test/dist/cgm_apps/examples/facetdriver'
make[2]: *** [distdir] Error 1
make[2]: Leaving directory `/home/jason/cgm/test/dist/cgm_apps/examples'
make[1]: *** [distdir] Error 1
make[1]: Leaving directory `/home/jason/cgm/test/dist/cgm_apps'
make: *** [distdir] Error 1
More information about the cgma-dev
