[cgma-dev] r1727 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Mon Mar 31 13:03:49 CDT 2008
Author: janehu
Date: 2008-03-31 13:03:49 -0500 (Mon, 31 Mar 2008)
New Revision: 1727
Modified:
cgm/trunk/geom/OCC/OCCLump.hpp
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
cgm/trunk/geom/OCC/OCCQueryEngine.hpp
Log:
Added for the case that a shell with multi-face imprinting on one single face case. In testing.
Modified: cgm/trunk/geom/OCC/OCCLump.hpp
--- cgm/trunk/geom/OCC/OCCLump.hpp 2008-03-31 17:46:33 UTC (rev 1726)
+++ cgm/trunk/geom/OCC/OCCLump.hpp 2008-03-31 18:03:49 UTC (rev 1727)
@@ -50,8 +50,6 @@
virtual ~OCCLump();
//- The destructor
- BodySM* body() {return myBodyPtr;}
void add_body(BodySM* new_body)
{myBodyPtr = new_body;}
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-03-31 17:46:33 UTC (rev 1726)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-03-31 18:03:49 UTC (rev 1727)
@@ -1060,18 +1060,24 @@
TopoDS_Shell aShell = aMakeShell.Shell();
- BRepBuilderAPI_MakeSolid aMakeSolid(aShell);
- if (!aMakeSolid.IsDone())
+ if(aShell.Closed())
- PRINT_ERROR("Cannot create an OCC Lump from the given surfaces.\n"
- "OCC internal error.\n");
- return (Lump *)NULL;
+ BRepBuilderAPI_MakeSolid aMakeSolid(aShell);
+ if (!aMakeSolid.IsDone())
+ PRINT_ERROR("Cannot create an OCC Lump from the given surfaces.\n"
+ "OCC internal error.\n");
+ return (Lump *)NULL;
- TopoDS_Solid aSolid = aMakeSolid.Solid();
+ TopoDS_Solid aSolid = aMakeSolid.Solid();
- return
- OCCQueryEngine::instance()->populate_topology_bridge(aSolid, CUBIT_TRUE);
+ return
+ OCCQueryEngine::instance()->populate_topology_bridge(aSolid, CUBIT_TRUE);
+ OCCShell* occ_shell =
+ OCCQueryEngine::instance()->populate_topology_bridge(aShell, CUBIT_TRUE);
+ return occ_shell->my_lump();
@@ -1179,7 +1185,7 @@
if (lump == NULL)
return (BodySM*)NULL;
- return CAST_TO(lump, OCCLump)->body();
+ return CAST_TO(lump, OCCLump)->get_body();
@@ -1203,7 +1209,7 @@
if (lump == NULL)
@@ -1231,7 +1237,7 @@
if (lump == NULL)
@@ -1279,7 +1285,7 @@
if (lump == NULL)
@@ -1347,7 +1353,7 @@
@@ -1374,7 +1380,7 @@
@@ -1467,7 +1473,7 @@
lump = OCCQueryEngine::instance()->populate_topology_bridge(newSolid,
CUBIT_TRUE);
@@ -1797,7 +1803,8 @@
//find the intersecting edges and faces.
int max_edge = 0;
- TopoDS_Face from_face, tool_face;
+ TopoDS_Face from_face,tool_face;
+ DLIList<TopoDS_Face*> tool_faces;
for(; intersector.MoreIntersection(); intersector.NextIntersection())
TopoDS_Shape face1 = intersector.ChangeFacesIntersector().Face(1);
@@ -1806,13 +1813,52 @@
TopTools_ListOfShape temp_list_of_edges;
temp_list_of_edges.Assign(section.SectionEdges());
int num_edges = temp_list_of_edges.Extent();
- if (max_edge < num_edges)
+ CubitBoolean is_same = face1.IsSame(from_face);
+ CubitBoolean is_same_tool_face = CUBIT_FALSE;
+ for (int j = 0; j < tool_faces.size(); j++)
+ if(face2.IsSame(*(tool_faces.get_and_step())))
+ is_same_tool_face = CUBIT_TRUE;
+ break;
+ if (max_edge < num_edges && !is_same)
list_of_edges.Assign(temp_list_of_edges);
max_edge = num_edges ;
from_face = TopoDS::Face(face1);
tool_face = TopoDS::Face(face2);
+ tool_faces.clean_out();
+ for(int i = 0 ; i < num_edges; i++)
+ tool_faces.append(&tool_face);
+ else if(num_edges == max_edge && is_same && !is_same_tool_face)
+ //multi tool faces cut the same face
+ TopTools_ListIteratorOfListOfShape Itor, temp_Itor;
+ temp_Itor.Initialize(temp_list_of_edges);
+ for(; temp_Itor.More(); temp_Itor.Next())
+ TopoDS_Edge temp_edge = TopoDS::Edge(temp_Itor.Value());
+ Itor.Initialize(list_of_edges);
+ CubitBoolean same_edge = CUBIT_FALSE;
+ for(; Itor.More(); Itor.Next())
+ TopoDS_Edge edge = TopoDS::Edge(Itor.Value());
+ if(edge.IsSame(temp_edge))
+ same_edge = CUBIT_TRUE;
+ break;
+ if(!same_edge)
+ list_of_edges.Append(temp_edge);
+ tool_faces.append(&(TopoDS::Face(face2)));
TopTools_ListIteratorOfListOfShape Itor;
@@ -1830,7 +1876,7 @@
TopoDS_Edge from_edge = TopoDS::Edge(Ex.Current());
TopOpeBRep_EdgesIntersector intersector;
- intersector.SetFaces(tool_face, from_face);
+ intersector.SetFaces(*(tool_faces.get_and_step()), from_face);
intersector.Perform(edge, from_edge);
int num_edges = intersector.NbSegments();
if(num_edges == 1) //overlap
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-03-31 17:46:33 UTC (rev 1726)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-03-31 18:03:49 UTC (rev 1727)
@@ -1062,7 +1062,7 @@
DLIList<TopologyBridge*> OCCQueryEngine::populate_topology_bridge(TopoDS_Shape aShape)
DLIList<TopologyBridge*> tblist;
- // suitable to popolate for a TopoDS_CompSolid or TopoDS_Compound shape.
+ // suitable to populate for a TopoDS_CompSolid or TopoDS_Compound shape.
TopExp_Explorer Ex;
for (Ex.Init(aShape, TopAbs_COMPSOLID); Ex.More(); Ex.Next())
tblist.append(populate_topology_bridge(TopoDS::CompSolid(Ex.Current())));
@@ -1071,7 +1071,7 @@
Lump *lump =
populate_topology_bridge(TopoDS::Solid(Ex.Current()), CUBIT_TRUE);
- tblist.append(CAST_TO(lump, OCCLump)->body());
+ tblist.append(CAST_TO(lump, OCCLump)->get_body());
for (Ex.Init(aShape, TopAbs_SHELL, TopAbs_SOLID); Ex.More(); Ex.Next())
@@ -1545,8 +1545,8 @@
ShellSM* shell = CAST_TO(children.get_and_step(), ShellSM);
unhook_ShellSM_from_OCC(shell);
- if (occ_lump->body() != NULL)
- BodyList->remove(CAST_TO(occ_lump->body(), OCCBody));
+ if (occ_lump->get_body() != NULL)
+ BodyList->remove(CAST_TO(occ_lump->get_body(), OCCBody));
delete solid;
delete lump;
return CUBIT_SUCCESS;
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.hpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.hpp 2008-03-31 17:46:33 UTC (rev 1726)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.hpp 2008-03-31 18:03:49 UTC (rev 1727)
@@ -345,6 +345,8 @@
Curve* populate_topology_bridge(TopoDS_Edge aShape);
Point* populate_topology_bridge(TopoDS_Vertex aShape);
+ OCCShell* populate_topology_bridge(TopoDS_Shell aShape,
+ CubitBoolean standalone = CUBIT_FALSE );
DLIList<OCCBody*> *BodyList ;
DLIList<OCCSurface*> *SurfaceList ;
DLIList<OCCLoop*> *WireList; //standalone wire list
@@ -361,8 +363,6 @@
OCCLoop* populate_topology_bridge(TopoDS_Wire aShape,
CubitBoolean standalone = CUBIT_FALSE);
- OCCShell* populate_topology_bridge(TopoDS_Shell aShape,
- CubitBoolean standalone = CUBIT_FALSE );
CubitStatus write_topology( const char* file_name,
DLIList<OCCBody*> &facet_bodies,
More information about the cgma-dev
