[cgma-dev] r2297 - cgm/trunk/test
janehu at mcs.anl.gov
Tue Dec 2 14:14:10 CST 2008
Author: janehu
Date: 2008-12-02 14:14:10 -0600 (Tue, 02 Dec 2008)
New Revision: 2297
Modified:
cgm/trunk/test/makept.cpp
Log:
Changes to fix the nightly test problem. will continue to test on make_Body function to make sure that remove zero length TopoDS_Edge from creating OCCCurve works correctly.
Modified: cgm/trunk/test/makept.cpp
--- cgm/trunk/test/makept.cpp 2008-12-02 20:11:41 UTC (rev 2296)
+++ cgm/trunk/test/makept.cpp 2008-12-02 20:14:10 UTC (rev 2297)
@@ -135,6 +135,15 @@
objOCC = ( (OCCBody*) tmpBdSM )->get_TopoDS_Shape(); //Opencascade Object
OCCDrawTool::instance()->draw_TopoDS_Shape(objOCC, 200);
+ DLIList<Body*> bodies;
+ DLIList<RefEntity*> free_entities;
+ gti->bodies(bodies);
+ //delete all entities
+ gti->delete_Body(bodies);
+ gti->get_free_ref_entities(free_entities);
+ assert(free_entities.size() == 0);
// Read in the geometry from files specified on the command line
const char *argv = "66_shaver3.brep";
CubitStatus status = read_geometry(1, &argv);
@@ -173,7 +182,7 @@
CubitVector vector1(10,10,10);
CubitVector vector2(-10,-10,10);
CubitVector vector3(10, -10, 10);
- DLIList<RefEntity*> free_entities;
+ free_entities.clean_out();
// Make two vertices.
gmti->make_RefVertex(vector1,5);
@@ -192,7 +201,7 @@
num_ents_exported, cubit_version);
//check for vertex
- DLIList<Body*> bodies;
+ bodies.clean_out();
free_entities.clean_out();// get_free_ref_entities directly append
//without checking for duplicates, so clean_out first.
@@ -413,6 +422,7 @@
RefEdge* new_edge_4 = gmti->make_RefEdge(ELLIPSE_CURVE_TYPE, vertex1,
vertex3, ¢er_pnt);
d = new_edge_4->measure();
+ //d = 22.21
new_edge_4->closest_point_trimmed(vi, c_point);
RefEdge* new_edge_5 = gmti->make_RefEdge(ELLIPSE_CURVE_TYPE, vertex1,
More information about the cgma-dev
