[cgma-dev] r1541 - cgm/trunk/itaps
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Fri Jan 18 13:45:36 CST 2008
Author: kraftche
Date: 2008-01-18 13:45:35 -0600 (Fri, 18 Jan 2008)
New Revision: 1541
Modified:
   cgm/trunk/itaps/Makefile.am
Log:
fix 'make test' link errors
Modified: cgm/trunk/itaps/Makefile.am
--- cgm/trunk/itaps/Makefile.am	2008-01-18 18:27:05 UTC (rev 1540)
+++ cgm/trunk/itaps/Makefile.am	2008-01-18 19:45:35 UTC (rev 1541)
@@ -22,9 +22,10 @@
   TEST_XLIBS = $(TEST_ACISLIBS) \
                $(top_builddir)/geom/facet/libcubit_facet.la \
                $(top_builddir)/geom/facetbool/libcubit_facetbool.la \
+               $(top_builddir)/geom/Cholla/libcholla.la \
+               $(top_builddir)/geom/virtual/libcubit_virtual.la \
                $(top_builddir)/geom/libcubit_geom.la \
                $(top_builddir)/util/libcubit_util.la
-  TEST_XLDFLAGS = -R$(ACIS_LIB_DIR)
 else
   TEST_XLDFLAGS = $(CUBIT_LDFLAGS) $(CUBIT_LTFLAGS)
   TEST_XLIBS = $(CUBIT_LIBS)
@@ -63,8 +64,7 @@
 check_PROGRAMS = $(TESTS)
 testgeom_SOURCES = testgeom.cc
-testgeom_LDFLAGS = $(TEST_XLDFLAGS)
-testgeom_LDADD = libiGeom.la $(TEST_XLIBS)
+testgeom_LDADD = libiGeom.la  ../init/libcgma_init.la $(TEST_XLIBS)
 # Automake doesn't seem to have a directory defined for
More information about the cgma-dev mailing list
