[cgma-dev] r2298 - cgm/trunk/geom
tautges at mcs.anl.gov tautges at mcs.anl.gov
Tue Dec 2 18:21:55 CST 2008
Author: tautges
Date: 2008-12-02 18:21:53 -0600 (Tue, 02 Dec 2008)
New Revision: 2298
Modified:
   cgm/trunk/geom/CGMApp.cpp
   cgm/trunk/geom/CGMApp.hpp
Log:
Fixing CGMApp::delete_instance to set instance to NULL after
deleting it, also removing assignment of member variable after
delete_instance is called from shutdown, since then there won't be any member
variables.
Avoids shutdown-time segfault in testgeom_occ.
Jane, run valgrind on testgeom_occ, there's still a memory access
error in one of the booleans, it just doesn't happen to kill the
code.
Modified: cgm/trunk/geom/CGMApp.cpp
--- cgm/trunk/geom/CGMApp.cpp	2008-12-02 20:14:10 UTC (rev 2297)
+++ cgm/trunk/geom/CGMApp.cpp	2008-12-03 00:21:53 UTC (rev 2298)
@@ -96,7 +96,10 @@
    delete GeometryModifyTool::instance();
    delete GeometryQueryTool::instance();
-mAppStarted = CUBIT_FALSE;
+   CGMApp::delete_instance();
+   AppUtil::instance()->shutdown();
+   AppUtil::delete_instance();
 void CGMApp::initialize_settings()
Modified: cgm/trunk/geom/CGMApp.hpp
--- cgm/trunk/geom/CGMApp.hpp	2008-12-02 20:14:10 UTC (rev 2297)
+++ cgm/trunk/geom/CGMApp.hpp	2008-12-03 00:21:53 UTC (rev 2298)
@@ -47,7 +47,7 @@
    static CGMApp* instance();
      //- Access to the application object
-  static void delete_instance() {if (instance_) delete instance_;};
+   static void delete_instance() {if (instance_) {delete instance_; instance_ = NULL;}};
    ~CGMApp();
More information about the cgma-dev mailing list
