[cgma-dev] r1566 - in cgm/trunk: geom/OCC util
janehu at mcs.anl.gov
Tue Jan 29 14:04:20 CST 2008
Author: janehu
Date: 2008-01-29 14:04:20 -0600 (Tue, 29 Jan 2008)
New Revision: 1566
Modified:
cgm/trunk/geom/OCC/OCCCurve.cpp
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
cgm/trunk/geom/OCC/OCCShell.cpp
cgm/trunk/geom/OCC/OCCSurface.cpp
cgm/trunk/util/GeometryDefines.h
Log:
Added make_Curve for spline curves, corrected mistakes on curve and surface types.
Modified: cgm/trunk/geom/OCC/OCCCurve.cpp
--- cgm/trunk/geom/OCC/OCCCurve.cpp 2008-01-28 21:30:01 UTC (rev 1565)
+++ cgm/trunk/geom/OCC/OCCCurve.cpp 2008-01-29 20:04:20 UTC (rev 1566)
@@ -585,9 +585,9 @@
BRepAdaptor_Curve acurve(*myTopoDSEdge);
if (acurve.GetType() == GeomAbs_BezierCurve)
- return BEZIER_CURVE_TYPE;
+ return SPLINE_CURVE_TYPE;
if (acurve.GetType() == GeomAbs_BSplineCurve)
- return SPLINE_CURVE_TYPE;
+ return BSPLINE_CURVE_TYPE;
if (acurve.GetType() == GeomAbs_Line)
return STRAIGHT_CURVE_TYPE;
if (acurve.GetType() == GeomAbs_Parabola)
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-01-28 21:30:01 UTC (rev 1565)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-01-29 20:04:20 UTC (rev 1566)
@@ -15,6 +15,10 @@
#include "config.h"
#include "gp_Pnt.hxx"
#include "TopoDS_Shape.hxx"
+#include "TColgp_Array1OfPnt.hxx"
+#include "Geom_BezierCurve.hxx"
+#include "BRepBuilderAPI_MakeEdge.hxx"
+#include "BRep_Tool.hxx"
#include "TopoDS.hxx"
#include "TopologyBridge.hpp"
#include "OCCModifyEngine.hpp"
@@ -162,8 +166,14 @@
if(third_point != NULL && face_ptr != NULL)
closed = CUBIT_TRUE;
- //curve = make_Curve(type, point1_ptr, third_point, mid_points);
+ Point * Pnt = make_Point(*third_point);
+ curve = make_Curve(type, point1_ptr, Pnt, mid_points);
+ else
+ PRINT_ERROR("Cannot create an OCC curve from the given duplicated points.\n");
+ return (Curve *)NULL;
Curve* new_curve = NULL;
@@ -180,7 +190,7 @@
// Function : make_Curve
// Member Type: PUBLIC
-// Description: make a curve
+// Description: make a spline curve by using the points on surface.
// Author : Jane Hu
// Date : 01/08
@@ -191,22 +201,84 @@
Surface* face_ptr) const
assert(point1_ptr != NULL && point2_ptr != NULL);
- OCCPoint const* occ_point1 = CAST_TO(point1_ptr, OCCPoint);
- OCCPoint const* occ_point2 = CAST_TO(point2_ptr, OCCPoint);
+ if (curve_type != SPLINE_CURVE_TYPE
+ && curve_type != STRAIGHT_CURVE_TYPE)
+ PRINT_ERROR("Cannot create an OCC curve from the given curve_type.\n"
+ "Candidates are SPLINE_CURVE_TYPE and STRAIGHT_CURVE_TYPE.\n");
+ OCCPoint* occ_point1 = CAST_TO(const_cast<Point*>(point1_ptr), OCCPoint);
+ OCCPoint* occ_point2 = CAST_TO(const_cast<Point*>(point2_ptr), OCCPoint);
if (occ_point1 == NULL || occ_point2 == NULL)
PRINT_ERROR("Cannot create an OCC curve from the given points.\n"
"Possible incompatible geometry engines.\n");
- //project all points on the surface
+ //project all points on the surface if possible
+ OCCSurface* occ_face = NULL;
if (face_ptr != NULL)
+ occ_face = CAST_TO(face_ptr, OCCSurface);
+ gp_Pnt pt;
+ int size = 2+vector_list.size();
+ TColgp_Array1OfPnt points(1, size);
+ CubitVector* vector = NULL;
+ CubitVector closest_location;
+ for(int i = 1; i <= size; i++)
+ if (i == 1)
+ TopoDS_Vertex *point = occ_point1->get_TopoDS_Vertex();
+ pt = BRep_Tool::Pnt(*point);
+ vector = new CubitVector(point1_ptr->coordinates());
+ else if (i == size)
+ TopoDS_Vertex *point = occ_point2->get_TopoDS_Vertex();
+ vector = new CubitVector(point2_ptr->coordinates());
+ else
+ vector = vector_list.get_and_step();
+ pt.SetCoord(vector->x(), vector->y(), vector->z());
+ if (occ_face != NULL)
+ occ_face->closest_point(*vector, &closest_location);
+ pt.SetCoord(closest_location.x(), closest_location.y(), closest_location.z()) ;
+ points.SetValue(i, pt);
+ //make curve according to the curve type.
+ if(curve_type == SPLINE_CURVE_TYPE)
+ Geom_BezierCurve BezierCurve(points);
+ Handle(Geom_Curve) curve_ptr(&BezierCurve);
+ TopoDS_Edge new_edge = BRepBuilderAPI_MakeEdge(curve_ptr);
+ return OCCQueryEngine::instance()->populate_topology_bridge(new_edge);
+ else if(curve_type == STRAIGHT_CURVE_TYPE)
+ TColgp_Array1OfPnt two_points(1,2);
+ two_points.SetValue(1, points.Value(1));
+ two_points.SetValue(2, points.Value(size));
+ Geom_BezierCurve BezierCurve(two_points);
return (Curve*) NULL;
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-01-28 21:30:01 UTC (rev 1565)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-01-29 20:04:20 UTC (rev 1566)
@@ -1540,12 +1540,12 @@
k = OCCMap->Find(*face);
if(!OCCMap->UnBind(*face))
- PRINT_ERROR("The OccSurface and TopoDS_Face pair is not in the map!");
+ PRINT_WARNING("The OccSurface and TopoDS_Face pair is not in the map!");
SurfaceList->remove((OCCSurface*)(OccToCGM->find(k))->second);
if(!OccToCGM->erase(k))
DLIList<TopologyBridge*> children;
@@ -1555,6 +1555,7 @@
LoopSM* loop = CAST_TO(children.get_and_step(), LoopSM);
unhook_LoopSM_from_OCC(loop);
+ return CUBIT_SUCCESS;
@@ -1657,10 +1658,11 @@
k = OCCMap->Find(*edge);
if(!OCCMap->UnBind(*edge))
- PRINT_ERROR("The OccCurve and TopoDS_Edge pair is not in the map!");
+ PRINT_WARNING("The OccCurve and TopoDS_Edge pair is not in the map!");
CurveList->remove((OCCCurve*)(OccToCGM->find(k))->second);
- PRINT_ERROR("The OccCurve and TopoDS_Edge pair is not in the map!"); }
fcurve->get_children_virt(children);
@@ -1669,6 +1671,7 @@
Point* point = CAST_TO(children.get_and_step(), Point);
unhook_Point_from_OCC(point);
// Purpose : Delete a OCCPoint and child entities.
@@ -1729,6 +1732,7 @@
PRINT_ERROR("The OccPoint and TopoDS_Vertex pair is not in the map!");
Modified: cgm/trunk/geom/OCC/OCCShell.cpp
--- cgm/trunk/geom/OCC/OCCShell.cpp 2008-01-28 21:30:01 UTC (rev 1565)
+++ cgm/trunk/geom/OCC/OCCShell.cpp 2008-01-29 20:04:20 UTC (rev 1566)
@@ -169,6 +169,7 @@
surface->update_OCC_entity(aBRepTrsf);
set_TopoDS_Shell(shell);
// ********** END PUBLIC FUNCTIONS **********
Modified: cgm/trunk/geom/OCC/OCCSurface.cpp
--- cgm/trunk/geom/OCC/OCCSurface.cpp 2008-01-28 21:30:01 UTC (rev 1565)
+++ cgm/trunk/geom/OCC/OCCSurface.cpp 2008-01-29 20:04:20 UTC (rev 1566)
@@ -186,9 +186,9 @@
BRepAdaptor_Surface asurface(*myTopoDSFace);
if (asurface.GetType() == GeomAbs_BezierSurface)
- return BEZIER_SURFACE_TYPE;
+ return SPLINE_SURFACE_TYPE;
if (asurface.GetType() == GeomAbs_BSplineSurface)
- return SPLINE_SURFACE_TYPE;
+ return BSPLINE_SURFACE_TYPE;
if (asurface.GetType() == GeomAbs_Plane)
return PLANE_SURFACE_TYPE;
if (asurface.GetType() == GeomAbs_Cylinder ||
@@ -769,6 +769,7 @@
loop->update_OCC_entity(aBRepTrsf);
set_TopoDS_Face(surface);
Modified: cgm/trunk/util/GeometryDefines.h
--- cgm/trunk/util/GeometryDefines.h 2008-01-28 21:30:01 UTC (rev 1565)
+++ cgm/trunk/util/GeometryDefines.h 2008-01-29 20:04:20 UTC (rev 1566)
@@ -68,7 +68,7 @@
SPLINE_CURVE_TYPE,
STRAIGHT_CURVE_TYPE,
POINT_CURVE_TYPE,
- BEZIER_CURVE_TYPE, //OCC curve types
+ BSPLINE_CURVE_TYPE, //OCC curve types
HYPERBOLA_CURVE_TYPE,
UNDEFINED_CURVE_TYPE,
@@ -80,7 +80,7 @@
TORUS_SURFACE_TYPE,
BEST_FIT_SURFACE_TYPE,
FACET_SURFACE_TYPE,
- BEZIER_SURFACE_TYPE, //OCC surface type
+ BSPLINE_SURFACE_TYPE, //OCC surface type
REVOLUTION_SURFACE_TYPE, //OCC surface type
EXTRUSION_SURFACE_TYPE, //OCC surface type
OFFSET_SURFACE_TYPE, //OCC surface type
More information about the cgma-dev
