[cgma-dev] r2486 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Wed Dec 17 12:32:29 CST 2008
Author: janehu
Date: 2008-12-17 12:32:28 -0600 (Wed, 17 Dec 2008)
New Revision: 2486
Modified:
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
cgm/trunk/geom/OCC/OCCQueryEngine.hpp
Log:
Added exporting function for exporting to iges or step format.
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-12-17 16:50:20 UTC (rev 2485)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-12-17 18:32:28 UTC (rev 2486)
@@ -37,6 +37,9 @@
#include "BRepAdaptor_Curve.hxx"
#include "STEPControl_Reader.hxx"
#include "IGESControl_Reader.hxx"
+#include "STEPControl_Writer.hxx"
+#include "IGESControl_Writer.hxx"
+#include "STEPControl_StepModelType.hxx"
#include "IFSelect_ReturnStatus.hxx"
#include "BndLib_Add3dCurve.hxx"
#include "Poly_Polygon3D.hxx"
@@ -854,7 +857,9 @@
const CubitString &,
const char*)
- if( strcmp( file_type, "OCC" ) != 0 )
+ if( strcmp( file_type, "OCC" ) != 0 &&
+ strcmp( file_type, "STEP") != 0 &&
+ strcmp( file_type, "IGES") != 0)
//PRINT_ERROR("The specified file type, %s, is not supported!\n", filetype );
return CUBIT_FAILURE;
@@ -919,7 +924,7 @@
CubitStatus status;
//write out topology and attributes
- status = write_topology( file_name,
+ status = write_topology( file_name, file_type,
OCC_bodies, OCC_surfaces,
OCC_curves, OCC_points );
if( status == CUBIT_FAILURE ) return CUBIT_FAILURE;
@@ -934,36 +939,36 @@
if( flg )PRINT_INFO( " " );else flg=1;
if( free_body_count == 1 )
- PRINT_INFO( "%4d OCC Body\n", free_body_count );
+ PRINT_INFO( "%4d OCC Body to %s\n", free_body_count, file_name );
else
- PRINT_INFO( "%4d OCC Bodies\n", free_body_count );
+ PRINT_INFO( "%4d OCC Bodies to %s\n", free_body_count, file_name );
if( free_surface_count )
if( free_surface_count == 1 )
- PRINT_INFO( "%4d OCC Surface\n", free_surface_count );
+ PRINT_INFO( "%4d OCC Surface to %s\n", free_surface_count, file_name );
else
if( free_curve_count )
if( free_curve_count == 1 )
- PRINT_INFO( "%4d OCC Curve\n", free_curve_count );
+ PRINT_INFO( "%4d OCC Curve to %s\n", free_curve_count, file_name );
else
- PRINT_INFO( "%4d OCC Curves\n", free_curve_count );
+ PRINT_INFO( "%4d OCC Curves to %s\n", free_curve_count, file_name );
if( free_point_count )
if( free_point_count == 1 )
- PRINT_INFO( "%4d OCC Point\n", free_point_count );
+ PRINT_INFO( "%4d OCC Point to %s\n", free_point_count, file_name );
else
- PRINT_INFO( "%4d OCC Points\n", free_point_count );
+ PRINT_INFO( "%4d OCC Points to %s\n", free_point_count, file_name );
PRINT_INFO( "\n" );
@@ -980,6 +985,7 @@
CubitStatus
OCCQueryEngine::write_topology( const char* file_name,
+ const char* file_type,
DLIList<OCCBody*> &OCC_bodies,
DLIList<OCCSurface*> &OCC_surfaces,
DLIList<OCCCurve*> &OCC_curves,
@@ -1058,14 +1064,41 @@
B.Add(Co, *vertex);
- TDF_Label label;
- if(EXPORT_ATTRIB)
- label = mainLabel;
+ if(strcmp(file_type, "OCC") == 0)
+ TDF_Label label;
+ if(EXPORT_ATTRIB)
+ label = mainLabel;
- if(!Write(Co, const_cast<char*>(file_name),label))
- //if(!BRepTools::Write(Co, const_cast<char*>(file_name)))
- return CUBIT_FAILURE;
+ if(!Write(Co, const_cast<char*>(file_name),label))
+ return CUBIT_FAILURE;
+ else if(strcmp(file_type, "STEP") == 0)
+ STEPControl_Writer writer;
+ writer.Model( Standard_True);
+ writer.Transfer(Co, STEPControl_AsIs );
+ IFSelect_ReturnStatus stat = writer.Write( (char*) file_name);
+ if (stat != IFSelect_RetDone)
+ PRINT_INFO("%s: Cannot open file", file_name );
+ else // IGES file
+ IGESControl_Writer writer;
+ writer.AddShape(Co);
+ writer.ComputeModel();
+ Standard_Boolean stat = writer.Write( (char*) file_name);
+ if (!stat )
return CUBIT_SUCCESS;
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.hpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.hpp 2008-12-17 16:50:20 UTC (rev 2485)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.hpp 2008-12-17 18:32:28 UTC (rev 2486)
@@ -381,6 +381,7 @@
CubitBoolean standalone = CUBIT_FALSE);
CubitStatus write_topology( const char* file_name,
DLIList<OCCBody*> &facet_bodies,
DLIList<OCCSurface*> &facet_surfaces,
DLIList<OCCCurve*> &facet_curves,
More information about the cgma-dev
