[cgma-dev] r2490 - in cgm/trunk/geom: . OCC
janehu at mcs.anl.gov
Thu Dec 18 14:02:55 CST 2008
Author: janehu
Date: 2008-12-18 14:02:55 -0600 (Thu, 18 Dec 2008)
New Revision: 2490
Modified:
cgm/trunk/geom/GeometryModifyTool.cpp
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
restore the previous version of the code.
Modified: cgm/trunk/geom/GeometryModifyTool.cpp
--- cgm/trunk/geom/GeometryModifyTool.cpp 2008-12-18 18:19:12 UTC (rev 2489)
+++ cgm/trunk/geom/GeometryModifyTool.cpp 2008-12-18 20:02:55 UTC (rev 2490)
@@ -4559,7 +4559,7 @@
if ( result == CUBIT_FAILURE )
- PRINT_WARNING("Subtract FAILED\n" );
+ PRINT_ERROR("Subtract FAILED\n" );
return CUBIT_FAILURE;
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-12-18 18:19:12 UTC (rev 2489)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-12-18 20:02:55 UTC (rev 2490)
@@ -1,5 +1,5 @@
// Filename : OCCModifyEngine.cpp
@@ -194,7 +194,7 @@
OCCCurve* occ_curve = CAST_TO(curve_ptr, OCCCurve);
if (!occ_curve)
- PRINT_WARNING("Cannot create an OCC curve from the given curve.\n"
+ PRINT_ERROR("Cannot create an OCC curve from the given curve.\n"
"Possible incompatible geometry engines.\n");
return (Curve *)NULL;
@@ -242,7 +242,7 @@
else
- PRINT_WARNING("Cannot create an OCC curve from the given duplicated points.\n");
+ PRINT_ERROR("Cannot create an OCC curve from the given duplicated points.\n");
@@ -277,7 +277,7 @@
if (curve_type != SPLINE_CURVE_TYPE
&& curve_type != STRAIGHT_CURVE_TYPE)
- PRINT_WARNING("Cannot create an OCC curve from the given curve_type.\n"
+ PRINT_ERROR("Cannot create an OCC curve from the given curve_type.\n"
"Candidates are SPLINE_CURVE_TYPE and STRAIGHT_CURVE_TYPE.\n");
@@ -290,7 +290,7 @@
if (occ_point1 == NULL || occ_point2 == NULL)
- PRINT_WARNING("Cannot create an OCC curve from the given points.\n"
+ PRINT_ERROR("Cannot create an OCC curve from the given points.\n"
@@ -431,13 +431,13 @@
ellipse = ellipse2.Value();
else
- PRINT_WARNING("Can't create an ellipse from give 3 points.\n");
+ PRINT_ERROR("Can't create an ellipse from give 3 points.\n");
else
CubitBoolean use_sense = (sense == CUBIT_FORWARD ? CUBIT_TRUE : CUBIT_FALSE);
@@ -454,7 +454,7 @@
CubitVector width_vec = v2 - v1;
if(width_vec.length_squared() < tol * tol)
- PRINT_WARNING("Cannot create a parabola or hyperbola curve from the given points.\n"
+ PRINT_ERROR("Cannot create a parabola or hyperbola curve from the given points.\n"
"2 end points are the same.\n");
@@ -465,7 +465,7 @@
if (height_vec.length_squared() < tol * tol)
"3 points are in the same line.\n");
@@ -476,7 +476,7 @@
CubitVector N = x * (v2 - v1);
if (N.length_squared() < tol * tol)
@@ -525,7 +525,7 @@
else
- PRINT_WARNING("In OCCModifyEngine::make_Curve\n"
+ PRINT_ERROR("In OCCModifyEngine::make_Curve\n"
" Invalid curve type.\n");
@@ -555,7 +555,7 @@
OCCSurface* occ_surface = CAST_TO(surface_ptr, OCCSurface);
if (!occ_surface)
- PRINT_WARNING("Cannot create an OCC surface from the given surface.\n"
+ PRINT_ERROR("Cannot create an OCC surface from the given surface.\n"
return (Surface *)NULL;
@@ -568,7 +568,7 @@
TopoDS_Face *theFace = occ_surface->get_TopoDS_Face();
if( !theFace)
@@ -703,7 +703,7 @@
//check intscts point should be vertex or outside boundary.
if (intscts.size() > 2 )
- PRINT_WARNING("In OCCModifyEngine::make_Surface\n"
+ PRINT_ERROR("In OCCModifyEngine::make_Surface\n"
" Cannot make Surface with intersecting curves.\n");
@@ -723,7 +723,7 @@
else if(is_on == CUBIT_PNT_INSIDE)
@@ -735,7 +735,7 @@
if (count > curve_list.size())
@@ -758,7 +758,7 @@
if(!topo_face)
" Cannot make Surface object.\n");
@@ -812,7 +812,7 @@
if(occ_curve == NULL)
- PRINT_WARNING("In OCCModifyEngine::sort_curves\n"
+ PRINT_ERROR("In OCCModifyEngine::sort_curves\n"
" Got a NULL pointer to OCCCurve\n") ;
@@ -949,7 +949,7 @@
if (!made_face.IsDone())
- PRINT_WARNING("In OCCModifyEngine::make_TopoDS_Face\n"
+ PRINT_ERROR("In OCCModifyEngine::make_TopoDS_Face\n"
" Cannot find the best fit surface for given curves.\n");
return topo_face;
@@ -1013,7 +1013,7 @@
if(error)
return (TopoDS_Face*) NULL;
@@ -1039,14 +1039,14 @@
OCCSurface* occ_surface = CAST_TO(surface_list.get_and_step(), OCCSurface);
if (occ_surface == NULL)
- PRINT_WARNING("Cannot create an OCC lump from the given surfaces.\n"
+ PRINT_ERROR("Cannot create an OCC lump from the given surfaces.\n"
return (Lump *)NULL;
OCCBody* occ_body = occ_surface->my_body();
if(occ_body && occ_body->my_sheet_surface() == NULL)
"The surfaces are not free.\n");
@@ -1055,7 +1055,7 @@
OCCShell* shell = occ_surface->my_shell();
if(!shell)
- PRINT_WARNING("This is a bug, please report it. \n");
+ PRINT_ERROR("This is a bug, please report it. \n");
return (Lump*)NULL;
occ_body = shell->my_body();
@@ -1067,7 +1067,7 @@
CubitStatus stat = stitch_surfs(body_list, aShape);
if(!stat)
- PRINT_WARNING("The surfaces are not all connected, can't make a lump. \n");
+ PRINT_ERROR("The surfaces are not all connected, can't make a lump. \n");
return (Lump*)NULL;
@@ -1133,14 +1133,14 @@
aShell.Closed(CUBIT_TRUE);
else
- PRINT_WARNING("Surfaces must make a water-tight shape to make a lump.\n");
+ PRINT_ERROR("Surfaces must make a water-tight shape to make a lump.\n");
if(aShell.Closed())
BRepBuilderAPI_MakeSolid aMakeSolid(aShell);
if (!aMakeSolid.IsDone())
- PRINT_WARNING("Cannot create an OCC Lump from the given surfaces.\n"
+ PRINT_ERROR("Cannot create an OCC Lump from the given surfaces.\n"
"OCC internal error.\n");
@@ -1166,7 +1166,7 @@
OCCSurface* occ_surface = CAST_TO(surface, OCCSurface);
if(!occ_surface)
- PRINT_WARNING("Cannot create an OCC body from the given surface.\n"
+ PRINT_ERROR("Cannot create an OCC body from the given surface.\n"
return (BodySM *)NULL;
@@ -1208,7 +1208,7 @@
OCCLump* occ_lump = CAST_TO(lump, OCCLump);
if(!occ_lump)
- PRINT_WARNING("Cannot create an OCC BodySM from the given lumps.\n"
+ PRINT_ERROR("Cannot create an OCC BodySM from the given lumps.\n"
@@ -1315,7 +1315,7 @@
//currently OCC only support 4 sided prism
if (sides != 4)
- PRINT_WARNING("Option not supported for OCC based geometry.\n");
+ PRINT_ERROR("Option not supported for OCC based geometry.\n");
return (BodySM*) NULL;
@@ -1335,7 +1335,7 @@
//currently OCC only support 4 sided pyramid
if (sides != 4)
@@ -1413,7 +1413,7 @@
if (lump == NULL)
- PRINT_WARNING("In OCCModifyEngine::cylinder\n"
+ PRINT_ERROR("In OCCModifyEngine::cylinder\n"
" Cannot create a cylinder for given radii.\n");
return (BodySM*)NULL;
@@ -1443,7 +1443,7 @@
if (lump == NULL)
- PRINT_WARNING("In OCCModifyEngine::torus\n"
+ PRINT_ERROR("In OCCModifyEngine::torus\n"
" Cannot create a torus for given radii.\n");
@@ -1502,7 +1502,7 @@
OCCBody* occ_body = CAST_TO(bodyPtr, OCCBody);
if (!occ_body)
- PRINT_WARNING("Cannot create an OCC bodySM from the given bodySM.\n"
+ PRINT_ERROR("Cannot create an OCC bodySM from the given bodySM.\n"
@@ -1524,7 +1524,7 @@
Surface* surface = make_Surface(occ_body->my_sheet_surface());
if (surface == NULL)
- PRINT_WARNING("Cannot create an OCC sheet bodySM from the given bodySM.\n");
+ PRINT_ERROR("Cannot create an OCC sheet bodySM from the given bodySM.\n");
@@ -1623,7 +1623,7 @@
OCCShell* shell = occ_body->shell();
if (surface == NULL && shell == NULL)
- PRINT_WARNING("Can't stitch non-sheet bodySM's. \n");
+ PRINT_ERROR("Can't stitch non-sheet bodySM's. \n");
@@ -1699,7 +1699,7 @@
if ( count_shell != 1)
- PRINT_WARNING("Can't stitch all surfaces into one BodySM's. \n");
+ PRINT_ERROR("Can't stitch all surfaces into one BodySM's. \n");
return CUBIT_SUCCESS;
@@ -1799,7 +1799,7 @@
if (cmi->Interrupt())
- PRINT_WARNING("Subtraction interrupted. Aborting...\n");
+ PRINT_ERROR("Subtraction interrupted. Aborting...\n");
while (tool_boxes->size())
delete tool_boxes->pop();
delete tool_boxes;
@@ -1834,7 +1834,7 @@
stat = imprint_toposhapes(from_shape, tool_shape);
if(!stat)
- PRINT_WARNING("Can't do imprint operation on the body. \n");
+ PRINT_ERROR("Can't do imprint operation on the body. \n");
count++;
continue;
@@ -2408,7 +2408,7 @@
continue;
if ( shapes.Extent() > 1)
- PRINT_WARNING("Edge has multiple intersection with the shape, make it simpler. \n");
+ PRINT_ERROR("Edge has multiple intersection with the shape, make it simpler. \n");
continue;
if (shapes.First().TShape()->ShapeType() != TopAbs_EDGE)
@@ -2653,7 +2653,7 @@
DLIList<Lump*> lumps = occ_body->lumps();
if (lumps.size() > 1)
- PRINT_WARNING("Can't do boolean operation on CompSolid types. \n");
+ PRINT_ERROR("Can't do boolean operation on CompSolid types. \n");
stat = CUBIT_FAILURE;
break;
@@ -3244,7 +3244,7 @@
stat = OCCQueryEngine::instance()->delete_solid_model_entities( curve );
if (stat == CUBIT_FAILURE)
- PRINT_WARNING("In OCCQueryEngine::delete_geometry\n"
+ PRINT_ERROR("In OCCQueryEngine::delete_geometry\n"
" Could not delete OCCCurve.\n"
" The Model database is likely corrupted "
"due to\n this unsuccessful deletion.\n" );
@@ -3283,7 +3283,7 @@
if(surface->is_closed_in_U() || surface->is_closed_in_V())
if(print_error)
- PRINT_WARNING("This function can't project curves on closed surfaces.\n");
+ PRINT_ERROR("This function can't project curves on closed surfaces.\n");
@@ -3336,7 +3336,7 @@
- PRINT_WARNING("In OCCModifyEngine::delete_geometry\n"
+ PRINT_ERROR("In OCCModifyEngine::delete_geometry\n"
" Could not delete Curve.\n"
@@ -3653,7 +3653,7 @@
double depth,
CubitBoolean both) const
@@ -3674,7 +3674,7 @@
if(bodies.size() != 1 || surfs_to_remove.size() < 1)
- PRINT_WARNING("Making thick solid in OCC will take one body and at least one surface at a time.\n");
+ PRINT_ERROR("Making thick solid in OCC will take one body and at least one surface at a time.\n");
@@ -3687,7 +3687,7 @@
if(!is_volume.get())//sheet body
- PRINT_WARNING("Making thick solid in OCC needs an initial solid body to hollow with.\n");
+ PRINT_ERROR("Making thick solid in OCC needs an initial solid body to hollow with.\n");
@@ -3697,7 +3697,7 @@
if(lumps.size()!=1)
- PRINT_WARNING("bodies with more than one lump can't be hollowed to make a thick body.\n");
+ PRINT_ERROR("bodies with more than one lump can't be hollowed to make a thick body.\n");
@@ -3718,7 +3718,7 @@
if(face_shapes.IsEmpty())
- PRINT_WARNING("The surfaces provided should be from the body to be hollowed.\n");
+ PRINT_ERROR("The surfaces provided should be from the body to be hollowed.\n");
@@ -3961,7 +3961,7 @@
surf = make_Surface(BEST_FIT_SURFACE_TYPE, curves);
if(!surf)
- PRINT_WARNING("Can't calculate for the top surface.\n");
+ PRINT_ERROR("Can't calculate for the top surface.\n");
continue;
surface_list.append(surf);
@@ -3995,7 +3995,7 @@
curve = CAST_TO(c_curve, OCCCurve);
else
- PRINT_WARNING("Can't copy the curve for sweep.\n");
+ PRINT_ERROR("Can't copy the curve for sweep.\n");
@@ -4019,7 +4019,7 @@
c_surface = make_Surface(surface);
if (c_surface == NULL)
- PRINT_WARNING("Cannot copy surface in sweep_translational.\n");
+ PRINT_ERROR("Cannot copy surface in sweep_translational.\n");
surface = CAST_TO(c_surface, OCCSurface);
@@ -4042,7 +4042,7 @@
else if(normal % sweep_vector == 0)
- PRINT_WARNING("Sweeping direction should not be on the surface.\n");
+ PRINT_ERROR("Sweeping direction should not be on the surface.\n");
@@ -4120,7 +4120,7 @@
if(edge_list.size())
- PRINT_WARNING("Curves cannot be swept perpendicularly, please use the vector sweep.\n");
+ PRINT_ERROR("Curves cannot be swept perpendicularly, please use the vector sweep.\n");
@@ -4177,7 +4177,7 @@
intersect_pts, CUBIT_TRUE);
if(intersect_pts.size() > 0)
- PRINT_WARNING("Only surfaces with no intersection point with the axis can be revolve-swept.\n");
+ PRINT_ERROR("Only surfaces with no intersection point with the axis can be revolve-swept.\n");
continue;
@@ -4215,7 +4215,7 @@
prt.distance_between(end) > tol)
non_int = CUBIT_TRUE;
- PRINT_WARNING("Only curves with no intersection point with the axis can be revolve-swept.\n");
+ PRINT_ERROR("Only curves with no intersection point with the axis can be revolve-swept.\n");
break;
else if(prt.distance_between(start) <= tol)
@@ -4227,7 +4227,7 @@
continue;
if(start_int && end_int && type == STRAIGHT_CURVE_TYPE)
- PRINT_WARNING("Sweep along curve itself is not allowed.\n");
+ PRINT_ERROR("Sweep along curve itself is not allowed.\n");
continue;
@@ -4236,14 +4236,14 @@
continue;
else
- PRINT_WARNING("Only surface or curve can be revolve-swept.\n");
+ PRINT_ERROR("Only surface or curve can be revolve-swept.\n");
continue;
TopoDS_Shape new_shape;
@@ -4358,7 +4358,7 @@
if(L.IsEmpty())
- PRINT_WARNING("There's no valid sweeping path.\n");
+ PRINT_ERROR("There's no valid sweeping path.\n");
@@ -4413,7 +4413,7 @@
BRepOffsetAPI_MakePipe maker(wire, toposhape);
if(!maker.IsDone())
- PRINT_WARNING("Can't sweep along the provided curve(s).\n");
+ PRINT_ERROR("Can't sweep along the provided curve(s).\n");
continue;
TopoDS_Shape newShape = maker.Shape();
@@ -4445,7 +4445,7 @@
DLIList<BodySM*>& results_list,
bool imprint ) const
- PRINT_WARNING("Option not supported for mesh based geometry.\n");
+ PRINT_ERROR("Option not supported for mesh based geometry.\n");
@@ -4461,7 +4461,7 @@
DLIList<BodySM*>& /*results_list*/,
bool /*imprint*/ ) const
@@ -4478,7 +4478,7 @@
@@ -4494,7 +4494,7 @@
DLIList<BodySM*> & /*new_bodies*/,
bool /*imprint*/ )
@@ -4511,7 +4511,7 @@
int & /*num_cut*/,
bool /*imprint*/ )
@@ -4529,7 +4529,7 @@
bool imprint )
@@ -4548,7 +4548,7 @@
DLIList<BodySM*> &/*results_list*/,
bool /*imprint*/ )
@@ -4568,7 +4568,7 @@
bool /*imprint*/ )
@@ -4585,7 +4585,7 @@
bool /*imprint*/)
@@ -4607,7 +4607,7 @@
if (keep_both_sides == CUBIT_TRUE )
- PRINT_WARNING("keeping both sides of section is not implemented.\n");
+ PRINT_ERROR("keeping both sides of section is not implemented.\n");
@@ -4618,7 +4618,7 @@
normal = ~(v1 * v2);
if(normal.length() != 1)
- PRINT_WARNING("The three points are co-linear, and can't be used as a cutting plane.\n");
+ PRINT_ERROR("The three points are co-linear, and can't be used as a cutting plane.\n");
@@ -4690,7 +4690,7 @@
CubitStatus OCCModifyEngine::split_periodic( BodySM * /*body_ptr*/,
BodySM *& /*new_body*/ )
@@ -4704,7 +4704,7 @@
CubitStatus OCCModifyEngine::regularize_body( BodySM * /*body_ptr*/,
BodySM *& /*new_body_ptr*/ )
@@ -4718,7 +4718,7 @@
CubitStatus OCCModifyEngine::regularize_entity( GeometryEntity * /*old_entity_ptr*/,
@@ -4735,7 +4735,7 @@
const CubitVector& /*offset_direction*/,
int /*gap_type*/ )
@@ -4751,7 +4751,7 @@
const CubitVector& /*keep_vector*/,
bool )
return 0;
@@ -4817,7 +4817,7 @@
// Function : create_arc_three
// Member Type: PUBLIC
-// Description: arc or circle tangent to all three straight curves.
+// Description:
// Author : Jane Hu
// Date : 12/08
@@ -4826,6 +4826,7 @@
Curve* curve3,
bool full )
@@ -4849,7 +4850,7 @@
OCCModifyEngine::create_curve_combine( DLIList<Curve*>& curve_list,
Curve *&new_curve_ptr )
- PRINT_WARNING("Curve combine is not implemented for facet based models\n");
+ PRINT_ERROR("Curve combine is not implemented for facet based models\n");
@@ -4890,7 +4891,7 @@
double /*offset*/,
CubitBoolean /*ext_first*/ )
@@ -4907,7 +4908,7 @@
double /*offset*/,
CubitBoolean /*ext_surf*/ )
@@ -4923,7 +4924,7 @@
DLIList<Curve*> &/*inter_graph*/,
const double /*tol*/) const
@@ -4940,7 +4941,7 @@
BodySM * /*body_to_trim_to*/,
BodySM *& /*midplane_body*/ ) const
@@ -4949,7 +4950,7 @@
BodySM* body_to_trim_to,
BodySM*& midsurface_body ) const
@@ -4958,7 +4959,7 @@
@@ -4967,7 +4968,7 @@
@@ -4988,7 +4989,7 @@
CubitBoolean /*keep_old_body*/,
CubitBoolean /*preview*/ ) const
@@ -5015,7 +5016,7 @@
@@ -5033,7 +5034,7 @@
@@ -5053,7 +5054,7 @@
@@ -5072,7 +5073,7 @@
@@ -5089,7 +5090,7 @@
CubitBoolean /*keep_old_body*/ ,
CubitBoolean show_preview) const
@@ -5106,7 +5107,7 @@
CubitBoolean show_preview ) const
@@ -5124,7 +5125,7 @@
@@ -5142,7 +5143,7 @@
@@ -5161,7 +5162,7 @@
@@ -5178,7 +5179,7 @@
@@ -5197,7 +5198,7 @@
@@ -5216,7 +5217,7 @@
@@ -5236,14 +5237,14 @@
CubitStatus OCCModifyEngine::remove_curve_slivers( BodySM* /*body*/,
double /*lengthlimit*/ ) const
@@ -5259,7 +5260,7 @@
double /*net_tol*/,
CubitBoolean /*heal*/ ) const
- PRINT_WARNING("Function not implemented in this engine.\n");
+ PRINT_ERROR("Function not implemented in this engine.\n");
@@ -5274,7 +5275,7 @@
double /*net_tol*/,
@@ -5287,7 +5288,7 @@
BodySM*& /*new_body*/,
double /*offset_distance*/ ) const
@@ -5311,7 +5312,7 @@
CubitStatus OCCModifyEngine::create_skin_surface( DLIList<Curve*>& /*curves*/,
BodySM*& /*new_body*/ ) const
@@ -5331,7 +5332,7 @@
CubitBoolean /*perpendicular*/,
CubitBoolean /*simplify_option*/ ) const
@@ -5351,7 +5352,7 @@
@@ -5365,7 +5366,7 @@
Surface * /*ref_face_ptr*/,
CubitBoolean /*project_points*/ ) const
@@ -5381,7 +5382,7 @@
double /*leg2*/,
BodySM *& /*new_body*/ ) const
@@ -5398,7 +5399,7 @@
DLIList<BodySM*> &results_list,
CubitBoolean imprint)
@@ -5412,7 +5413,7 @@
@@ -5427,7 +5428,7 @@
@@ -5441,7 +5442,7 @@
@@ -5455,7 +5456,7 @@
DLIList<TopologyBridge*>*,
DLIList<TopologyBridge*>* ) const
More information about the cgma-dev
