[cgma-dev] r1773 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov janehu at mcs.anl.gov
Tue Apr 22 14:30:00 CDT 2008
Author: janehu
Date: 2008-04-22 14:30:00 -0500 (Tue, 22 Apr 2008)
New Revision: 1773
Modified:
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
   cgm/trunk/geom/OCC/OCCQueryEngine.cpp
   cgm/trunk/geom/OCC/OCCQueryEngine.hpp
Log:
worked on interface of stitch_surf into a shell body or into a solid body.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-04-21 19:49:42 UTC (rev 1772)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-04-22 19:30:00 UTC (rev 1773)
@@ -1016,7 +1016,7 @@
   if (surface_list.size() < 2)
     return (Lump*) NULL;
-  //all surfaces should be stand along surface bodies
+  //all surfaces should be stand along surface bodies or shell bodies' surface
   DLIList<BodySM*> body_list;
   for(int i = 0; i < surface_list.size(); i++)
@@ -1028,18 +1028,33 @@
        return (Lump *)NULL;
     OCCBody* occ_body = occ_surface->my_body();
-    if(occ_body->my_sheet_surface() == NULL)
+    if(occ_body && occ_body->my_sheet_surface() == NULL)
       PRINT_ERROR("Cannot create an OCC lump from the given surfaces.\n"
                  "The surfaces are not free.\n");
-       return (Lump *)NULL;
+      return (Lump *)NULL;
-    body_list.append(occ_body);
+    else if(!occ_body)
+      OCCShell* shell = occ_surface->my_shell();
+      if(!shell)
+        PRINT_ERROR("This is a bug, please report it. \n");
+        return (Lump*)NULL;
+      occ_body = shell->my_body();
+    body_list.append_unique(occ_body);
   TopoDS_Shape aShape;
   CubitStatus stat = stitch_surfs(body_list, aShape);
+  if(!stat)
+    PRINT_ERROR("The surfaces are not all connected, can't make a lump. \n");
   TopExp_Explorer Ex, Ex2;
   TopoDS_Shell aShell ;
   for (Ex.Init(aShape, TopAbs_SHELL, TopAbs_SOLID); Ex.More()&& stat; Ex.Next())
@@ -1052,7 +1067,7 @@
     TopoDS_Edge edge1 = TopoDS::Edge(Ex.Current());
     num_edges++;
-    for (Ex2.Init(aShell, TopAbs_EDGE); Ex2.More()&& stat; Ex2.Next())
+    for (Ex2.Init(aShell, TopAbs_EDGE); Ex2.More(); Ex2.Next())
       TopoDS_Edge edge2 = TopoDS::Edge(Ex2.Current());
       if (!edge1.IsEqual(edge2)&& edge1.IsSame(edge2))
@@ -1080,9 +1095,6 @@
     TopoDS_Solid aSolid = aMakeSolid.Solid();
-    int num_edge = 0;
-    for (Ex.Init(aSolid, TopAbs_EDGE); Ex.More()&& stat; Ex.Next())
-      num_edge++;
     return
       OCCQueryEngine::instance()->populate_topology_bridge(aSolid, CUBIT_TRUE);
@@ -1163,26 +1175,10 @@
      TopoDS_Solid* solid = occ_lump->get_TopoDS_Solid();
      B.Add(CS, *solid);
-     BodySM* bodysm_ptr = occ_lump->get_body();
-     if(bodysm_ptr == NULL)
-          continue;
-     bodysm_list.append_unique(bodysm_ptr);
   BodySM* bodysm = OCCQueryEngine::instance()->populate_topology_bridge(CS);
-  if(bodysm)
-     //remove each Lump's body from the BodyList
-     for(int i = 0; i < bodysm_list.size(); i++)
-        BodySM* bodysm_ptr = bodysm_list.get_and_step();
-        OCCQueryEngine::instance()->unhook_BodySM_from_OCC(bodysm_ptr);
   return bodysm;
@@ -1517,34 +1513,36 @@
 CubitStatus OCCModifyEngine::stitch_surfs(
                       DLIList<BodySM*>& surf_bodies,
-                      BodySM*& stitched_body) const
+                      BodySM*& new_body) const
-  stitched_body = NULL;
   if (surf_bodies.size()==0)
     return CUBIT_SUCCESS;
   if (surf_bodies.size()==1)
-    stitched_body = surf_bodies.get();
+    new_body = surf_bodies.get();
   TopoDS_Shape fuse;
   CubitStatus stat =  stitch_surfs(surf_bodies, fuse);
-  if (stat == CUBIT_FAILURE)
-    return stat;
   DLIList<TopologyBridge*> tbs = OCCQueryEngine::instance()->
      populate_topology_bridge(fuse);
-  OCCBody* body = CAST_TO(tbs.get(), OCCBody);
-  if (body)
-    stitched_body = body ;
+  if (stat)
+    OCCBody* body = CAST_TO(tbs.get(), OCCBody);
+    if (body)
+      new_body = body ;
   else
-    OCCSurface* face = CAST_TO(tbs.get(), OCCSurface);
-    if(face)
-      stitched_body = face->my_body();
+    surf_bodies.clean_out();
+    for(int i= 0; i<tbs.size(); i++)
+      surf_bodies.append(CAST_TO(tbs.get_and_step(), OCCBody));
@@ -1566,16 +1564,26 @@
   DLIList<TopoDS_Face*> faces_to_stitch;
+  DLIList<OCCSurface*> surfaces;
   for (int i = 0; i < surf_bodies.size(); i++)
      BodySM * tool_body = surf_bodies.get_and_step();
      OCCBody* occ_body = CAST_TO(tool_body, OCCBody);
      OCCSurface* surface = occ_body->my_sheet_surface();
+     OCCShell* shell = occ_body->shell();
      if (surface == NULL)
        PRINT_ERROR("Can't stitch non-sheet bodySM's. \n");
        return CUBIT_FAILURE;
+     surfaces.append(surface);
+     delete occ_body;
+     delete surface->my_shell();
+     delete surface->my_lump();
+     surface->set_shell(NULL);
+     surface->set_lump(NULL);
+     surface->set_body(NULL);
      TopoDS_Face* topods_face = surface->get_TopoDS_Face();
      if (topods_face != NULL)
        faces_to_stitch.append(topods_face);
@@ -1590,8 +1598,8 @@
      second_face = faces_to_stitch[i];
      BRepAlgoAPI_Fuse fuser(*second_face, *first_face);
-     OCCBody* occ_body = CAST_TO(surf_bodies[i], OCCBody);
-     occ_body->my_sheet_surface()->update_OCC_entity(NULL, &fuser);
+     OCCSurface* surface = surfaces[i];
+     surface->update_OCC_entity(NULL, &fuser);
      TopoDS_Shape new_shape ;
      TopTools_IndexedMapOfShape M;
      TopExp::MapShapes(*first_face, TopAbs_FACE, M);
@@ -3018,15 +3026,54 @@
 // Function   : create_body_from_surfs
 // Member Type: PUBLIC
-// Description:
-// Author     : Steve Owen
-// Date       : 9/11/03
+// Description:
+// Author     : Jane Hu
+// Date       : 4/22/08
 CubitStatus OCCModifyEngine::create_solid_bodies_from_surfs(DLIList<Surface*> & ref_face_list,
                                           DLIList<BodySM*>& new_bodies,
                                           bool keep_old,
                                           bool heal) const
+  //keep_old and heal are ignored, always delete old.
+  DLIList<BodySM*> body_list;
+  for(int i = 0; i < ref_face_list.size(); i++)
+    OCCSurface* occ_surface = CAST_TO(ref_face_list.get_and_step(), OCCSurface);
+    if (occ_surface == NULL)
+       PRINT_ERROR("Cannot create an OCC lump from the given surfaces.\n"
+                 "Possible incompatible geometry engines.\n");
+       return CUBIT_FAILURE;
+    OCCBody* occ_body = occ_surface->my_body();
+                 "The surfaces are not free.\n");
+      if(!shell)
+  BodySM* new_body = NULL;
+  CubitStatus stat = stitch_surfs(body_list,new_body);
+  if (!new_body)
+    new_bodies = body_list;
+  else
+    new_bodies.append(new_body);
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2008-04-21 19:49:42 UTC (rev 1772)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2008-04-22 19:30:00 UTC (rev 1773)
@@ -1404,7 +1404,11 @@
       if (remove_lower_entities)
         return ( this->delete_solid_model_entities(ref_face_ptr) );
-      return ( this->unhook_Surface_from_OCC(ref_face_ptr));
+      TopoDS_Face *face = NULL;
+      CubitStatus stat = this->unhook_Surface_from_OCC(ref_face_ptr, face);
+      if(stat)
+        delete face;
+      return stat;
      // Curve
@@ -1413,7 +1417,11 @@
         return ( this->delete_solid_model_entities(ref_edge_ptr));
-      return ( this->unhook_Curve_from_OCC(ref_edge_ptr));
+      TopoDS_Edge *edge = NULL;
+      CubitStatus stat = this->unhook_Curve_from_OCC(ref_edge_ptr, edge);
+      if(stat)
+        delete edge;
+      return stat;
      // Point
@@ -1460,30 +1468,66 @@
     delete occ_shell->my_body();
     delete occ_shell->my_lump();
-    return unhook_ShellSM_from_OCC(occ_shell);
+    TopoDS_Shell* Shell;
+    CubitStatus stat = unhook_ShellSM_from_OCC(occ_shell,Shell);
+    DLIList<TopologyBridge*> tb_surfaces;
+    occ_shell->get_children_virt(tb_surfaces);
+    for(int k = 0; k < tb_surfaces.size(); k++)
+      delete_solid_model_entities(CAST_TO(tb_surfaces.get_and_step(), Surface));
+    if(Shell)
+      delete Shell;
+    return stat;
+  TopoDS_Shape* shape = NULL;
+  CubitStatus stat = unhook_BodySM_from_OCC(bodysm, shape);
+  DLIList<TopologyBridge*> children;
   DLIList<Lump*> lumps = occ_body->lumps();
+  DLIList<TopoDS_Shell*> Shell_list;
   for(int i =0; i < lumps.size(); i++)
      Lump* lump = lumps.get_and_step();
      OCCLump* occ_lump = CAST_TO(lump, OCCLump);
-     if (occ_lump)
-       occ_lump->remove_body();
-     unhook_Lump_from_OCC(lump);
+     if (!occ_lump)
+        continue;
+     children.clean_out();
+     occ_lump->get_children_virt(children);
+     for(int j = 0; j < children.size(); j++)
+       ShellSM* shell = CAST_TO(children.get_and_step(), ShellSM);
+       TopoDS_Shell* Shell = CAST_TO(shell, OCCShell)->get_TopoDS_Shell();
+       if (Shell)
+         Shell_list.append(Shell);
+       shell->get_children_virt(tb_surfaces);
+     for(int j = 0; j < Shell_list.size(); j++)
+       delete Shell_list.pop();
+     TopoDS_Solid* solid = occ_lump->get_TopoDS_Solid();
+     delete solid;
-  return unhook_BodySM_from_OCC(bodysm);
+  if(shape)
+    delete shape;
+  return stat;
 CubitStatus
-OCCQueryEngine::unhook_BodySM_from_OCC( BodySM* bodysm)const
+OCCQueryEngine::unhook_BodySM_from_OCC( BodySM* bodysm,
+                                        TopoDS_Shape*& shape)const
   OCCBody* occ_body = dynamic_cast<OCCBody*>(bodysm);
   if (!occ_body)
-  TopoDS_Shape* shape = occ_body->get_TopoDS_Shape();
+  shape = occ_body->get_TopoDS_Shape();
   if (!shape)
@@ -1503,15 +1547,25 @@
       if(!OccToCGM->erase(k))
         PRINT_ERROR("The OccBody and TopoDS_Shape pair is not in the map!");
-  DLIList<Lump*> lumps;
-  occ_body->lumps(lumps);
   if (occ_body_find)
      BodyList->remove(occ_body_find);
   else
      BodyList->remove(occ_body);
-  //delete shape;
-  delete shape;
+  DLIList<Lump*> lumps = occ_body->lumps();
+  for(int i =0; i < lumps.size(); i++)
+     Lump* lump = lumps.get_and_step();
+     OCCLump* occ_lump = CAST_TO(lump, OCCLump);
+     if (occ_lump)
+       occ_lump->remove_body();
+     TopoDS_Solid* solid;
+     unhook_Lump_from_OCC(lump, solid);
   delete bodysm;
+  return CUBIT_SUCCESS;
@@ -1524,7 +1578,7 @@
 // Creation Date : 11/29/07
 CubitStatus
-OCCQueryEngine::unhook_Lump_from_OCC( Lump* lump ) const
+OCCQueryEngine::unhook_Lump_from_OCC( Lump* lump, TopoDS_Solid*& solid ) const
   if (lump == NULL)
@@ -1533,7 +1587,7 @@
   if (!occ_lump)
-  TopoDS_Solid* solid = occ_lump->get_TopoDS_Solid();
+  solid = occ_lump->get_TopoDS_Solid();
   if(!solid)
@@ -1556,11 +1610,11 @@
   for(int i = 0; i < children.size(); i++)
-     unhook_ShellSM_from_OCC(shell);
+     unhook_ShellSM_from_OCC(shell,Shell);
   if (occ_lump->get_body() != NULL)
     BodyList->remove(CAST_TO(occ_lump->get_body(), OCCBody));
-  delete solid;
   delete lump;
@@ -1575,13 +1629,14 @@
 // Creation Date : 12/12/07
 CubitStatus
-OCCQueryEngine::unhook_ShellSM_from_OCC( ShellSM* shell ) const
+OCCQueryEngine::unhook_ShellSM_from_OCC( ShellSM* shell,
+                                         TopoDS_Shell*& Shell  ) const
   OCCShell* occ_shell = dynamic_cast<OCCShell*>(shell);
   if (!occ_shell)
-  TopoDS_Shell* Shell = occ_shell->get_TopoDS_Shell();
+  Shell = occ_shell->get_TopoDS_Shell();
   if(!Shell)
@@ -1599,14 +1654,6 @@
         PRINT_ERROR("The OccSurface and TopoDS_Face pair is not in the map!");
-  DLIList<TopologyBridge*> children;
-  occ_shell->get_children_virt(children);
-  for(int i = 0; i < children.size(); i++)
-     Surface* surface = CAST_TO(children.get_and_step(), Surface);
-     delete_solid_model_entities(surface);
-  delete Shell;
   delete shell;
@@ -1634,9 +1681,11 @@
      LoopSM* loop = CAST_TO(children.get_and_step(), LoopSM);
      delete_loop(loop);
-  return unhook_Surface_from_OCC(surface);
+  TopoDS_Face* face;
+  CubitStatus stat = unhook_Surface_from_OCC(surface, face);
+  if (stat)
+    delete face;
+  return stat;
@@ -1649,13 +1698,14 @@
 CubitStatus
-OCCQueryEngine::unhook_Surface_from_OCC( Surface* surface ) const
+OCCQueryEngine::unhook_Surface_from_OCC( Surface* surface,
+                                         TopoDS_Face*& face ) const
   OCCSurface* fsurf = dynamic_cast<OCCSurface*>(surface);
   if (!fsurf)
-  TopoDS_Face* face = fsurf->get_TopoDS_Face();
+  face = fsurf->get_TopoDS_Face();
   if(!face)
@@ -1675,7 +1725,6 @@
         PRINT_WARNING("The OccSurface and TopoDS_Face pair is not in the map!");
-  delete face;
   delete surface;
@@ -1707,17 +1756,60 @@
      if (occ_curve == NULL)
 	continue;
+     delete_solid_model_entities(curve);
+  TopoDS_Wire* wire;
+  CubitStatus status = unhook_LoopSM_from_OCC(loopsm, wire);
+  if (status)
+    delete wire;
+  return status;
+// Purpose       : unhook a LoopSM from its underlining OCC entity.
+// Special Notes :
+// Creator       : Jane Hu
+// Creation Date : 12/12/07
+CubitStatus
+OCCQueryEngine::unhook_LoopSM_from_OCC( LoopSM* loopsm,
+                                        TopoDS_Wire*& wire ) const
+  OCCLoop* occ_loop = dynamic_cast<OCCLoop*>(loopsm);
+  if (!occ_loop)
+  wire = occ_loop->get_TopoDS_Wire();
+  if(!wire)
+  DLIList<OCCCoEdge*> children;
+  children = occ_loop->coedges();
+  int size = children.size();
+  while(size > 0)
+     OCCCoEdge* coedge = children.pop();
+     Curve* curve = coedge->curve();
+     OCCCurve *occ_curve = CAST_TO(curve, OCCCurve);
+     if (occ_curve == NULL)
+        continue;
      DLIList<OCCLoop*> loops;
      //remove all coedges corresponding to this curve from their loops.
      loops =  occ_curve->loops();
      for(int j = 0; j < loops.size(); j++)
        OCCLoop* occ_loop = loops.get_and_step();
-       OCCCoEdge* found_coedge = occ_loop->remove_coedge(coedge);
+       OCCCoEdge* found_coedge = occ_loop->remove_coedge(coedge);
        if (found_coedge)
-	 delete found_coedge;
+         delete found_coedge;
        //there might be 2 coedges in the same loop that uses the same curve
        //as in a scar curve situation
@@ -1727,40 +1819,15 @@
          found_coedge = coedges.get_and_step();
          if (CAST_TO(found_coedge->curve(), OCCCurve) == occ_curve)
-           occ_loop->remove_coedge(found_coedge);
+           occ_loop->remove_coedge(found_coedge);
            children.remove(found_coedge);
-     delete_solid_model_entities(curve);
-  return unhook_LoopSM_from_OCC(loopsm);
-// Purpose       : unhook a LoopSM from its underlining OCC entity.
-// Special Notes :
-// Creator       : Jane Hu
-// Creation Date : 12/12/07
-CubitStatus
-OCCQueryEngine::unhook_LoopSM_from_OCC( LoopSM* loopsm ) const
-  OCCLoop* occ_loop = dynamic_cast<OCCLoop*>(loopsm);
-  if (!occ_loop)
-    return CUBIT_FAILURE;
-  TopoDS_Wire* wire = occ_loop->get_TopoDS_Wire();
-  if(!wire)
   //remove the entry from the map
   int k;
   if(OCCMap->IsBound(*wire))
@@ -1775,7 +1842,6 @@
   WireList->remove(CAST_TO(loopsm, OCCLoop));
-  delete wire;
   delete loopsm;
@@ -1803,8 +1869,12 @@
      Point* point = CAST_TO(children.get_and_step(), Point);
      delete_solid_model_entities(point);
-  return unhook_Curve_from_OCC(curve);
+  TopoDS_Edge* edge;
+  CubitStatus stat = unhook_Curve_from_OCC(curve, edge);
+  if (stat)
+    delete edge;
+  return stat;
@@ -1817,14 +1887,14 @@
 CubitStatus
-OCCQueryEngine::unhook_Curve_from_OCC( Curve* curve ) const
+OCCQueryEngine::unhook_Curve_from_OCC( Curve* curve, TopoDS_Edge*& edge ) const
   OCCCurve* fcurve = dynamic_cast<OCCCurve*>(curve);
   if (!fcurve )
   fcurve->clean_loops();
-  TopoDS_Edge * edge = fcurve->get_TopoDS_Edge();
+  edge = fcurve->get_TopoDS_Edge();
   if (!edge)
@@ -1841,7 +1911,6 @@
         PRINT_WARNING("The OccCurve and TopoDS_Edge pair is not in the map!");
-  delete edge;
   delete curve;
@@ -1861,8 +1930,11 @@
   if (!fpoint)
-  return unhook_Point_from_OCC(point);
+  TopoDS_Vertex* vertex;
+  CubitStatus stat = unhook_Point_from_OCC(point, vertex);
+  if(stat)
+    delete vertex;
+  return stat;
@@ -1875,13 +1947,14 @@
 CubitStatus
-OCCQueryEngine::unhook_Point_from_OCC( Point* point ) const
+OCCQueryEngine::unhook_Point_from_OCC( Point* point,
+                                       TopoDS_Vertex*& vertex ) const
   OCCPoint* fpoint = dynamic_cast<OCCPoint*>(point);
   if (!fpoint)
-  TopoDS_Vertex *vertex = fpoint->get_TopoDS_Vertex();
+  vertex = fpoint->get_TopoDS_Vertex();
   if (!vertex)
@@ -1897,7 +1970,6 @@
         PRINT_ERROR("The OccPoint and TopoDS_Vertex pair is not in the map!");
-  delete vertex;
   delete point;
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.hpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.hpp	2008-04-21 19:49:42 UTC (rev 1772)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.hpp	2008-04-22 19:30:00 UTC (rev 1773)
@@ -248,7 +248,14 @@
                                          CubitBoolean import_vertices = CUBIT_TRUE,
                                          CubitBoolean free_surfaces = CUBIT_TRUE );
-  CubitStatus unhook_BodySM_from_OCC( BodySM* bodysm)const;
+  CubitStatus unhook_BodySM_from_OCC( BodySM* bodysm,
+                                      TopoDS_Shape*& shape)const;
+  CubitStatus unhook_Surface_from_OCC( Surface* surface,
+                                       TopoDS_Face*& topo_face ) const;
+  CubitStatus unhook_Curve_from_OCC( Curve* curve,
+                                     TopoDS_Edge*& edge ) const;
+  CubitStatus unhook_Point_from_OCC( Point* point,
+                                     TopoDS_Vertex*& vertex ) const;
 private:
   CubitStatus import_solid_model(FILE *file_ptr,
@@ -263,12 +270,11 @@
                                  CubitBoolean free_surfaces = CUBIT_TRUE);
-  CubitStatus unhook_Lump_from_OCC( Lump* lump ) const;
-  CubitStatus unhook_ShellSM_from_OCC( ShellSM* shell ) const;
-  CubitStatus unhook_LoopSM_from_OCC( LoopSM* loopsm ) const;
-  CubitStatus unhook_Surface_from_OCC( Surface* surface ) const;
-  CubitStatus unhook_Curve_from_OCC( Curve* curve ) const;
-  CubitStatus unhook_Point_from_OCC( Point* point ) const;
+  CubitStatus unhook_Lump_from_OCC( Lump* lump, TopoDS_Solid*& solid ) const;
+  CubitStatus unhook_ShellSM_from_OCC( ShellSM* shell,
+                                       TopoDS_Shell*& shell ) const;
+  CubitStatus unhook_LoopSM_from_OCC( LoopSM* loopsm,
+                                      TopoDS_Wire*& wire ) const;
   CubitStatus delete_loop( LoopSM* loopsm)const;
 public:
   virtual void delete_solid_model_entities(DLIList<BodySM*>& body_list) const;
More information about the cgma-dev mailing list
