[cgma-dev] r1770 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov janehu at mcs.anl.gov
Thu Apr 17 15:12:35 CDT 2008
Author: janehu
Date: 2008-04-17 15:12:35 -0500 (Thu, 17 Apr 2008)
New Revision: 1770
Modified:
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
   cgm/trunk/geom/OCC/OCCModifyEngine.hpp
   cgm/trunk/geom/OCC/OCCQueryEngine.cpp
   cgm/trunk/geom/OCC/OCCSurface.cpp
Log:
fine tuned the stitch_surfs function, makes a seperate call to stitch surfaces into a TopoDS_Shape, share this call with make_Lump in ModifyEngine. There's a global CurveList need to be updated.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-04-16 20:19:10 UTC (rev 1769)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-04-17 20:12:35 UTC (rev 1770)
@@ -1013,62 +1013,40 @@
 Lump* OCCModifyEngine::make_Lump( DLIList<Surface*>& surface_list ) const
-  if (surface_list.size() == 0)
+  if (surface_list.size() < 2)
     return (Lump*) NULL;
-  Surface* surface = surface_list.get();
-  OCCSurface* occ_surface = CAST_TO(surface, OCCSurface);
-  if(!occ_surface)
+  //all surfaces should be stand along surface bodies
+  DLIList<BodySM*> body_list;
+  for(int i = 0; i < surface_list.size(); i++)
-     PRINT_ERROR("Cannot create an OCC Lump from the given surfaces.\n"
+    OCCSurface* occ_surface = CAST_TO(surface_list.get_and_step(), OCCSurface);
+    if (occ_surface == NULL)
+       PRINT_ERROR("Cannot create an OCC lump from the given surfaces.\n"
                  "Possible incompatible geometry engines.\n");
-     return (Lump *)NULL;
+       return (Lump *)NULL;
+    OCCBody* occ_body = occ_surface->my_body();
+    if(occ_body->my_sheet_surface() == NULL)
+                 "The surfaces are not free.\n");
+    body_list.append(occ_body);
-  TopoDS_Face* face_ptr = occ_surface->get_TopoDS_Face();
-  for(int i = 1; i < surface_list.size(); i++)
-     Surface* surface = surface_list.step_and_get();
-     if(!occ_surface)
-                    "Possible incompatible geometry engines.\n");
-     TopoDS_Face* face2_ptr = occ_surface->get_TopoDS_Face();
-     BRepAlgoAPI_Fuse  aFuse(*face_ptr, *face2_ptr);
-     if(aFuse.ErrorStatus() == 1) //The Object is created but Nothing is Done
-                    "Check surface connectivities.\n");
-     else if (aFuse.ErrorStatus() != 0)
-                    "OCC internal error.\n");
-     TopTools_ListOfShape shapes;
-     shapes.Assign( aFuse.Modified(*face_ptr));
-     face_ptr = & (TopoDS::Face(shapes.First()));
+  TopoDS_Shape aShape;
+  CubitStatus stat = stitch_surfs(body_list, aShape);
-  Handle_Geom_Surface HGeom_surface = BRep_Tool::Surface(*face_ptr);
-  BRepBuilderAPI_MakeShell aMakeShell(HGeom_surface);
-  if(!aMakeShell.IsDone())
+  TopExp_Explorer Ex;
+  TopoDS_Shell aShell ;
+  for (Ex.Init(aShape, TopAbs_SHELL, TopAbs_SOLID); Ex.More()&& stat; Ex.Next())
+    aShell = TopoDS::Shell(Ex.Current());
+  if(aShell.Closed(CUBIT_TRUE))
-  TopoDS_Shell aShell = aMakeShell.Shell();
-  if(aShell.Closed())
     BRepBuilderAPI_MakeSolid aMakeSolid(aShell);
     if (!aMakeSolid.IsDone())
@@ -1082,9 +1060,8 @@
     return
       OCCQueryEngine::instance()->populate_topology_bridge(aSolid, CUBIT_TRUE);
-  OCCShell* occ_shell =
-    OCCQueryEngine::instance()->populate_topology_bridge(aShell, CUBIT_TRUE);
-  return occ_shell->my_lump();
+  return (Lump*) NULL;
@@ -1514,6 +1491,42 @@
     return CUBIT_SUCCESS;
+  TopoDS_Shape fuse;
+  CubitStatus stat =  stitch_surfs(surf_bodies, fuse);
+  if (stat == CUBIT_FAILURE)
+    return stat;
+  DLIList<TopologyBridge*> tbs = OCCQueryEngine::instance()->
+     populate_topology_bridge(fuse);
+  OCCBody* body = CAST_TO(tbs.get(), OCCBody);
+  if (body)
+    stitched_body = body ;
+  else
+    OCCSurface* face = CAST_TO(tbs.get(), OCCSurface);
+    if(face)
+      stitched_body = face->my_body();
+  return CUBIT_SUCCESS;
+// Function   : stitch_surfs
+// Member Type: PUBLIC
+// Description: stitch all surfs and try to make a TopoDS_Shell .
+//              called by stitch into surface body
+// Author     : Jane Hu
+// Date       : 03/08
+CubitStatus OCCModifyEngine::stitch_surfs(
+                      DLIList<BodySM*>& surf_bodies,
+                      TopoDS_Shape& fuse) const
+  if (surf_bodies.size() < 2)
   DLIList<TopoDS_Face*> faces_to_stitch;
   for (int i = 0; i < surf_bodies.size(); i++)
@@ -1524,7 +1537,7 @@
        PRINT_ERROR("Can't stitch non-sheet bodySM's. \n");
        return CUBIT_FAILURE;
      TopoDS_Face* topods_face = surface->get_TopoDS_Face();
      if (topods_face != NULL)
        faces_to_stitch.append(topods_face);
@@ -1535,12 +1548,10 @@
   TopoDS_Shape* first_face  = faces_to_stitch.pop();
   TopoDS_Face* second_face = NULL;
-  TopoDS_Shape fuse;
   for( int i = faces_to_stitch.size()-1; i >= 0; i --)
      second_face = faces_to_stitch[i];
      BRepAlgoAPI_Fuse fuser(*second_face, *first_face);
-     fuse = fuser.Shape();
      OCCBody* occ_body = CAST_TO(surf_bodies[i], OCCBody);
      occ_body->my_sheet_surface()->update_OCC_entity(NULL, &fuser);
      TopoDS_Shape new_shape ;
@@ -1548,7 +1559,7 @@
      TopExp::MapShapes(*first_face, TopAbs_FACE, M);
      for(int ii=1; ii<=M.Extent(); ii++)
-	TopoDS_Face face = TopoDS::Face(M(ii));
+        TopoDS_Face face = TopoDS::Face(M(ii));
         shapes.Assign(fuser.Modified(face));
         if (shapes.Extent() > 0)
@@ -1556,7 +1567,10 @@
           new_shape = shapes.First();
           OCCSurface::update_OCC_entity(face, TopoDS::Face(new_shape), &fuser);
+        else
+          OCCSurface::update_OCC_entity(face, face, &fuser);
+      fuse = fuser.Shape();
       first_face = &fuse;
@@ -1573,21 +1587,7 @@
      PRINT_ERROR("Can't stitch all surfaces into one BodySM's. \n");
-  DLIList<TopologyBridge*> tbs = OCCQueryEngine::instance()->
-     populate_topology_bridge(fuse);
-  OCCBody* body = CAST_TO(tbs.get(), OCCBody);
-  if (body)
-    stitched_body = body ;
-  else
-    OCCSurface* face = CAST_TO(tbs.get(), OCCSurface);
-    if(face)
-      stitched_body = face->my_body();
-  return CUBIT_SUCCESS;
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.hpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.hpp	2008-04-16 20:19:10 UTC (rev 1769)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.hpp	2008-04-17 20:12:35 UTC (rev 1770)
@@ -664,6 +664,9 @@
  CubitStatus sort_curves(DLIList<Curve*> curve_list,
                          DLIList<DLIList<TopoDS_Edge*>*>& topo_edges_loops)const;
+ CubitStatus stitch_surfs(DLIList<BodySM*>& surf_bodies,
+                          TopoDS_Shape& stitched_shape) const;
 private:
  int check_intersection(DLIList<TopoDS_Edge*>* edge_list,
                         TopoDS_Face from_face)const;
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2008-04-16 20:19:10 UTC (rev 1769)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2008-04-17 20:12:35 UTC (rev 1770)
@@ -2360,6 +2360,8 @@
 void OCCQueryEngine::update_OCC_map(TopoDS_Shape old_shape,
                                     TopoDS_Shape new_shape)
+  if (!OCCMap->IsBound(old_shape))
+    return;
   int k = OCCMap->Find(old_shape);
   assert (k > 0 && k <= iTotalTBCreated);
   OCCMap->UnBind(old_shape);
Modified: cgm/trunk/geom/OCC/OCCSurface.cpp
--- cgm/trunk/geom/OCC/OCCSurface.cpp	2008-04-16 20:19:10 UTC (rev 1769)
+++ cgm/trunk/geom/OCC/OCCSurface.cpp	2008-04-17 20:12:35 UTC (rev 1770)
@@ -774,6 +774,7 @@
   assert(aBRepTrsf != NULL || op != NULL);
   TopoDS_Shape shape;
+  CubitBoolean need_update = CUBIT_TRUE;
   if (aBRepTrsf)
     shape = aBRepTrsf->ModifiedShape(*get_TopoDS_Face());
   else
@@ -783,13 +784,13 @@
     else
+      need_update = CUBIT_FALSE;
   TopoDS_Face surface;
   surface = TopoDS::Face(shape);
-  if (aBRepTrsf)
+  if (aBRepTrsf  && need_update)
     OCCQueryEngine::instance()->update_OCC_map(*myTopoDSFace, surface);
@@ -804,9 +805,13 @@
     set_TopoDS_Face(surface);
-  else
+  else if(op && need_update)
     update_OCC_entity(*myTopoDSFace, surface, op);
+  else
+    update_OCC_entity(*myTopoDSFace, *myTopoDSFace, op); //underling curves may
+    //need update
@@ -852,10 +857,9 @@
        else
-         need_update = CUBIT_FALSE;
+         continue;
-       if (need_update)
-         OCCQueryEngine::instance()->update_OCC_map(edge, shape);
+       OCCQueryEngine::instance()->update_OCC_map(edge, shape);
        //update vertex
        TopoDS_Vertex vertex = Ex.CurrentVertex();
More information about the cgma-dev mailing list
