[cgma-dev] r1572 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov janehu at mcs.anl.gov
Thu Jan 31 14:39:48 CST 2008
Author: janehu
Date: 2008-01-31 14:39:48 -0600 (Thu, 31 Jan 2008)
New Revision: 1572
Modified:
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
studied on how to generate Hyperbola, Parabola, Ellipse using three points, added creating circles
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-01-31 19:56:52 UTC (rev 1571)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-01-31 20:39:48 UTC (rev 1572)
@@ -286,6 +286,19 @@
 // Function   : make_Curve
 // Member Type: PUBLIC
 // Description: make a curve
+// For STRAIGHT_CURVE_TYPE:
+//    intermediate_point_ptr  is not used
+// For PARABOLA_CURVE_TYPE
+//    intermediate_point_ptr is the tip of the parabola
+// For ELLIPSE_CURVE_TYPE
+//    intermediate_point_ptr is the center of the ellipse
+//    sense is used to determine which part of the ellipse is required
+// For ARC_CURVE_TYPE
+//    arc passes three points
 // Author     : Jane Hu
 // Date       : 01/08
@@ -307,7 +320,92 @@
      point1_ptr = point2_ptr;
      point2_ptr = tmp_point;
-  return make_Curve(curve_type, point1_ptr, point2_ptr, mid_points);
+  if(curve_type == SPLINE_CURVE_TYPE)
+    return make_Curve(curve_type, point1_ptr, point2_ptr, mid_points);
+  CubitVector v1(point1_ptr->coordinates());
+  CubitVector v2(point2_ptr->coordinates());
+  gp_Pnt pt1(v1.x(),v1.y(), v1.z());
+  gp_Pnt pt2(v2.x(),v2.y(), v2.z());
+  CubitVector v3;
+  gp_Pnt pt3;
+  if(intermediate_point_ptr != NULL)
+    v3 = point1_ptr->coordinates();
+    pt3.SetValue(v3.x(),v3.y(), v3.z());
+  if (curve_type == STRAIGHT_CURVE_TYPE)
+    Handle(Geom_TrimmedCurve) curve_ptr = GC_MakeSegment(pt1,pt2);
+  else if (curve_type == ARC_CURVE_TYPE)
+     assert(intermediate_point_ptr != NULL);
+     Handle(Geom_TrimmedCurve) curve_ptr = GC_MakeArcOfCircle(pt1, pt2, pt3);
+  else if (curve_type == ELLIPSE_CURVE_TYPE)
+     Handle(Geom_TrimmedCurve) curve_ptr = GC_MakeArcOfEllipse(
+  else if(curve_type == PARABOLA_CURVE_TYPE)
+    //find the directrix and focus of this parabola
+    CubitVector width_vec = v2 - v1;
+    CubitVector midpoint_vec = (v1 + v2)/2.0;
+    CubitVector height_vec = v3 - midpoint_vec;
+    // Find the focus of this parabola.
+    // Since for a parabola with its peak at the origin, y = (1/(4*a))*x^2,
+    // and since we have restricted this parabola to be symmetric (per the FastQ
+    // method, see the FastQ file getwt.f), we can use the following relationship
+    // to determine "a", the distance the focus lies from the peak on the line
+    // formed by the peak and the midpoint of the start and end points`
+  else if(curve_type == HYPERBOLA_CURVE_TYPE)
+    //given two foci and a third point on the curve
+    // if a = 1/2 length major axis, b = 1/2 length minor axis and
+    // c = distance center to focus, then a*a + b*b = c*c
+    gp_Pnt center(midpoint_vec.x(), midpoint_vec.y(), midpoint_vec.z());
+    //x direction:
+    CubitVector x = v1 - v2;
+    if(x.length() > 0.000001)
+      x.normalize();
+    else
+    //main direction:
+    CubitVector N = x * (v3 - v1);
+    if (N.length() > 0.000001)
+       N.normalize();
+    else
+    gp_Ax2 axis(center, N, x);
+    double major = x.length()/2.0;
+    double minor = sqrt((center - v1).length() ^ 2 - major ^ 2);
+    gp_Hypr hypt(axis, major, minor);
+A
+A
+  TopoDS_Edge new_edge = BRepBuilderAPI_MakeEdge(curve_ptr);
+  return OCCQueryEngine::instance()->populate_topology_bridge(new_edge);
More information about the cgma-dev mailing list
