[cgma-dev] r1718 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov janehu at mcs.anl.gov
Fri Mar 28 14:25:36 CDT 2008
Author: janehu
Date: 2008-03-28 14:25:35 -0500 (Fri, 28 Mar 2008)
New Revision: 1718
Modified:
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Now imprint_toposhape can handle following problems, all of them applies for
one face getting imprinted, because the imprint option is now only valid in
subtract function when no actual cutting happened.
1. Face cutting with two lines;
2. Face cutting with a open wire;
3. Face cutting with a closed wire.
It needs improvement for shell face imprinting and body body imprinting."
test passed the above 3 options.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-03-28 18:02:52 UTC (rev 1717)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-03-28 19:25:35 UTC (rev 1718)
@@ -63,6 +63,7 @@
 #include "BRepPrimAPI_MakeWedge.hxx"
 #include "Handle_Geom_TrimmedCurve.hxx"
 #include "Handle_Geom_RectangularTrimmedSurface.hxx"
+#include "TopOpeBRep_EdgesIntersector.hxx"
 #include "TopExp_Explorer.hxx"
 #include "OCCModifyEngine.hpp"
 #include "OCCQueryEngine.hpp"
@@ -758,7 +759,8 @@
   topo_edges_loops.clean_out();
   CubitStatus stat = CUBIT_SUCCESS;
   DLIList<TopoDS_Edge*>* topo_edges[curve_list.size()];
-  for(int i = 0; i < curve_list.size(); i++)
+  int size_in = curve_list.size();
+  for(int i = 0; i < size_in; i++)
     topo_edges[i] = new DLIList<TopoDS_Edge*>;
   curve_list.reset() ;
@@ -770,12 +772,14 @@
   OCCPoint* end = NULL;
   DLIList<OCCPoint*> point_list;
   double tol = OCCQueryEngine::instance()->get_sme_resabs_tolerance();
-  CubitBoolean new_end = CUBIT_TRUE;
+  CubitBoolean new_end;
   int size = curve_list.size();
   int count = 0;
   for ( int i = 0 ; i < size ; i++ )
+     if (i == 0)
+       new_end = CUBIT_TRUE;
      for(int j = 0; j < curve_list.size(); j ++)
         curve_ptr = curve_list.get() ;
@@ -800,12 +804,21 @@
         if(end->is_equal(*(point_list.get()), tol) ||
-                end->is_equal(*(point_list.step_and_get()),tol))
+           end->is_equal(*(point_list.step_and_get()),tol))
            end = point_list.step_and_get();
            break;
+        else if(start->is_equal(*(point_list.get()), tol) ||
+           start->is_equal(*(point_list.step_and_get()),tol))
+           start = end;
+           end = point_list.step_and_get();
+           break;
         curve_list.step();
@@ -816,7 +829,7 @@
         curve_list.remove();
         if(start->is_equal( *end, tol))  //formed a closed loop
-          i = 0;
+          i = -1;
           size = curve_list.size() ;
           topo_edges_loops.append(topo_edges[count]);
           count++;
@@ -829,11 +842,22 @@
         stat = CUBIT_FAILURE;
         i = -1;
+        topo_edges_loops.append(topo_edges[count]);
+        count++;
   if( new_end == CUBIT_FALSE ) //case of one disconnected curve
+     if(topo_edges[i]->size() == 0)
+       delete topo_edges[i];
   return stat;
@@ -1671,6 +1695,7 @@
         double after_mass = myProps.Mass();
         if((-after_mass + orig_mass) <= tol*tol*tol)
+          stat = CUBIT_FAILURE;
           //Add imprint code here
           if(imprint)
             stat = imprint_toposhapes(from_shape, tool_shape);
@@ -1691,6 +1716,7 @@
         if((-after_mass + orig_mass) <= tol*tol)
           if(imprint)
@@ -1761,6 +1787,7 @@
                                                 TopoDS_Shape* tool_shape)const
   int num_cuts = 1;
+  CubitStatus stat = CUBIT_SUCCESS;
   while(num_cuts)
       TopOpeBRep_ShapeIntersector intersector;
@@ -1768,6 +1795,7 @@
       BRepFeat_SplitShape splitor(*from_shape);
       TopTools_ListOfShape list_of_edges;
+      //find the intersecting edges and faces.
       int max_edge = 0;
       TopoDS_Face from_face, tool_face;
       for(; intersector.MoreIntersection(); intersector.NextIntersection())
@@ -1790,6 +1818,7 @@
       TopTools_ListIteratorOfListOfShape Itor;
       Itor.Initialize(list_of_edges);
       DLIList<Curve*> curve_list;
+      CubitBoolean topo_changed = CUBIT_FALSE;
       for(; Itor.More(); Itor.Next())
         TopoDS_Edge edge = TopoDS::Edge(Itor.Value());
@@ -1800,31 +1829,28 @@
 	for (Ex.Init(from_face, TopAbs_EDGE); Ex.More(); Ex.Next())
 	  TopoDS_Edge from_edge = TopoDS::Edge(Ex.Current());
-          TopOpeBRep_ShapeIntersector intersector;
-   	  intersector.InitIntersection(edge, from_edge, tool_face, from_face);
-	  for(; intersector.MoreIntersection(); intersector.NextIntersection())
-            TopoDS_Shape section_shape = intersector.CurrentGeomShape(1);
-            TopExp_Explorer Ex;
-            int num_edges = 0;
-            for (Ex.Init(section_shape, TopAbs_EDGE); Ex.More(); Ex.Next())
-              num_edges++;
-	    if(num_edges== 1) //overlap
+          TopOpeBRep_EdgesIntersector intersector;
+   	  intersector.SetFaces(tool_face, from_face);
+          intersector.Perform(edge, from_edge);
+          int num_edges = intersector.NbSegments();
+	  if(num_edges == 1) //overlap
 	      added = CUBIT_TRUE;
    	      splitor.Add(edge, from_edge);
 	      max_edge--;
 	      break;
-	  if(added)
-	    continue;
+        if(added)
+          topo_changed = CUBIT_TRUE;
+          continue;
 	Curve* curve = OCCQueryEngine::instance()->populate_topology_bridge(edge);
 	curve_list.append(curve);
       DLIList<DLIList<TopoDS_Edge*>*> edge_lists;
-      if (max_edge > 1)
+      if (max_edge >= 1)
 	  sort_curves(curve_list, edge_lists);
 	  DLIList<TopoDS_Edge*>* edge_list;
@@ -1836,11 +1862,17 @@
 	      myWire.Add(e);
 	  splitor.Add(myWire.Wire(),from_face);
-      splitor.Build();
-      if(splitor.IsDone())
-	delete from_shape;
-      from_shape = new TopoDS_Shape(splitor.Shape());
+      if(topo_changed)
+        splitor.Build();
+        if(splitor.IsDone())
+	  delete from_shape;
+        from_shape = new TopoDS_Shape(splitor.Shape());
+      else
       if(edge_lists.size()==0)
 	num_cuts--;
@@ -1853,7 +1885,7 @@
      num_face++;
-  return CUBIT_SUCCESS;
+  return stat;
 // Function   : imprint
More information about the cgma-dev mailing list
