Author: janehu
Date: 2008-01-22 11:18:28 -0600 (Tue, 22 Jan 2008)
New Revision: 1550
Modified:
cgm/trunk/geom/OCC/OCCSurface.cpp
cgm/trunk/geom/RefFace.cpp
cgm/trunk/test/Makefile.am
cgm/trunk/test/makept.cpp
Log:
changed the call to get_point_normal in test file to normal_at; returned the get_point_normal to its original design of getting origin and normal for planar surface; added back webcut test in the Makefile per Jason's suggestion.
Modified: cgm/trunk/geom/OCC/OCCSurface.cpp
--- cgm/trunk/geom/OCC/OCCSurface.cpp 2008-01-22 02:10:10 UTC (rev 1549)
+++ cgm/trunk/geom/OCC/OCCSurface.cpp 2008-01-22 17:18:28 UTC (rev 1550)
@@ -227,8 +227,7 @@
CubitStatus OCCSurface::get_point_normal( CubitVector& location,
CubitVector& normal )
- //assert(0);
- return closest_point( location, NULL, &normal );
+ return closest_point( bounding_box().center_point(), &location, &normal );
CubitStatus OCCSurface::closest_point_uv_guess(
Modified: cgm/trunk/geom/RefFace.cpp
--- cgm/trunk/geom/RefFace.cpp 2008-01-22 02:10:10 UTC (rev 1549)
+++ cgm/trunk/geom/RefFace.cpp 2008-01-22 17:18:28 UTC (rev 1550)
@@ -1484,13 +1484,11 @@
+//To get planar surface's origin and normal, both are pure output.
CubitStatus RefFace::get_point_normal( CubitVector& origin, CubitVector& normal )
- // non-planar surface can calculate for point normal too. If certain
- //geometry engine can't provide normal for non-planar surfaces, check
- //should be done in the geometry engine level.
- //if( is_planar() == CUBIT_FALSE)
- // return CUBIT_FAILURE;
+ if( is_planar() == CUBIT_FALSE)
+ return CUBIT_FAILURE;
Surface* surface_ptr = get_surface_ptr();
Modified: cgm/trunk/test/Makefile.am
--- cgm/trunk/test/Makefile.am 2008-01-22 02:10:10 UTC (rev 1549)
+++ cgm/trunk/test/Makefile.am 2008-01-22 17:18:28 UTC (rev 1550)
@@ -13,8 +13,13 @@
-I..\$(OCC_INC_FLAG)
TESTS = makept
+if build_ACIS
+ TESTS += webcut
+endif
check_PROGRAMS = $(TESTS)
+webcut_SOURCES = webcut.cpp
makept_SOURCES = makept.cpp
opt_libs=
LDADD = ../geom/virtual/libcubit_virtual.la \
@@ -25,6 +30,9 @@
../geom/libcubit_geom.la \
../util/libcubit_util.la
+if build_ACIS
+ opt_libs += ../geom/ACIS/libcubit_ACIS.la
+endif
if WITH_OCC
opt_libs += ../geom/OCC/libcubit_OCC.la $(OCC_LIB_FLAG) $(OCC_LIBS)
endif
Modified: cgm/trunk/test/makept.cpp
--- cgm/trunk/test/makept.cpp 2008-01-22 02:10:10 UTC (rev 1549)
+++ cgm/trunk/test/makept.cpp 2008-01-22 17:18:28 UTC (rev 1550)
@@ -223,7 +223,7 @@
// center point
CubitVector normal;
- ref_face->get_point_normal(vi, normal);
+ normal = ref_face->normal_at(vi);
// surface normal at center point.
CubitVector closest_location ;
