[cgma-dev] r1614 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Thu Feb 21 15:56:51 CST 2008
Author: janehu
Date: 2008-02-21 15:56:50 -0600 (Thu, 21 Feb 2008)
New Revision: 1614
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
cgm/trunk/geom/OCC/OCCModifyEngine.hpp
Log:
changed for a correct calling prototype, needs implementation for sort/make connected curves and make multi-loop surface. This sorting efford is provide in ACIS, and OCC reqires for orderd TopoDS_Edge to build surface.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-02-21 19:51:25 UTC (rev 1613)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-02-21 21:56:50 UTC (rev 1614)
@@ -645,6 +645,7 @@
//Create TopoDS_Edge list to make a surface.
DLIList<TopoDS_Edge*> topo_edges;
+ DLIList<DLIList<TopoDS_Edge*>*> topo_edges_loops;
curve_list.reset() ;
Curve const* curve_ptr = NULL ;
OCCCurve* occ_curve = NULL;
@@ -687,9 +688,11 @@
topo_edges.append(topo_edge);
+ topo_edges_loops.append(&topo_edges);
// Use the topo_edges to make a topo_face
TopoDS_Face* topo_face = make_TopoDS_Face(surface_type,
- topo_edges, old_surface_ptr) ;
+ topo_edges_loops, old_surface_ptr) ;
if(topo_face == NULL)
@@ -747,6 +750,7 @@
for(int i = 1; i < topo_edges->size(); i++)
aWire.Add(*(topo_edges->step_and_get()));
+ return (TopoDS_Face*) NULL;
// Function : make_Lump
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.hpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.hpp 2008-02-21 19:51:25 UTC (rev 1613)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.hpp 2008-02-21 21:56:50 UTC (rev 1614)
@@ -652,13 +652,10 @@
DLIList<BodySM*> &new_bodies,
DLIList<TopologyBridge*>*,
DLIList<TopologyBridge*>* ) const;
- TopoDS_Face* make_TopoDS_Face(GeometryType surface_type,
- DLIList<DLIList<TopoDS_Edge*>*> topo_edges_list,
- Surface * old_surface_ptr)const;
protected:
TopoDS_Face* make_TopoDS_Face( GeometryType surface_type,
- const DLIList<TopoDS_Edge*>& topo_edges,
+ DLIList<DLIList<TopoDS_Edge*>*> topo_edges,
Surface* old_surface_ptr) const;
private:
More information about the cgma-dev
