[cgma-dev] r2491 - cgm/trunk/test
janehu at mcs.anl.gov
Thu Dec 18 14:03:40 CST 2008
Author: janehu
Date: 2008-12-18 14:03:40 -0600 (Thu, 18 Dec 2008)
New Revision: 2491
Modified:
cgm/trunk/test/modify.cpp
Log:
Changed to not reporting failure because of expected ERROR
's.
Modified: cgm/trunk/test/modify.cpp
--- cgm/trunk/test/modify.cpp 2008-12-18 20:02:55 UTC (rev 2490)
+++ cgm/trunk/test/modify.cpp 2008-12-18 20:03:40 UTC (rev 2491)
@@ -79,10 +79,13 @@
PRINT_INFO("Operation Failed");
int ret_val = ( CubitMessage::instance()->error_count() );
- if ( ret_val > 0 )
+ if ( ret_val != 5 )
PRINT_ERROR("Errors found during Mergechk session.\n");
+ else
+ ret_val = 0;
return ret_val;
@@ -932,7 +935,7 @@
//d = 8.07227
//test sweep_along_curve function
- //sweep along a staight curve with draft
+ //sweep along a straight curve with draft
refentities.clean_out();
refentities.append(rotate_face);
CubitVector pt4(0,1,0);
More information about the cgma-dev
