[cgma-dev] r1593 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Thu Feb 7 14:42:46 CST 2008
Author: janehu
Date: 2008-02-07 14:42:46 -0600 (Thu, 07 Feb 2008)
New Revision: 1593
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Added make_Surface with option for extended_from == true, need to add more surfaces types' creation
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-02-06 21:46:08 UTC (rev 1592)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-02-07 20:42:46 UTC (rev 1593)
@@ -19,6 +19,7 @@
#include "gp_Hypr.hxx"
#include "gp_Parab.hxx"
#include "gp_Elips.hxx"
+#include "gp_Pln.hxx"
#include "TopoDS_Shape.hxx"
#include "TColgp_Array1OfPnt.hxx"
#include "GC_MakeArcOfCircle.hxx"
@@ -26,8 +27,12 @@
#include "GC_MakeArcOfParabola.hxx"
#include "GC_MakeArcOfEllipse.hxx"
#include "GC_MakeSegment.hxx"
+#include "GC_MakePlane.hxx"
#include "Geom_BezierCurve.hxx"
+#include "Handle_Geom_Plane.hxx"
#include "BRepBuilderAPI_MakeEdge.hxx"
+#include "BRepAdaptor_Surface.hxx"
+#include "BRepBuilderAPI_MakeFace.hxx"
#include "BRep_Tool.hxx"
#include "TopoDS.hxx"
#include "TopologyBridge.hpp"
@@ -481,7 +486,10 @@
// Function : make_Surface
// This function creates a surface given an existing surface, copy.
// Member Type: PUBLIC
-// Description: make a surface
+// Description: make a surface, OCC allows to create a stand along surface,
+// however the CGM has a design of making all surfaces in a (sheet)
+// body. This will add complexity on all free surface related
+// calculation and modification, and adding potential bugs too.
// Author : Jane Hu
// Date : 02/08
@@ -497,11 +505,42 @@
TopoDS_Face *theFace = occ_surface->get_TopoDS_Face();
+ TopoDS_Face newFace;
- TopoDS_Shape newShape = theFace->EmptyCopied();
- TopoDS_Face newFace = TopoDS::Face(newShape);
+ if (extended_from == CUBIT_TRUE)
+ // We need to get the type of surface.
+ GeometryType type = occ_surface->geometry_type();
+ if (type == PLANE_SURFACE_TYPE)
+ BRepAdaptor_Surface asurface(*theFace);
+ gp_Pln plane = asurface.Plane();
+ Handle(Geom_Plane) gc_plane = GC_MakePlane(plane);
+ newFace = BRepBuilderAPI_MakeFace(gc_plane);
+ else if(extended_from == CONE_SURFACE_TYPE)
+ //make a whole cone 2 times longer
+ else if(extended_from == SPHERE_SURFACE_TYPE)
+ //make a whole sphere.
+ else if(extended_from == TORUS_SURFACE_TYPE)
+ //make a whole torus
+ else if(extended_from == SPLINE_SURFACE_TYPE || BSPLINE_SURFACE_TYPE)
+ //extend the surfaces using the equation if possible.
+ else
+ TopoDS_Shape newShape = theFace->EmptyCopied();
+ newFace = TopoDS::Face(newShape);
return OCCQueryEngine::instance()->populate_topology_bridge(newFace);
@@ -509,16 +548,16 @@
-// Author : John Fowler
-// Date : 10/02
+// Description: make a surface of type surface_type, given the list of curves.
+// Author : Jane Hu
+// Date : 02/08
-Surface* OCCModifyEngine::make_Surface( GeometryType /*surface_type*/,
- DLIList<Curve*>& /*curve_list*/,
- Surface * /*old_surface_ptr*/,
- bool /*check_edges*/) const
+Surface* OCCModifyEngine::make_Surface( GeometryType surface_type,
+ DLIList<Curve*>& curve_list,
+ Surface * old_surface_ptr,
+ bool check_edges) const
- PRINT_ERROR("Option not supported for mesh based geometry.\n");
return (Surface*) NULL;
More information about the cgma-dev
