[cgma-dev] r1771 - cgm/trunk/geom/OCC
    janehu at mcs.anl.gov
    Fri Apr 18 14:20:39 CDT 2008
Author: janehu
Date: 2008-04-18 14:20:39 -0500 (Fri, 18 Apr 2008)
New Revision: 1771
Modified:
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
make_Lump failed because it doesn't consider the shell with 6 faces a closed shell, debugging on it.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-04-17 20:12:35 UTC (rev 1770)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-04-18 19:20:39 UTC (rev 1771)
@@ -1045,7 +1045,10 @@
   for (Ex.Init(aShape, TopAbs_SHELL, TopAbs_SOLID); Ex.More()&& stat; Ex.Next())
     aShell = TopoDS::Shell(Ex.Current());
-  if(aShell.Closed(CUBIT_TRUE))
+  int num_edge = 0;
+  for (Ex.Init(aShell, TopAbs_EDGE); Ex.More()&& stat; Ex.Next())
+    num_edge++;
+  if(aShell.Closed())
     BRepBuilderAPI_MakeSolid aMakeSolid(aShell);
     if (!aMakeSolid.IsDone())
@@ -1057,6 +1060,9 @@
     TopoDS_Solid aSolid = aMakeSolid.Solid();
+    int num_edge = 0;
+    for (Ex.Init(aSolid, TopAbs_EDGE); Ex.More()&& stat; Ex.Next())
+      num_edge++;
     return
       OCCQueryEngine::instance()->populate_topology_bridge(aSolid, CUBIT_TRUE);
@@ -1571,18 +1577,19 @@
           OCCSurface::update_OCC_entity(face, face, &fuser);
       fuse = fuser.Shape();
+      TopExp_Explorer Ex_edge;
+      TopoDS_Edge edge;
+      for (Ex_edge.Init(fuse,TopAbs_EDGE); Ex_edge.More(); Ex_edge.Next())
+        edge = TopoDS::Edge(Ex_edge.Current());
       first_face = &fuse;
   TopExp_Explorer Ex;
-  int count_face = 0;
   int count_shell = 0;
-  for (Ex.Init(fuse, TopAbs_FACE, TopAbs_SHELL); Ex.More(); Ex.Next())
-    count_face++;
   for (Ex.Init(fuse, TopAbs_SHELL, TopAbs_SOLID); Ex.More(); Ex.Next())
     count_shell++;
-  if (count_face != 1 && count_shell != 1)
+  if ( count_shell != 1)
      PRINT_ERROR("Can't stitch all surfaces into one BodySM's. \n");
      return CUBIT_FAILURE;
@@ -1642,6 +1649,15 @@
        TopoDS_Solid* solid = CAST_TO(lumps.get(), OCCLump)->get_TopoDS_Solid();
+       TopoDS_Edge edge;
+       int num_edge = 0;
+       for (Ex_edge.Init(*solid,TopAbs_EDGE); Ex_edge.More(); Ex_edge.Next())
+         num_edge++;
        BRepBuilderAPI_Copy api_copy(*solid);
        TopoDS_Shape newShape = api_copy.ModifiedShape(*solid);
        TopoDS_Shape* newShape_ptr = new TopoDS_Shape(newShape);
More information about the cgma-dev
