[cgma-dev] r1757 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov janehu at mcs.anl.gov
Thu Apr 10 15:45:58 CDT 2008
Author: janehu
Date: 2008-04-10 15:45:58 -0500 (Thu, 10 Apr 2008)
New Revision: 1757
Modified:
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Added imprint for a list of BodySM's, need to add map mechanism to determine if the 'owner' has been changed for id consistance.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-04-10 17:26:24 UTC (rev 1756)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-04-10 20:45:58 UTC (rev 1757)
@@ -60,6 +60,7 @@
 #include "BRepGProp.hxx"
 #include "TopoDS.hxx"
 #include "TopologyBridge.hpp"
+#include "ProgressTool.hpp"
 #include "BRepAlgoAPI_Fuse.hxx"
 #include "BRepAlgoAPI_Cut.hxx"
 #include "BRepAlgoAPI_Section.hxx"
@@ -2174,6 +2175,8 @@
                                          bool  keep_old) const
   OCCBody* occ_body = NULL;
+  newBody1 = NULL;
+  newBody2 = NULL;
   DLIList<TopoDS_Shape*> shape_list;
   for(int i = 0; i <2; i++)
@@ -2234,24 +2237,135 @@
     tbs += OCCQueryEngine::instance()->populate_topology_bridge(*shape2);
     newBody2 = CAST_TO(tbs.get(),BodySM);
-  return CUBIT_FAILURE;
+  if (!keep_old)
+    if (newBody1)
+      OCCQueryEngine::instance()->delete_solid_model_entities(BodyPtr1);
+    if (newBody2)
+      OCCQueryEngine::instance()->delete_solid_model_entities( BodyPtr2);
+  if (!newBody1)
+    delete shape1;
+    newBody1 = BodyPtr1;
+  if(!newBody2)
+    delete shape2;
+    newBody2 = BodyPtr2;
+  return CUBIT_SUCCESS;
-// Function   : imprint
+// Function   : imprint multiple bodies at once
 // Member Type: PUBLIC
-// Description: imprint boolean operation on facet-based bodies
-// Author     : John Fowler
-// Date       : 10/02
+// Description: imprint boolean operation on OCC-based bodies
+// Author     : Jane HU
+// Date       : 04/08
-CubitStatus     OCCModifyEngine::imprint(DLIList<BodySM*> &from_body_list ,
-                                           DLIList<BodySM*> &new_from_body_list,
-                                           bool keep_old,
-                                           DLIList<TopologyBridge*>* ,
-                                           DLIList<TopologyBridge*>*) const
+CubitStatus OCCModifyEngine::imprint(DLIList<BodySM*> &from_body_list ,
+                                     DLIList<BodySM*> &new_from_body_list,
+                                     bool keep_old,
+                                     DLIList<TopologyBridge*>* new_tbs,
+                                     DLIList<TopologyBridge*>* att_tbs) const
   CubitStatus success = CUBIT_SUCCESS;
+  OCCBody* occ_body = NULL;
+  DLIList<TopoDS_Shape*> shape_list;
+  // pass in keep_old to the delete_owner_attrib flag; if we're not keeping
+  // old bodies, we want to keep the owner attrib, so we can pick up entities
+  // that didn't change
+  bool delete_attribs =
+        (GeometryModifyTool::instance()->get_new_ids() || keep_old);
+  for(int i = 0; i <from_body_list.size(); i++)
+    occ_body = CAST_TO(from_body_list.get_and_step(), OCCBody);
+    OCCSurface* surface = occ_body->my_sheet_surface();
+    OCCShell*   shell = occ_body->shell();
+    if(surface)
+      TopoDS_Face* topo_face = surface->get_TopoDS_Face();
+      BRepBuilderAPI_Copy api_copy(*topo_face);
+      TopoDS_Shape newShape = api_copy.ModifiedShape(*topo_face);
+      TopoDS_Shape* Shape1 = new TopoDS_Shape(newShape);
+      shape_list.append(Shape1);
+    else if(shell)
+      TopoDS_Shell* topo_shell = shell->get_TopoDS_Shell();
+      BRepBuilderAPI_Copy api_copy(*topo_shell);
+      TopoDS_Shape newShape = api_copy.ModifiedShape(*topo_shell);
+    else
+      DLIList<Lump*> lumps = occ_body->lumps();
+      if (lumps.size() > 1)
+        PRINT_ERROR("Can't do boolean operation on CompSolid types. \n");
+        return CUBIT_FAILURE;
+      TopoDS_Solid* solid = CAST_TO(lumps.get(), OCCLump)->get_TopoDS_Solid();
+      BRepBuilderAPI_Copy api_copy(*solid);
+      TopoDS_Shape newShape = api_copy.ModifiedShape(*solid);
+  int size = shape_list.size();
+  // total number of imprints to be done
+  int total_imprints = (size * (size -1))/2;
+  if( size > 2 )
+     char message[128];
+     sprintf(message, "Imprinting %d ACIS Bodies", from_body_list.size() );          AppUtil::instance()->progress_tool()->start(0, total_imprints, message);
+  for(int i = 0; i < size; i++)
+    TopoDS_Shape* shape1 = shape_list[i];
+    shape_list.append(shape1);
+    CubitBoolean modified = CUBIT_FALSE;
+    for(int j = i+1; j < size+i; j ++)
+       if (CubitMessage::instance()->Interrupt())
+          success = CUBIT_FAILURE;
+          break;
+       TopoDS_Shape* shape2 = shape_list[j];
+       DLIList<TopologyBridge*> tbs;
+       CubitStatus stat = imprint_toposhapes(shape1, shape2);
+       if(stat)
+          modified = CUBIT_TRUE;
+    if(modified)
+      tbs += OCCQueryEngine::instance()->populate_topology_bridge(*shape1);
+      new_from_body_list.append(CAST_TO(tbs.get(),BodySM));
+    if( size > 2 )
+      AppUtil::instance()->progress_tool()->step();
+  if( size > 2 )
+    AppUtil::instance()->progress_tool()->end();
+  if( CubitMessage::instance()->Interrupt() )
+        PRINT_INFO("Imprint aborted.\n");
   return success;
More information about the cgma-dev mailing list
