[cgma-dev] r1741 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Thu Apr 3 15:29:20 CDT 2008
Author: janehu
Date: 2008-04-03 15:29:19 -0500 (Thu, 03 Apr 2008)
New Revision: 1741
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Worked on body body imprinting, still has a last face to pass the bug.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-04-03 19:40:15 UTC (rev 1740)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-04-03 20:29:19 UTC (rev 1741)
@@ -37,6 +37,7 @@
#include "GC_MakeTrimmedCone.hxx"
#include "GC_MakeTrimmedCylinder.hxx"
#include "Geom_BezierCurve.hxx"
+#include "BndLib_AddSurface.hxx"
#include "Handle_Geom_Plane.hxx"
#include "BRepPrimAPI_MakePrism.hxx"
#include "BRepPrimAPI_MakeCone.hxx"
@@ -1884,42 +1885,64 @@
DLIList<Curve*> curve_list;
CubitBoolean topo_changed = CUBIT_FALSE;
tool_faces.reset();
+ double tol = OCCQueryEngine::instance()->get_sme_resabs_tolerance();
+ Bnd_Box aBox2;
+ BRepAdaptor_Surface asurface(from_face);
+ BndLib_AddSurface::Add(asurface, tol, aBox2);
for(; Itor.More(); Itor.Next())
TopoDS_Edge edge = TopoDS::Edge(Itor.Value());
+ Curve* curve = OCCQueryEngine::instance()->populate_topology_bridge(edge);
//check if the edge is on from_face edges, add such edge on existing
//edge to split it.
+ //note: even if the edge is on one of from_face edges, if it's not
+ //shorter than the from_face edge, we won't need to added it either.
+ //For this reason, do the length check out first, because there's a bug
+ //in TopOpeBRep_EdgesIntersector so that when the two edges are
+ //overlapping and has the same length, but on two non-parallel faces
+ //the sector will crash.
TopExp_Explorer Ex;
CubitBoolean added = CUBIT_FALSE;
CubitBoolean skipped = CUBIT_FALSE;
- double tol = OCCQueryEngine::instance()->get_sme_resabs_tolerance();
+ GProp_GProps myProps1;
+ BRepGProp::LinearProperties(edge, myProps1);
+ double d1 = myProps1.Mass();
for (Ex.Init(from_face, TopAbs_EDGE); Ex.More(); Ex.Next())
TopoDS_Edge from_edge = TopoDS::Edge(Ex.Current());
+ Curve* curve = OCCQueryEngine::instance()->populate_topology_bridge(from_edge);
TopOpeBRep_EdgesIntersector intersector;
- intersector.SetFaces(*(tool_faces.get_and_step()), from_face);
+ TopoDS_Face face = *(tool_faces.get_and_step());
+ BRepAdaptor_Surface asurface(face);
+ Bnd_Box aBox1;
+ BndLib_AddSurface::Add(asurface, tol, aBox1);
+ intersector.SetFaces(face, from_face, aBox1, aBox2);
intersector.Perform(edge, from_edge);
int num_edges = intersector.NbSegments();
if(num_edges == 1) //overlap
- //check if they are the same edge, so don't need to be split
- //the overlapped edges are considered the same if they have the
- //same length
- GProp_GProps myProps1, myProps2;
- BRepGProp::LinearProperties(edge, myProps1);
- double d1 = myProps1.Mass();
- BRepGProp::LinearProperties(from_edge, myProps2);
- double d2 = myProps2.Mass();
- if (fabs(d1 - d2) > tol)
- added = CUBIT_TRUE;
- splitor.Add(edge, from_edge);
- else
- skipped = CUBIT_TRUE;
- max_edge--;
- break;
+ //check if they are the same edge, so don't need to be split
+ //the overlapped edges are considered the same if they have the
+ //same length
+ GProp_GProps myProps2;
+ BRepGProp::LinearProperties(from_edge, myProps2);
+ double d2 = myProps2.Mass();
+ if((d2 - d1) > tol)
+ added = CUBIT_TRUE;
+ splitor.Add(edge, from_edge);
+ else
+ skipped = CUBIT_TRUE;
+ max_edge--;
+ break;
if(added)
@@ -1940,6 +1963,7 @@
DLIList<TopoDS_Edge*>* edge_list;
edge_list = edge_lists.pop();
BRepBuilderAPI_MakeWire myWire;
for(int i = 0; i < edge_list->size(); i++)
TopoDS_Edge e = *(edge_list->get_and_step());
More information about the cgma-dev
