[cgma-dev] r1674 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Thu Mar 20 13:50:32 CDT 2008
Author: janehu
Date: 2008-03-20 13:50:32 -0500 (Thu, 20 Mar 2008)
New Revision: 1674
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
cgm/trunk/geom/OCC/OCCModifyEngine.hpp
Log:
Added check to determine if the subtract operation is actually performed, if did not perform, don't change the original BodySM; Added part of impritn_toposhapes, investigating on splitshape in OCC.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-03-19 19:15:46 UTC (rev 1673)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-03-20 18:50:32 UTC (rev 1674)
@@ -55,6 +55,7 @@
#include "TopologyBridge.hpp"
#include "BRepAlgoAPI_Fuse.hxx"
#include "BRepAlgoAPI_Cut.hxx"
+#include "BRepAlgoAPI_Section.hxx"
#include "BRepPrimAPI_MakeSphere.hxx"
#include "BRepPrimAPI_MakeBox.hxx"
#include "BRepPrimAPI_MakeWedge.hxx"
@@ -66,6 +67,7 @@
#include "CubitMessage.hpp"
#include "CubitDefines.h"
#include "TopTools_DataMapOfShapeInteger.hxx"
+#include "TopOpeBRep_ShapeIntersector.hxx"
#include "CubitUtil.hpp"
#include "CubitPoint.hpp"
#include "CubitPointData.hpp"
@@ -1508,12 +1510,14 @@
// copy the bodies in case subtraction has some errors
DLIList<TopoDS_Shape*> tool_bodies_copy;
DLIList<TopoDS_Shape*> from_bodies_copy;
+ DLIList<CubitBoolean> is_volume;
for (int i = 0; i < from_bodies.size(); i++)
BodySM* body = from_bodies.get_and_step();
OCCBody* occ_body = CAST_TO(body, OCCBody);
OCCSurface* surface = occ_body->my_sheet_surface();
OCCShell* shell = occ_body->shell();
+ is_volume.append( CUBIT_TRUE);
if(surface)
TopoDS_Face* topo_face = surface->get_TopoDS_Face();
@@ -1521,6 +1525,7 @@
TopoDS_Shape newShape = api_copy.ModifiedShape(*topo_face);
TopoDS_Shape* newShape_ptr = new TopoDS_Shape(newShape);
from_bodies_copy.append(newShape_ptr);
+ is_volume.change_to( CUBIT_FALSE);
else if(shell)
@@ -1529,6 +1534,7 @@
TopoDS_Shape newShape = api_copy.ModifiedShape(*topo_shell);
else
@@ -1624,11 +1630,40 @@
TopoDS_Shape* tool_shape = tool_bodies_copy.get_and_step();
//bodies overlap, proceed with the subtract
TopoDS_Shape cut_shape = BRepAlgoAPI_Cut(*from_shape, *tool_shape);
- if(!from_shape->Modified())
+ //compare to see if the from_shape is getting cut.
+ if(is_volume[i])
- count++;
- continue;
+ GProp_GProps myProps;
+ BRepGProp::VolumeProperties(*from_shape, myProps);
+ double orig_mass = myProps.Mass();
+ BRepGProp::VolumeProperties(cut_shape, myProps);
+ double after_mass = myProps.Mass();
+ if((-after_mass + orig_mass) <= tol*tol*tol)
+ //Add imprint code here
+ if(imprint)
+ imprint_toposhapes(from_shape, tool_shape);
+ count++;
+ continue;
+ else
+ BRepGProp::SurfaceProperties(*from_shape, myProps);
+ BRepGProp::SurfaceProperties(cut_shape, myProps);
+ if((-after_mass + orig_mass) <= tol*tol)
+ if(imprint)
+ count++;
+ continue;
delete from_shape;
from_shape = new TopoDS_Shape(cut_shape);
@@ -1651,7 +1686,7 @@
if ((100 - frac_done) < fraction_remaining)
fraction_remaining = 100 - frac_done;
- PRINT_INFO("%d% remaining.\n ", fraction_remaining);
+ PRINT_INFO("%d% remaining.\n ", fraction_remaining+1);
@@ -1677,6 +1712,20 @@
return CUBIT_SUCCESS;
+CubitStatus OCCModifyEngine::imprint_toposhapes(TopoDS_Shape*& from_shape,
+ TopoDS_Shape* tool_shape)const
+ TopOpeBRep_ShapeIntersector intersector;
+ intersector.InitIntersection(*from_shape, *tool_shape);
+ TopTools_ListOfShape list_of_edges;
+ for(; intersector.MoreIntersection(); intersector.NextIntersection())
+ TopoDS_Shape face1 = intersector.ChangeFacesIntersector().Face(1);
+ TopoDS_Shape face2 = intersector.ChangeFacesIntersector().Face(2);
+ BRepAlgoAPI_Section section(face1, face2);
+ list_of_edges.Assign(section.SectionEdges());
// Function : imprint
// Member Type: PUBLIC
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.hpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.hpp 2008-03-19 19:15:46 UTC (rev 1673)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.hpp 2008-03-20 18:50:32 UTC (rev 1674)
@@ -658,6 +658,8 @@
const TopoDS_Face* make_TopoDS_Face( GeometryType surface_type,
DLIList<DLIList<TopoDS_Edge*>*> topo_edges,
Surface* old_surface_ptr) const;
+ CubitStatus imprint_toposhapes(TopoDS_Shape*&, TopoDS_Shape*) const;
private:
More information about the cgma-dev
