[cgma-dev] r1926 - in cgm/trunk: geom geom/Cholla util
janehu at mcs.anl.gov
Wed Jun 25 12:34:56 CDT 2008
Author: janehu
Date: 2008-06-25 12:34:56 -0500 (Wed, 25 Jun 2008)
New Revision: 1926
Modified:
cgm/trunk/geom/Cholla/CubitFacet.hpp
cgm/trunk/geom/Cholla/CubitPoint.hpp
cgm/trunk/geom/Curve.hpp
cgm/trunk/geom/DagType.hpp
cgm/trunk/geom/IntermediateGeomEngine.hpp
cgm/trunk/geom/RefEntity.hpp
cgm/trunk/geom/TBOwner.hpp
cgm/trunk/util/CubitFileIOWrapper.hpp
cgm/trunk/util/CubitString.hpp
cgm/trunk/util/CubitUtil.hpp
cgm/trunk/util/CubitVector.hpp
cgm/trunk/util/DLIList.cpp
cgm/trunk/util/DLIList.hpp
cgm/trunk/util/KDDTree.cpp
cgm/trunk/util/KDDTree.hpp
cgm/trunk/util/PriorityQueue.cpp
cgm/trunk/util/RTreeNode.cpp
cgm/trunk/util/RTreeNode.hpp
Log:
Check in for Serge Gosselin to remove compiling warnings we see in CGM.
Modified: cgm/trunk/geom/Cholla/CubitFacet.hpp
--- cgm/trunk/geom/Cholla/CubitFacet.hpp 2008-06-25 14:31:10 UTC (rev 1925)
+++ cgm/trunk/geom/Cholla/CubitFacet.hpp 2008-06-25 17:34:56 UTC (rev 1926)
@@ -134,7 +134,7 @@
virtual int id() = 0;
virtual void set_id( int ii ) = 0;
int tool_id(){return toolID;}
- void set_tool_id(int tool_id){toolID = tool_id;}
+ void set_tool_id(int my_tool_id){toolID = my_tool_id;}
virtual CubitFacetEdge *edge( int index ) = 0;
virtual void edge( CubitFacetEdge *the_edge, int index ) = 0;
@@ -261,7 +261,7 @@
//- Returns all adjacent facets to this edge (not including
//- this facet)
- CubitFacet *adjacent( int &index, int *tool_data )
+ CubitFacet *adjacent( int &index, int *my_tool_data )
//- Returns all adjacent facets to this edge index(not including
//- this facet)
@@ -270,7 +270,7 @@
CubitPoint *p1, *p2;
get_edge_pts( index, p1, p2 );
- return shared_facet_on_surf( p1, p2, *tool_data );
+ return shared_facet_on_surf( p1, p2, *my_tool_data );
CubitPoint* next_node(CubitPoint *current_point)
Modified: cgm/trunk/geom/Cholla/CubitPoint.hpp
--- cgm/trunk/geom/Cholla/CubitPoint.hpp 2008-06-25 14:31:10 UTC (rev 1925)
+++ cgm/trunk/geom/Cholla/CubitPoint.hpp 2008-06-25 17:34:56 UTC (rev 1926)
@@ -85,7 +85,7 @@
virtual double z() = 0;
virtual void set( const CubitVector &pos ) = 0;
- virtual void marked(int marked) {markedFlag = marked;};
+ virtual void marked(int is_marked) {markedFlag = is_marked;};
virtual int marked() {return markedFlag;};
virtual CubitVector coordinates() const = 0;
@@ -111,8 +111,9 @@
virtual double u() { return uVal; };
virtual double v() { return vVal; };
virtual double size() {return sizeVal; };
- virtual void set_uv( double u, double v ) { uVal = u; vVal = v; };
- virtual void set_uvs(double u, double v, double s) {uVal = u; vVal = v; sizeVal = s; }
+ virtual void set_uv( double u_new, double v_new ) { uVal = u_new; vVal = v_new; };
+ virtual void set_uvs(double u_new, double v_new, double s_new)
+ {uVal = u_new; vVal = v_new; sizeVal = s_new; }
//- get and set the u-v coordinates (careful with internal boundaries - see TDFacetBoundarPoint)
virtual CubitStatus get_uv( CubitFacet *facet, double &u, double &v );
virtual CubitStatus get_uvs( CubitFacet *facet, double &u, double &v, double &s);
Modified: cgm/trunk/geom/Curve.hpp
--- cgm/trunk/geom/Curve.hpp 2008-06-25 14:31:10 UTC (rev 1925)
+++ cgm/trunk/geom/Curve.hpp 2008-06-25 17:34:56 UTC (rev 1926)
@@ -109,7 +109,7 @@
virtual CubitStatus mid_point(const CubitVector &point1,
const CubitVector &point2,
- CubitVector& mid_point );
+ CubitVector& my_mid_point );
//R CubitStatus
//I CubitVector, CubitVector
//I- points between which the mid_point is needed
@@ -118,7 +118,7 @@
//- This function returns the mid point between two points on this
//-edge, by parameter
- virtual CubitStatus mid_point(CubitVector& mid_point);
+ virtual CubitStatus mid_point(CubitVector& my_mid_point);
//R CubitStatus
//O CubitVector
//O- mid point on this edge
@@ -397,11 +397,11 @@
inline
-CubitStatus Curve::mid_point(CubitVector &mid_point)
+CubitStatus Curve::mid_point(CubitVector &my_mid_point)
double param1 = 0.5 * (start_param() + end_param());
- return position_from_u(param1, mid_point);
+ return position_from_u(param1, my_mid_point);
inline
@@ -418,12 +418,12 @@
inline
CubitStatus Curve::mid_point(const CubitVector &point1,
double param1 = u_from_position(point1);
double param2 = u_from_position(point2);
param1 = 0.5 * (param1 + param2);
//R CubitStatus
Modified: cgm/trunk/geom/DagType.hpp
--- cgm/trunk/geom/DagType.hpp 2008-06-25 14:31:10 UTC (rev 1925)
+++ cgm/trunk/geom/DagType.hpp 2008-06-25 17:34:56 UTC (rev 1926)
@@ -27,8 +27,8 @@
// Dimension may be outside the range [0,3], but
// if so is_valid() will return false. (i.e. it is
// possible to construct invalid DagType objects.)
- inline DagType( int dimension, FunctionalType func )
- : intType( 3 * dimension + func )
+ inline DagType( int my_dimension, FunctionalType func )
+ : intType( 3 * my_dimension + func )
@@ -44,7 +44,7 @@
// Return values are one of GroupingEntity_TYPE,
// SenseEntity_TYPE, or BasicTopologyEntity_TYPE.
inline FunctionalType functional_type() const
- { return (FunctionalType)(intType % 3); }
+ { return static_cast<FunctionalType> (intType % 3); }
// Is this a valid DagType?
@@ -55,8 +55,8 @@
// move above a Body or below a RefVertex in the DAG.
inline bool is_valid() const
- const unsigned body_type = 11;
- return (unsigned)intType <= body_type;
+ const unsigned my_body_type = 11;
+ return static_cast<unsigned>(intType) <= my_body_type;
// get parent of this type
Modified: cgm/trunk/geom/IntermediateGeomEngine.hpp
--- cgm/trunk/geom/IntermediateGeomEngine.hpp 2008-06-25 14:31:10 UTC (rev 1925)
+++ cgm/trunk/geom/IntermediateGeomEngine.hpp 2008-06-25 17:34:56 UTC (rev 1926)
@@ -12,6 +12,9 @@
public:
+ virtual ~IntermediateGeomEngine() {}
virtual bool is_composite(TBOwner *bridge_owner) = 0;
virtual bool is_partition(TBOwner *bridge_owner) = 0;
Modified: cgm/trunk/geom/RefEntity.hpp
--- cgm/trunk/geom/RefEntity.hpp 2008-06-25 14:31:10 UTC (rev 1925)
+++ cgm/trunk/geom/RefEntity.hpp 2008-06-25 17:34:56 UTC (rev 1926)
@@ -304,7 +304,7 @@
inline int
RefEntity::marked()
-{return (int) markedFlag;}
+{return static_cast<int>(markedFlag);}
inline void
RefEntity::list_mark(int value)
Modified: cgm/trunk/geom/TBOwner.hpp
--- cgm/trunk/geom/TBOwner.hpp 2008-06-25 14:31:10 UTC (rev 1925)
+++ cgm/trunk/geom/TBOwner.hpp 2008-06-25 17:34:56 UTC (rev 1926)
@@ -22,6 +22,8 @@
public:
+ virtual ~TBOwner() {}
virtual CubitStatus remove_bridge( TopologyBridge* bridge ) = 0;
@@ -33,7 +35,7 @@
bool reversed ) = 0;
virtual CubitBoolean contains_bridge( TopologyBridge* bridge ) const
- { return (CubitBoolean)(bridge->owner() == this); }
+ { return static_cast<CubitBoolean>(bridge->owner() == this); }
virtual void notify_reversed( TopologyBridge* ) = 0;
Modified: cgm/trunk/util/CubitFileIOWrapper.hpp
--- cgm/trunk/util/CubitFileIOWrapper.hpp 2008-06-25 14:31:10 UTC (rev 1925)
+++ cgm/trunk/util/CubitFileIOWrapper.hpp 2008-06-25 17:34:56 UTC (rev 1926)
@@ -77,7 +77,7 @@
unsigned char* lpCurFromByte;
unsigned char lachrBuffer[sizeof(T)];
- unsigned char* lpCurAtom = (unsigned char*)xpT;
+ unsigned char* lpCurAtom = reinterpret_cast<unsigned char*>(xpT);
int lintAtom = xintCount;
while(lintAtom) {
lintAtom--;
Modified: cgm/trunk/util/CubitString.hpp
--- cgm/trunk/util/CubitString.hpp 2008-06-25 14:31:10 UTC (rev 1925)
+++ cgm/trunk/util/CubitString.hpp 2008-06-25 17:34:56 UTC (rev 1926)
@@ -27,7 +27,7 @@
class CubitStringRep;
-const size_t MAX_POS = (size_t) -1; // "SIZE_T_MAX"
+const size_t MAX_POS = static_cast<size_t>(-1); // "SIZE_T_MAX"
class CUBIT_UTIL_EXPORT CubitString
Modified: cgm/trunk/util/CubitUtil.hpp
--- cgm/trunk/util/CubitUtil.hpp 2008-06-25 14:31:10 UTC (rev 1925)
+++ cgm/trunk/util/CubitUtil.hpp 2008-06-25 17:34:56 UTC (rev 1926)
@@ -130,7 +130,7 @@
sense == CUBIT_REVERSED );
if ( sense == CUBIT_UNKNOWN ) return CUBIT_UNKNOWN;
else {
- CubitSense opp_sense = (CubitSense) (1 - sense);
+ CubitSense opp_sense = static_cast<CubitSense>(1 - sense);
return opp_sense;
Modified: cgm/trunk/util/CubitVector.hpp
--- cgm/trunk/util/CubitVector.hpp 2008-06-25 14:31:10 UTC (rev 1925)
+++ cgm/trunk/util/CubitVector.hpp 2008-06-25 17:34:56 UTC (rev 1926)
@@ -44,7 +44,7 @@
CubitVector(const CubitVectorStruct& from);
//- Heading: Set and Inquire Functions
- void set(const double x, const double y, const double z);
+ void set(const double x_coord, const double y_coord, const double z_coord);
//- Change vector components to {x}, {y}, and {z}
void set( const double xyz[3] );
@@ -66,22 +66,22 @@
double& y();
double& z();
- void get_xyz( double &x, double &y, double &z ) const; //- Get x, y, z components
+ void get_xyz( double &x_coord, double &y_coord, double &z_coord ) const; //- Get x, y, z components
void get_xyz( double xyz[3] ) const; //- Get xyz tuple
double &r(); //- Return r component of vector, if (r,theta) format
double &theta(); //- Return theta component of vector, if (r,theta) format
- void x( const double x ); //- Set x component of vector
+ void x( const double x_coord ); //- Set x component of vector
- void y( const double y ); //- Set y component of vector
+ void y( const double y_coord ); //- Set y component of vector
- void z( const double z ); //- Set z component of vector
+ void z( const double z_coord ); //- Set z component of vector
- void r( const double x ); //- Set r component of vector, if (r,theta) format
+ void r( const double radius ); //- Set r component of vector, if (r,theta) format
- void theta( const double y ); //- Set theta component of vector, if (r,theta) format
+ void theta( const double angle ); //- Set theta component of vector, if (r,theta) format
void xy_to_rtheta();
//- convert from cartesian to polar coordinates, just 2d for now
@@ -303,26 +303,26 @@
xyz[1] = yVal;
xyz[2] = zVal;
-inline void CubitVector::get_xyz(double &x, double &y, double &z) const
+inline void CubitVector::get_xyz(double &x_coord, double &y_coord, double &z_coord) const
- x = xVal;
- y = yVal;
- z = zVal;
+ x_coord = xVal;
+ y_coord = yVal;
+ z_coord = zVal;
inline double &CubitVector::r()
{ return xVal; }
inline double &CubitVector::theta()
{ return yVal; }
-inline void CubitVector::x( const double x )
-{ xVal = x; }
-inline void CubitVector::y( const double y )
-{ yVal = y; }
-inline void CubitVector::z( const double z )
-{ zVal = z; }
-inline void CubitVector::r( const double x )
-{ xVal = x; }
-inline void CubitVector::theta( const double y )
-{ yVal = y; }
+inline void CubitVector::x( const double x_coord )
+{ xVal = x_coord; }
+inline void CubitVector::y( const double y_coord )
+{ yVal = y_coord; }
+inline void CubitVector::z( const double z_coord )
+{ zVal = z_coord; }
+inline void CubitVector::r( const double radius )
+{ xVal = radius; }
+inline void CubitVector::theta( const double angle )
+{ yVal = angle; }
inline CubitVector& CubitVector::operator+=(const CubitVector &v)
xVal += v.xVal;
@@ -386,13 +386,13 @@
y( -temp );
-inline void CubitVector::set(const double x,
- const double y,
- const double z)
+inline void CubitVector::set(const double x_coord,
+ const double y_coord,
+ const double z_coord)
- xVal = x;
- yVal = y;
- zVal = z;
+ xVal = x_coord;
+ yVal = y_coord;
+ zVal = z_coord;
inline void CubitVector::set(const double xyz[3])
Modified: cgm/trunk/util/DLIList.cpp
--- cgm/trunk/util/DLIList.cpp 2008-06-25 14:31:10 UTC (rev 1925)
+++ cgm/trunk/util/DLIList.cpp 2008-06-25 17:34:56 UTC (rev 1926)
@@ -27,16 +27,16 @@
//- will be grown by {increment} each time it is filled. Memory for the
//- list is not allocated until the first element is inserted using
//- {insertLink}.
-template <class X> MY_INLINE DLIList<X>::DLIList (int size)
+template <class X> MY_INLINE DLIList<X>::DLIList (int list_size)
index = 0;
itemCount = 0;
listLength = 0;
listArray = NULL;
- if (size)
+ if (list_size)
- listArray = new X [size];
- listLength = size;
+ listArray = new X [list_size];
+ listLength = list_size;
@@ -76,7 +76,7 @@
// Make a new array
int new_size =
- (int) ((double)listLength * by_what_factor)
+ static_cast<int>( static_cast<double>(listLength) * by_what_factor )
+ by_how_much;
X* temp_list = new X [new_size];
@@ -173,7 +173,7 @@
X* end1 = iter1 + itemCount; // end of this array
X* iter2 = intersect_list.listArray; // iterstor for other array
X* end2 = iter2 + intersect_list.itemCount;// end of other array
- X* insert = iter1 - 1; // location of last insert
+ X* last_insert = iter1 - 1; // location of last insert
for ( ; iter1 < end1; ++iter1 )
@@ -183,13 +183,13 @@
if (iter2 == end2)
break;
- if ((*iter2 == *iter1) && // items are the same and ...
- (insert < listArray || // is the first item or ...
- *iter1 != *insert)) // is not the same as the previous item
- *++insert = *iter1;
+ if ((*iter2 == *iter1) && // items are the same and ...
+ (last_insert < listArray || // is the first item or ...
+ *iter1 != *last_insert)) // is not the same as the previous item
+ *++last_insert = *iter1;
- itemCount = insert - listArray + 1;
+ itemCount = last_insert - listArray + 1;
reset();
@@ -218,7 +218,7 @@
template <class X> MY_INLINE void DLIList<X>::intersect ( void* merge_list )
- intersect( *(DLIList<X>*)merge_list );
+ intersect( *static_cast< DLIList<X>* >(merge_list) );
@@ -230,7 +230,7 @@
if ( !itemCount )
PRINT_WARNING("Attempted link removal from empty DLIList\n");
- return (X)0;
+ return X(0);
// save the current value
@@ -267,7 +267,7 @@
if ( !itemCount )
- return (X)0;
+ return X(0);
@@ -334,7 +334,7 @@
if ( !itemCount )
PRINT_WARNING("Attempted step_and_get from empty DLIList\n");
- return (X)0;
+ return X(0);
if (++index == itemCount)
@@ -400,7 +400,7 @@
template <class X> MY_INLINE DLIList<X>& DLIList<X>::
operator+=(void* from)
- DLIList<X>* cast_from = (DLIList<X>*)from;
+ DLIList<X>* cast_from = static_cast< DLIList<X>* >(from);
// Don't do anything if the list being appended is empty.
if (cast_from->itemCount == 0)
@@ -594,14 +594,14 @@
// report amount of memory allocated
- int size = listLength * sizeof(X);
+ int my_size = listLength * sizeof(X);
if (verbose_boolean)
- PRINT_INFO(" DLIList: %d bytes\n",size);
+ PRINT_INFO(" DLIList: %d bytes\n", my_size);
- return size;
+ return my_size;
template <class X> MY_INLINE void DLIList<X>::copy_to(X *other_array)
Modified: cgm/trunk/util/DLIList.hpp
--- cgm/trunk/util/DLIList.hpp 2008-06-25 14:31:10 UTC (rev 1925)
+++ cgm/trunk/util/DLIList.hpp 2008-06-25 17:34:56 UTC (rev 1926)
@@ -37,7 +37,7 @@
public:
friend class DLIListIterator<X>;
- explicit DLIList (int size = 0);
+ explicit DLIList (int list_size = 0);
//- Constructor: Create a list with initial size 'size'. Memory for the
//- list is not allocated until the first element is added to the list.
@@ -109,7 +109,7 @@
int operator==(const DLIList<X>& from);
int operator!=(const DLIList<X>& from);
- X & operator[](int index) const;
+ X & operator[](int my_index) const;
void merge_unique(const DLIList<X>& merge_list,
bool merge_list_unique = false);
//- Merges the contents of the list, merge_list, with those of "this"
@@ -264,10 +264,10 @@
template <class X> inline
-X & DLIList<X>::operator[](int index) const
+X & DLIList<X>::operator[](int my_index) const
- assert( index >= 0 && index < itemCount );
- return listArray[index];
+ assert( my_index >= 0 && my_index < itemCount );
+ return listArray[my_index];
template <class X> inline void DLIList<X>::step()
@@ -379,7 +379,7 @@
if ( !itemCount )
PRINT_WARNING("Attempted get of empty DLIList\n");
- return (X)0;
+ return X(0);
else
@@ -393,7 +393,7 @@
if ( !itemCount )
PRINT_WARNING("Attempted get_and_step from empty DLIList\n");
- return (X)0;
+ return X(0);
else
#endif
@@ -410,7 +410,7 @@
if ( !itemCount )
PRINT_WARNING("Attempted get_and_back from empty DLIList\n");
- return (X)0;
+ return X(0);
X temp = listArray[index--];
if (index < 0)
@@ -423,7 +423,7 @@
if (!itemCount)
PRINT_WARNING("Attempted next of empty DLIList\n");
- return (X)0;
+ return X(0);
else if (index == itemCount-1)
return listArray[0];
@@ -436,7 +436,7 @@
if ( !itemCount )
- return (X)0;
+ return X(0);
else
@@ -484,7 +484,7 @@
template <class X> inline X DLIList<X>::change_to (X new_value)
- X temp = (X)0;
+ X temp = X(0);
if ( !itemCount )
PRINT_WARNING("DLIList: Attempted update of empty list\n");
@@ -516,7 +516,7 @@
// If the item was found and removed it is returned, else 0 is returned.
template <class X> inline X DLIList<X>::remove (X item)
- X temp = (X)0;
+ X temp = X(0);
if (move_to(item))
temp = remove();
return temp;
Modified: cgm/trunk/util/KDDTree.cpp
--- cgm/trunk/util/KDDTree.cpp 2008-06-25 14:31:10 UTC (rev 1925)
+++ cgm/trunk/util/KDDTree.cpp 2008-06-25 17:34:56 UTC (rev 1926)
@@ -60,7 +60,7 @@
if (myRandomOn)
//// seed the random number generator
- srand( (unsigned)time( NULL ) );
+ srand( static_cast<unsigned>(time(NULL)) );
@@ -375,17 +375,17 @@
//- Find the depth of the tree
template <class Z> void KDDTree<Z>::recursive_find_max_height
- (KDDTreeNode<Z> *root, int depth, int *maxdepth)
+ (KDDTreeNode<Z> *the_root, int depth, int *maxdepth)
- if (root)
+ if (the_root)
depth++;
if (depth > *maxdepth)
*maxdepth = depth;
- recursive_find_max_height (root->left, depth, maxdepth);
- recursive_find_max_height (root->right, depth, maxdepth);
+ recursive_find_max_height (the_root->left, depth, maxdepth);
+ recursive_find_max_height (the_root->right, depth, maxdepth);
@@ -495,7 +495,7 @@
myMarkedNodes++;
if (myDeletionTolerance != 0)
- if ( (((double)myMarkedNodes / myNodeList.size()) > myDeletionTolerance) &&
+ if ( (( static_cast<double>(myMarkedNodes) / myNodeList.size()) > myDeletionTolerance) &&
(myMarkedNodes > 1)
Modified: cgm/trunk/util/KDDTree.hpp
--- cgm/trunk/util/KDDTree.hpp 2008-06-25 14:31:10 UTC (rev 1925)
+++ cgm/trunk/util/KDDTree.hpp 2008-06-25 17:34:56 UTC (rev 1926)
@@ -49,7 +49,7 @@
double min_dist_sq (CubitVector &q, CubitBox &b_box);
//- Find the depth of the tree recursively
- void recursive_find_max_height (KDDTreeNode<Z> *root, int depth, int *maxdepth);
+ void recursive_find_max_height (KDDTreeNode<Z> *the_root, int depth, int *maxdepth);
//- Balance the tree recursively
KDDTreeNode<Z> *recursive_balance (DIMENSION dim, int left, int right,
Modified: cgm/trunk/util/PriorityQueue.cpp
--- cgm/trunk/util/PriorityQueue.cpp 2008-06-25 14:31:10 UTC (rev 1925)
+++ cgm/trunk/util/PriorityQueue.cpp 2008-06-25 17:34:56 UTC (rev 1926)
@@ -35,7 +35,7 @@
PRINT_ERROR("Empty priority queue had top request.\n");
assert(!empty());
- return (Object)0;
+ return static_cast<Object>(0);
return theItems[1];
Modified: cgm/trunk/util/RTreeNode.cpp
--- cgm/trunk/util/RTreeNode.cpp 2008-06-25 14:31:10 UTC (rev 1925)
+++ cgm/trunk/util/RTreeNode.cpp 2008-06-25 17:34:56 UTC (rev 1926)
@@ -35,7 +35,7 @@
myChildrenNodes = new RTreeNode<Y>* [maxChildren];
int ii;
for ( ii = 0; ii < maxChildren; ii++ )
- myChildrenNodes[ii] = (RTreeNode<Y>*) NULL;
+ myChildrenNodes[ii] = static_cast< RTreeNode<Y>* >(NULL);
if ( data == NULL )
PRINT_ERROR("Building RTree with null data is not allowed!\n");
@@ -70,17 +70,17 @@
distIsBox = 1;
myDist = CUBIT_DBL_MAX;
-template <class Y> MY_INLINE RTreeNode<Y>::RTreeNode (CubitBox &bounding_box,
+template <class Y> MY_INLINE RTreeNode<Y>::RTreeNode (CubitBox &bound_box,
int max_children,
int min_children)
maxChildren = max_children;
minChildren = min_children;
- myBoundingBox = new CubitBox(bounding_box);
+ myBoundingBox = new CubitBox(bound_box);
int ii;
myData = NULL;
myLevel = UNSET_RNODE;
myParent = NULL;
@@ -199,7 +199,7 @@
//do error checking...
if ( child_index == -1 || child_index >= maxChildren )
- return (RTreeNode<Y>*)NULL;
+ return static_cast< RTreeNode<Y>* >(NULL);
RTreeNode<Y> *f = n->myChildrenNodes[child_index];
//Now continue on...
curr_node = choose_leaf(f,e);
@@ -420,12 +420,12 @@
myBoundingBox = new CubitBox(new_box);
template <class Y> MY_INLINE void RTreeNode<Y>::add_child(RTreeNode<Y> *child_node,
- CubitBoolean recalc_b_box)
+ CubitBoolean recalc_bound_box)
assert(nextChildIndex < maxChildren && child_node != NULL );
myChildrenNodes[nextChildIndex] = child_node;
//update the bounding box. by uniting with child node...
- if ( recalc_b_box )
+ if ( recalc_bound_box )
CubitBox *old_box = myBoundingBox;
myBoundingBox = new CubitBox( *old_box |= child_node->bounding_box());
@@ -464,8 +464,8 @@
RTreeNode<Y> *e_1, *e_2;
CubitBox e_box_1, e_box_2, j;
double d, max_d = -CUBIT_DBL_MAX;
- seed_1 = (RTreeNode<Y>*)NULL;
- seed_2 = (RTreeNode<Y>*)NULL;
+ seed_1 = static_cast< RTreeNode<Y>* >(NULL);
+ seed_2 = static_cast< RTreeNode<Y>* >(NULL);
for(ii = 0; ii < input_list_size; ii++ )
@@ -509,7 +509,7 @@
int ii, next_index = 0;
double d1, d2, max_diff = -CUBIT_DBL_MAX;
add_to_group_1 = CUBIT_TRUE;
- RTreeNode<Y> *max_diff_node = (RTreeNode<Y>*)NULL;
+ RTreeNode<Y> *max_diff_node = static_cast< RTreeNode<Y>* >(NULL);
RTreeNode<Y> *curr_node;
CubitBox group_1_box = group_1->bounding_box();
CubitBox group_2_box = group_2->bounding_box();
@@ -659,7 +659,7 @@
if ( root->num_children() == 1 )
new_root = root->get_child(0);
- new_root->set_parent((RTreeNode<Y>*)NULL);
+ new_root->set_parent(static_cast< RTreeNode<Y>* >(NULL));
delete_root = CUBIT_TRUE;
return CUBIT_TRUE;
Modified: cgm/trunk/util/RTreeNode.hpp
--- cgm/trunk/util/RTreeNode.hpp 2008-06-25 14:31:10 UTC (rev 1925)
+++ cgm/trunk/util/RTreeNode.hpp 2008-06-25 17:34:56 UTC (rev 1926)
@@ -110,7 +110,7 @@
public:
RTreeNode(Y data, double tol, int max_children, int min_children );
- RTreeNode(CubitBox &bounding_box, int max_children, int min_children);
+ RTreeNode(CubitBox &bound_box, int max_children, int min_children);
~RTreeNode();
//- Constructor/Destructor
@@ -140,7 +140,7 @@
{return myData;}
//- Determine if the RTreeNode is a leaf node.
- void add_child(RTreeNode<Y>* child_node, CubitBoolean recalc_b_box);
+ void add_child(RTreeNode<Y>* child_node, CubitBoolean recalc_bound_box);
//- Add the child to the myChildrenNodes' list. Adds
//- it to the next availabel spot. Won't add if overflow will
//- occur.
@@ -156,7 +156,7 @@
//- Returns the number of children in the myChildrenNode's array.
RTreeNode<Y>* get_child(int i)
- {return ((i < nextChildIndex) ? myChildrenNodes[i] : (RTreeNode<Y>*)NULL) ;}
+ {return ( (i < nextChildIndex) ? myChildrenNodes[i] : static_cast< RTreeNode<Y>* >(NULL) );}
void flush(CubitBox &new_box);
More information about the cgma-dev
