[cgma-dev] r1673 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Wed Mar 19 14:15:46 CDT 2008
Author: janehu
Date: 2008-03-19 14:15:46 -0500 (Wed, 19 Mar 2008)
New Revision: 1673
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Fine tuned subtract function.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-03-18 15:43:32 UTC (rev 1672)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-03-19 19:15:46 UTC (rev 1673)
@@ -1599,8 +1599,9 @@
DLIList<TopologyBridge*> tbs;
for (int i = 0; i < from_bodies_copy.size(); i++)
- BodySM* from_body = from_bodies.get_and_step();
+ BodySM* from_body = from_bodies.get();
CubitBox box1 = CAST_TO(from_body, OCCBody)->get_bounding_box();
+ int count = 0; //count for not preforming cut
for(int j = 0; j < tool_body_list.size(); j ++)
if (cmi->Interrupt())
@@ -1616,17 +1617,31 @@
CubitBox tool_box = *tool_boxes.get_and_step();
if(!tool_box.overlap(tol,box1))
+ count++;
continue;
TopoDS_Shape* tool_shape = tool_bodies_copy.get_and_step();
//bodies overlap, proceed with the subtract
TopoDS_Shape cut_shape = BRepAlgoAPI_Cut(*from_shape, *tool_shape);
+ if(!from_shape->Modified())
+ count++;
+ continue;
delete from_shape;
from_shape = new TopoDS_Shape(cut_shape);
//ok, we're done wih all cuts, construct new Body'
- tbs = OCCQueryEngine::instance()->populate_topology_bridge(*from_shape);
+ if (count < tool_body_list.size())
+ tbs += OCCQueryEngine::instance()->populate_topology_bridge(*from_shape);
+ else
+ PRINT_INFO("The %d body did not change because cutting tools are not interscting with it.\n", i+1);
+ from_bodies.change_to(NULL);
+ from_bodies.step();
from_shape = from_bodies_copy.step_and_get();
// done with this j iteration; write out count, if necessary
@@ -1636,14 +1651,14 @@
if ((100 - frac_done) < fraction_remaining)
fraction_remaining = 100 - frac_done;
- PRINT_INFO("%d% remaining. ", fraction_remaining);
+ PRINT_INFO("%d% remaining.\n ", fraction_remaining);
for (int i = 0; i< tbs.size(); i++)
- BodySM* bodysm = CAST_TO(tbs.get(), BodySM);
+ BodySM* bodysm = CAST_TO(tbs.get_and_step(), BodySM);
if (bodysm)
new_bodies.append(bodysm);
@@ -1655,6 +1670,7 @@
delete tool_bodies_copy.pop();
if (!keep_old)
+ from_bodies.remove_all_with_value(NULL);
OCCQueryEngine::instance()->delete_solid_model_entities(from_bodies);
OCCQueryEngine::instance()->delete_solid_model_entities( tool_body_list);
More information about the cgma-dev
