[cgma-dev] r1350 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov janehu at mcs.anl.gov
Wed Oct 31 13:07:43 CDT 2007
Author: janehu
Date: 2007-10-31 13:07:43 -0500 (Wed, 31 Oct 2007)
New Revision: 1350
Modified:
   cgm/trunk/geom/OCC/OCCBody.cpp
   cgm/trunk/geom/OCC/OCCBody.hpp
   cgm/trunk/geom/OCC/OCCCurve.cpp
   cgm/trunk/geom/OCC/OCCQueryEngine.cpp
   cgm/trunk/geom/OCC/OCCQueryEngine.hpp
   cgm/trunk/geom/OCC/OCCShell.cpp
   cgm/trunk/geom/OCC/OCCSurface.cpp
   cgm/trunk/geom/OCC/OCCSurface.hpp
Log:
Added a check in find interior extrema for curve to make sure the endpoints are not in the return list and the points has no duplications; Added delete occbody and occface call in query function.
Modified: cgm/trunk/geom/OCC/OCCBody.cpp
--- cgm/trunk/geom/OCC/OCCBody.cpp	2007-10-31 17:43:34 UTC (rev 1349)
+++ cgm/trunk/geom/OCC/OCCBody.cpp	2007-10-31 18:07:43 UTC (rev 1350)
@@ -104,56 +104,6 @@
   return (BodySM*)NULL;
-// Function: can_be_deleted
-// Description: determine if the body can be deleted
-// Author: sjowen
-CubitBoolean OCCBody::can_be_deleted( DLIList <Body*> &body_list )
-  CubitBoolean delete_ok = CUBIT_TRUE;
-  DLIList<OCCSurface *>surf_list;
-  //get_surfaces(surf_list);
-  int ii;
-  for (ii=0; ii<surf_list.size() && delete_ok; ii++)
-    OCCSurface *surf_ptr = surf_list.get_and_step();
-    DLIList<OCCBody*>my_body_list;
-    surf_ptr->get_bodies(my_body_list);
-    int jj;
-    if (my_body_list.size() >= 2)
-      for (jj=0; jj<my_body_list.size() && delete_ok; jj++)
-        BodySM *my_body_ptr = my_body_list.get_and_step();
-        if (my_body_ptr != this)
-          int kk;
-          int found = 0;
-          for (kk=0; kk<body_list.size() && !found; kk++)
-            Body *body_ptr = body_list.get_and_step();
-            OCCBody* fbody_ptr = CAST_TO(body_ptr->get_body_sm_ptr(), OCCBody);
-            if (fbody_ptr)
-              if (my_body_ptr == fbody_ptr)
-                found = 1;
-          if (!found)
-            delete_ok = CUBIT_FALSE;
-            PRINT_ERROR("Body cannot be deleted because it is merged with adjacent Body\n");
-            PRINT_INFO("    Mesh Based Geometry entities cannot be unmerged.\n"
-              "    Try using the no_merge option when importing the mesh\n");
-  return delete_ok;
 // Function: move
Modified: cgm/trunk/geom/OCC/OCCBody.hpp
--- cgm/trunk/geom/OCC/OCCBody.hpp	2007-10-31 17:43:34 UTC (rev 1349)
+++ cgm/trunk/geom/OCC/OCCBody.hpp	2007-10-31 18:07:43 UTC (rev 1350)
@@ -53,8 +53,6 @@
   virtual ~OCCBody() ;
     //- The destructor.
-  CubitBoolean can_be_deleted( DLIList <Body*> &body_list );
   virtual GeometryQueryEngine* get_geometry_query_engine() const;
     //R GeometryQueryEngine*
     //R- A pointer to the geometric modeling engine associated with
Modified: cgm/trunk/geom/OCC/OCCCurve.cpp
--- cgm/trunk/geom/OCC/OCCCurve.cpp	2007-10-31 17:43:34 UTC (rev 1349)
+++ cgm/trunk/geom/OCC/OCCCurve.cpp	2007-10-31 18:07:43 UTC (rev 1350)
@@ -48,6 +48,7 @@
 #include <BRepLProp_CLProps.hxx>
 #include <BRep_Tool.hxx>
 #include <TopoDS.hxx>
+#include "TopExp_Explorer.hxx"
 #include "GeomLProp_CurveTool.hxx"
 #include "GeomAPI_ExtremaCurveCurve.hxx"
 #include "Geom_Line.hxx"
@@ -296,13 +297,57 @@
   // Will do 3 primary directions seperately.
   assert(0);
+  DLIList<CubitVector*> point_list;
   CubitVector x(1.0, 0.0, 0.0);
-  get_interior_extrema_in_direction(interior_points, x);
+  get_interior_extrema_in_direction(point_list, x);
   CubitVector y(0.0, 1.0, 0.0);
-  get_interior_extrema_in_direction(interior_points, y);
+  get_interior_extrema_in_direction(point_list, y);
   CubitVector z(0.0, 0.0, 1.0);
-  get_interior_extrema_in_direction(interior_points, z );
+  get_interior_extrema_in_direction(point_list, z );
+  //like ACIS, return only points that aren't at an endpoint and are not
+  //close to previous point
+  const double epsilon = 30.* GEOMETRY_RESABS;
+  const double epsilon_squared = epsilon*epsilon;
+  //get both vertices' coordinates.
+  CubitVector endpoints[2];
+  int i = 0;
+  TopExp_Explorer aVertexExp(*myTopoDSEdge, TopAbs_VERTEX);
+  while(aVertexExp.More())
+     TopoDS_Vertex v = TopoDS::Vertex(aVertexExp.Current());
+     gp_Pnt p = BRep_Tool::Pnt(v);
+     endpoints[i].x(p.X());
+     endpoints[i].y(p.Y());
+     endpoints[i].z(p.Z());
+     i++;
+     aVertexExp.Next();
+  //compare to see if the Points in point_list are interior and far apart
+  int j;
+  CubitVector* cubit_position = NULL;
+  CubitVector * temp_position = NULL;
+  point_list.sort();
+  point_list.reset();
+  for (j = point_list.size(); j--; )
+     temp_position = point_list.get_and_step();
+     // save if not equal to an endpoint, or prior point
+     if (temp_position->distance_between_squared(endpoints[0]) > epsilon_squared
+        temp_position->distance_between_squared(endpoints[1]) > epsilon_squared)
+        if (!cubit_position ||
+            temp_position->distance_between_squared(*cubit_position) > epsilon_squared)
+          cubit_position = temp_position ;
+          interior_points.append( cubit_position );
+        } // If point isn't close to previous point
+     } // If point isn't at an endpoint
+  } // for each point
   // Return sense is whatever the sense of this curve is.
   TopAbs_Orientation sense = myTopoDSEdge->Orientation();
   return_sense = (sense == TopAbs_FORWARD ? CUBIT_FORWARD : CUBIT_REVERSED);
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2007-10-31 17:43:34 UTC (rev 1349)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2007-10-31 18:07:43 UTC (rev 1350)
@@ -142,28 +142,6 @@
   instance_ = NULL;
-// Description:  can_delete_bodies
-// Author     : sjowen
-// Date       : 4/25/02
-CubitBoolean OCCQueryEngine::can_delete_bodies(DLIList<Body*>body_list)
-  int ii;
-  for (ii=0; ii<body_list.size() && delete_ok; ii++)
-    // Extract the BODY from Body
-    if (fbody_ptr)
-      delete_ok = fbody_ptr->can_be_deleted(body_list);
-  return delete_ok;
 int OCCQueryEngine::get_major_version()
   return OCCQE_MAJOR_VERSION;
@@ -1390,7 +1368,7 @@
 		} else {
 			surface = (OCCSurface*)(*CGMList)[OCCMap->Find(*poface)];
-		surface->add_shell((OCCShell*)(*CGMList)[OCCMap->Find(aShape)]);
+		//surface->add_shell((OCCShell*)(*CGMList)[OCCMap->Find(aShape)]);
 	return CUBIT_SUCCESS;
@@ -1594,9 +1572,9 @@
 // Special Notes :
-// Creator       : Jason Kraftcheck
+// Creator       : Jane Hu
-// Creation Date : 09/29/03
+// Creation Date : 10/29/07
 CubitStatus
 OCCQueryEngine::delete_solid_model_entities( BodySM* bodysm ) const
@@ -1605,40 +1583,15 @@
   if (!fbody)
     return CUBIT_FAILURE;
-  DLIList<OCCShell*> shells;
-  DLIList<OCCSurface*> surfaces;
+  TopoDS_Shape* shape = fbody->get_TopoDS_Shape();
-  fbody->disconnect_all_lumps();
-  delete fbody;
+  // Remove the links between OCC and Cubit
+  //  unhook_ENTITY_from_VGI(shape);
-  for (int i = lumps.size(); i--; )
-    OCCLump* lump = lumps.get_and_step();
+  if (!shape)
+    return CUBIT_FAILURE;
-    shells.clean_out();
-    lump->get_shells(shells);
-    lump->disconnect_all_shells();
-    delete lump;
-    for (int j = shells.size(); j--; )
-      OCCShell* shell = shells.get_and_step();
-      surfaces.clean_out();
-      shell->get_surfaces(surfaces);
-      shell->disconnect_all_surfaces();
-      delete shell;
-      for (int k = surfaces.size(); k--; )
-        OCCSurface* surface = surfaces.get_and_step();
-        if (!surface->has_parent_shell())
-          delete_solid_model_entities(surface);
+  delete shape;
@@ -1647,9 +1600,9 @@
 // Special Notes :
 CubitStatus
 OCCQueryEngine::delete_solid_model_entities( Surface* surface ) const
@@ -1658,37 +1611,15 @@
   if (!fsurf || fsurf->has_parent_shell())
-  DLIList<OCCLoop*> loops;
-  DLIList<OCCCoEdge*> coedges;
+  TopoDS_Face* face = fsurf->get_TopoDS_Face();
-  fsurf->get_loops(loops);
-  fsurf->disconnect_all_loops();
-  delete fsurf;
+  //  unhook_ENTITY_from_VGI(face);
-  for (int i = loops.size(); i--; )
-    OCCLoop* loop = loops.get_and_step();
+  if(!face)
-    coedges.clean_out();
-    loop->get_coedges(coedges);
-    loop->disconnect_all_coedges();
-    delete loop;
-    for (int j = coedges.size(); j--; )
-      OCCCoEdge* coedge = coedges.get_and_step();
-      OCCCurve* curve = dynamic_cast<OCCCurve*>(coedge->curve());
-      if (curve)
-        curve->disconnect_coedge(coedge);
-        //if (!curve->has_parent_coedge())
-          delete_solid_model_entities(curve);
-      delete coedge;
+  delete face;
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.hpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.hpp	2007-10-31 17:43:34 UTC (rev 1349)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.hpp	2007-10-31 18:07:43 UTC (rev 1350)
@@ -129,8 +129,6 @@
     //R- This  is not a solid modeling engine.
 //HEADER- Functions for importing and exporting solid models.
-  CubitBoolean can_delete_bodies(DLIList<Body*>body_list);
   virtual CubitStatus get_graphics( Surface* surface_ptr,
                                           int& number_triangles,
                                           int& number_points,
Modified: cgm/trunk/geom/OCC/OCCShell.cpp
--- cgm/trunk/geom/OCC/OCCShell.cpp	2007-10-31 17:43:34 UTC (rev 1349)
+++ cgm/trunk/geom/OCC/OCCShell.cpp	2007-10-31 18:07:43 UTC (rev 1350)
@@ -266,8 +266,8 @@
     if( mySurfs.move_to( dynamic_cast<Surface*>(surface) ) )
       mySurfs.change_to(NULL);
-    if (surface)
-      surface->remove_shell(this);
+    //if (surface)
+     // surface->remove_shell(this);
   mySurfs.remove_all_with_value( NULL );
@@ -289,8 +289,8 @@
     Surface* sm_ptr = mySurfs.get_and_step();
     OCCSurface* surface = dynamic_cast<OCCSurface*>(sm_ptr);
-    if (surface)
+    //if (surface)
   mySurfs.clean_out();
Modified: cgm/trunk/geom/OCC/OCCSurface.cpp
--- cgm/trunk/geom/OCC/OCCSurface.cpp	2007-10-31 17:43:34 UTC (rev 1349)
+++ cgm/trunk/geom/OCC/OCCSurface.cpp	2007-10-31 18:07:43 UTC (rev 1350)
@@ -98,127 +98,13 @@
-//// OCCSurface::OCCSurface(FacetEvalTool *facet_tool,
-////                           DLIList<ShellSM*> &shellsms,
-////                           DLIList<LoopSM*> &loopsms)
-////  assert(0);
-////    // Calculate a bounding box if there isn't one already
-////  facetEvalTool = facet_tool;
-////    //sense_ = CUBIT_FORWARD;
-////  myShells += shellsms;
-////  myLoops += loopsms;
-////  myShellSense = CUBIT_UNKNOWN;
-////  myEvaluator = NULL;
-//// // Purpose       : The constructor with a pointer to the FacetEvalTool.
-//// // Special Notes : Used for save/restore
-//// OCCSurface::OCCSurface( const SphereEvaluatorData *sphere_data,
-////                             FacetEvalTool *facet_tool,
-////                             DLIList<LoopSM*> &loopsms )
-////   assert(0);
-////   myEvaluator = new SphereEvaluator( sphere_data );
-//// OCCSurface::OCCSurface( const CylinderEvaluatorData *cylinder_data,
-////   assert(0);
-////   myEvaluator = new CylinderEvaluator( cylinder_data );
-////                            CubitSense sense,
-////                            CubitSense shell_sense0,
-////                            CubitBoolean use_facets,
-////   assert(0);
-////   myShellSense = shell_sense0;
-//// // Purpose       : The default destructor.
 OCCSurface::~OCCSurface()
-  ////  if ( facetEvalTool )
-  ////  delete facetEvalTool;
-// Purpose       : get the interpolation order of the FacetEvalTool
-// Special Notes :
-//// int OCCSurface::interp_order()
-////   assert(0);
-////   assert(facetEvalTool != NULL);
-////  return facetEvalTool->interp_order();
-// Purpose       : get the min dot of the FacetEvalTool
-// Special Notes :
-//// double OCCSurface::min_dot()
-////  assert(0);
-////  return facetEvalTool->get_min_dot();
 // Purpose       : The purpose of this function is to append a
 //                 attribute to the GE. The name is attached to the
 //                 underlying solid model entity this one points to.
@@ -267,6 +153,7 @@
 CubitStatus OCCSurface::get_simple_attribute(DLIList<CubitSimpleAttrib*>&
                                                  csa_list)
   { return attribSet.get_attributes(csa_list); }
 CubitStatus OCCSurface::get_simple_attribute(const CubitString& name,
                                         DLIList<CubitSimpleAttrib*>& csa_list )
   { return attribSet.get_attributes( name, csa_list ); }
@@ -661,16 +548,6 @@
-//// // Purpose       : Updates the (cached) area of the Surface so that if
-//// //                 measure() is called, the correct value is returned.
-//// void OCCSurface::update_measurement()
-////  assert(0);
-////  facetEvalTool->calculate_area();
 //// // Purpose       : Returns whether the facet surface is completely flat
@@ -712,16 +589,6 @@
 ////     return CUBIT_FALSE;
-//// const CubitEvaluatorData *OCCSurface::evaluator_data( void )
-////   assert(0);
-////     if ( myEvaluator )
-////         return myEvaluator->evaluator_data();
-////     return NULL;
 // Purpose       : This function tests the passed in position to see if
 //                 is on the underlying surface.
@@ -1065,65 +932,6 @@
-// Purpose       : Remove Shell from shell list
-// Special Notes :
-CubitStatus OCCSurface::remove_shell(OCCShell* shell)
-  assert(0);
-    // Something strange here -- A DLIList of Shells and a
-    // two-element array for senses?  Try to keep the senses
-    // intact anyway...
-  myShells.reset();
-  if (myShells.get() == shell)
-    myShellSense = CUBIT_UNKNOWN;
-  if (!myShells.move_to(shell))
-    return CUBIT_FAILURE;
-  myShells.remove();
-  return CUBIT_SUCCESS;
-// Purpose       : Tear down topology
-// Special Notes :
-void OCCSurface::disconnect_all_loops()
-  assert(0);
-  myLoops.reset();
-  for (int i = myLoops.size(); i--; )
-    LoopSM* sm_ptr = myLoops.get_and_step();
-    OCCLoop* loop = dynamic_cast<OCCLoop*>(sm_ptr);
-    if (loop)
-      assert(loop->get_surface() == this);
-      loop->remove_surface();
-  myLoops.clean_out();
-void OCCSurface::add_transformation( CubitTransformMatrix &tfmat )
-  assert(0);
-    if ( myEvaluator )
-        myEvaluator->add_transformation( tfmat );
 // ********** END PUBLIC FUNCTIONS         **********
 // ********** BEGIN PROTECTED FUNCTIONS    **********
Modified: cgm/trunk/geom/OCC/OCCSurface.hpp
--- cgm/trunk/geom/OCC/OCCSurface.hpp	2007-10-31 17:43:34 UTC (rev 1349)
+++ cgm/trunk/geom/OCC/OCCSurface.hpp	2007-10-31 18:07:43 UTC (rev 1350)
@@ -99,14 +99,7 @@
   virtual ~OCCSurface() ;
     //- The destructor
-  void add_shell(ShellSM *shell_ptr)    //// Not in SurfaceACIS
-    {myShells.append(shell_ptr);}
-  CubitStatus remove_shell(OCCShell* shell_ptr);  //// Not in SurfaceACIS
-  void disconnect_all_loops();   //// Not in SurfaceACIS
-  inline bool has_parent_shell() { return myShells.size() > 0; }  //// Not in SurfaceACIS
+  bool has_parent_shell() ;   //// Not in SurfaceACIS
     //CubitSense get_relative_surface_sense();
     //- Return the relative surface sense. (see below)
More information about the cgma-dev mailing list
