[cgma-dev] r1546 - cgm/trunk/geom
janehu at mcs.anl.gov
Fri Jan 18 15:50:04 CST 2008
Author: janehu
Date: 2008-01-18 15:50:04 -0600 (Fri, 18 Jan 2008)
New Revision: 1546
Modified:
cgm/trunk/geom/RefFace.cpp
Log:
Adding comments for RefFace change.
Modified: cgm/trunk/geom/RefFace.cpp
--- cgm/trunk/geom/RefFace.cpp 2008-01-18 21:46:33 UTC (rev 1545)
+++ cgm/trunk/geom/RefFace.cpp 2008-01-18 21:50:04 UTC (rev 1546)
@@ -1486,6 +1486,9 @@
CubitStatus RefFace::get_point_normal( CubitVector& origin, CubitVector& normal )
+ // non-planar surface can calculate for point normal too. If certain
+ //geometry engine can't provide normal for non-planar surfaces, check
+ //should be done in the geometry engine level.
//if( is_planar() == CUBIT_FALSE)
// return CUBIT_FAILURE;
More information about the cgma-dev
