[cgma-dev] r1551 - in cgm/trunk: geom/OCC test
janehu at mcs.anl.gov
Tue Jan 22 13:23:44 CST 2008
Author: janehu
Date: 2008-01-22 13:23:44 -0600 (Tue, 22 Jan 2008)
New Revision: 1551
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
cgm/trunk/geom/OCC/OCCSurface.cpp
cgm/trunk/test/makept.cpp
Log:
Added copy curve for OCCModifyEngine and updated this function and edge-edge angle test in test file, corrected a mistake in OCCSurface.cpp
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-01-22 17:18:28 UTC (rev 1550)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-01-22 19:23:44 UTC (rev 1551)
@@ -16,6 +16,7 @@
#include "config.h"
#include "gp_Pnt.hxx"
#include "TopoDS_Shape.hxx"
+#include "TopoDS.hxx"
#include "TopologyBridge.hpp"
#include "OCCModifyEngine.hpp"
#include "OCCQueryEngine.hpp"
@@ -110,15 +111,29 @@
// Function : make_Curve
+// This function creates a curve given an existing curve, copy.
// Member Type: PUBLIC
// Description: make a curve
-// Author : John Fowler
-// Date : 10/02
+// Author : Jane Hu
+// Date : 01/08
-Curve* OCCModifyEngine::make_Curve(Curve * /*curve_ptr*/) const
+Curve* OCCModifyEngine::make_Curve(Curve * curve_ptr) const
- PRINT_ERROR("Option not supported for mesh based geometry.\n");
- return (Curve*) NULL;
+ OCCCurve* occ_curve = CAST_TO(curve_ptr, OCCCurve);
+ if (!occ_curve)
+ PRINT_ERROR("Cannot create an OCC curve from the given curve.\n"
+ "Possible incompatible geometry engines.\n");
+ return (Curve *)NULL;
+ TopoDS_Edge *theEdge = occ_curve->get_TopoDS_Edge();
+ TopoDS_Shape newShape = theEdge->EmptyCopied();
+ TopoDS_Edge newEdge = TopoDS::Edge(newShape);
+ return OCCQueryEngine::instance()->populate_topology_bridge(newEdge);
Modified: cgm/trunk/geom/OCC/OCCSurface.cpp
--- cgm/trunk/geom/OCC/OCCSurface.cpp 2008-01-22 17:18:28 UTC (rev 1550)
+++ cgm/trunk/geom/OCC/OCCSurface.cpp 2008-01-22 19:23:44 UTC (rev 1551)
@@ -227,7 +227,7 @@
CubitStatus OCCSurface::get_point_normal( CubitVector& location,
CubitVector& normal )
- return closest_point( bounding_box().center_point(), &location, &normal );
+ return closest_point( bounding_box().center(), &location, &normal );
CubitStatus OCCSurface::closest_point_uv_guess(
Modified: cgm/trunk/test/makept.cpp
--- cgm/trunk/test/makept.cpp 2008-01-22 17:18:28 UTC (rev 1550)
+++ cgm/trunk/test/makept.cpp 2008-01-22 19:23:44 UTC (rev 1551)
@@ -149,8 +149,8 @@
//check for vertex
DLIList<Body*> bodies;
gti->bodies(bodies);
- free_entities.clean_out(); //currently there's bug in that it created
- //new entities after translating, debug next week.
+ free_entities.clean_out();// get_free_ref_entities directly append
+ //without checking for duplicates, so clean_out first.
gti->get_free_ref_entities(free_entities);
RefVertex* vertex1 = CAST_TO(free_entities.get_and_step(),RefVertex);
@@ -280,15 +280,42 @@
CubitPointContainment pc2 = ref_face->point_containment(3,-20000);
// this (u,v) location should be inside of the surface.
+ DLIList<DLIList<RefEdge*>*> ref_edge_loops;
+ int num_loops = ref_face->ref_edge_loops(ref_edge_loops);
+ DLIList<RefEdge*> *ref_edges1;
+ ref_edges1 = ref_edge_loops.get();
+ RefEdge* edge1 = ref_edges1->get();
+ RefEdge* edge2 = ref_edges1->step_and_get();
+ double angle = edge1->angle_between(edge2, ref_face);
//test for curve
DLIList<RefEdge *> ref_edges;
gti->ref_edges(ref_edges);
+ //make a new refedge out of existing refedge.
RefEdge* ref_edge = ref_edges.step_and_get();
+ RefEdge* new_edge = gmti->make_RefEdge(ref_edge);
+ gti->get_free_ref_entities(free_entities);
+ //translate the new curve by (30,30,30)
+ for(int i = 1; i <= free_entities.size(); i++)
+ if( i != 3)
+ continue;
+ RefEntity * entity = free_entities.get_and_step();
+ gti->translate((BasicTopologyEntity*)entity, i*vector1);
+ box = new_edge->get_curve_ptr()->bounding_box();
+ // test free curve translation
DLIList<OCCCurve*> curves;
CAST_TO(body, OCCBody)->get_all_curves(curves);
OCCCurve *curve = curves.step_and_get();
type = curve->geometry_type();
// ARC_CURVE_TYPE
More information about the cgma-dev
