[cgma-dev] r1778 - cgm/trunk/geom/OCC
Jason Kraftcheck
kraftche at cae.wisc.edu
Thu May 15 15:01:50 CDT 2008
janehu at mcs.anl.gov wrote:
> Author: janehu
> Date: 2008-04-25 14:24:47 -0500 (Fri, 25 Apr 2008)
> New Revision: 1778
> Modified:
> cgm/trunk/geom/OCC/Makefile.am
> cgm/trunk/geom/OCC/OCCBody.cpp
> cgm/trunk/geom/OCC/OCCCurve.cpp
> cgm/trunk/geom/OCC/OCCCurve.hpp
> cgm/trunk/geom/OCC/OCCLoop.cpp
> cgm/trunk/geom/OCC/OCCLump.cpp
> cgm/trunk/geom/OCC/OCCModifyEngine.cpp
> cgm/trunk/geom/OCC/OCCPoint.cpp
> cgm/trunk/geom/OCC/OCCQueryEngine.cpp
> cgm/trunk/geom/OCC/OCCQueryEngine.hpp
> cgm/trunk/geom/OCC/OCCShell.cpp
> cgm/trunk/geom/OCC/OCCShell.hpp
> cgm/trunk/geom/OCC/OCCSurface.cpp
> Log:
> Modified to delete free curves after a unite operation.
Jane,
Several files in the checkin below reference a "OCCCoFace" class and related
files. These files have not been checked in, thus the CGM build is broken
if configured with OCC support.
- jason
> Modified: cgm/trunk/geom/OCC/Makefile.am
> --- cgm/trunk/geom/OCC/Makefile.am 2008-04-24 19:55:06 UTC (rev 1777)
> +++ cgm/trunk/geom/OCC/Makefile.am 2008-04-25 19:24:47 UTC (rev 1778)
> @@ -33,6 +33,7 @@
> OCCAttribSet.cpp \
> OCCBody.cpp \
> OCCCoEdge.cpp \
> + OCCCoFace.cpp \
> OCCCurve.cpp \
> OCCLoop.cpp \
> OCCLump.cpp \
> Modified: cgm/trunk/geom/OCC/OCCBody.cpp
> --- cgm/trunk/geom/OCC/OCCBody.cpp 2008-04-24 19:55:06 UTC (rev 1777)
> +++ cgm/trunk/geom/OCC/OCCBody.cpp 2008-04-25 19:24:47 UTC (rev 1778)
> @@ -102,6 +102,7 @@
> OCCBody::~OCCBody()
> + delete myTopoDSShape;
> GeometryQueryEngine* OCCBody::get_geometry_query_engine() const
> Modified: cgm/trunk/geom/OCC/OCCCurve.cpp
> --- cgm/trunk/geom/OCC/OCCCurve.cpp 2008-04-24 19:55:06 UTC (rev 1777)
> +++ cgm/trunk/geom/OCC/OCCCurve.cpp 2008-04-25 19:24:47 UTC (rev 1778)
> @@ -111,7 +111,7 @@
> OCCCurve::~OCCCurve()
> - assert(myLoopList.size() == 0);
> + delete myTopoDSEdge;
> Modified: cgm/trunk/geom/OCC/OCCCurve.hpp
> --- cgm/trunk/geom/OCC/OCCCurve.hpp 2008-04-24 19:55:06 UTC (rev 1777)
> +++ cgm/trunk/geom/OCC/OCCCurve.hpp 2008-04-25 19:24:47 UTC (rev 1778)
> @@ -45,7 +45,7 @@
> public :
> - OCCCurve( TopoDS_Edge *theEdge );
> + OCCCurve( TopoDS_Edge* theEdge );
> virtual ~OCCCurve() ;
> //- The destructor
> Modified: cgm/trunk/geom/OCC/OCCLoop.cpp
> --- cgm/trunk/geom/OCC/OCCLoop.cpp 2008-04-24 19:55:06 UTC (rev 1777)
> +++ cgm/trunk/geom/OCC/OCCLoop.cpp 2008-04-25 19:24:47 UTC (rev 1778)
> @@ -62,6 +62,7 @@
> OCCLoop::~OCCLoop()
> disconnect_all_curves();
> + delete myTopoDSWire;
> Modified: cgm/trunk/geom/OCC/OCCLump.cpp
> --- cgm/trunk/geom/OCC/OCCLump.cpp 2008-04-24 19:55:06 UTC (rev 1777)
> +++ cgm/trunk/geom/OCC/OCCLump.cpp 2008-04-25 19:24:47 UTC (rev 1778)
> @@ -73,7 +73,7 @@
> OCCLump::~OCCLump()
> +{ delete myTopoDSSolid;}
> // Purpose : Find centroid
> Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
> --- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-04-24 19:55:06 UTC (rev 1777)
> +++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-04-25 19:24:47 UTC (rev 1778)
> @@ -119,7 +119,6 @@
> #include "AppUtil.hpp"
> #include "SphereEvaluator.hpp"
> #include "CylinderEvaluator.hpp"
> OCCModifyEngine* OCCModifyEngine::instance_ = 0;
> @@ -1595,6 +1594,7 @@
> delete shell->my_lump();
> shell->set_body(NULL);
> shell->set_lump(NULL);
> TopoDS_Shell* topods_shell = shell->get_TopoDS_Shell();
> if(topods_shell)
> faces_to_stitch.append(topods_shell);
> @@ -1629,8 +1629,20 @@
> new_shape = shapes.First();
> OCCSurface::update_OCC_entity(face, TopoDS::Face(new_shape), &fuser);
> - //else
> - // OCCSurface::update_OCC_entity(face, face, &fuser);
> + else if(fuser.IsDeleted(face))
> + TopoDS_Face null_face;
> + int k = OCCSurface::update_OCC_entity(face, null_face, &fuser);
> + std::map<int, TopologyBridge*>::iterator it =
> + OCCQueryEngine::instance()->OccToCGM->find(k);
> + TopologyBridge* tb = NULL;
> + if (it != OCCQueryEngine::instance()->OccToCGM->end())
> + OCCQueryEngine::instance()->OccToCGM->erase(k);
> + tb = (*it).second;
> + delete tb;
> Modified: cgm/trunk/geom/OCC/OCCPoint.cpp
> --- cgm/trunk/geom/OCC/OCCPoint.cpp 2008-04-24 19:55:06 UTC (rev 1777)
> +++ cgm/trunk/geom/OCC/OCCPoint.cpp 2008-04-25 19:24:47 UTC (rev 1778)
> @@ -82,6 +82,7 @@
> OCCPoint::~OCCPoint()
> + delete myTopoDSVertex;
> Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
> --- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-04-24 19:55:06 UTC (rev 1777)
> +++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-04-25 19:24:47 UTC (rev 1778)
> @@ -53,6 +53,7 @@
> #include "OCCPoint.hpp"
> #include "OCCCurve.hpp"
> #include "OCCCoEdge.hpp"
> +#include "OCCCoFace.hpp"
> #include "OCCLoop.hpp"
> #include "OCCSurface.hpp"
> #include "OCCShell.hpp"
> @@ -1212,14 +1213,22 @@
> TopExp_Explorer Ex;
> + DLIList<OCCCoFace*> cofaces;
> for (Ex.Init(aShape, TopAbs_FACE); Ex.More(); Ex.Next())
> + TopoDS_Face topo_face = TopoDS::Face(Ex.Current());
> Surface* face =
> - populate_topology_bridge(TopoDS::Face(Ex.Current()), build_body);
> + populate_topology_bridge(topo_face, build_body);
> + OCCSurface *occ_surface = CAST_TO(face, OCCSurface);
> + OCCCoFace * coface = new OCCCoFace( occ_surface, shell,
> + ( topo_face.Orientation()== TopAbs_FORWARD ? CUBIT_FORWARD : CUBIT_REVERSED));
> + cofaces.append(coface);
> if(standalone)
> - CAST_TO(face,OCCSurface)->set_shell(shell);
> + occ_surface->set_shell(shell);
> + shell->cofaces(cofaces);
> return shell;
> @@ -2429,14 +2438,33 @@
> return CUBIT_FALSE;
> -void OCCQueryEngine::update_OCC_map(TopoDS_Shape old_shape,
> +int OCCQueryEngine::update_OCC_map(TopoDS_Shape old_shape,
> TopoDS_Shape new_shape)
> if (!OCCMap->IsBound(old_shape))
> - return;
> + return -1;
> int k = OCCMap->Find(old_shape);
> assert (k > 0 && k <= iTotalTBCreated);
> + if (!new_shape.IsNull() && !old_shape.IsSame(new_shape)&&
> + OCCMap->IsBound(new_shape))
> + //already has a TB built on new_shape
> + //delete the second TB corresponding to old_shape
> + std::map<int, TopologyBridge*>::iterator it = OccToCGM->find(k);
> + if (it != OccToCGM->end())
> + OccToCGM->erase(k);
> + delete tb;
> OCCMap->UnBind(old_shape);
> - OCCMap->Bind(new_shape, k);
> + if(!new_shape.IsNull())
> + OCCMap->Bind(new_shape, k);
> + return k;
> //EOF
> Modified: cgm/trunk/geom/OCC/OCCQueryEngine.hpp
> --- cgm/trunk/geom/OCC/OCCQueryEngine.hpp 2008-04-24 19:55:06 UTC (rev 1777)
> +++ cgm/trunk/geom/OCC/OCCQueryEngine.hpp 2008-04-25 19:24:47 UTC (rev 1778)
> @@ -110,7 +110,7 @@
> //- Singleton pattern
> //- Controlled access and creation of the sole instance of this class.
> - void update_OCC_map(TopoDS_Shape old_shape, TopoDS_Shape new_shape);
> + int update_OCC_map(TopoDS_Shape old_shape, TopoDS_Shape new_shape);
> virtual ~OCCQueryEngine();
> Modified: cgm/trunk/geom/OCC/OCCShell.cpp
> --- cgm/trunk/geom/OCC/OCCShell.cpp 2008-04-24 19:55:06 UTC (rev 1777)
> +++ cgm/trunk/geom/OCC/OCCShell.cpp 2008-04-25 19:24:47 UTC (rev 1778)
> @@ -70,8 +70,14 @@
> OCCShell::~OCCShell()
> + delete myTopoDSShell;
> +OCCCoFace* OCCShell::remove_coface(OCCCoFace *coface)
> + return myCoFaceList.remove(coface);
> void OCCShell::set_TopoDS_Shell(TopoDS_Shell shell)
> if (!myTopoDSShell)
> Modified: cgm/trunk/geom/OCC/OCCShell.hpp
> --- cgm/trunk/geom/OCC/OCCShell.hpp 2008-04-24 19:55:06 UTC (rev 1777)
> +++ cgm/trunk/geom/OCC/OCCShell.hpp 2008-04-25 19:24:47 UTC (rev 1778)
> @@ -31,7 +31,7 @@
> class OCCLump;
> class OCCSurface;
> class OCCLoop;
> -class OCCCoEdge;
> +class OCCCoFace;
> class OCCCurve;
> class OCCPoint;
> class BRepBuilderAPI_Transform;
> @@ -48,6 +48,11 @@
> virtual ~OCCShell() ;
> //- Destructor.
> + void cofaces(DLIList<OCCCoFace *> cofaces) {myCoFaceList = cofaces;}
> + DLIList<OCCCoFace*> cofaces() {return myCoFaceList;}
> + OCCCoFace* remove_coface(OCCCoFace *coface);
> TopoDS_Shell* get_TopoDS_Shell() {return myTopoDSShell;}
> void set_TopoDS_Shell(TopoDS_Shell shell);
> @@ -120,6 +125,7 @@
> OCCSurface* mySheetSurface;
> OCCLump* myLump;
> OCCBody* myBody;
> + DLIList<OCCCoFace *> myCoFaceList;
> Modified: cgm/trunk/geom/OCC/OCCSurface.cpp
> --- cgm/trunk/geom/OCC/OCCSurface.cpp 2008-04-24 19:55:06 UTC (rev 1777)
> +++ cgm/trunk/geom/OCC/OCCSurface.cpp 2008-04-25 19:24:47 UTC (rev 1778)
> @@ -94,6 +94,7 @@
> OCCSurface::~OCCSurface()
> + delete myTopoDSFace;
> @@ -774,7 +775,6 @@
> assert(aBRepTrsf != NULL || op != NULL);
> TopoDS_Shape shape;
> - CubitBoolean need_update = CUBIT_TRUE;
> if (aBRepTrsf)
> shape = aBRepTrsf->ModifiedShape(*get_TopoDS_Face());
> else
> @@ -828,47 +828,82 @@
> TopExp::MapShapes(old_surface, TopAbs_WIRE, M);
> double tol = OCCQueryEngine::instance()->get_sme_resabs_tolerance();
> int ii;
> + TopTools_ListOfShape shapes;
> for (ii=1; ii<=M.Extent(); ii++) {
> - TopoDS_Wire wire = TopoDS::Wire(M(ii));
> - TopTools_ListOfShape shapes;
> - shapes.Assign(op->Modified(wire));
> - if (shapes.Extent() > 0)
> - shape = shapes.First();
> - else
> + TopoDS_Wire wire = TopoDS::Wire(M(ii));
> + if(!new_surface.IsNull())
> - TopTools_IndexedMapOfShape M_new;
> - TopExp::MapShapes(new_surface, TopAbs_WIRE, M_new);
> - shape = M_new(ii);
> + shapes.Assign(op->Modified(wire));
> + if (shapes.Extent() > 0)
> + shape = shapes.First();
> + else
> + TopTools_IndexedMapOfShape M_new;
> + TopExp::MapShapes(new_surface, TopAbs_WIRE, M_new);
> + shape = M_new(ii);
> - OCCQueryEngine::instance()->update_OCC_map(wire, shape);
> + OCCQueryEngine::instance()->update_OCC_map(wire, shape);
> //set curves
> BRepTools_WireExplorer Ex;
> for(Ex.Init(wire); Ex.More();Ex.Next())
> TopoDS_Edge edge = Ex.Current();
> + shape.Nullify();
> shapes.Assign(op->Modified(edge));
> + shape.Nullify();
> - else
> + else if (op->IsDeleted(edge))
> + int k = OCCQueryEngine::instance()->update_OCC_map(edge, shape);
> + delete tb;
> + else
> continue;
> - if(wire.Orientation() == TopAbs_REVERSED)
> + if(wire.Orientation() == TopAbs_REVERSED && !shape.IsNull())
> shape.Orientation(
> shape.Orientation()==TopAbs_FORWARD? TopAbs_REVERSED:TopAbs_FORWARD);
> - OCCQueryEngine::instance()->update_OCC_map(edge, shape);
> + OCCQueryEngine::instance()->update_OCC_map(edge, shape);
> //update vertex
> TopoDS_Vertex vertex = Ex.CurrentVertex();
> shapes.Assign(op->Modified(vertex));
> - need_update = CUBIT_TRUE;
> + shape.Nullify();
> OCCQueryEngine::instance()->update_OCC_map(vertex, shape);
> + else if(op->IsDeleted(vertex))
> + int k = OCCQueryEngine::instance()->update_OCC_map(vertex, shape);
> + delete tb;
> return CUBIT_SUCCESS;
"A foolish consistency is the hobgoblin of little minds" - Ralph Waldo Emerson
More information about the cgma-dev
