[cgma-dev] r1815 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Thu May 15 15:10:24 CDT 2008
Author: janehu
Date: 2008-05-15 15:10:24 -0500 (Thu, 15 May 2008)
New Revision: 1815
Added:
cgm/trunk/geom/OCC/OCCCoFace.cpp
cgm/trunk/geom/OCC/OCCCoFace.hpp
Modified:
cgm/trunk/geom/OCC/OCCLump.cpp
cgm/trunk/geom/OCC/OCCLump.hpp
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
cgm/trunk/geom/OCC/OCCShell.cpp
cgm/trunk/geom/OCC/OCCShell.hpp
cgm/trunk/geom/OCC/OCCSurface.cpp
cgm/trunk/geom/OCC/OCCSurface.hpp
Log:
Added for imprint keeping old surfaces.
Added: cgm/trunk/geom/OCC/OCCCoFace.cpp
--- cgm/trunk/geom/OCC/OCCCoFace.cpp (rev 0)
+++ cgm/trunk/geom/OCC/OCCCoFace.cpp 2008-05-15 20:10:24 UTC (rev 1815)
@@ -0,0 +1,93 @@
+// Filename : OCCCoFace.cpp
+// Purpose :
+// Special Notes :
+// Creator : Jane Hu
+// Creation Date : 04/28/08
+// ********** BEGIN STANDARD INCLUDES **********
+// ********** END STANDARD INCLUDES **********
+#include "config.h"
+// ********** BEGIN CUBIT INCLUDES **********
+#include "CubitDefines.h"
+#include "CastTo.hpp"
+#include "OCCCoFace.hpp"
+#include "OCCLoop.hpp"
+#include "OCCQueryEngine.hpp"
+#include "CubitUtil.hpp"
+#include "OCCBody.hpp"
+#include "OCCLump.hpp"
+#include "OCCShell.hpp"
+#include "OCCSurface.hpp"
+#include "OCCCurve.hpp"
+// ********** END CUBIT INCLUDES **********
+// ********** BEGIN FORWARD DECLARATIONS **********
+// ********** END FORWARD DECLARATIONS **********
+// ********** BEGIN STATIC DECLARATIONS **********
+// ********** END STATIC DECLARATIONS **********
+// ********** BEGIN PUBLIC FUNCTIONS **********
+OCCCoFace::OCCCoFace( OCCSurface *surf_ptr,
+ OCCShell *shell_ptr, CubitSense sense )
+ : mySurface(surf_ptr),
+ myShell(shell_ptr),faceSense(sense)
+// Purpose : The destructor
+// Special Notes :
+// Creator : Jane HU
+OCCCoFace::~OCCCoFace()
+GeometryQueryEngine*
+OCCCoFace::get_geometry_query_engine() const
+void OCCCoFace::get_parents_virt( DLIList<TopologyBridge*>& parents )
+ parents.append(shell());
+void OCCCoFace::get_children_virt( DLIList<TopologyBridge*>& children )
+ children.append(surface());
+// ********** END PUBLIC FUNCTIONS **********
+// ********** BEGIN PROTECTED FUNCTIONS **********
+// ********** END PROTECTED FUNCTIONS **********
+// ********** BEGIN PRIVATE FUNCTIONS **********
+// ********** END PRIVATE FUNCTIONS **********
+// ********** BEGIN HELPER CLASSES **********
+// ********** END HELPER CLASSES **********
+// ********** BEGIN EXTERN FUNCTIONS **********
+// ********** END EXTERN FUNCTIONS **********
+// ********** BEGIN STATIC FUNCTIONS **********
+// ********** END STATIC FUNCTIONS **********
Property changes on: cgm/trunk/geom/OCC/OCCCoFace.cpp
___________________________________________________________________
Added: cgm/trunk/geom/OCC/OCCCoFace.hpp
--- cgm/trunk/geom/OCC/OCCCoFace.hpp (rev 0)
+++ cgm/trunk/geom/OCC/OCCCoFace.hpp 2008-05-15 20:10:24 UTC (rev 1815)
@@ -0,0 +1,96 @@
+// Filename : OCCCoFace.hpp
+// Purpose :
+// Special Notes :
+// Creation Date : 04/23/08
+#ifndef OCCCOFACE_HPP
+#define OCCCOFACE_HPP
+#include "CubitEntity.hpp"
+#include <TopoDS_Face.hxx>
+#include "DLIList.hpp"
+class GeometryQueryEngine;
+class TopologyEntity;
+class TopologyBridge;
+class LoopSM;
+class OCCBody;
+class OCCLump;
+class OCCShell;
+class OCCSurface;
+class OCCLoop;
+class OCCCurve;
+class OCCPoint;
+class OCCCoFace
+public:
+ OCCCoFace(OCCSurface *surf_ptr, OCCShell *shell_ptr, CubitSense sense);
+ //- A constructor
+ virtual ~OCCCoFace() ;
+ //- The destructor
+ inline CubitSense sense(){return faceSense;}
+ //- returns the sense of the underlying coface wrt the underlying face
+ inline void set_sense(CubitSense sense) {faceSense = sense;}
+ inline OCCSurface *surface()
+ {return mySurface;}
+ //- get the surface associated with this coedge
+ inline void set_surface(OCCSurface* surface) {mySurface = surface;}
+ inline OCCShell* shell() const { return myShell; }
+ inline void set_shell(OCCShell * shell) {myShell = shell;}
+ GeometryQueryEngine*
+ get_geometry_query_engine() const;
+ //R GeometryQueryEngine*
+ //R- A pointer to the geometric modeling engine associated with
+ //R- the object.
+ //- This function returns a pointer to the geometric modeling engine
+ //- associated with the object.
+ void get_parents_virt( DLIList<TopologyBridge*>& parents );
+ void get_children_virt( DLIList<TopologyBridge*>& children );
+protected:
+private:
+ OCCShell *myShell;
+ OCCSurface *mySurface;
+ CubitSense faceSense;
+// ********** BEGIN INLINE FUNCTIONS **********
+// ********** END INLINE FUNCTIONS **********
+// ********** BEGIN FRIEND FUNCTIONS **********
+// ********** END FRIEND FUNCTIONS **********
+#endif
Property changes on: cgm/trunk/geom/OCC/OCCCoFace.hpp
Modified: cgm/trunk/geom/OCC/OCCLump.cpp
--- cgm/trunk/geom/OCC/OCCLump.cpp 2008-05-15 19:56:01 UTC (rev 1814)
+++ cgm/trunk/geom/OCC/OCCLump.cpp 2008-05-15 20:10:24 UTC (rev 1815)
@@ -40,6 +40,7 @@
#include "BRepBuilderAPI_Transform.hxx"
#include "TopTools_DataMapOfShapeInteger.hxx"
#include "BRepAlgoAPI_BooleanOperation.hxx"
+#include "BRepBuilderAPI_MakeShape.hxx"
#include "Bnd_Box.hxx"
#include "BRepBndLib.hxx"
#include "GProp_GProps.hxx"
@@ -352,7 +353,7 @@
CubitStatus OCCLump::update_OCC_entity(TopoDS_Solid& old_solid,
TopoDS_Shape& new_shape,
- BRepAlgoAPI_BooleanOperation *op)
+ BRepBuilderAPI_MakeShape *op)
//set the Shells
TopTools_IndexedMapOfShape M;
@@ -399,5 +400,12 @@
TopoDS_Solid new_solid;
if(!is_null_new_shape && !op->IsDeleted(old_solid))
new_solid = TopoDS::Solid(new_shape);
+ else if (op->IsDeleted(old_solid))
+ M.Clear();
+ TopExp::MapShapes(new_shape, TopAbs_SOLID, M);
+ if(M.Extent() == 1)
+ new_solid = TopoDS::Solid(M(1));
OCCQueryEngine::instance()->update_OCC_map(old_solid, new_solid);
Modified: cgm/trunk/geom/OCC/OCCLump.hpp
--- cgm/trunk/geom/OCC/OCCLump.hpp 2008-05-15 19:56:01 UTC (rev 1814)
+++ cgm/trunk/geom/OCC/OCCLump.hpp 2008-05-15 20:10:24 UTC (rev 1815)
@@ -37,6 +37,7 @@
class OCCCurve;
class OCCPoint;
class BRepBuilderAPI_Transform;
+class BRepBuilderAPI_MakeShape;
class BRepAlgoAPI_BooleanOperation;
@@ -156,7 +157,7 @@
BRepAlgoAPI_BooleanOperation *op = NULL);
static CubitStatus update_OCC_entity(TopoDS_Solid& old_shape,
- BRepAlgoAPI_BooleanOperation *op);
+ BRepBuilderAPI_MakeShape *op);
protected:
private:
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-05-15 19:56:01 UTC (rev 1814)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-05-15 20:10:24 UTC (rev 1815)
@@ -69,6 +69,7 @@
#include "BRepPrimAPI_MakeWedge.hxx"
#include "Handle_Geom_TrimmedCurve.hxx"
#include "Handle_Geom_RectangularTrimmedSurface.hxx"
+#include "BndLib_Add3dCurve.hxx"
#include "TopOpeBRep_EdgesIntersector.hxx"
#include "TopExp_Explorer.hxx"
#include "TopExp.hxx"
@@ -1808,7 +1809,7 @@
double orig_mass = myProps.Mass();
BRepGProp::VolumeProperties(cut_shape, myProps);
double after_mass = myProps.Mass();
- if((-after_mass + orig_mass) <= tol*tol*tol)
+ if((-after_mass + orig_mass) <= tol)
stat = CUBIT_FAILURE;
//Add imprint code here
@@ -1822,7 +1823,7 @@
continue;
//got cut. Update the entities
- if(after_mass > tol*tol*tol)
+ if(after_mass > tol)
TopoDS_Solid old_solid = TopoDS::Solid(cutter.Shape1());
OCCLump::update_OCC_entity(old_solid , cut_shape, &cutter);
@@ -1835,7 +1836,7 @@
BRepGProp::SurfaceProperties(cut_shape, myProps);
- if((-after_mass + orig_mass) <= tol*tol)
@@ -1849,7 +1850,7 @@
continue;
- if(after_mass > tol*tol)
if(from_shape->TShape()->ShapeType() == TopAbs_SHELL)
@@ -1958,6 +1959,7 @@
TopTools_ListOfShape temp_list_of_edges;
temp_list_of_edges.Assign(section.SectionEdges());
int num_edges = temp_list_of_edges.Extent();
CubitBoolean is_same = face1.IsSame(from_face);
CubitBoolean is_same_tool_face = CUBIT_FALSE;
for (int j = 0; j < tool_faces.size(); j++)
@@ -2023,7 +2025,7 @@
TopTools_ListIteratorOfListOfShape Itor;
- //list_of_edges is the intersection edges on from_face from all tool_faces
+ //list_of_edges is the intersection edges on tool_faces
Itor.Initialize(list_of_edges);
int total_edges = list_of_edges.Extent();
DLIList<Curve*> curve_list;
@@ -2080,9 +2082,6 @@
//check if they are the same edge, so don't need to be split
//the overlapped edges are considered the same if they have the
//same length
- GProp_GProps myProps1;
- BRepGProp::LinearProperties(edge, myProps1);
- double d1 = myProps1.Mass();
GProp_GProps myProps2;
BRepGProp::LinearProperties(from_edge, myProps2);
double d2 = myProps2.Mass();
@@ -2104,8 +2103,22 @@
if (!skipped)
- Curve* curve = OCCQueryEngine::instance()->populate_topology_bridge(edge);
- curve_list.append(curve);
+ //check if edge's inside from_face by checking bounding boxes
+ BRepAdaptor_Curve acurve(edge);
+ BRepAdaptor_Surface asurface( from_face);
+ Bnd_Box aBox_edge, aBox_face;
+ BndLib_Add3dCurve::Add(acurve, Precision::Approximation(), aBox_edge);
+ BndLib_AddSurface::Add(asurface, Precision::Approximation(), aBox_face);
+ double min[3], max[3];
+ aBox_edge.Get( min[0], min[1], min[2], max[0], max[1], max[2]);
+ CubitBox aBox_e(min, max);
+ aBox_face.Get( min[0], min[1], min[2], max[0], max[1], max[2]);
+ CubitBox aBox_f(min, max);
+ if (aBox_e <= aBox_f)
+ Curve* curve = OCCQueryEngine::instance()->populate_topology_bridge(edge);
+ curve_list.append(curve);
@@ -2144,8 +2157,46 @@
splitor.Build();
if(splitor.IsDone())
- delete from_shape;
- from_shape = new TopoDS_Shape(splitor.Shape());
+ TopoDS_Shape new_from_shape = splitor.Shape();
+ if(from_shape->TShape()->ShapeType() == TopAbs_COMPSOLID)
+ TopTools_IndexedMapOfShape M;
+ TopExp::MapShapes(*from_shape, TopAbs_SOLID, M);
+ if (M.Extent() == 1)
+ TopoDS_Solid old_solid = TopoDS::Solid(M(1));
+ OCCLump::update_OCC_entity(old_solid, new_from_shape, &splitor);
+ from_shape = new TopoDS_Shape(old_solid);
+ else if(from_shape->TShape()->ShapeType() == TopAbs_SOLID)
+ TopoDS_Solid old_solid = TopoDS::Solid(*from_shape);
+ else if(from_shape->TShape()->ShapeType() == TopAbs_SHELL)
+ TopoDS_Shell old_shell = TopoDS::Shell(*from_shape);
+ OCCShell::update_OCC_entity(old_shell,new_from_shape, &splitor);
+ from_shape = new TopoDS_Shape(old_shell);
+ else if(from_shape->TShape()->ShapeType() == TopAbs_FACE)
+ TopoDS_Face old_face = TopoDS::Face(*from_shape);
+ OCCSurface::update_OCC_entity(old_face,new_from_shape, &splitor);
+ from_shape = new TopoDS_Shape(old_face);
+ else //imprinting an edge
+ TopoDS_Edge old_edge = TopoDS::Edge(*from_shape);
+ TopExp::MapShapes(new_from_shape, TopAbs_EDGE, M);
+ if (M.Extent() > 1) //split successfully
+ OCCQueryEngine::instance()->update_OCC_map(old_edge, M(1));
TopTools_ListOfShape shapes;
for(int i = 0; i < from_faces.size(); i++)
@@ -2155,13 +2206,6 @@
from_faces.change_to(topo_face);
from_faces.step();
- shapes.Assign(splitor.Modified(from_face));
- TopTools_ListIteratorOfListOfShape It(shapes);
- for(; It.More(); It.Next())
- TopoDS_Face* topo_face = new TopoDS_Face(TopoDS::Face(It.Value()));
- from_faces.append(topo_face);
count++;
Modified: cgm/trunk/geom/OCC/OCCShell.cpp
--- cgm/trunk/geom/OCC/OCCShell.cpp 2008-05-15 19:56:01 UTC (rev 1814)
+++ cgm/trunk/geom/OCC/OCCShell.cpp 2008-05-15 20:10:24 UTC (rev 1815)
@@ -42,6 +42,7 @@
#include "TopTools_ListOfShape.hxx"
@@ -258,7 +259,7 @@
CubitStatus OCCShell::update_OCC_entity(TopoDS_Shell& old_shell,
TopoDS_Shape& new_shell,
//set the surfaces
Modified: cgm/trunk/geom/OCC/OCCShell.hpp
--- cgm/trunk/geom/OCC/OCCShell.hpp 2008-05-15 19:56:01 UTC (rev 1814)
+++ cgm/trunk/geom/OCC/OCCShell.hpp 2008-05-15 20:10:24 UTC (rev 1815)
@@ -36,7 +36,7 @@
class OCCPoint;
class OCCShell : public ShellSM
@@ -120,7 +120,7 @@
double measure(); //area of the shell
static CubitStatus update_OCC_entity(TopoDS_Shell& old_shell,
protected:
private:
Modified: cgm/trunk/geom/OCC/OCCSurface.cpp
--- cgm/trunk/geom/OCC/OCCSurface.cpp 2008-05-15 19:56:01 UTC (rev 1814)
+++ cgm/trunk/geom/OCC/OCCSurface.cpp 2008-05-15 20:10:24 UTC (rev 1815)
@@ -44,6 +44,7 @@
#include "LoopSM.hpp"
#include "CubitPointData.hpp"
#include "BRepTools_WireExplorer.hxx"
#include "BRep_Tool.hxx"
@@ -828,7 +829,7 @@
CubitStatus OCCSurface::update_OCC_entity(TopoDS_Face& old_surface,
TopoDS_Shape& new_surface,
//set the Wires
Modified: cgm/trunk/geom/OCC/OCCSurface.hpp
--- cgm/trunk/geom/OCC/OCCSurface.hpp 2008-05-15 19:56:01 UTC (rev 1814)
+++ cgm/trunk/geom/OCC/OCCSurface.hpp 2008-05-15 20:10:24 UTC (rev 1815)
@@ -49,6 +49,7 @@
class OCCPoint;
//// class CubitTransformMatrix;
class OCCSurface : public Surface
@@ -63,7 +64,7 @@
static CubitStatus update_OCC_entity(TopoDS_Face& old_surface,
void add_shell(OCCShell* shell) { myShellList.append_unique(shell);}
More information about the cgma-dev
