[cgma-dev] r1891 - in cgm/trunk: geom/OCC test
janehu at mcs.anl.gov
Wed Jun 11 14:08:54 CDT 2008
Author: janehu
Date: 2008-06-11 14:08:53 -0500 (Wed, 11 Jun 2008)
New Revision: 1891
Modified:
cgm/trunk/geom/OCC/OCCCurve.cpp
cgm/trunk/geom/OCC/OCCCurve.hpp
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
cgm/trunk/test/modify.cpp
Log:
Test-passed one case of imprint-project-curve. project curvecould return different results, haven't test them all yet.
Modified: cgm/trunk/geom/OCC/OCCCurve.cpp
--- cgm/trunk/geom/OCC/OCCCurve.cpp 2008-06-11 01:14:43 UTC (rev 1890)
+++ cgm/trunk/geom/OCC/OCCCurve.cpp 2008-06-11 19:08:53 UTC (rev 1891)
@@ -969,6 +969,7 @@
// Date : 01/08
Curve* OCCCurve::project_curve(Surface* face_ptr,
+ DLIList<Point*>& normal_proj_points,
CubitBoolean closed,
const CubitVector* third_point)
@@ -998,35 +999,84 @@
return (Curve*) NULL;
- TopTools_ListOfShape projections;
- projections = aProjection.Generated(*edge);
- int num_projection = projections.Extent();
- if (num_projection == 0)
+ TopoDS_Shape new_shape = aProjection.Projection();//compound shape
+ int num_projection = 0;
+ if (new_shape.IsNull())
PRINT_ERROR("Cannot project the curve to the surface.\n");
+ else
+ //count how many free edges and vertices the new_shape has.
+ TopExp_Explorer Ex;
+ for (Ex.Init(new_shape,TopAbs_EDGE); Ex.More(); Ex.Next())
+ num_projection++;
+ for (Ex.Init(new_shape,TopAbs_VERTEX, TopAbs_EDGE); Ex.More(); Ex.Next())
+ num_projection++;
+ if(num_projection == 0)
+ PRINT_INFO("No projection on the surface.\n");
+ return (Curve*) NULL;
else if ( num_projection == 1 )
if(closed == true)
PRINT_WARNING("Cannot project the curve to create a closed projection.\n" "There is only one projection segment.\n");
- TopoDS_Shape new_shape = aProjection.Projection();//compound shape
- TopoDS_Edge new_edge = TopoDS::Edge(new_shape);
- return OCCQueryEngine::instance()->populate_topology_bridge(new_edge);
+ TopoDS_Edge new_edge;
+ TopoDS_Vertex new_point;
+ new_edge = TopoDS::Edge(Ex.Current());
+ return OCCQueryEngine::instance()->populate_topology_bridge(new_edge);
+ for(Ex.Init(new_shape,TopAbs_VERTEX);Ex.More(); Ex.Next())
+ new_point = TopoDS::Vertex(Ex.Current());
+ normal_proj_points.append(OCCQueryEngine::instance()->populate_topology_bridge(new_point));
else if (num_projection == 2)
double d;
double first, last;
- TopoDS_Shape shape1 = projections.First();
- TopoDS_Edge edge1 = TopoDS::Edge(shape1);
+ TopoDS_Edge edge1, edge2;
+ TopoDS_Vertex point;
- TopoDS_Shape shape2 = projections.Last();
- TopoDS_Edge edge2 = TopoDS::Edge(shape2);
+ int count = 0;
+ count++;
+ if(count == 1)
+ edge1 = TopoDS::Edge(Ex.Current());
+ if(count == 2)
+ edge2 = TopoDS::Edge(Ex.Current());
+ point = TopoDS::Vertex(Ex.Current());
+ normal_proj_points.append(OCCQueryEngine::instance()->populate_topology_bridge(point));
+ if(edge1.IsNull())
+ return OCCQueryEngine::instance()->populate_topology_bridge(edge2);
+ if(edge2.IsNull())
+ return OCCQueryEngine::instance()->populate_topology_bridge(edge1);
+ if(edge1.IsNull() && edge2.IsNull())
Handle(Geom_Curve) myCurve1 =
BRep_Tool::Curve(edge1,first,last);
@@ -1055,9 +1105,8 @@
double d2 = projOncurve2.LowerDistance();
- d > d2 ? projections.Last() : projections.First() ;
+ TopoDS_Edge new_edge =
+ d > d2 ? edge2 : edge1 ;
Modified: cgm/trunk/geom/OCC/OCCCurve.hpp
--- cgm/trunk/geom/OCC/OCCCurve.hpp 2008-06-11 01:14:43 UTC (rev 1890)
+++ cgm/trunk/geom/OCC/OCCCurve.hpp 2008-06-11 19:08:53 UTC (rev 1891)
@@ -327,6 +327,7 @@
BRepAlgoAPI_BooleanOperation *op = NULL );
Curve* project_curve(Surface* face_ptr,
const CubitVector* third_point);
protected:
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-06-11 01:14:43 UTC (rev 1890)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-06-11 19:08:53 UTC (rev 1891)
@@ -239,8 +239,9 @@
if(face_ptr == NULL)
return curve;
+ DLIList<Point*> points;
new_curve =
- CAST_TO(curve, OCCCurve)->project_curve(face_ptr, closed, third_point);
+ CAST_TO(curve, OCCCurve)->project_curve(face_ptr, points, closed, third_point);
delete curve;
return new_curve;
@@ -2913,6 +2914,7 @@
TopExp_Explorer Ex;
TopoDS_Face the_face;
TopoDS_Shape ashape = *(body->get_TopoDS_Shape());
+ M.Clear();
TopExp::MapShapesAndAncestors(ashape, TopAbs_FACE, TopAbs_COMPSOLID, M);
if(!M.Contains(*topo_face))
continue;
@@ -3248,6 +3250,7 @@
CubitVector* v = NULL;
Curve* projected_curve = NULL;
//project curves onto surfaces.
for(int i = 0; i < ref_edge_list.size(); i++)
@@ -3267,11 +3270,13 @@
- projected_curve = curve->project_curve(surface, CUBIT_FALSE, v);
+ projected_curve = curve->project_curve(surface, points, CUBIT_FALSE, v);
if(projected_curve)
- projected_curves.append(projected_curve);
+ projected_curves.append_unique(projected_curve);
+ while(points.size() > 0)
+ delete points.pop();
return CUBIT_SUCCESS;
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-06-11 01:14:43 UTC (rev 1890)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-06-11 19:08:53 UTC (rev 1891)
@@ -1582,9 +1582,9 @@
delete occ_shell->my_body();
delete occ_shell->my_lump();
- CubitStatus stat = unhook_ShellSM_from_OCC(occ_shell);
DLIList<TopologyBridge*> tb_surfaces;
occ_shell->get_children_virt(tb_surfaces);
+ CubitStatus stat = unhook_ShellSM_from_OCC(occ_shell);
for(int k = 0; k < tb_surfaces.size(); k++)
delete_solid_model_entities(CAST_TO(tb_surfaces.get_and_step(), Surface));
delete occ_shell;
Modified: cgm/trunk/test/modify.cpp
--- cgm/trunk/test/modify.cpp 2008-06-11 01:14:43 UTC (rev 1890)
+++ cgm/trunk/test/modify.cpp 2008-06-11 19:08:53 UTC (rev 1891)
@@ -343,7 +343,7 @@
n = new_bodies.get()->num_ref_edges();//n = 17
- OCCBody* check_body = CAST_TO(face_list.get()->body()->get_body_sm_ptr(), OCCBody);
+ new_bodies.clean_out();
stat = gmti->imprint(face_list, ref_edges, new_bodies, CUBIT_FALSE);
//test for multi-cut imprint for subtract.
@@ -403,14 +403,9 @@
tool_body = gmti->brick(4, 4, 4);
CubitVector v_move3(0,1,0);
gti->translate(tool_body,v_move3);
- BodySM* copy_bodysm = ome->copy_body(tool_body->get_body_sm_ptr());
Body* copy_tool_body = gmti->copy_body(tool_body);
Body* copy_tool_body2 = gmti->copy_body(tool_body);
- //test shell body imprint
- //TopoDS_Shape* tool_shape = CAST_TO(copy_bodysm,OCCBody)->get_TopoDS_Shape();
- //TopoDS_Shape* from_shape = CAST_TO(bodysm,OCCBody)->shell()->get_TopoDS_Shell();
- //ome->imprint_toposhapes(tool_shape, from_shape);
from_bodies.clean_out();
from_bodies.append(copy_tool_body);
@@ -456,6 +451,31 @@
from_bodies.append(tool_body);
stat = gmti->imprint(from_bodies, new_bodies, CUBIT_FALSE);
+ //test imprint projected edges
+ bodies.clean_out();
+ gti->bodies(bodies);
+ //delete all entities
+ gti->delete_Body(bodies);
+ free_entities.clean_out();
+ gti->get_free_ref_entities(free_entities);
+ OCCQueryEngine* oqe = OCCQueryEngine::instance();
+ DLIList <OCCBody* > *occ_bodies = oqe->BodyList;
+ from_body = gmti->brick(4, 4, 4);
+ CubitVector v_move9(0,3,0);
+ gti->translate(from_body,v_move9);
+ ref_faces.clean_out();
+ from_body->ref_faces(ref_faces);
+ tool_body = gmti->brick(11, 1, 1);
+ ref_edges.clean_out();
+ tool_body->ref_edges(ref_edges);
+ gmti->imprint_projected_edges(ref_faces,ref_edges, new_bodies, CUBIT_TRUE,
+ CUBIT_FALSE);
+ if(new_bodies.size())
+ n = new_bodies.get()->num_ref_faces();
More information about the cgma-dev
