[cgma-dev] r1545 - in cgm/trunk: . geom geom/OCC test
janehu at mcs.anl.gov
Fri Jan 18 15:46:34 CST 2008
Author: janehu
Date: 2008-01-18 15:46:33 -0600 (Fri, 18 Jan 2008)
New Revision: 1545
Modified:
cgm/trunk/CMakeLists.txt
cgm/trunk/Makefile.am
cgm/trunk/geom/OCC/OCCCurve.cpp
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
cgm/trunk/geom/OCC/OCCSurface.cpp
cgm/trunk/geom/RefFace.cpp
cgm/trunk/test/Makefile.am
cgm/trunk/test/makept.cpp
Log:
Updated using RefFace and RefEdge for reference of testing, fixed some bug, updated some comments. Added test directory in the Makefile for future reference.
Modified: cgm/trunk/CMakeLists.txt
--- cgm/trunk/CMakeLists.txt 2008-01-18 20:09:56 UTC (rev 1544)
+++ cgm/trunk/CMakeLists.txt 2008-01-18 21:46:33 UTC (rev 1545)
@@ -1,5 +1,5 @@
-# do util and geom subdirs
-SUBDIRS( util geom init )
+# do util and geom and test subdirs
+SUBDIRS( util geom test init )
Modified: cgm/trunk/Makefile.am
--- cgm/trunk/Makefile.am 2008-01-18 20:09:56 UTC (rev 1544)
+++ cgm/trunk/Makefile.am 2008-01-18 21:46:33 UTC (rev 1545)
@@ -1,5 +1,5 @@
AUTOMAKE_OPTIONS = foreign
-SUBDIRS = util geom init itaps
+SUBDIRS = util geom init itaps test
if build_ACIS
ACIS_EXAMPLE_TEST=cd cgm_apps/examples/driverc++; make check-TESTS
Modified: cgm/trunk/geom/OCC/OCCCurve.cpp
--- cgm/trunk/geom/OCC/OCCCurve.cpp 2008-01-18 20:09:56 UTC (rev 1544)
+++ cgm/trunk/geom/OCC/OCCCurve.cpp 2008-01-18 21:46:33 UTC (rev 1545)
@@ -436,10 +436,9 @@
*tangent_ptr = CubitVector(tangent.X(), tangent.Y(), tangent.Z());
- if (curvature_ptr != NULL) {
- double curvature = CLP.Curvature();
- // Danilov: confused here
+ if (curvature_ptr != NULL)
+ get_curvature( location, *curvature_ptr);
if (param != NULL) {
*param = newVal;
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-01-18 20:09:56 UTC (rev 1544)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-01-18 21:46:33 UTC (rev 1545)
@@ -782,7 +782,7 @@
//Function Name:export_solid_model
//Member Type: PUBLIC
-//Description: function called for save/restore to save temporary FACET file
+//Description: function called for save/restore to save temporary Brep file
//Author: Jane Hu
//Date: 11/16/2007
@@ -909,6 +909,14 @@
return CUBIT_SUCCESS;
+//Function Name:export_solid_model
+//Member Type: PUBLIC
+//Description: function called for write out temporary Brep file
+//Author: Jane Hu
+//Date: 11/16/2007
CubitStatus
OCCQueryEngine::write_topology( const char* file_name,
DLIList<OCCBody*> &OCC_bodies,
@@ -1002,6 +1010,14 @@
return CUBIT_FAILURE;
+//Function Name:import_solid_model
+//Description: function called for read in temporary Brep file
+//Author: Jane Hu
+//Date: 11/16/2007
CubitStatus OCCQueryEngine::import_solid_model(
const char* file_name ,
const char* file_type,
@@ -1025,6 +1041,14 @@
+//Function Name:populate_topology_bridge
+//Description: function called for populating topology bridge for OCC entity
+//Author: Jane Hu
+//Date: 11/16/2007
DLIList<TopologyBridge*> OCCQueryEngine::populate_topology_bridge(TopoDS_Shape aShape)
DLIList<TopologyBridge*> tblist;
@@ -1707,6 +1731,16 @@
+// Purpose : fire a ray at the specified body, returning the entities hit.
+// Special Notes :
+// Creator : Jane Hu
+// Creation Date : 12/12/07
CubitStatus OCCQueryEngine::fire_ray(BodySM * body,
const CubitVector &start,
const CubitVector &unit,
@@ -2065,7 +2099,7 @@
// Function : bodies_overlap
// Member Type: PUBLIC
// Description: determine if OCC-based bodies overlap
-// Author :
+// Author : Jane Hu
// Date : 10/07
CubitBoolean OCCQueryEngine::bodies_overlap (BodySM * body_ptr_1,
Modified: cgm/trunk/geom/OCC/OCCSurface.cpp
--- cgm/trunk/geom/OCC/OCCSurface.cpp 2008-01-18 20:09:56 UTC (rev 1544)
+++ cgm/trunk/geom/OCC/OCCSurface.cpp 2008-01-18 21:46:33 UTC (rev 1545)
@@ -310,7 +310,7 @@
int i;
Extrema_ExtPS ext(p, asurface, Precision::Approximation(), Precision::Approximation());
if (ext.IsDone() && (ext.NbExt() > 0)) {
- for ( i = 1 ; i < ext.NbExt() ; i++ ) {
+ for ( i = 1 ; i <= ext.NbExt() ; i++ ) {
if ( (i==1) || (p.Distance(ext.Point(i).Value()) < minDist) ) {
minDist = p.Distance(ext.Point(i).Value());
newP = ext.Point(i).Value();
Modified: cgm/trunk/geom/RefFace.cpp
--- cgm/trunk/geom/RefFace.cpp 2008-01-18 20:09:56 UTC (rev 1544)
+++ cgm/trunk/geom/RefFace.cpp 2008-01-18 21:46:33 UTC (rev 1545)
@@ -1486,8 +1486,8 @@
CubitStatus RefFace::get_point_normal( CubitVector& origin, CubitVector& normal )
- if( is_planar() == CUBIT_FALSE)
- return CUBIT_FAILURE;
+ //if( is_planar() == CUBIT_FALSE)
+ // return CUBIT_FAILURE;
Surface* surface_ptr = get_surface_ptr();
Modified: cgm/trunk/test/Makefile.am
--- cgm/trunk/test/Makefile.am 2008-01-18 20:09:56 UTC (rev 1544)
+++ cgm/trunk/test/Makefile.am 2008-01-18 21:46:33 UTC (rev 1545)
@@ -13,13 +13,8 @@
-I..\$(OCC_INC_FLAG)
TESTS = makept
-if build_ACIS
- TESTS += webcut
-endif
check_PROGRAMS = $(TESTS)
-webcut_SOURCES = webcut.cpp
makept_SOURCES = makept.cpp
opt_libs=
LDADD = ../geom/virtual/libcubit_virtual.la \
@@ -30,9 +25,6 @@
../geom/libcubit_geom.la \
../util/libcubit_util.la
-if build_ACIS
- opt_libs += ../geom/ACIS/libcubit_ACIS.la
-endif
if WITH_OCC
opt_libs += ../geom/OCC/libcubit_OCC.la $(OCC_LIB_FLAG) $(OCC_LIBS)
endif
Modified: cgm/trunk/test/makept.cpp
--- cgm/trunk/test/makept.cpp 2008-01-18 20:09:56 UTC (rev 1544)
+++ cgm/trunk/test/makept.cpp 2008-01-18 21:46:33 UTC (rev 1545)
@@ -4,10 +4,7 @@
* \brief makept, another simple C++ driver for CGM
* This program acts as a simple driver for CGM. It reads in a geometry,
- * performs imprints between all the bodies, merges them, and writes information
- * on the results. It also performs pairwise intersections between the
- * bodies to check for overlaps. Results are written to stardard output.
+ * and performs varies checks for bodies, surfaces, curves and vertices.
#include "config.h"
#include "CpuTimer.hpp"
@@ -124,18 +121,20 @@
CubitVector vector1(10,10,10);
CubitVector vector2(15,15,15);
DLIList<RefEntity*> free_entities;
+ // Make two vertices.
+ gmti->make_RefVertex(vector1,5);
+ gmti->make_RefVertex(vector2,5);
gti->get_free_ref_entities(free_entities);
+ //translate the two vertice by (10,10,10) and (20,20,20)
for(int i = 1; i <= free_entities.size(); i++)
RefEntity * entity = free_entities.get_and_step();
- gti->translate((BasicTopologyEntity*)entity, i*vector1);
+ gti->translate((BasicTopologyEntity*)entity, i*vector1);
- // Read in the geometry from files specified on the command line
- gmti->make_RefVertex(vector1,5);
- gmti->make_RefVertex(vector2,5);
CubitStatus rsl = CUBIT_SUCCESS;
DLIList<RefEntity*> ref_entity_list;
int num_ents_exported=0;
@@ -150,6 +149,8 @@
//check for vertex
DLIList<Body*> bodies;
gti->bodies(bodies);
+ free_entities.clean_out(); //currently there's bug in that it created
+ //new entities after translating, debug next week.
RefVertex* vertex1 = CAST_TO(free_entities.get_and_step(),RefVertex);
@@ -161,7 +162,9 @@
CubitVector vi, vii;
double d;
gti->entity_entity_distance(vertex1,vertex2,vi, vii,d);
- // distance (d) between vertex1,vertex2
+ // distance (d) between vertex1,vertex2. vi (20, 20, 20) is vertex1
+ //translated by (10,10,10) and vii(35, 35, 35) is vertex2 translated
+ //by 2*(10,10,10).
//check for body
d = bodies.get()->measure();
@@ -174,9 +177,11 @@
//first body's bounding box.
gti->entity_entity_distance(gti->get_first_ref_volume(), vertex2,vi, vii,d);
- //first body and vertex2 's distance(d).
+ //first body and vertex2 's minimum distance(d) and locations for the minimum.
BodySM* body = bodies.get()->get_body_sm_ptr();
+ OCCBody* occ_body = CAST_TO(body, OCCBody);
CubitVector axis(10,0,0);
gti->reflect(bodies, axis);
vi = bodies.get()->center_point();
@@ -194,7 +199,6 @@
// After rotation, center point changed in y and z value.
- OCCBody* occ_body = CAST_TO(body, OCCBody);
occ_body->mass_properties(vi, d);
//true center and volume, volume should be 8 times of the original one.
@@ -203,7 +207,6 @@
//check for surface
DLIList<OCCSurface*> surfaces;
CAST_TO(body, OCCBody)->get_all_surfaces(surfaces);
OCCSurface* surface = surfaces.step_and_get();
GeometryType type = surface->geometry_type();
@@ -212,11 +215,15 @@
box = surface->bounding_box();
// bounding box
- vi = surface->center_point();
+ DLIList<RefFace*> ref_faces;
+ gti->ref_faces(ref_faces);
+ RefFace* ref_face = ref_faces.step_and_get();
+ vi = ref_face->center_point();
// center point
CubitVector normal;
- surface->get_point_normal(vi, normal);
+ ref_face->get_point_normal(vi, normal);
// surface normal at center point.
CubitVector closest_location ;
@@ -224,35 +231,41 @@
CubitVector curvature1_ptr ;
CubitVector curvature2_ptr ;
- surface->closest_point(vi, &closest_location, &unit_normal_ptr,
- &curvature1_ptr, &curvature2_ptr);
- // another way to get normal at center point, and found surface
- // projection location for vi.
+ ref_face->find_closest_point_trimmed(vi, closest_location);
+ // Found surface projection location for vi.
double curvature1, curvature2;
- surface->principal_curvatures(closest_location, curvature1, curvature2);
+ ref_face->get_principal_curvatures(closest_location, curvature1, curvature2);
// get principal curvatures at center point.
- double u = 0.5;
+ double area = ref_face->area();
+ // area of the face
+ double u = 2.5;
double v = -20000;
- vi = surface->position_from_u_v(u,v);
+ vi = ref_face->position_from_u_v(u,v);
// get location on surface for it's u,v
- CubitBoolean periodic = surface->is_periodic();
+ ref_face->u_v_from_position(vi, u, v);
+ // get (u,v) from this vi.
+ CubitBoolean periodic = ref_face->is_periodic();
// found if surface is periodic.
double p = 0; //period
- periodic = surface->is_periodic_in_U(p);
+ periodic = ref_face->is_periodic_in_U(p);
// found if surface is periodic in U and its period.
- periodic = surface->is_periodic_in_V(p);
+ periodic = ref_face->is_periodic_in_V(p);
// found if surface is periodic in V and its period.
+ //All OCC entities are parametric.
double lower, upper;
- surface->get_param_range_U(lower, upper);
+ ref_face->get_param_range_U(lower, upper);
// get surface U direction boundaries. here it's (2.48, 3.91)
- surface->get_param_range_V(lower, upper);
+ ref_face->get_param_range_V(lower, upper);
// get surface V direction boundaries. here it's (-20010,-19998)
CubitBoolean closed = surface->is_closed_in_U();
@@ -261,13 +274,17 @@
closed = surface->is_closed_in_V();
// check if surface is closed in V direction.
- CubitPointContainment pc = surface->point_containment(1,-20000);
+ CubitPointContainment pc = ref_face->point_containment(1,-20000);
// this (u,v) location should be outside of the surface.
- CubitPointContainment pc2 = surface->point_containment(3,-20000);
+ CubitPointContainment pc2 = ref_face->point_containment(3,-20000);
// this (u,v) location should be inside of the surface.
//test for curve
+ DLIList<RefEdge *> ref_edges;
+ gti->ref_edges(ref_edges);
+ RefEdge* ref_edge = ref_edges.step_and_get();
DLIList<OCCCurve*> curves;
CAST_TO(body, OCCBody)->get_all_curves(curves);
@@ -278,42 +295,42 @@
box = curve-> bounding_box();
// bounding box
- d = curve->measure();
+ d = ref_edge->measure();
// length of the curve.
- curve->get_param_range(lower,upper);
+ ref_edge->get_param_range(lower,upper);
// paremeter range.
- d = curve->length_from_u(lower,upper);
+ d = ref_edge->length_from_u(lower,upper);
// double check whole curve length.
- d = curve->length_from_u(lower/2+upper/2, upper);
+ d = ref_edge->length_from_u(lower/2+upper/2, upper);
// half curve length.
- periodic = curve->is_periodic(p);
+ periodic = ref_edge->is_periodic(p);
// if curve is periodic and its period (p). here it's not.
- curve->position_from_u(lower/2+upper/2, vi);
+ ref_edge->position_from_u(lower/2+upper/2, vi);
// middle point.
+ u = ref_edge->u_from_position(vi);
+ // middle point's u value.
CubitVector c_point, tangent, center;
double radius;
- curve->closest_point(vi, c_point);
+ ref_edge->closest_point(vi, c_point, &tangent, & curvature1_ptr);
// Closed point on middle point.
- curve->get_tangent(vi, tangent);
+ ref_edge->tangent(vi, tangent);
// tangent at middle point.
- curve->get_point_direction(c_point, tangent);
+ ref_edge->get_point_direction(c_point, tangent);
// double check tangent
- curve->get_curvature(c_point, curvature1_ptr);
- // get mid-point curvature.
- curve->get_center_radius(center, radius);
+ ref_edge->get_center_radius(center, radius);
// center and radius for arc curves
- pc = curve->point_containment(c_point);
+ pc = ref_edge->point_containment(c_point);
// middle point should be on the curve.
//delete all entities
More information about the cgma-dev
