[cgma-dev] r1887 - cgm/trunk/geom/OCC
    janehu at mcs.anl.gov
    Tue Jun 10 14:34:51 CDT 2008
Author: janehu
Date: 2008-06-10 14:34:51 -0500 (Tue, 10 Jun 2008)
New Revision: 1887
Modified:
   cgm/trunk/geom/OCC/OCCCurve.cpp
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
   cgm/trunk/geom/OCC/OCCModifyEngine.hpp
Log:
Added imprint_projected_curve function, testing.
Modified: cgm/trunk/geom/OCC/OCCCurve.cpp
--- cgm/trunk/geom/OCC/OCCCurve.cpp	2008-06-10 14:31:31 UTC (rev 1886)
+++ cgm/trunk/geom/OCC/OCCCurve.cpp	2008-06-10 19:34:51 UTC (rev 1887)
@@ -437,6 +437,7 @@
   gp_Pnt p(location.x(), location.y(), location.z()), newP(0.0, 0.0, 0.0);
   double newVal=0.0, global_newVal = 0.0;
   int i;
+  CubitBoolean found = CUBIT_FALSE;
   BRepLProp_CLProps CLP(acurve, 2, Precision::PConfusion());
   Extrema_ExtPC ext(p, acurve, Precision::Approximation());
   if (ext.IsDone() && (ext.NbExt() > 0)) {
@@ -447,6 +448,7 @@
                             global_newVal = newVal;
                           if(newVal <= global_newVal)
+                            found = CUBIT_TRUE;
 			    newP = ext.Point(i).Value();
 			    CLP.SetParameter(newVal);
@@ -454,7 +456,7 @@
-  if(global_newVal > 0.0)
+  if(found)
     closest_location = CubitVector(newP.X(), newP.Y(), newP.Z());
     if (tangent_ptr != NULL) {
@@ -967,8 +969,8 @@
 // Date       : 01/08
 Curve* OCCCurve::project_curve(Surface* face_ptr,
-                                      CubitBoolean closed,
-                                      const CubitVector* third_point)
+                               CubitBoolean closed,
+                               const CubitVector* third_point)
    TopoDS_Edge* edge = get_TopoDS_Edge();
    if (edge == NULL)
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-06-10 14:31:31 UTC (rev 1886)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-06-10 19:34:51 UTC (rev 1887)
@@ -69,6 +69,7 @@
 #include "BRepPrimAPI_MakeSphere.hxx"
 #include "BRepPrimAPI_MakeBox.hxx"
 #include "BRepPrimAPI_MakeWedge.hxx"
+#include "BRepTools_WireExplorer.hxx"
 #include "Handle_Geom_TrimmedCurve.hxx"
 #include "Handle_Geom_RectangularTrimmedSurface.hxx"
 #include "BndLib_Add3dCurve.hxx"
@@ -2139,9 +2140,47 @@
         face = OCCQueryEngine::instance()->populate_topology_bridge(from_face);
       OCCSurface* occ_face = CAST_TO(face, OCCSurface);
+      DLIList<Curve*> common_curves;
       for(; Itor.More(); Itor.Next())
         TopoDS_Edge edge = TopoDS::Edge(Itor.Value());
+        //copy the edge for imprinting.
+        BRepBuilderAPI_Copy api_copy(edge);
+        TopoDS_Shape newShape = api_copy.ModifiedShape(edge);
+        edge = TopoDS::Edge(newShape);
+        Curve* curve = NULL;
+        curve = OCCQueryEngine::instance()->populate_topology_bridge(edge);
+        if(curve)
+          common_curves.append(curve);
+      DLIList<DLIList<TopoDS_Edge*>*> temp_edge_lists;
+      list_of_edges.Clear();
+      if (common_curves.size() >= 1)
+        sort_curves(common_curves, temp_edge_lists);
+        DLIList<TopoDS_Edge*>* edge_list;
+        int size = temp_edge_lists.size();
+        for(int i = 0; i < size; i++)
+          edge_list = temp_edge_lists.pop();
+          //make sure the copied edges are sharing vertices.
+          BRepBuilderAPI_MakeWire myWire;
+          edge_list->reset();
+          for(int i = 0; i < edge_list->size(); i++)
+             TopoDS_Edge e = *(edge_list->get_and_step());
+             myWire.Add(e);
+          TopoDS_Wire wire = myWire.Wire();
+          BRepTools_WireExplorer Ex(wire);
+          for(; Ex.More(); Ex.Next())
+            list_of_edges.Append(Ex.Current());
+      for(Itor.Initialize(list_of_edges); Itor.More(); Itor.Next())
+        TopoDS_Edge edge = TopoDS::Edge(Itor.Value());
         //check to see if the intersection edge is on from_face
 	TopExp_Explorer Ex;
 	CubitBoolean added = CUBIT_FALSE;
@@ -2164,7 +2203,7 @@
 	  for (Ex.Init(from_face, TopAbs_EDGE); Ex.More(); Ex.Next())
-            //check if the edge is on from_face edges, add such edge on existing
+           //check if the edge is on from_face edges, add such edge on existing
             //edge to split it.
 	    TopoDS_Edge from_edge = TopoDS::Edge(Ex.Current());
@@ -3153,20 +3192,89 @@
 // Function   : imprint_projected_edges
 // Member Type: PUBLIC
-// Description:
-// Author     : John Fowler
-// Date       : 10/02
+// Description: Projects a list of Curves on to a list of Surfaces
+//              and imprint the faces with the new Curves
+// Author     : Jane Hu
+// Date       : 06/08
-CubitStatus     OCCModifyEngine::imprint_projected_edges( DLIList<Surface*> &/*ref_face_list*/,
-                                                           DLIList<Curve*> &/*ref_edge_list*/,
-                                                           DLIList<BodySM*>& /*new_body_list*/,
-                                                           bool /*keep_old_body*/,
-                                                           bool /*keep_free_edges*/) const
+CubitStatus
+OCCModifyEngine::imprint_projected_edges( DLIList<Surface*> &ref_face_list,
+                                          DLIList<Curve*> &ref_edge_list,
+                                          DLIList<BodySM*>& new_body_list,
+                                          bool keep_old_body,
+                                          bool keep_free_edges) const
-  PRINT_ERROR("Option not supported for mesh based geometry.\n");
-  return CUBIT_FAILURE;
+  DLIList<Curve*> projected_curves;
+  CubitStatus
+     stat = project_curves(ref_face_list, ref_edge_list, projected_curves);
+  if(!stat)
+    return stat;
+  // imprint Surface with curves
+  stat = imprint(ref_face_list, projected_curves, new_body_list, keep_old_body );
+  if(keep_free_edges)
+     return  stat;
+  PRINT_INFO( "Removing projected curves \n");
+  for(int i=0; i< projected_curves.size();i++)
+    // Now delete this Curve and its underlying solid model entities
+    Curve* curve = projected_curves.get_and_step();
+    stat = OCCQueryEngine::instance()->delete_solid_model_entities( curve );
+    if (stat == CUBIT_FAILURE)
+       PRINT_ERROR("In OCCQueryEngine::delete_geometry\n"
+                 "       Could not delete OCCCurve.\n"
+                 "       The Model database is likely corrupted "
+                 "due to\n       this unsuccessful deletion.\n" );
+  return stat;
+// Function   : project_curves
+// Member Type: PRIVATE
+// Date       : 06/08
+CubitStatus
+ OCCModifyEngine::project_curves( DLIList<Surface*> &ref_face_list,
+                                  DLIList<Curve*> &projected_curves)const
+  CubitVector* v = NULL;
+  Curve* projected_curve = NULL;
+  //project curves onto surfaces.
+  for(int i = 0; i < ref_edge_list.size(); i++)
+    OCCCurve* curve = CAST_TO(ref_edge_list.get_and_step(), OCCCurve);
+    if(!curve)
+       continue;
+    for (int j = 0; j < ref_face_list.size(); j++)
+      OCCSurface* surface = CAST_TO(ref_face_list.get_and_step(), OCCSurface);
+      if(!surface)
+        continue;
+      if(surface->is_closed_in_U() || surface->is_closed_in_V())
+        PRINT_ERROR("This function can't project curves on closed surfaces.\n");
+        return CUBIT_FAILURE;
+      projected_curve = NULL;
+      projected_curve = curve->project_curve(surface, CUBIT_FALSE, v);
+      if(projected_curve)
+        projected_curves.append(projected_curve);
+  return CUBIT_SUCCESS;
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.hpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.hpp	2008-06-10 14:31:31 UTC (rev 1886)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.hpp	2008-06-10 19:34:51 UTC (rev 1887)
@@ -683,6 +683,10 @@
                                 bool keep_old ) const;
  void shape_to_bodySM( DLIList<TopoDS_Shape*> shape_list,
                        DLIList<BodySM*>& new_body_list)const;
+ CubitStatus project_curves( DLIList<Surface*> &ref_face_list,
+                             DLIList<Curve*> &projected_curves)const;
 #endif
More information about the cgma-dev
