[cgma-dev] r1346 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Tue Oct 30 11:44:50 CDT 2007
Author: janehu
Date: 2007-10-30 11:44:50 -0500 (Tue, 30 Oct 2007)
New Revision: 1346
Modified:
cgm/trunk/geom/OCC/OCCCurve.cpp
cgm/trunk/geom/OCC/OCCCurve.hpp
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
Log:
Added curve_interior_extrema to calculate the extrema corresponding to 3 primary direction. Also, it seems there's no extrema functions likein api_entity_extrema, so added a comment.
Modified: cgm/trunk/geom/OCC/OCCCurve.cpp
--- cgm/trunk/geom/OCC/OCCCurve.cpp 2007-10-26 15:24:50 UTC (rev 1345)
+++ cgm/trunk/geom/OCC/OCCCurve.cpp 2007-10-30 16:44:50 UTC (rev 1346)
@@ -49,6 +49,9 @@
#include <BRep_Tool.hxx>
#include <TopoDS.hxx>
#include "GeomLProp_CurveTool.hxx"
+#include "GeomAPI_ExtremaCurveCurve.hxx"
+#include "Geom_Line.hxx"
+#include "GC_MakeLine.hxx"
//#include "TopOpeBRep_ShapeIntersector.hxx"
//#include "TopOpeBRep_Point2d.hxx"
//#include "TopOpeBRep_EdgesIntersector.hxx"
@@ -290,24 +293,48 @@
CubitSense& return_sense )
// Danilov: try to use GeomAPI_ExtremaCurveCurve
+ // Will do 3 primary directions seperately.
assert(0);
+ CubitVector x(1.0, 0.0, 0.0);
+ get_interior_extrema_in_direction(interior_points, x);
+ CubitVector y(0.0, 1.0, 0.0);
+ get_interior_extrema_in_direction(interior_points, y);
+ CubitVector z(0.0, 0.0, 1.0);
+ get_interior_extrema_in_direction(interior_points, z );
+ // Return sense is whatever the sense of this curve is.
+ TopAbs_Orientation sense = myTopoDSEdge->Orientation();
+ return_sense = (sense == TopAbs_FORWARD ? CUBIT_FORWARD : CUBIT_REVERSED);
+ return CUBIT_SUCCESS;
+CubitStatus OCCCurve::get_interior_extrema_in_direction(
+ DLIList<CubitVector*>& interior_points,
+ CubitVector dir)
+ //Create a straight line.
+ gp_Pnt origin(0.0, 0.0, 0.0);
+ gp_Dir adir(dir.x(), dir.y(), dir.z());
+ Handle(Geom_Line) line = GC_MakeLine(origin, adir);
//get the Geom_Curve of the OCCCurve
Standard_Real first;
Standard_Real last;
Handle(Geom_Curve) myCurve = BRep_Tool::Curve(*myTopoDSEdge, first, last);
- //only when the curve's second derivative is computable, does it possibly
- //have interior_extrema
- if(1 == GeomLProp_CurveTool::Continuity(myCurve))
- return CUBIT_SUCCESS;
- // Return sense is whatever the sense of this curve is.
- return_sense = sense_;
+ GeomAPI_ExtremaCurveCurve extrema(myCurve, line);
+ int nPnt = extrema.NbExtrema();
+ for (int i = 1; i <= nPnt ; i++)
+ gp_Pnt P1, P2;
+ extrema.Points(i, P1, P2);
+ CubitVector* v = new CubitVector(P1.X(), P1.Y(), P1.Z());
+ interior_points.append(v);
// Purpose : This function computes the point on the curve closest
// to the input location. Optionally, it can also compute
Modified: cgm/trunk/geom/OCC/OCCCurve.hpp
--- cgm/trunk/geom/OCC/OCCCurve.hpp 2007-10-26 15:24:50 UTC (rev 1345)
+++ cgm/trunk/geom/OCC/OCCCurve.hpp 2007-10-30 16:44:50 UTC (rev 1346)
@@ -180,6 +180,9 @@
//- delete these CubitVectors (or in the case of RefEdge, to make sure
//- that *it's* calling code knows that it should delete the CubitVectors)!
+ CubitStatus get_interior_extrema_in_direction(DLIList<CubitVector*>&,
+ CubitVector);
virtual CubitStatus closest_point( CubitVector const& location,
CubitVector& closest_location,
CubitVector* tangent_ptr = NULL,
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2007-10-26 15:24:50 UTC (rev 1345)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2007-10-30 16:44:50 UTC (rev 1346)
@@ -616,18 +616,20 @@
// Description: Find extrema position on an entity list
-// Author :
-// Date :
+// Author : Jane Hu
+// Date : 10/30/07
CubitStatus
-OCCQueryEngine::entity_extrema( DLIList<GeometryEntity*> &,
- const CubitVector *,
- CubitVector &,
- GeometryEntity *& )
+OCCQueryEngine::entity_extrema( DLIList<GeometryEntity*> &ref_entity_list,
+ const CubitVector *dir1,
+ const CubitVector *dir2,
+ const CubitVector *dir3,
+ CubitVector &extrema,
+ GeometryEntity *&extrema_entity_ptr )
- PRINT_ERROR("Option not supported for mesh based geometry.\n");
+ //in Acis, the api_entity_extrema is used to calculate "possible
+ //self-intersecting sweeping and to align lofting sections"
+ PRINT_ERROR("There's no such call in OCC correponding to Acis call.");
return CUBIT_FAILURE;
More information about the cgma-dev
