[cgma-dev] r1587 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Tue Feb 5 14:11:04 CST 2008
Author: janehu
Date: 2008-02-05 14:11:04 -0600 (Tue, 05 Feb 2008)
New Revision: 1587
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Added surface copy creation,fixed a previous code.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-02-05 18:40:26 UTC (rev 1586)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-02-05 20:11:04 UTC (rev 1587)
@@ -372,25 +372,26 @@
gp_Dir x_dir(x.x(), x.y(), x.z());
CubitVector N = (v1 - v3) * (v2 - v3);
+ if(N.length_squared() < tol * tol)
- PRINT_ERROR("Cannot create a parabola or hyperbola curve from the given points.\n"
+ PRINT_ERROR("Cannot create an ellipse curve from the given points.\n"
"3 points are in the same line.\n");
return (Curve *)NULL;
- N.normalize();
- gp_Dir N_dir(N.x(), N.y(), N.z());
+ N.normalize();
+ gp_Dir N_dir(N.x(), N.y(), N.z());
- gp_Pnt center(v3.x(), v3.y(), v3.z());
- gp_Ax2 axis(center, N_dir, x_dir);
+ gp_Pnt center(v3.x(), v3.y(), v3.z());
+ gp_Ax2 axis(center, N_dir, x_dir);
- //calculate for the major and minor radius.
- double major = d1 >= d2 ? sqrt(d1): sqrt(d2);
- double other_d = d1 >= d2 ? sqrt(d2) : sqrt(d1);
- double c = cos((v1 - v3).interior_angle(v2 - v3)) * other_d;
- double minor = sqrt(major * major - c * c);
+ //calculate for the major and minor radius.
+ double major = d1 >= d2 ? sqrt(d1): sqrt(d2);
+ double other_d = d1 >= d2 ? sqrt(d2) : sqrt(d1);
+ double c = cos((v1 - v3).interior_angle(v2 - v3)) * other_d;
+ double minor = sqrt(major * major - c * c);
- gp_Elips ellipse(axis, major, minor);
- curve_ptr = GC_MakeArcOfEllipse(ellipse, pt1, pt2, sense);
+ gp_Elips ellipse(axis, major, minor);
+ curve_ptr = GC_MakeArcOfEllipse(ellipse, pt1, pt2, sense);
else if(curve_type == PARABOLA_CURVE_TYPE ||
@@ -478,16 +479,31 @@
// Function : make_Surface
+// This function creates a surface given an existing surface, copy.
// Member Type: PUBLIC
// Description: make a surface
-// Author : John Fowler
-// Date : 10/02
+// Author : Jane Hu
+// Date : 02/08
-Surface* OCCModifyEngine::make_Surface( Surface * /*old_surface_ptr*/,
- CubitBoolean /*extended_from*/) const
+Surface* OCCModifyEngine::make_Surface( Surface * surface_ptr,
+ CubitBoolean extended_from) const
- PRINT_ERROR("Option not supported for mesh based geometry.\n");
- return (Surface*) NULL;
+ OCCSurface* occ_surface = CAST_TO(surface_ptr, OCCSurface);
+ if (!occ_surface)
+ PRINT_ERROR("Cannot create an OCC surface from the given surface.\n"
+ "Possible incompatible geometry engines.\n");
+ return (Surface *)NULL;
+ TopoDS_Face *theFace = occ_surface->get_TopoDS_Face();
+ TopoDS_Shape newShape = theFace->EmptyCopied();
+ TopoDS_Face newFace = TopoDS::Face(newShape);
+ return OCCQueryEngine::instance()->populate_topology_bridge(newFace);
More information about the cgma-dev
