[cgma-dev] r1310 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov janehu at mcs.anl.gov
Thu Oct 11 14:30:24 CDT 2007
Author: janehu
Date: 2007-10-11 14:30:24 -0500 (Thu, 11 Oct 2007)
New Revision: 1310
Modified:
   cgm/trunk/geom/OCC/Makefile.am
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
   cgm/trunk/geom/OCC/OCCPoint.cpp
   cgm/trunk/geom/OCC/OCCPoint.hpp
   cgm/trunk/geom/OCC/OCCQueryEngine.hpp
Log:
OCCPoint update.
Modified: cgm/trunk/geom/OCC/Makefile.am
--- cgm/trunk/geom/OCC/Makefile.am	2007-10-11 19:09:08 UTC (rev 1309)
+++ cgm/trunk/geom/OCC/Makefile.am	2007-10-11 19:30:24 UTC (rev 1310)
@@ -27,6 +27,7 @@
 # The non-template sources
 libcubit_OCC_la_SOURCES = \
+    OCCAttrib.cpp \
     OCCAttribSet.cpp \
     OCCBody.cpp \
     OCCCoEdge.cpp \
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2007-10-11 19:09:08 UTC (rev 1309)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2007-10-11 19:30:24 UTC (rev 1310)
@@ -99,11 +99,8 @@
 Point* OCCModifyEngine::make_Point( CubitVector const& point) const
-  gp_Pnt pt(point.x(), point.y(), point.z());
-  OCCPoint *occ_pt = new OCCPoint(pt);
+  OCCPoint *occ_pt = new OCCPoint(point);
   return  CAST_TO(occ_pt, Point);
Modified: cgm/trunk/geom/OCC/OCCPoint.cpp
--- cgm/trunk/geom/OCC/OCCPoint.cpp	2007-10-11 19:09:08 UTC (rev 1309)
+++ cgm/trunk/geom/OCC/OCCPoint.cpp	2007-10-11 19:30:24 UTC (rev 1310)
@@ -21,7 +21,8 @@
 #include "OCCPoint.hpp"
 #include "OCCQueryEngine.hpp"
 #include "CastTo.hpp"
+#include "OCCAttribSet.hpp"
+#include "CubitSimpleAttrib.hpp"
 #include "BRep_Tool.hxx"
 // ********** END CUBIT INCLUDES           **********
@@ -40,9 +41,10 @@
 // Creation Date : 10/08/07
-OCCPoint::OCCPoint( CubitVector &location )
+OCCPoint::OCCPoint( const CubitVector &location )
-  myPoint = gp_Pnt( location.x(), location.y(), location.z());
+  gp_Pnt pt = gp_Pnt( location.x(), location.y(), location.z());
+  myPoint = BRepBuilderAPI_MakeVertex(pt);
@@ -71,7 +73,7 @@
 // Creation Date : 07/16/00
 void OCCPoint::append_simple_attribute_virt(CubitSimpleAttrib *csa)
-  { /*attribSet.append_attribute(csa); */}
+  { attribSet.append_attribute(csa); }
 // Purpose       : The purpose of this function is to remove a simple
@@ -85,7 +87,7 @@
 void OCCPoint::remove_simple_attribute_virt(CubitSimpleAttrib *csa)
-  { /*attribSet.remove_attribute(csa);*/ }
+  { attribSet.remove_attribute(csa); }
 // Purpose       : The purpose of this function is to remove all simple
@@ -100,7 +102,7 @@
 void OCCPoint::remove_all_simple_attribute_virt()
-  { /*attribSet.remove_all_attributes();*/ }
+  { attribSet.remove_all_attributes(); }
 // Purpose       : The purpose of this function is to get the
@@ -115,35 +117,31 @@
 CubitStatus OCCPoint::get_simple_attribute(DLIList<CubitSimpleAttrib*>&
                                                csa_list)
-  { /*return attribSet.get_attributes(csa_list);*/
-    return CUBIT_SUCCESS;
+  { return attribSet.get_attributes(csa_list);
 CubitStatus OCCPoint::get_simple_attribute(const CubitString& name,
                                      DLIList<CubitSimpleAttrib*>& csa_list )
-  { /*return attribSet.get_attributes( name, csa_list );*/
+  { return attribSet.get_attributes( name, csa_list );
 CubitStatus OCCPoint::save_attribs( FILE *file_ptr )
-  { //return attribSet.save_attributes(file_ptr);
+  { return attribSet.save_attributes(file_ptr);
 CubitStatus OCCPoint::restore_attribs( FILE *file_ptr, unsigned int endian )
-  { //return attribSet.restore_attributes(file_ptr, endian);
+  { return attribSet.restore_attributes(file_ptr, endian);
-gp_Pnt OCCPoint::get_gp()const
+TopoDS_Vertex OCCPoint::get_pnt()const
   return myPoint;
-void OCCPoint::set_gp(const gp_Pnt gp_point)
+void OCCPoint::set_pnt( TopoDS_Vertex &v_point)
-  myPoint = gp_point;
+  myPoint = v_point;
 // Purpose       : Returns the coordinates of this Point.
@@ -156,33 +154,27 @@
 CubitVector OCCPoint::coordinates() const
-  CubitVector p(myPoint.X(), myPoint.Y(), myPoint.Z());
+  gp_Pnt pt = BRep_Tool::Pnt(myPoint);
+  CubitVector p(pt.X(), pt.Y(), pt.Z());
   return p;
-void OCCPoint::set_coord(CubitVector &location )
-  myPoint.SetCoord(location.x(), location.y(), location.z());
-void OCCPoint::set_coord(double x, double y, double z)
-  myPoint.SetCoord(x, y, z);
 CubitBoolean OCCPoint::is_equal(const OCCPoint & other, double Tol)
-  return myPoint.IsEqual(other.get_gp(), Tol);
+  return pt.IsEqual(BRep_Tool::Pnt(other.get_pnt()), Tol);
 double OCCPoint::distance(const OCCPoint & other)
-  return myPoint.Distance(other.get_gp());
+  return pt.Distance(BRep_Tool::Pnt(other.get_pnt()));
 double OCCPoint::SquareDistance (const OCCPoint & other)
-  return myPoint.SquareDistance(other.get_gp());
+  return pt.SquareDistance(BRep_Tool::Pnt(other.get_pnt()));
 // Purpose       : Get geometry modeling engine: AcisGeometryEngine
Modified: cgm/trunk/geom/OCC/OCCPoint.hpp
--- cgm/trunk/geom/OCC/OCCPoint.hpp	2007-10-11 19:09:08 UTC (rev 1309)
+++ cgm/trunk/geom/OCC/OCCPoint.hpp	2007-10-11 19:30:24 UTC (rev 1310)
@@ -22,53 +22,100 @@
 #include "Point.hpp"
 #include <stdio.h>
 #include "gp_Pnt.hxx"
+#include "TopoDS_Vertex.hxx"
+#include "BRepBuilderAPI_MakeVertex.hxx"
 // ********** BEGIN FORWARD DECLARATIONS   **********
 class CubitSimpleAttrib;
-class OCCAttrib;
 // ********** END FORWARD DECLARATIONS     **********
 class OCCPoint : public Point
 private:
-  gp_Pnt myPoint;
+  TopoDS_Vertex myPoint;
+  OCCAttribSet attribSet;
 public :
-  OCCPoint(CubitVector &location );
+  OCCPoint(const CubitVector &location );
     //I- CubitVector &location
     //I- location of point (creates a CubiPoint).
     //I- DLIList<Curve*> curves
     //I- curves attaced to point
-  OCCPoint(gp_Pnt& thePoint ):myPoint(thePoint){};
+  OCCPoint(TopoDS_Vertex& thePoint ):myPoint(thePoint){};
     //I- gp_Pnt *thePoint
     //I- pointer to the TopoDS_Vertex associated with OCCPoint
-  gp_Pnt get_gp()const;
-  void set_gp( const
-gp_Pnt gp_ptr);
-  // - get/set the gp_Pnt associated with this object
+  OCCPoint(gp_Pnt& thePoint ):myPoint(BRepBuilderAPI_MakeVertex(thePoint)){};
+    //I- gp_Pnt *thePoint
+    //I- pointer to the TopoDS_Vertex associated with OCCPoint
+    //I- DLIList<Curve*> curves
+    //I- curves attaced to point
   virtual ~OCCPoint();
     //- The destructor
+  TopoDS_Vertex get_pnt()const;
+  void set_pnt( TopoDS_Vertex& gp_pnt);
+  // - get/set the gp_Pnt associated with this object
 #ifdef BOYD14
   OCCPoint *copy();
     // make a new copy of this point and return it
 #endif
+  virtual void append_simple_attribute_virt(CubitSimpleAttrib*);
+    //R void
+    //I
+    //I-
+    //I- that is to be appended to this OSME object.
+    //- The purpose of this function is to append a
+    //- attribute to the OSME. The  is attached to each of the
+    //- underlying solid model entities this one points to.
+  virtual void remove_simple_attribute_virt(CubitSimpleAttrib*);
+    //R void
+    //I CubitSimpleAttrib*
+    //I- A reference to a CubitSimpleAttrib object which is the object
+    //I- that is to be removed to this OSME object.
+    //- The purpose of this function is to remove a simple
+    //- attribute from the OSME. The attribute is attached to each of the
+  virtual void remove_all_simple_attribute_virt();
+    //R void
+    //I-
+    //- The purpose of this function is to remove all simple
+    //- attributes from the OSME.
+  virtual CubitStatus get_simple_attribute(DLIList<CubitSimpleAttrib*>&);
+  virtual CubitStatus get_simple_attribute(const CubitString& name,
+                                           DLIList<CubitSimpleAttrib*>&);
+    //R CubitSimpleAttrib*
+    //R- the returned cubit simple attribute.
+    //- The purpose of this function is to get the attributes
+    //- of the geometry entity. The name is attached to the underlying solid
+    //- model entity(ies) this one points to.
+    //- MJP Note:
+    //- This is the code that implements the requirement that names
+    //- of VGI Entities propagate across solid model boolean
+    //- operations.  The success of this relies, of course, on the underlying
+    //- solid modeler being able to propagate attributes across
+    //- such operations on its entities. If it cannot, then "names"
+    //- of VGI entities will not propagate.
   virtual CubitVector coordinates() const;
     //R CubitVector
     //R- Contains the coordinate values {x y z} of this Point
     //- Returns the spatial coordinates of this Point.
-  virtual void set_coord(CubitVector &location );
-  virtual void set_coord(double x, double y, double z);
   CubitBoolean is_equal(const OCCPoint & other, double Tol);
   double distance(const OCCPoint & other);
@@ -88,13 +135,6 @@
   void get_parents_virt( DLIList<TopologyBridge*>& parents );
   void get_children_virt( DLIList<TopologyBridge*>& children );
-  virtual void append_simple_attribute_virt(CubitSimpleAttrib*);
-  virtual void remove_simple_attribute_virt(CubitSimpleAttrib*);
-  virtual void remove_all_simple_attribute_virt();
-  virtual CubitStatus get_simple_attribute(DLIList<CubitSimpleAttrib*>&);
-  virtual CubitStatus get_simple_attribute(const CubitString&,
-                                           DLIList<CubitSimpleAttrib*>&);
   CubitStatus save_attribs( FILE *file_ptr );
   CubitStatus restore_attribs( FILE *file_ptr, unsigned int endian );
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.hpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.hpp	2007-10-11 19:09:08 UTC (rev 1309)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.hpp	2007-10-11 19:30:24 UTC (rev 1310)
@@ -28,11 +28,11 @@
 // ********** END STANDARD INCLUDES           **********
 // ********** BEGIN CUBIT INCLUDES            **********
+#include "config.h"
 #include "CubitFileIOWrapper.hpp"
 #include "GeometryQueryEngine.hpp"
-#include "TopTools_DataMapOfShapeInteger.hxx"
+#include <TopTools_DataMapOfShapeInteger.hxx>
 #include <map>
More information about the cgma-dev mailing list
