[cgma-dev] r1777 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Thu Apr 24 14:55:06 CDT 2008
Author: janehu
Date: 2008-04-24 14:55:06 -0500 (Thu, 24 Apr 2008)
New Revision: 1777
Modified:
cgm/trunk/geom/OCC/OCCBody.hpp
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
bug fixed in unite surfaces or build solid out of surfaces, after it's done, there are still some free ref_edges and refvertices left, debugging on it.
Modified: cgm/trunk/geom/OCC/OCCBody.hpp
--- cgm/trunk/geom/OCC/OCCBody.hpp 2008-04-24 18:08:03 UTC (rev 1776)
+++ cgm/trunk/geom/OCC/OCCBody.hpp 2008-04-24 19:55:06 UTC (rev 1777)
@@ -182,6 +182,8 @@
return (OCCSurface*) NULL;}
void set_sheet_surface(OCCSurface* surface);
+ virtual CubitBoolean is_sheet_body(){return IsSheetBody;}
protected:
private:
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-04-24 18:08:03 UTC (rev 1776)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-04-24 19:55:06 UTC (rev 1777)
@@ -1515,6 +1515,7 @@
DLIList<BodySM*>& surf_bodies,
BodySM*& new_body) const
+ new_body = NULL;
if (surf_bodies.size()==0)
return CUBIT_SUCCESS;
@@ -1563,64 +1564,77 @@
if (surf_bodies.size() < 2)
- DLIList<TopoDS_Face*> faces_to_stitch;
- DLIList<OCCSurface*> surfaces;
+ DLIList<TopoDS_Shape*> faces_to_stitch;
for (int i = 0; i < surf_bodies.size(); i++)
BodySM * tool_body = surf_bodies.get_and_step();
OCCBody* occ_body = CAST_TO(tool_body, OCCBody);
OCCSurface* surface = occ_body->my_sheet_surface();
OCCShell* shell = occ_body->shell();
- if (surface == NULL)
+ if (surface == NULL && shell == NULL)
PRINT_ERROR("Can't stitch non-sheet bodySM's. \n");
return CUBIT_FAILURE;
- surfaces.append(surface);
delete occ_body;
- delete surface->my_shell();
- delete surface->my_lump();
- surface->set_shell(NULL);
- surface->set_lump(NULL);
- surface->set_body(NULL);
- TopoDS_Face* topods_face = surface->get_TopoDS_Face();
- if (topods_face != NULL)
- faces_to_stitch.append(topods_face);
+ if (surface)
+ delete surface->my_shell();
+ delete surface->my_lump();
+ surface->set_shell(NULL);
+ surface->set_lump(NULL);
+ surface->set_body(NULL);
+ TopoDS_Face* topods_face = surface->get_TopoDS_Face();
+ if (topods_face != NULL)
+ faces_to_stitch.append(topods_face);
+ else
+ delete shell->my_lump();
+ shell->set_body(NULL);
+ shell->set_lump(NULL);
+ TopoDS_Shell* topods_shell = shell->get_TopoDS_Shell();
+ if(topods_shell)
+ faces_to_stitch.append(topods_shell);
faces_to_stitch.reset();
surf_bodies.reset();
TopoDS_Shape* first_face = faces_to_stitch.pop();
- TopoDS_Face* second_face = NULL;
+ TopoDS_Shape* second_face = NULL;
for( int i = faces_to_stitch.size()-1; i >= 0; i --)
second_face = faces_to_stitch[i];
BRepAlgoAPI_Fuse fuser(*second_face, *first_face);
- OCCSurface* surface = surfaces[i];
- surface->update_OCC_entity(NULL, &fuser);
TopoDS_Shape new_shape ;
- TopTools_IndexedMapOfShape M;
- TopExp::MapShapes(*first_face, TopAbs_FACE, M);
- for(int ii=1; ii<=M.Extent(); ii++)
+ for(int j = 0; j < 2; j++)
- TopoDS_Face face = TopoDS::Face(M(ii));
- TopTools_ListOfShape shapes;
- shapes.Assign(fuser.Modified(face));
- if (shapes.Extent() > 0)
- new_shape = shapes.First();
- OCCSurface::update_OCC_entity(face, TopoDS::Face(new_shape), &fuser);
+ TopTools_IndexedMapOfShape M;
+ if(j == 0)
+ TopExp::MapShapes(*second_face, TopAbs_FACE, M);
+ else
+ TopExp::MapShapes(*first_face, TopAbs_FACE, M);
+ for(int ii=1; ii<=M.Extent(); ii++)
+ TopoDS_Face face = TopoDS::Face(M(ii));
+ TopTools_ListOfShape shapes;
+ shapes.Assign(fuser.Modified(face));
+ if (shapes.Extent() > 0)
+ new_shape = shapes.First();
+ OCCSurface::update_OCC_entity(face, TopoDS::Face(new_shape), &fuser);
+ //else
+ // OCCSurface::update_OCC_entity(face, face, &fuser);
- else
- OCCSurface::update_OCC_entity(face, face, &fuser);
fuse = fuser.Shape();
- TopExp_Explorer Ex_edge;
- TopoDS_Edge edge;
- for (Ex_edge.Init(fuse,TopAbs_EDGE); Ex_edge.More(); Ex_edge.Next())
- edge = TopoDS::Edge(Ex_edge.Current());
first_face = &fuse;
@@ -2355,11 +2369,6 @@
CubitStatus success = CUBIT_SUCCESS;
OCCBody* occ_body = NULL;
DLIList<TopoDS_Shape*> shape_list;
- // pass in keep_old to the delete_owner_attrib flag; if we're not keeping
- // old bodies, we want to keep the owner attrib, so we can pick up entities
- // that didn't change
- bool delete_attribs =
- (GeometryModifyTool::instance()->get_new_ids() || keep_old);
for(int i = 0; i <from_body_list.size(); i++)
@@ -3037,43 +3046,11 @@
//keep_old and heal are ignored, always delete old.
//all surfaces should be stand along surface bodies or shell bodies' surface
- DLIList<BodySM*> body_list;
- for(int i = 0; i < ref_face_list.size(); i++)
- OCCSurface* occ_surface = CAST_TO(ref_face_list.get_and_step(), OCCSurface);
- if (occ_surface == NULL)
- PRINT_ERROR("Cannot create an OCC lump from the given surfaces.\n"
- "Possible incompatible geometry engines.\n");
- return CUBIT_FAILURE;
- OCCBody* occ_body = occ_surface->my_body();
- if(occ_body && occ_body->my_sheet_surface() == NULL)
- "The surfaces are not free.\n");
- else if(!occ_body)
- OCCShell* shell = occ_surface->my_shell();
- if(!shell)
- PRINT_ERROR("This is a bug, please report it. \n");
- occ_body = shell->my_body();
- body_list.append_unique(occ_body);
- BodySM* new_body = NULL;
- CubitStatus stat = stitch_surfs(body_list,new_body);
- if (!new_body)
- new_bodies = body_list;
- else
- new_bodies.append(new_body);
+ Lump* lump = make_Lump(ref_face_list);
+ if (!lump)
+ return CUBIT_FAILURE;
+ new_bodies.append(CAST_TO(lump, OCCLump)->get_body());
More information about the cgma-dev
