[cgma-dev] r1736 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov janehu at mcs.anl.gov
Wed Apr 2 14:11:26 CDT 2008
Author: janehu
Date: 2008-04-02 14:11:26 -0500 (Wed, 02 Apr 2008)
New Revision: 1736
Modified:
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Added body body imprint, however TopOpeBRep_EdgesIntersector has a bug which prevented the correct performance, looking for ways to avoid it.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-04-02 18:59:56 UTC (rev 1735)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-04-02 19:11:26 UTC (rev 1736)
@@ -71,7 +71,6 @@
 #include "CubitDefines.h"
 #include "TopTools_DataMapOfShapeInteger.hxx"
 #include "BRepFeat_SplitShape.hxx"
-#include "TopOpeBRep_trace.cxx"
 #include "TopOpeBRep_ShapeIntersector.hxx"
 #include "TopTools_ListIteratorOfListOfShape.hxx"
 #include "CubitUtil.hpp"
@@ -1784,9 +1783,14 @@
 CubitStatus OCCModifyEngine::imprint_toposhapes(TopoDS_Shape*& from_shape,
                                                 TopoDS_Shape* tool_shape)const
-  int num_cuts = 1;
-  CubitStatus stat = CUBIT_SUCCESS;
-  while(num_cuts)
+  int count = 0;   //number of imprinting
+  //indicate if there's more faces to be imprinted
+  CubitBoolean more_face = CUBIT_TRUE;
+  //list of face on from_shape that has been imprinted
+  DLIList<TopoDS_Face*> from_faces;
+  while( more_face)
       TopOpeBRep_ShapeIntersector intersector;
       intersector.InitIntersection(*from_shape, *tool_shape);
@@ -1800,6 +1804,20 @@
       for(; intersector.MoreIntersection(); intersector.NextIntersection())
 	  TopoDS_Shape face1 = intersector.ChangeFacesIntersector().Face(1);
+          CubitBoolean has_imprinted = CUBIT_FALSE;
+          for (int j = 0; j < from_faces.size(); j++)
+            TopoDS_Face* topo_face = from_faces.get_and_step();
+            if(face1.IsSame(*topo_face))
+              has_imprinted = CUBIT_TRUE;
+              break;
+          if (has_imprinted)
+	    continue;
 	  TopoDS_Shape face2 = intersector.ChangeFacesIntersector().Face(2);
 	  BRepAlgoAPI_Section section(face1, face2);
 	  TopTools_ListOfShape temp_list_of_edges;
@@ -1816,7 +1834,7 @@
 	      break;
-	  if (max_edge < num_edges && !is_same)
+	  if (max_edge < num_edges )
 	      list_of_edges.Assign(temp_list_of_edges);
 	      max_edge =  num_edges ;
@@ -1855,7 +1873,12 @@
+      if (from_face.IsNull())
+        more_face = CUBIT_FALSE;
+        continue;
       TopTools_ListIteratorOfListOfShape Itor;
       Itor.Initialize(list_of_edges);
       DLIList<Curve*> curve_list;
@@ -1868,10 +1891,8 @@
         //edge to split it.
 	TopExp_Explorer Ex;
 	CubitBoolean added = CUBIT_FALSE;
-        //temp. set TopOpeBRep_contextNOFEI to be true to avoid calculating
-        //intersecting points from 2d to 3d space.
-        CubitBoolean contextNOFEI = TopOpeBRep_trace::TopOpeBRep_contextNOFEI;
-        TopOpeBRep_trace::TopOpeBRep_contextNOFEI =CUBIT_TRUE;
+        CubitBoolean skipped = CUBIT_FALSE;
+        double tol = OCCQueryEngine::instance()->get_sme_resabs_tolerance();
 	for (Ex.Init(from_face, TopAbs_EDGE); Ex.More(); Ex.Next())
 	  TopoDS_Edge from_edge = TopoDS::Edge(Ex.Current());
@@ -1881,20 +1902,35 @@
           int num_edges = intersector.NbSegments();
 	  if(num_edges == 1) //overlap
-	      added = CUBIT_TRUE;
-   	      splitor.Add(edge, from_edge);
+              //check if they are the same edge, so don't need to be split
+	      //the overlapped edges are considered the same if they have the
+              //same length
+              GProp_GProps myProps1, myProps2;
+              BRepGProp::LinearProperties(edge, myProps1);
+              double d1 = myProps1.Mass();
+              BRepGProp::LinearProperties(from_edge, myProps2);
+              double d2 = myProps2.Mass();
+              if (fabs(d1 - d2) > tol)
+	        added = CUBIT_TRUE;
+   	        splitor.Add(edge, from_edge);
+              else
+                skipped = CUBIT_TRUE;
 	      max_edge--;
 	      break;
-        TopOpeBRep_trace::TopOpeBRep_contextNOFEI = contextNOFEI;
         if(added)
           topo_changed = CUBIT_TRUE;
           continue;
-	Curve* curve = OCCQueryEngine::instance()->populate_topology_bridge(edge);
-	curve_list.append(curve);
+        if (!skipped)
+	  Curve* curve = OCCQueryEngine::instance()->populate_topology_bridge(edge);
+	  curve_list.append(curve);
       DLIList<DLIList<TopoDS_Edge*>*> edge_lists;
@@ -1916,15 +1952,28 @@
         splitor.Build();
         if(splitor.IsDone())
 	  delete from_shape;
-        from_shape = new TopoDS_Shape(splitor.Shape());
+          from_shape = new TopoDS_Shape(splitor.Shape());
+          TopTools_ListOfShape shapes;
+          shapes.Assign(splitor.Modified(from_face));
+          TopTools_ListIteratorOfListOfShape It(shapes);
+          for(; It.More(); It.Next())
+	    TopoDS_Face* topo_face = new TopoDS_Face(TopoDS::Face(It.Value()));
+            from_faces.append(topo_face);
+          count++;
       else
-        stat = CUBIT_FAILURE;
-      if(edge_lists.size()==0)
-	num_cuts--;
+        TopoDS_Face* topo_face = new TopoDS_Face(from_face);
   TopExp_Explorer Ex;
   int num_face = 0;
   for (Ex.Init(*from_shape, TopAbs_FACE); Ex.More(); Ex.Next())
@@ -1932,8 +1981,10 @@
      TopoDS_Face face = TopoDS::Face(Ex.Current());
      num_face++;
-  return stat;
+  if (count > 0)
+     return CUBIT_SUCCESS;
+  return CUBIT_FAILURE;
 // Function   : imprint
More information about the cgma-dev mailing list
