[cgma-dev] r1927 - in cgm/trunk/geom: . ACIS_SRC OCC facet
    janehu at mcs.anl.gov
    Wed Jun 25 13:34:20 CDT 2008
Author: janehu
Date: 2008-06-25 13:34:20 -0500 (Wed, 25 Jun 2008)
New Revision: 1927
Modified:
   cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.cpp
   cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.hpp
   cgm/trunk/geom/GeometryModifyEngine.hpp
   cgm/trunk/geom/GeometryModifyTool.cpp
   cgm/trunk/geom/GeometryModifyTool.hpp
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
   cgm/trunk/geom/OCC/OCCModifyEngine.hpp
   cgm/trunk/geom/facet/FacetModifyEngine.cpp
   cgm/trunk/geom/facet/FacetModifyEngine.hpp
Log:
change back the thicken interface for making thick solid, and added a hollow method of making thick solid.
Modified: cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.cpp
--- cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.cpp	2008-06-25 17:34:56 UTC (rev 1926)
+++ cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.cpp	2008-06-25 18:34:20 UTC (rev 1927)
@@ -5922,6 +5922,16 @@
   return CUBIT_SUCCESS;
+CubitStatus AcisModifyEngine::hollow( DLIList<BodySM*>& bodies,
+                                         DLIList<Surface*>& surfs_to_remove,
+                                         DLIList<BodySM*>& new_body_list,
+                                         double depth) const
+  PRINT_ERROR( "This function is not available in ACIS engine.\n");
+  return CUBIT_FAILURE;
 // Purpose       : To thicken sheet bodies
@@ -5941,7 +5951,6 @@
 #else
   CubitStatus AcisModifyEngine::thicken( DLIList<BodySM*>& bodies,
-                                         DLIList<Surface*>& surfs_to_remove,
 					 double depth,
 					 bool both) const
Modified: cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.hpp
--- cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.hpp	2008-06-25 17:34:56 UTC (rev 1926)
+++ cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.hpp	2008-06-25 18:34:20 UTC (rev 1927)
@@ -382,16 +382,23 @@
  virtual CubitStatus thicken( DLIList<BodySM*>& bodies,
                               DLIList<BodySM*>& new_bodies,
                               double depth,
                               bool both = false) const;
     //- Thicken a sheet body into a solid
-    //- surfs_to_remove is a dummy input
     //R CubitStatus
     //R-the result of the thicken operation: Success or Failure
+ virtual CubitStatus hollow(  DLIList<BodySM*>& bodies,
+                              DLIList<BodySM*>& new_bodies,
+                              double depth) const;
+    //- Hollow a solid body into a thick body
+    //R CubitStatus
+    //R-the result of the hollow operation: Failure
  virtual CubitStatus flip_normals( DLIList<Surface*>& face_list ) const;
     //R CubitStatus
     //R-the result of the flip_normals operation: Success or Failure
Modified: cgm/trunk/geom/GeometryModifyEngine.hpp
--- cgm/trunk/geom/GeometryModifyEngine.hpp	2008-06-25 17:34:56 UTC (rev 1926)
+++ cgm/trunk/geom/GeometryModifyEngine.hpp	2008-06-25 18:34:20 UTC (rev 1927)
@@ -412,7 +412,6 @@
                                    double depth,
                                    bool both = false) const = 0;
@@ -420,9 +419,6 @@
     //I bodies
     //I-DLIList<Body*>: a list of Body pointers that will be thicken
-    //I- or for OCC: a list of solid BodySM's that will be hollowed into a
-    //I- thick solid.
-    //I- surfs_to_remove: the faces to be removed from the original solid (OCC).
     //O- new Bodies build by thicken operation on the list of  Body pointers.
     //- This function performs a thicken of sheet bodies and returns
     //- the result through the output argument in_out_body. If the thicken
@@ -431,6 +427,23 @@
     //- argument is assigned a NULL value and the function returns
     //- CUBIT_FAILURE.
+     virtual CubitStatus hollow(DLIList<BodySM*>& bodies,
+                                double depth) const = 0;
+     //R CubitStatus
+    //R-the result of the hollow operation: Success or Failure
+    //I body
+    //I- for OCC: a list of solid BodySM's that will be hollowed into a list of
+    //I- thick solids.
+    //I- surfs_to_remove: the faces to be removed from the original solid (OCC).
+    //O- new Bodies build by hollow operation on the  body pointers.
+    //- This function performs a hollow of solid body and returns
+    //- the result through the output argument in_out_body. If the hollow
+    //- operation went through OK, the function returns CUBIT_SUCCESS. If,
+    //- for some reason, the hollow operation did not go well, the output
+    //- argument is assigned a NULL value and the function returns
+    //- CUBIT_FAILURE.
      virtual CubitStatus flip_normals( DLIList<Surface*>& face_list ) const = 0;
             //R CubitStatus
Modified: cgm/trunk/geom/GeometryModifyTool.cpp
--- cgm/trunk/geom/GeometryModifyTool.cpp	2008-06-25 17:34:56 UTC (rev 1926)
+++ cgm/trunk/geom/GeometryModifyTool.cpp	2008-06-25 18:34:20 UTC (rev 1927)
@@ -4155,12 +4155,10 @@
-CubitStatus GeometryModifyTool::
-        make_thick_solid( DLIList<Body*>& bodies,
-                          DLIList<RefFace*>& faces_to_remove,
-                          DLIList<Body*>& new_bodies,
-                          double depth,
-                          bool both )
+CubitStatus GeometryModifyTool::thicken( DLIList<Body*>& bodies,
+                                         DLIList<Body*>& new_bodies,
+                                         double depth,
+                                         bool both )
   if (bodies.size() <= 0)
@@ -4188,24 +4186,11 @@
-  DLIList<Surface*> surfs_to_remove;
-  if(faces_to_remove.size() > 0)
-    GeometryModifyEngine* gme2 = common_modify_engine(faces_to_remove,
-						      surfs_to_remove);
-    if(gme2 != gme)
-       PRINT_ERROR("Performing THICKEN with volumes containing geometry\n"
-                   " from different modeling engines is not allowed.\n"
-                   "Delete uncommon geometry on these volumes before operation.\n\n");
-       return CUBIT_FAILURE;
   DLIList<BodySM*> new_sms(count);
   DLIList<BodySM*> body_sms(count);
   CAST_LIST(bridge_list, body_sms, BodySM);
-  CubitStatus result = gme->thicken( body_sms, surfs_to_remove, new_sms, depth, both);
+  CubitStatus result = gme->thicken( body_sms, new_sms, depth, both);
   // check for resued entities, they have been moved and we need to notify observers
   DLIList<RefEntity*> entities_to_update;
Modified: cgm/trunk/geom/GeometryModifyTool.hpp
--- cgm/trunk/geom/GeometryModifyTool.hpp	2008-06-25 17:34:56 UTC (rev 1926)
+++ cgm/trunk/geom/GeometryModifyTool.hpp	2008-06-25 18:34:20 UTC (rev 1927)
@@ -225,8 +225,7 @@
                     bool keep_old = false,
                     bool nonreg = false );
-  CubitStatus make_thick_solid( DLIList<Body*>& bodies,
+  CubitStatus thicken( DLIList<Body*>& bodies,
                        double depth,
                        bool both = false );
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-06-25 17:34:56 UTC (rev 1926)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-06-25 18:34:20 UTC (rev 1927)
@@ -3580,23 +3580,29 @@
+CubitStatus OCCModifyEngine::thicken( DLIList<BodySM*>& bodies,
+                                      double depth,
+                                      CubitBoolean both) const
+  PRINT_ERROR("Option not supported for OCC based geometry.\n");
-// Function   : thicken
+// Function   : hollow
 // Member Type: PUBLIC
 // Description: Hollow existing solid body by remove one or several surfaces
 //              Can only take one body at a time.
-//              No both (side) option.
 //              depth > 0, thick body going outside bodies
 //              depth < 0, thick body going inside bodies
 // Author     : Jane Hu
 // Date       : 06/08
-CubitStatus OCCModifyEngine::thicken(DLIList<BodySM*>& bodies,
+CubitStatus OCCModifyEngine::hollow( DLIList<BodySM*>& bodies,
-                                     double depth,
-                                     bool /*both*/) const
   if(bodies.size() != 1 || surfs_to_remove.size() < 1)
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.hpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.hpp	2008-06-25 17:34:56 UTC (rev 1926)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.hpp	2008-06-25 18:34:20 UTC (rev 1927)
@@ -201,11 +201,15 @@
     bool keep_old = CUBIT_FALSE) const;
   virtual CubitStatus thicken(DLIList<BodySM*>& bodies,
     double depth,
     bool both = CUBIT_FALSE) const ;
+                              double depth) const ;
   virtual CubitStatus  sweep_translational(
Modified: cgm/trunk/geom/facet/FacetModifyEngine.cpp
--- cgm/trunk/geom/facet/FacetModifyEngine.cpp	2008-06-25 17:34:56 UTC (rev 1926)
+++ cgm/trunk/geom/facet/FacetModifyEngine.cpp	2008-06-25 18:34:20 UTC (rev 1927)
@@ -1737,6 +1737,15 @@
+CubitStatus FacetModifyEngine::hollow( DLIList<BodySM*>& /*bodies*/,
+                                       DLIList<Surface*> & /*surfs*/,
+                                       DLIList<BodySM*>& /*new_bodies*/,
+                                       double /*depth*/) const
+  PRINT_ERROR("Option not supported for mesh based geometry.\n");
@@ -1745,7 +1754,6 @@
 // Date       : 10/02
 CubitStatus FacetModifyEngine::thicken(DLIList<BodySM*>& /*bodies*/,
-                                       DLIList<Surface*> & /*surfs*/,
                                        double /*depth*/,
Modified: cgm/trunk/geom/facet/FacetModifyEngine.hpp
--- cgm/trunk/geom/facet/FacetModifyEngine.hpp	2008-06-25 17:34:56 UTC (rev 1926)
+++ cgm/trunk/geom/facet/FacetModifyEngine.hpp	2008-06-25 18:34:20 UTC (rev 1927)
@@ -216,11 +216,15 @@
     double depth,
More information about the cgma-dev
