[cgma-dev] r1307 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Wed Oct 10 11:32:10 CDT 2007
Author: janehu
Date: 2007-10-10 11:32:10 -0500 (Wed, 10 Oct 2007)
New Revision: 1307
Removed:
cgm/trunk/geom/OCC/FacetboolInterface.cpp
cgm/trunk/geom/OCC/FacetboolInterface.hpp
cgm/trunk/geom/OCC/GridSearchTree.cpp
cgm/trunk/geom/OCC/GridSearchTree.hpp
cgm/trunk/geom/OCC/GridSearchTreeNode.hpp
Log:
Delete some of the irrelavant files.
Deleted: cgm/trunk/geom/OCC/FacetboolInterface.cpp
--- cgm/trunk/geom/OCC/FacetboolInterface.cpp 2007-10-10 16:30:25 UTC (rev 1306)
+++ cgm/trunk/geom/OCC/FacetboolInterface.cpp 2007-10-10 16:32:10 UTC (rev 1307)
@@ -1,1763 +0,0 @@
-#include "FacetboolInterface.hpp"
-#include "FacetDataUtil.hpp"
-#include "FBDataUtil.hpp"
-#include "FBIntersect.hpp"
-#include "IntegerHash.hpp"
-#include "OCCBody.hpp"
-#include "BodySM.hpp"
-#include "Body.hpp"
-#include "OCCSurface.hpp"
-#include "CubitPoint.hpp"
-#include "CubitPointData.hpp"
-#include "CubitFacetData.hpp"
-#include "OCCModifyEngine.hpp"
-#include "OCCQueryEngine.hpp"
-#include "OCCCurve.hpp"
-#include "CubitFacetEdge.hpp"
-#include "TDFacetboolData.hpp"
-#include "CurveFacetEvalTool.hpp"
-#include "OCCPoint.hpp"
-#include "OCCLump.hpp"
-#include "OCCShell.hpp"
-#include "CubitBox.hpp"
-#include "FBImprint.hpp"
-#include "GfxDebug.hpp"
-#include "ChollaEngine.hpp"
-FacetboolInterface::FacetboolInterface()
-FacetboolInterface::~FacetboolInterface()
-// Function : webcut_FB
-// Member Type: PUBLIC
-// Description: webcut a OCCBody with a FacetBool cutter
-// Author : John Fowler
-// Date : 02/04
-CubitStatus FacetboolInterface::webcut_FB(BodySM *bodysm_ptr,
- STD(vector)<double>& cutter_verts,
- STD(vector)<int>& cutter_connections,
- bool cutter_is_plane,
- CubitBoolean delete_bodies,
- CubitBoolean &intersects,
- DLIList<BodySM*>& results_list)
- intersects = CUBIT_TRUE;
- DLIList<OCCSurface*> facet_surf_list;
- STD(vector)<double> body_verts;
- STD(vector)<int> body_connections, newbodyfacets;
- STD(vector)<int> newcutterfacets;
- STD(vector)<int> f_c_indices1;
- STD(vector)<OCCSurface *> fsurfarray;
- STD(vector)<OCCCurve *> fcurvearray;
- CubitStatus status;
- int mydebug = 0;
- OCCModifyEngine *fme = OCCModifyEngine::instance();
- OCCBody *facet_body_ptr = CAST_TO(bodysm_ptr, OCCBody);
- facet_body_ptr->get_surfaces(facet_surf_list);
- status = facetbody_to_facetbool(facet_surf_list,body_verts,
- body_connections,&f_c_indices1,
- fsurfarray,fcurvearray);
- if( status == CUBIT_FAILURE )
- return status;
- FBIntersect *intersector = new FBIntersect();
- intersector->set_classify_flag(true);
- if ( cutter_is_plane == true ) intersector->set_body2_planar();
- status = intersector->intersect(body_verts,body_connections,
- cutter_verts,cutter_connections,
- newbodyfacets,newcutterfacets,
- &f_c_indices1,
- 0);
- return status;
- bool *surfs_in_intersection, *surfs_in_subtraction;
- bool *curves_in_intersection, *curves_in_subtraction;
- surfs_in_intersection = new bool[1+fsurfarray.size()];
- surfs_in_subtraction = new bool[1+fsurfarray.size()];
- curves_in_intersection = new bool[1+fcurvearray.size()];
- curves_in_subtraction = new bool[1+fcurvearray.size()];
- unsigned int k;
- for ( k = 1; k < 1 + fsurfarray.size(); k++ )
- surfs_in_subtraction[k] = surfs_in_intersection[k] = false;
- for ( k = 1; k < 1 + fcurvearray.size(); k++ )
- curves_in_subtraction[k] = curves_in_intersection[k] = false;
- status = intersector->get_persistent_entity_info(surfs_in_intersection,
- curves_in_intersection,surfs_in_subtraction,
- curves_in_subtraction,CUBIT_FB_INTERSECTION,1);
- return status;
- facet_surf_list.reset();
- STD(vector)<int> surfindex, surfindex2;
- STD(vector)<int> curveindex, curveindex2;
- STD(vector)<double> vertsout, vertsout2;
- STD(vector)<int> coordsout, coordsout2;
- status = intersector->gather_by_boolean(vertsout,coordsout,
- &surfindex,&curveindex,0,
- CUBIT_FB_INTERSECTION);
- return status;
- status = intersector->gather_by_boolean(vertsout2,coordsout2,
- &surfindex2,&curveindex2,0,
- CUBIT_FB_SUBTRACTION);
- return status;
- // If there were no intersections
- if ( (vertsout.size() == 0) || (coordsout.size() == 0) ||
- (vertsout2.size() == 0) || (coordsout2.size() == 0) )
- intersects = CUBIT_FALSE;
- delete intersector;
- delete [] surfs_in_intersection; delete [] surfs_in_subtraction;
- delete [] curves_in_intersection; delete [] curves_in_subtraction;
- return CUBIT_SUCCESS;
- CubitPoint *new_point;
- STD(vector)<CubitPoint *> points;
- for ( k = 0; k < vertsout.size(); k += 3 ) {
- new_point = (CubitPoint *) new CubitPointData( vertsout[k],
- vertsout[k+1],
- vertsout[k+2] );
- points.push_back(new_point);
- DLIList <CubitFacet *>facet_list;
- DLIList <CubitPoint *>point_list;
- CubitFacet *facet_ptr;
- if(mydebug)
- GfxDebug::clear();
- for ( k = 0; k < coordsout.size(); k += 3 ) {
- facet_ptr = new CubitFacetData( points[coordsout[k]],
- points[coordsout[k+1]],
- points[coordsout[k+2]] );
- int *cptr = new int[3];
- cptr[0] = curveindex[k];
- cptr[1] = curveindex[k+1];
- cptr[2] = curveindex[k+2];
- TDFacetboolData::add_facetbool_facet( facet_ptr );
- TDFacetboolData* td = TDFacetboolData::get(facet_ptr);
- td->set(surfindex[k/3],cptr[0],cptr[1],cptr[2],false,
- facet_ptr->is_backwards());
- if(mydebug){
- facet_ptr->debug_draw(CUBIT_YELLOW);
- CubitVector tmp1 = points[coordsout[k]]->coordinates();
- CubitVector tmp2 = points[coordsout[k+1]]->coordinates();
- CubitVector tmp3 = points[coordsout[k+2]]->coordinates();
- if(cptr[0]){
- GfxDebug::draw_line(tmp1, tmp2, CUBIT_WHITE);
- if(cptr[1]){
- GfxDebug::draw_line(tmp2, tmp3, CUBIT_GREEN);
- if(cptr[2]){
- GfxDebug::draw_line(tmp3, tmp1, CUBIT_BLUE);
- facet_list.append( facet_ptr );
- if(mydebug){
- GfxDebug::mouse_xforms();
- points.clear(); // clear out the points vector since we are through with it.
- double feature_angle;
- int interp_order;
- CubitBoolean smooth_non_manifold, split_surfaces;
- BodySM *body_ptr, *body_ptr2;
- //determine if original body is a sheet body
- Body *tmp_body = CAST_TO(bodysm_ptr->topology_entity(), Body);
- bool is_sheet_body = false;
- if( tmp_body->is_sheet_body() )
- is_sheet_body = true;
- //mbrewer: This is not the best solution. For now, we are using
- // a no feature angle unless we are working with a sheet-body. For
- // sheet-bodies, however, we are not marking the vertices that
- // bound curves. Therefore, if we do not use a feature angle, curves
- // are not split correctly. The correct fix would be to mark
- // the vertices and maintain them through the webcut.
- if( is_sheet_body )
- feature_angle = 135.0;
- else
- feature_angle = 0.0;
- interp_order = 0;
- smooth_non_manifold = CUBIT_TRUE;
- split_surfaces = CUBIT_FALSE;
- ChollaEngine *cholla_ptr = NULL;
- status = fme->build_cholla_surfaces( facet_list,
- point_list,
- feature_angle,
- interp_order,
- smooth_non_manifold,
- split_surfaces,
- cholla_ptr );
- return status;
- status = fme->finish_facet_Body( cholla_ptr,
- NULL,
- feature_angle, interp_order,
- body_ptr);
- return status;
- if ( cholla_ptr )
- cholla_ptr->delete_me();
- delete cholla_ptr;
- DLIList<BodySM*> new_bodies;
- status = separate_shells_into_bodies( body_ptr, is_sheet_body, new_bodies );
- return status;
- for(k=new_bodies.size(); k--;)
- results_list.append( new_bodies.get_and_step() );
- vertsout.clear();
- coordsout.clear();
- facet_list.clean_out();
- for ( k = 0; k < vertsout2.size(); k += 3 ) {
- new_point = (CubitPoint *) new CubitPointData( vertsout2[k],
- vertsout2[k+1],
- vertsout2[k+2] );
- for ( k = 0; k < coordsout2.size(); k += 3 ) {
- facet_ptr = new CubitFacetData( points[coordsout2[k]],
- points[coordsout2[k+1]],
- points[coordsout2[k+2]] );
- cptr[0] = curveindex2[k];
- cptr[1] = curveindex2[k+1];
- cptr[2] = curveindex2[k+2];
- td->set(surfindex2[k/3],cptr[0],cptr[1],cptr[2],false,
- if(mydebug){
- CubitVector tmp1 = points[coordsout2[k]]->coordinates();
- CubitVector tmp2 = points[coordsout2[k+1]]->coordinates();
- CubitVector tmp3 = points[coordsout2[k+2]]->coordinates();
- if(cptr[0]){
- if(cptr[1]){
- if(cptr[2]){
- point_list,
- feature_angle,
- interp_order,
- split_surfaces,
- cholla_ptr );
- return status;
- NULL,
- body_ptr2);
- return status;
- if ( cholla_ptr )
- new_bodies.clean_out();
- status = separate_shells_into_bodies( body_ptr2, is_sheet_body, new_bodies );
- return status;
- if ( delete_bodies == CUBIT_TRUE )
- make_persistents_webcut(bodysm_ptr,body_ptr,body_ptr2,fsurfarray,fcurvearray,
- surfs_in_intersection,surfs_in_subtraction,
- curves_in_intersection,curves_in_subtraction);
- vertsout2.clear();
- coordsout2.clear();
-CubitStatus FacetboolInterface::separate_lumps( BodySM *body_ptr,
- bool is_sheet_body)
- //get all the shells in 'body_ptr'
- DLIList<OCCShell*> facet_shells;
- OCCBody *facet_body = CAST_TO( body_ptr, OCCBody );
- facet_body->get_shells( facet_shells );
- // some shells here might contain more than one connected
- // patch of surfaces...which is illegal. Separate them into their own shells.
- bool created_shells = false;
- int k,i;
- for( k=facet_shells.size(); k--; )
- OCCShell *facet_shell = facet_shells.get_and_step();
- DLIList<OCCSurface*> facet_surfs;
- facet_shell->get_surfaces( facet_surfs );
- DLIList<OCCSurface*> connected_patch;
- int max_num_passes = facet_surfs.size();
- int num_passes=0; //prevents infinite loop
- while( facet_surfs.size() && num_passes < max_num_passes )
- connected_patch.clean_out();
- OCCQueryEngine::instance()->get_connected_patch( facet_surfs, connected_patch );
- if( num_passes == 0 )
- int kk;
- for( kk=connected_patch.size(); kk--; )
- OCCSurface *f_surf = connected_patch.get_and_step();
- f_surf->set_shell_sense( facet_shell, CUBIT_UNKNOWN );
- else
- f_surf->set_shell_sense( facet_shell, CUBIT_FORWARD );
- else //extract surfaces out of current shell and make them into their own shell
- facet_shell->disconnect_surfaces( connected_patch );
- DLIList<Surface*> tmp_surfs;
- CAST_LIST( connected_patch, tmp_surfs, Surface );
- ShellSM *shellsm_ptr;
- OCCModifyEngine::instance()->make_facet_shell(tmp_surfs, shellsm_ptr);
- if ( shellsm_ptr == NULL )
- PRINT_ERROR("Problems building facet based shell entity.\n");
- else
- OCCShell *tmp_shell = static_cast<OCCShell*>(shellsm_ptr);
- int kk;
- //now for each surface, add sense wrt this new shell
- for( kk=tmp_surfs.size(); kk--;)
- OCCSurface *tmp_facet_surf = CAST_TO(tmp_surfs.get_and_step(), OCCSurface);
- //if it's not a sheet body, tag the surfs wrt the shell, FORWARD
- tmp_facet_surf->set_shell_sense( tmp_shell, CUBIT_UNKNOWN );
- else
- tmp_facet_surf->set_shell_sense( tmp_shell, CUBIT_FORWARD );
- created_shells = true;
- OCCLump *facet_lump = static_cast<OCCLump*>( facet_shell->get_lump() );
- facet_lump->add_shell( tmp_shell );
- num_passes++;
- bool created_lumps = false;
- DLIList<OCCShell*> void_shells;
- int number_regions = 0;
- if( created_shells )
- //determine which shells are regions and which are voids
- //get a point we know is outside the body
- CubitBox bbox;
- CubitVector centroid;
- double vol;
- facet_body->mass_properties( centroid, vol );
- OCCQueryEngine::instance()->create_facet_bounding_box( facet_body, bbox );
- CubitVector point_outside = 2*(bbox.maximum() - centroid);
- point_outside = centroid + point_outside;
- facet_shells.clean_out();
- CubitPointContainment point_cont;
- point_cont = facet_shell->point_containment( point_outside );
- if( point_cont == CUBIT_PNT_OUTSIDE )
- number_regions++;
- else if( point_cont == CUBIT_PNT_INSIDE )
- void_shells.append( facet_shell );
- //is a region...if it is the second found region, should be
- //in its own lump
- if( number_regions>1 && point_cont == CUBIT_PNT_OUTSIDE )
- created_lumps = true;
- //remove this shell from its current Lump
- OCCLump *tmp_lump = static_cast<OCCLump*>(facet_shell->get_lump());
- tmp_lump->remove_shell( facet_shell );
- //make a new lump containing this shell
- Lump *new_lump;
- DLIList<ShellSM*> sm_shells;
- sm_shells.append( static_cast<ShellSM*>(facet_shell) );
- OCCModifyEngine::instance()->make_facet_lump( sm_shells, new_lump );
- //add lump to body
- facet_body->add_lump( static_cast<OCCLump*>(new_lump) );
- if( void_shells.size() && created_lumps )
- //the void shells are still in the original lump. We need to pair each
- //up with the region that encloses it
- //make a list of all the region (non-void) shells in the body
- DLIList<OCCShell*> region_shells;
- facet_body->get_shells( region_shells );
- for(k=void_shells.size(); k--;)
- if( region_shells.move_to( void_shells.get_and_step() ) )
- region_shells.change_to( NULL );
- region_shells.remove_all_with_value( NULL );
- //for each void lump...find the region that contains it
- for( k=void_shells.size(); k--; )
- OCCShell *void_shell = void_shells.get_and_step();
- //get a point on the void
- DLIList<OCCSurface*> tmp_surfs;
- void_shell->get_surfaces( tmp_surfs );
- CubitVector point_on_shell;
- DLIList<CubitFacet*> facet_list;
- tmp_surfs.get()->tris( facet_list );
- point_on_shell = facet_list.get()->center();
- //get the region that contains that point
- for( i=region_shells.size(); i--; )
- OCCShell *region_shell = region_shells.get_and_step();
- tmp_surfs.clean_out();
- region_shell->get_surfaces( tmp_surfs );
- if( region_shell->point_containment( point_on_shell )
- == CUBIT_PNT_INSIDE )
- //remove the void shell from it's lump
- OCCLump *tmp_lump = static_cast<OCCLump*>(void_shell->get_lump());
- tmp_lump->remove_shell( void_shell );
- //add the void shell to the region's lump
- tmp_lump = static_cast<OCCLump*>(region_shell->get_lump());
- tmp_lump->add_shell( void_shell );
- break;
-CubitStatus FacetboolInterface::separate_shells_into_bodies(BodySM *body_ptr,
- bool is_sheet_body,
- DLIList<BodySM*> &new_bodies)
- //first separate the body into its lumps
- if(!separate_lumps(body_ptr,is_sheet_body))
- return CUBIT_FAILURE;
- //split out each lump into it's own body
- DLIList<BodySM*> split_bodies;
- OCCModifyEngine::instance()->split_body( body_ptr, split_bodies);
- new_bodies += split_bodies;
-CubitStatus FacetboolInterface::facetbody_to_facetbool(
- DLIList<OCCSurface*> &facet_surf_list,
- STD(vector)<double> &body_verts,
- STD(vector)<int> &body_connections,
- STD(vector)<int> *f_c_indices,
- STD(vector)<OCCSurface *>& fsurfarray,
- STD(vector)<OCCCurve *>& fcurvearray
- int mydebug = 0;
- if(mydebug){
- int i, j, k, m, n, vtx[3], hashvalue, *hasharrayptr, hasharraysize, ifoundit;
- IntegerHash *hashobj;
- double xx, yy, zz, xval, yval, zval;
- OCCSurface *facet_surface;
- DLIList<CubitFacet*> facetlist;
- DLIList<CubitFacetEdge*> c_edgelist, f_edgelist;
- DLIList<OCCCurve *> curve_list;
- CubitPoint *point;
- CubitFacet *facet;
- OCCCurve *curve;
- CubitFacetEdge *c_edge, *edge;
- int numhashbins, c_index;
- numhashbins = 101;
- status = CUBIT_SUCCESS;
- hashobj = new IntegerHash(numhashbins,20);
- for ( i = 0; i < facet_surf_list.size(); i++ ) {
- facet_surface = facet_surf_list.get_and_step();
- fsurfarray.push_back(facet_surface);
- facet_surface->get_my_facetedges(f_edgelist);
- for ( m = f_edgelist.size(); m > 0; m-- ) {
- edge = f_edgelist.get_and_step();
- edge->set_flag(0); // Initialize edge flags.
- if(mydebug)
- edge->debug_draw(CUBIT_PINK);
- // Assume that each facet surf occurs only once, so there won't be
- // duplicates on fsarray.
- facetlist.clean_out();
- facet_surface->tris(facetlist);
- curve_list.clean_out();
- facet_surface->get_curves(curve_list);
- for ( m = 0; m < curve_list.size(); m++ ) {
- curve = curve_list.get_and_step();
- c_index = findcurve(curve,fcurvearray);
- c_edgelist.clean_out();
- curve->get_facets(c_edgelist);
- for ( n = c_edgelist.size(); n > 0; n-- ) {
- c_edge = c_edgelist.get_and_step();
- c_edge->set_flag(c_index+1);
- if(mydebug)
- c_edge->debug_draw(CUBIT_RED);
- int efindex[3];
- for ( j = facetlist.size(); j > 0; j-- ) {
- facet = facetlist.get_and_step();
- for ( k = 0; k < 3; k++ ) {
- point = facet->point(k);
- edge = facet->edge(k);
- if(mydebug){
- if(edge->get_flag()){
- edge->debug_draw(CUBIT_WHITE);
- efindex[k] = edge->get_flag();
- xx = point->x();
- yy = point->y();
- zz = point->z();
- // Get a vertex number.
- hashvalue = FBDataUtil::makeahashvaluefrom_coord(xx,yy,zz,numhashbins);
- hasharrayptr = hashobj->getHashBin(hashvalue,&hasharraysize);
- ifoundit = -1;
- for ( m = 0; m < hasharraysize; m++ ) {
- n = hasharrayptr[m];
- xval = body_verts[3*n];
- yval = body_verts[3*n+1];
- zval = body_verts[3*n+2];
- if ( ( fabs(xval-xx) < 1.e-6 ) &&
- ( fabs(yval-yy) < 1.e-6 ) &&
- ( fabs(zval-zz) < 1.e-6 ) ) {
- ifoundit = n;
- break;
- if ( ifoundit == -1 ) {
- ifoundit = body_verts.size()/3;
- body_verts.push_back(xx);
- body_verts.push_back(yy);
- body_verts.push_back(zz);
- hashobj->addtoHashList(hashvalue,ifoundit);
- vtx[k] = ifoundit;
- body_connections.push_back(vtx[0]);
- body_connections.push_back(vtx[1]);
- body_connections.push_back(vtx[2]);
- f_c_indices->push_back(i+1); // put the surface index for the facet
- f_c_indices->push_back(efindex[2]); // edge indices for the facet
- f_c_indices->push_back(efindex[0]);
- f_c_indices->push_back(efindex[1]);
- if(mydebug)
- delete hashobj;
- return status;
-// Function : dofacetboolean
-// Description: do facetboolean operations on a list of bodies.
-// Date : 02/04
-CubitStatus FacetboolInterface::dofacetboolean(DLIList<BodySM*>& body_list,
- BodySM*& newBody,
- bool keep_old,
- const CubitFacetboolOp op)
- int k;
- BodySM *body_sm1, *body_sm2, *body_out;
- CubitStatus status = CUBIT_FAILURE;
- bool intersection_found = false;
- body_sm1 = body_list.get_and_step();
- for ( k = body_list.size() - 1; k > 0; k-- ) {
- body_out =0;
- if(!body_sm1)
- body_sm1=body_list.get_and_step();
- else{
- body_sm2 = body_list.get_and_step();
- status = dofacetboolean_2bodies(body_sm1,body_sm2,body_out,keep_old,
- intersection_found,op);
- if ( keep_old == false){
- //if there was an intersection, we want to delete the two
- //original bodies if we are not keeping old.
- //Also, if we we were performing an INTERSECTION we
- //want to delete the two original bodies even if there was
- //no intersection between the two bodies (again if we
- //are not keeping originals).
- if(intersection_found == true || op == CUBIT_FB_INTERSECTION) {
- delete_solid_model_entities(body_sm2);
- delete_solid_model_entities(body_sm1);
- body_sm2=NULL;
- body_sm1=NULL;
- //if we are not keeping old, we want to delete the second
- //body even if there was no intersection between the two
- //bodies (for a subtration).
- else if(op == CUBIT_FB_SUBTRACTION) {
- body_sm2=NULL;
- if ( body_out ) body_sm1 = body_out;
- newBody = body_sm1;
- return status;
-// Function : dofacetboolean_subtract
-// Description: do facetboolean subtract operations on a list of bodies.
-// Date : 02/04
-CubitStatus FacetboolInterface::dofacetboolean_subtract(BodySM*& tool_body,
- DLIList<BodySM*>& from_bodies,
- DLIList<BodySM*>& new_bodies,
- bool keep_old,
- bool* to_be_deleted,
- int k;
- BodySM *body_sm2, *body_out;
- for ( k = 0; k < from_bodies.size(); k++ ) {
- body_out = 0;
- body_sm2 = from_bodies.get_and_step();
- status = dofacetboolean_2bodies(body_sm2,tool_body,body_out,keep_old,
- if ( (keep_old == false) && (intersection_found == true) ) {
- to_be_deleted[k] = true;
- if ( (status == CUBIT_SUCCESS) && (body_out) ) new_bodies.append(body_out);
- return status;
-CubitStatus FacetboolInterface::dofacetboolean_2bodies(BodySM*& body_in1,
- BodySM*& body_in2,
- BodySM*& body_out,
- bool keep_old,
- bool& intersection_found,
-CubitStatus status;
-STD(vector)<double> body_verts;
-STD(vector)<double> body2_verts;
-STD(vector)<int> body_connections, newbodyfacets;
-STD(vector)<int> body2_connections, newbody2facets;
-STD(vector)<double> vertsout;
-STD(vector)<int> coordsout;
-STD(vector)<int> f_c_indices1;
-STD(vector)<int> f_c_indices2;
-STD(vector)<OCCSurface *> fsurfarray1, fsurfarray2;
-STD(vector)<OCCCurve *> fcurvearray1, fcurvearray2;
-STD(vector)<int> surfindex;
-STD(vector)<int> curveindex;
- bool *surfs_in_intersection2, *surfs_in_subtraction2;
- bool *curves_in_intersection2, *curves_in_subtraction2;
- intersection_found = true;
- Body *tmp_body_1 = CAST_TO(body_in1->topology_entity(), Body);
- Body *tmp_body_2 = CAST_TO(body_in2->topology_entity(), Body);
- //try to figure out if we are using sheet bodies
- //if it is ambiguous, print a warning.
- if(tmp_body_1 && tmp_body_1->is_sheet_body()){
- else if(tmp_body_2 && tmp_body_2->is_sheet_body()){
- if(tmp_body_1 && tmp_body_2 &&
- tmp_body_1->is_sheet_body() != tmp_body_2->is_sheet_body())
- PRINT_WARNING("Geometric boolean requested for a sheet body and a non-sheet body.\n");
- OCCBody *fbody_ptr;
- fbody_ptr = dynamic_cast<OCCBody *>(body_in1);
- fbody_ptr->get_surfaces(facet_surf_list);
- fsurfarray1,fcurvearray1);
- facet_surf_list.clean_out();
- fbody_ptr = dynamic_cast<OCCBody *>(body_in2);
- status = facetbody_to_facetbool(facet_surf_list,body2_verts,
- body2_connections,&f_c_indices2,
- fsurfarray2,fcurvearray2);
- body2_verts,body2_connections,
- newbodyfacets,newbody2facets,
- &f_c_indices1,
- &f_c_indices2);
- STD(vector)<bool> is_body_1;
- &surfindex,&curveindex,&is_body_1,op);
- if ( (vertsout.size() == 0) || (coordsout.size() == 0)) {
- intersection_found = false;
- // If there was no body_out, we are just checking if there was any
- // intersection. If we got this far, there was -- so return.
- if ( &body_out == 0 ) return CUBIT_SUCCESS;
- surfs_in_intersection = new bool[1+fsurfarray1.size()];
- surfs_in_subtraction = new bool[1+fsurfarray1.size()];
- curves_in_intersection = new bool[1+fcurvearray1.size()];
- curves_in_subtraction = new bool[1+fcurvearray1.size()];
- surfs_in_intersection2 = new bool[1+fsurfarray2.size()];
- surfs_in_subtraction2 = new bool[1+fsurfarray2.size()];
- curves_in_intersection2 = new bool[1+fcurvearray2.size()];
- curves_in_subtraction2 = new bool[1+fcurvearray2.size()];
- unsigned int k;
- for ( k = 1; k < 1 + fsurfarray1.size(); k++ ) {
- for ( k = 1; k < 1 + fcurvearray1.size(); k++ ) {
- for ( k = 1; k < 1 + fsurfarray2.size(); k++ ) {
- surfs_in_subtraction2[k] = surfs_in_intersection2[k] = false;
- for ( k = 1; k < 1 + fcurvearray2.size(); k++ ) {
- curves_in_subtraction2[k] = curves_in_intersection2[k] = false;
- curves_in_subtraction,op,1);
- // If op == unite, the curves ans surfs that are undamaged are those
- // for which xxx_in_intereseciton = 0 false and xxx_in_subtraction == true
- status = intersector->get_persistent_entity_info(surfs_in_intersection2,
- curves_in_intersection2,surfs_in_subtraction2,
- curves_in_subtraction2,op,2);
- vertsout[k+1],
- vertsout[k+2] );
- td->set(surfindex[k/3],cptr[0],cptr[1],cptr[2],is_body_1[k/3],
- int interp_order;
- BodySM *body_ptr;
- interp_order = 0;
- point_list,
- feature_angle,
- interp_order,
- split_surfaces,
- cholla_ptr );
- return status;
- NULL,
- body_ptr);
- return status;
- if ( cholla_ptr )
- if ( keep_old == false ) {
- make_persistents_boolean(body_in2,body_ptr,fsurfarray2,fcurvearray2,
- surfs_in_intersection2,surfs_in_subtraction2,
- curves_in_intersection2,curves_in_subtraction2,op,false);
- make_persistents_boolean(body_in1,body_ptr,fsurfarray1,fcurvearray1,
- curves_in_intersection,curves_in_subtraction,op,true);
- body_out = body_ptr;
- //separate the lumps in the "body_out", these will be converted to
- //separate volumes later in the code.
- status=separate_lumps(body_out,is_sheet_body);
- vertsout.clear();
- delete [] surfs_in_intersection2; delete [] surfs_in_subtraction2;
- delete [] curves_in_intersection2; delete [] curves_in_subtraction2;
- return status;
-int FacetboolInterface::findcurve(OCCCurve *curve,
- STD(vector)<OCCCurve *>& fcurvearray)
-unsigned int i;
- for ( i = 0; i < fcurvearray.size(); i++ ) {
- if ( fcurvearray[i] == curve ) {
- return i;
- fcurvearray.push_back(curve);
- return fcurvearray.size() - 1;
-void FacetboolInterface::make_persistents_webcut(BodySM *body_in,
- BodySM *body_out1,
- BodySM *body_out2,
- STD(vector)<OCCCurve *>& fcurvearray,
- bool *surfs_in_subtraction,
- bool *curves_in_subtraction
-unsigned int k, n;
-DLIList<CubitSimpleAttrib*> csa_list;
-OCCBody *facet_body_in = CAST_TO(body_in, OCCBody);
-OCCBody *facet_body_out1;
-OCCBody *facet_body_out2;
- facet_body_out1 = CAST_TO(body_out1, OCCBody);
- facet_body_out2 = CAST_TO(body_out2, OCCBody);
-// Fix the curves.
-DLIList<OCCCurve*> fcurvelist, fcurvelist2;
- facet_body_out1->get_curves(fcurvelist);
- facet_body_out2->get_curves(fcurvelist2);
- for ( n = 1; n < 1 + fcurvearray.size(); n++ ) {
- if ( (curves_in_intersection[n] == true) && (curves_in_subtraction[n] == false) ) {
- make_persistent_curves(fcurvelist,fcurvearray,n);
- } else if ( (curves_in_intersection[n] == false) &&
- (curves_in_subtraction[n] == true) ) {
- make_persistent_curves(fcurvelist2,fcurvearray,n);
-// Fix the surfaces
-DLIList<OCCSurface*> fsurfaceslist, fsurfaceslist2;
- facet_body_out1->get_surfaces(fsurfaceslist);
- facet_body_out2->get_surfaces(fsurfaceslist2);
- for ( n = 1; n < 1 + fsurfarray.size(); n++ ) {
- if ( (surfs_in_intersection[n] == true) && (surfs_in_subtraction[n] == false) ) {
- make_persistent_surfaces(fsurfaceslist,fsurfarray,n);
- } else if ( (surfs_in_intersection[n] == false) &&
- (surfs_in_subtraction[n] == true) ) {
- make_persistent_surfaces(fsurfaceslist2,fsurfarray,n);
-// Fix the lumps.
-OCCLump *florig, *fl2;
-DLIList<OCCLump*> flumplist, flumplist2;
- facet_body_in->get_lumps(flumplist);
- facet_body_out1->get_lumps(flumplist2);
- florig = flumplist.get();
- fl2 = flumplist2.get();
- if ( florig->owner() ) {
- florig->owner()->swap_bridge(florig,fl2,false);
- florig->get_simple_attribute(csa_list);
- for ( k = csa_list.size(); k > 0; k-- ) {
- CubitSimpleAttrib* csa = csa_list.get_and_step();
- fl2->append_simple_attribute_virt(csa);
-// Fix the bodies.
- if ( facet_body_in->owner() ) {
- facet_body_in->owner()->swap_bridge(facet_body_in,facet_body_out1,false);
- facet_body_in->get_simple_attribute(csa_list);
- facet_body_out1->append_simple_attribute_virt(csa);
-void FacetboolInterface::make_persistents_imprint(BodySM *body_in,
-OCCBody *facet_body_out1 = CAST_TO(body_out1, OCCBody);
-unsigned int n;
-// Fix the curves.
- DLIList<OCCCurve*> fcurvelist;
- make_persistent_curves(fcurvelist,fcurvearray,n,0);
- DLIList<OCCSurface*> fsurfaceslist;
- make_persistent_surfaces(fsurfaceslist,fsurfarray,n,0);
-// Fix the lumps.
-int k;
-// Fix the bodies.
-void FacetboolInterface::make_persistents_boolean(BodySM *body_in,
- bool *curves_in_subtraction,
- const CubitFacetboolOp op,
- bool body_1
- unsigned int n;
- DLIList<CubitSimpleAttrib*> csa_list;
- OCCBody *facet_body_in = CAST_TO(body_in, OCCBody);
- OCCBody *facet_body_out1 = CAST_TO(body_out1, OCCBody);
- int which_parent;
- bool bvalue1 = false, bvalue2 = false;
- if ( body_1 == true ) which_parent = 1;
- else which_parent = 2;
- switch (op) {
- case CUBIT_FB_UNION:
- bvalue1 = false;
- bvalue2 = true;
- break;
- case CUBIT_FB_INTERSECTION:
- bvalue2 = false;
- bvalue1 = true;
- break;
- case CUBIT_FB_SUBTRACTION:
- if ( body_1 == true ) {
- bvalue2 = false;
- bvalue1 = true;
- } else {
- bvalue1 = false;
- bvalue2 = true;
- break;
-// Fix the curves.
- if ( (curves_in_intersection[n] == bvalue1) &&
- (curves_in_subtraction[n] == bvalue2) ) {
- make_persistent_curves(fcurvelist,fcurvearray,n,which_parent);
- if ( (surfs_in_intersection[n] == bvalue1) &&
- (surfs_in_subtraction[n] == bvalue2) ) {
- make_persistent_surfaces(fsurfaceslist,fsurfarray,n,which_parent);
-// Fix the lumps.
-int k;
-// Fix the bodies.
-void FacetboolInterface::make_persistent_curves(DLIList<OCCCurve*> fcurvelist,
- int n,
- int which_parent)
-int k, m, jj;
-OCCCurve *fcurveorig, *fcurve2;
-int *marked3, index;
-bool ifoundit;
-OCCPoint *fpointorig, *fpoint2;
-DLIList<OCCPoint*> fpointlist, fpointlist2;
-CubitFacet *cfac;
-bool is_from_1, error;
-TDFacetboolData* tdf;
- fcurveorig = fcurvearray[n-1];
- ifoundit = false;
- for ( k = fcurvelist.size(); k > 0; k-- ) {
- fcurve2 = fcurvelist.get_and_step();
- if ( fcurve2->owner() ) continue; // If owner is already set, skip it.
- CurveFacetEvalTool *evaltool = fcurve2->get_eval_tool();
- DLIList<CubitFacetEdge*> edgelist;
- CubitFacetEdge *cfedge;
- evaltool->get_facets(edgelist);
- cfedge = edgelist.get();
- cfac = cfedge->adj_facet(0);
- index = cfac->edge_index(cfedge);
- tdf = TDFacetboolData::get(cfac);
- if ( which_parent ) {
- is_from_1 = tdf->parent_is_body_1();
- if ( ( (is_from_1 == true) && (which_parent == 2) ) ||
- ( (is_from_1 == false) && (which_parent == 1) ) ) continue;
- marked3 = tdf->get_edge_indices(cfac->is_backwards());
- if ( marked3[(index+1)%3] == n ) ifoundit = true;
- else {
- cfac = cfedge->adj_facet(1);
- if (cfac) {
- if ( ifoundit == true ) {
- fpointlist.clean_out();
- fpointlist2.clean_out();
- fcurveorig->get_points(fpointlist);
- fcurve2->get_points(fpointlist2);
- for ( jj = fpointlist.size(); jj > 0; jj-- ) {
- error = false;
- fpointorig = fpointlist.get_and_step();
- fpoint2 = fpointlist2.get_and_step();
- while ( fpoint2->coordinates() != fpointorig->coordinates() ) {
- if ( fpointlist2.is_at_beginning() == CUBIT_TRUE ) {
-// PRINT_WARNING("Unable to make point on curve persistent.\n");
- error = true;
- break;
- if ( error == true ) continue;
- if ( fpointorig->owner() && !(fpoint2->owner()) ) {
- fpointorig->owner()->swap_bridge(fpointorig,fpoint2,false);
- fpointorig->get_simple_attribute(csa_list);
- for ( m = csa_list.size(); m > 0; m-- ) {
- fpoint2->append_simple_attribute_virt(csa);
- if ( fcurveorig->owner() != 0 )
- fcurveorig->owner()->swap_bridge(fcurveorig,fcurve2,false);
- fcurveorig->get_simple_attribute(csa_list);
- fcurve2->append_simple_attribute_virt(csa);
- break;
-void FacetboolInterface::make_persistent_surfaces(DLIList<OCCSurface*> fsurfaceslist,
- int n,
- int which_parent)
-int k, m;
-OCCSurface *fsorig, *fsurf2;
-bool is_from_1;
- fsorig = fsurfarray[n-1];
- for ( k = fsurfaceslist.size(); k > 0; k-- ) {
- fsurf2 = fsurfaceslist.get_and_step();
- DLIList<CubitFacet*> facet_list2;
- fsurf2->tris(facet_list2);
- CubitFacet* facet2 = facet_list2.get();
- TDFacetboolData* tdf = TDFacetboolData::get(facet2);
- int marked2 = tdf->get_surf_index();
- if ( marked2 == n ) {
- if ( fsorig->owner() != 0 )
- fsorig->owner()->swap_bridge(fsorig,fsurf2,false);
- fsorig->get_simple_attribute(csa_list);
- fsurf2->append_simple_attribute_virt(csa);
- break;
-CubitStatus FacetboolInterface::FB_imprint_with_curves(BodySM*& body_in,
- bool keep_old)
- fbody_ptr = dynamic_cast<OCCBody *>(body_in);
-STD(vector)<int> f_c_indices;
-STD(vector)<OCCSurface *> fsurfarray;
-STD(vector)<OCCCurve *> fcurvearray;
- body_connections,&f_c_indices,
- FBImprint *imprinter = new FBImprint();
- status = imprinter->imprint_body_curve(body_verts,body_connections,
- FB_imprint_edge_coords,FB_imprint_edges,
- FB_imprint_edge_bboxes,&f_c_indices);
- status = imprinter->update_surfs_and_curves(vertsout,coordsout,
- &surfindex,&curveindex);
-unsigned int k;
- vertsout[k+1],
- vertsout[k+2] );
- int interp_order;
- interp_order = 0;
- split_surfaces = CUBIT_TRUE;
- point_list,
- feature_angle,
- interp_order,
- split_surfaces,
- cholla_ptr );
- return status;
- NULL,
- body_out);
- return status;
- if ( cholla_ptr )
- vertsout.clear();
- make_persistents_imprint(body_in,body_out,fsurfarray,fcurvearray);
- delete imprinter;
- return status;
-CubitStatus FacetboolInterface::dofacetboolean_2bodies_imprint(BodySM*& body_in1,
- BodySM*& body_out1,
- BodySM*& body_out2,
- bool keep_old)
-STD(vector)<double> vertsout1, vertsout2;
-STD(vector)<int> coordsout1, coordsout2;
-STD(vector)<int> surfindex1, surfindex2;
-STD(vector)<int> curveindex1, curveindex2;
- if(tmp_body_1->is_sheet_body() != tmp_body_2->is_sheet_body())
- intersector->set_imprint();
- &f_c_indices1,
- &f_c_indices2);
- status = intersector->update_surfs_and_curves(vertsout1,coordsout1,
- &surfindex1,&curveindex1,1);
- status = intersector->update_surfs_and_curves(vertsout2,coordsout2,
- &surfindex2,&curveindex2,2);
-unsigned int k;
- for ( k = 0; k < vertsout1.size(); k += 3 ) {
- new_point = (CubitPoint *) new CubitPointData( vertsout1[k],
- vertsout1[k+1],
- vertsout1[k+2] );
- for ( k = 0; k < coordsout1.size(); k += 3 ) {
- facet_ptr = new CubitFacetData( points[coordsout1[k]],
- points[coordsout1[k+1]],
- points[coordsout1[k+2]] );
- cptr[0] = curveindex1[k];
- cptr[1] = curveindex1[k+1];
- cptr[2] = curveindex1[k+2];
- td->set(surfindex1[k/3],cptr[0],cptr[1],cptr[2],false,
- int interp_order;
- interp_order = 0;
- point_list,
- feature_angle,
- interp_order,
- split_surfaces,
- cholla_ptr );
- return status;
- NULL,
- body_out1);
- return status;
- if ( cholla_ptr )
- vertsout1.clear();
- coordsout1.clear();
- vertsout2[k+1],
- vertsout2[k+2] );
- point_list,
- feature_angle,
- interp_order,
- split_surfaces,
- cholla_ptr );
- return status;
- NULL,
- body_out2);
- return status;
- if ( cholla_ptr )
- make_persistents_imprint(body_in1,body_out1,fsurfarray1,fcurvearray1);
- make_persistents_imprint(body_in2,body_out2,fsurfarray2,fcurvearray2);
- //separate the lumps in the "body_out1" and "body_out2", these will
- //be converted to separate volumes later in the code.
- status=separate_lumps(body_out1, is_sheet_body);
- status=separate_lumps(body_out2, is_sheet_body);
- return status;
-CubitStatus FacetboolInterface::make_FB_edge_list(DLIList<Curve*> &ref_edge_list)
-CubitStatus success = CUBIT_SUCCESS;
-Curve *ref_edge_ptr;
-OCCCurve *cfcurve;
-CubitPoint *cfpoint;
-DLIList<CubitPoint *> cfpointlist;
-int i, j, lastvert, nextvert;
-CubitVector coords;
- ref_edge_list.reset();
- for( i = ref_edge_list.size(); i > 0; i-- )
- ref_edge_ptr = ref_edge_list.get_and_step();
- cfcurve = CAST_TO( ref_edge_ptr, OCCCurve);
- cfpointlist.clean_out();
- cfcurve->get_points(cfpointlist);
- cfpoint = cfpointlist.get_and_step();
- coords = cfpoint->coordinates();
- lastvert = find_coord(coords.x(),coords.y(),coords.z());
- for ( j = cfpointlist.size()-1; j > 0; j-- ) {
- nextvert = find_coord(coords.x(),coords.y(),coords.z());
- FB_Edge *FBedge = new FB_Edge(lastvert,nextvert,0,0,false);
- FSBoundingBox *bb = make_edge_bounding_box(lastvert,nextvert);
- lastvert = nextvert;
- FB_imprint_edges.push_back(FBedge);
- FB_imprint_edge_bboxes.push_back(bb);
- return success;
-int FacetboolInterface::find_coord(double xx, double yy, double zz)
-int value;
-unsigned int i;
- value = -1;
- for ( i = 0; i < FB_imprint_edge_coords.size(); i++ ) {
- if ( (fabs(FB_imprint_edge_coords[i]->coord[0] - xx) < GEOMETRY_RESABS) &&
- (fabs(FB_imprint_edge_coords[i]->coord[1] - yy) < GEOMETRY_RESABS) &&
- (fabs(FB_imprint_edge_coords[i]->coord[2] - zz) < GEOMETRY_RESABS) ) {
- value = (int)i;
- break;
- if ( value == -1 ) {
- value = FB_imprint_edge_coords.size();
- FB_Coord *FBcoord = new FB_Coord(xx,yy,zz);
- FB_imprint_edge_coords.push_back(FBcoord);
- return value;
-FSBoundingBox* FacetboolInterface::make_edge_bounding_box(int v0, int v1)
-FSBoundingBox *bb;
-double xmin, ymin, zmin, xmax, ymax, zmax;
- xmin = ( FB_imprint_edge_coords[v0]->coord[0] < FB_imprint_edge_coords[v1]->coord[0] ) ?
- FB_imprint_edge_coords[v0]->coord[0] : FB_imprint_edge_coords[v1]->coord[0];
- ymin = ( FB_imprint_edge_coords[v0]->coord[1] < FB_imprint_edge_coords[v1]->coord[1] ) ?
- FB_imprint_edge_coords[v0]->coord[1] : FB_imprint_edge_coords[v1]->coord[1];
- zmin = ( FB_imprint_edge_coords[v0]->coord[2] < FB_imprint_edge_coords[v1]->coord[2] ) ?
- FB_imprint_edge_coords[v0]->coord[2] : FB_imprint_edge_coords[v1]->coord[2];
- xmax = ( FB_imprint_edge_coords[v0]->coord[0] > FB_imprint_edge_coords[v1]->coord[0] ) ?
- ymax = ( FB_imprint_edge_coords[v0]->coord[1] > FB_imprint_edge_coords[v1]->coord[1] ) ?
- zmax = ( FB_imprint_edge_coords[v0]->coord[2] > FB_imprint_edge_coords[v1]->coord[2] ) ?
- if ( (xmax - xmin) < 2.0*GEOMETRY_RESABS ) {
- xmin -= GEOMETRY_RESABS;
- xmax += GEOMETRY_RESABS;
- if ( (ymax - ymin) < 2.0*GEOMETRY_RESABS ) {
- ymin -= GEOMETRY_RESABS;
- ymax += GEOMETRY_RESABS;
- if ( (zmax - zmin) < 2.0*GEOMETRY_RESABS ) {
- zmin -= GEOMETRY_RESABS;
- zmax += GEOMETRY_RESABS;
- bb = new FSBoundingBox(xmin, ymin, zmin, xmax, ymax, zmax);
- return bb;
-void FacetboolInterface::get_edge_list_bbox(CubitBox& edge_list_bbox)
-unsigned int i;
-double min[3],max[3];
- min[0] = min[1] = min[2] = CUBIT_DBL_MAX - 1.0;
- max[0] = max[1] = max[2] = -CUBIT_DBL_MAX;
- min[0] = ( min[0] < FB_imprint_edge_coords[i]->coord[0] ) ? min[0] :
- FB_imprint_edge_coords[i]->coord[0];
- min[1] = ( min[1] < FB_imprint_edge_coords[i]->coord[1] ) ? min[1] :
- FB_imprint_edge_coords[i]->coord[1];
- min[2] = ( min[2] < FB_imprint_edge_coords[i]->coord[2] ) ? min[2] :
- FB_imprint_edge_coords[i]->coord[2];
- max[0] = ( max[0] > FB_imprint_edge_coords[i]->coord[0] ) ? max[0] :
- max[1] = ( max[1] > FB_imprint_edge_coords[i]->coord[1] ) ? max[1] :
- max[2] = ( max[2] > FB_imprint_edge_coords[i]->coord[2] ) ? max[2] :
- if ( (max[0] - min[0]) < 2.0*GEOMETRY_RESABS ) {
- min[0] -= GEOMETRY_RESABS;
- max[0] += GEOMETRY_RESABS;
- if ( (max[1] - min[1]) < 2.0*GEOMETRY_RESABS ) {
- min[1] -= GEOMETRY_RESABS;
- max[1] += GEOMETRY_RESABS;
- if ( (max[2] - min[2]) < 2.0*GEOMETRY_RESABS ) {
- min[2] -= GEOMETRY_RESABS;
- max[2] += GEOMETRY_RESABS;
- CubitBox box(min,max);
- edge_list_bbox = box;
Deleted: cgm/trunk/geom/OCC/FacetboolInterface.hpp
--- cgm/trunk/geom/OCC/FacetboolInterface.hpp 2007-10-10 16:30:25 UTC (rev 1306)
+++ cgm/trunk/geom/OCC/FacetboolInterface.hpp 2007-10-10 16:32:10 UTC (rev 1307)
@@ -1,136 +0,0 @@
-#ifndef FACETBOOLINTERFACE_HPP
-#define FACETBOOLINTERFACE_HPP
-class OCCBody;
-class BodySM;
-class OCCSurface;
-class OCCCurve;
-class Curve;
-class CubitBox;
-#include <vector>
-#include "CubitDefines.h"
-#include "DLIList.hpp"
-#include "FBStructs.hpp"
-class FacetboolInterface {
-public:
- FacetboolInterface();
- ~FacetboolInterface();
-CubitStatus webcut_FB(BodySM *bodysm_ptr,
- DLIList<BodySM*>& results_list);
- CubitStatus dofacetboolean(DLIList<BodySM*>& body_list,
- BodySM*& newBody,
- bool keep_old,
- const CubitFacetboolOp op);
- CubitStatus dofacetboolean_subtract(BodySM*& tool_body,
- bool keep_old,
- CubitStatus dofacetboolean_2bodies(BodySM*& body_in1,
- bool keep_old,
-CubitStatus FB_imprint_with_curves(BodySM*& body_in,
- bool keep_old);
- CubitStatus dofacetboolean_2bodies_imprint(BodySM*& body_in1,
- bool keep_old);
- CubitStatus make_FB_edge_list(DLIList<Curve*> &ref_edge_list);
- void get_edge_list_bbox(CubitBox& edge_list_bbox);
-private:
- STD(vector)<FB_Edge*> FB_imprint_edges;
- STD(vector)<FB_Coord*> FB_imprint_edge_coords;
- STD(vector)<FSBoundingBox*> FB_imprint_edge_bboxes;
- CubitStatus facetbody_to_facetbool(
- int findcurve(OCCCurve *curve, STD(vector)<OCCCurve *>& fcurvearray);
- void make_persistents_webcut(BodySM *body_in,
- void make_persistents_imprint(BodySM *body_in,
- void make_persistents_boolean(BodySM *body_in,
- bool body_1
- void make_persistent_curves(DLIList<OCCCurve*> fcurvelist,
- int n,
- int which_parent = 0);
- void make_persistent_surfaces(DLIList<OCCSurface*> fsurfaceslist,
- int n,
- int find_coord(double xx, double yy, double zz);
- FSBoundingBox* make_edge_bounding_box(int v0, int v1);
- //Separate out the different "lumps" in a given body. Generally,
- // lumps are disjoint volumes. They will be converted to separate
- // volumes later in the code.
- CubitStatus separate_lumps( BodySM *body_ptr, bool is_sheet_body );
- //First call separate_lumps to find the disjoing lumps in the body,
- // and then separates the lumps into different bodies.
- CubitStatus separate_shells_into_bodies( BodySM *body_ptr,
- DLIList<BodySM*> &new_bodies );
-#endif
Deleted: cgm/trunk/geom/OCC/GridSearchTree.cpp
--- cgm/trunk/geom/OCC/GridSearchTree.cpp 2007-10-10 16:30:25 UTC (rev 1306)
+++ cgm/trunk/geom/OCC/GridSearchTree.cpp 2007-10-10 16:32:10 UTC (rev 1307)
@@ -1,220 +0,0 @@
-#include <math.h>
-#include "GridSearchTree.hpp"
-double dist (CubitPoint * a, CubitPoint * b){
- return sqrt((a->x() - b->x())*(a->x() - b->x()) + (a->y() - b->y())*(a->y() - b->y()) + (a->z() - b->z())*(a->z() - b->z()) );
-CubitPoint * GridSearchTree::fix(CubitPoint * data) {
- long i, j, k;
- double x, y, z;
- x=data->x();
- y=data->y();
- z=data->z();
- // get the coordinates of the box containing the point
- i=(long)(x/(2*epsilon));
- j=(long)(y/(2*epsilon));
- k=(long)(z/(2*epsilon));
- if (x<0) i--;
- if (y<0) j--;
- if (z<0) k--;
- int ofi;
- int ofj;
- int ofk;
- int ii;
- // calculate the i, j, k offset for the seven neighboring boxes to be searched
- if (fabs(x-i*2*epsilon) < epsilon) ofi = -1; else ofi = 1;
- if (fabs(y-j*2*epsilon) < epsilon) ofj = -1; else ofj = 1;
- if (fabs(z-k*2*epsilon) < epsilon) ofk = -1; else ofk = 1;
- // mindist holds the distance to the current closest point
- double mindist=2*epsilon;
- // curdist holds the distance to the current point
- double curdist;
- // closest is the current closest point
- CubitPoint * closest = NULL;
- // curpoint is the current point
- CubitPoint * curpoint;
- // construct grid cell ( box )
- GridSearchTreeNode * curnode = new GridSearchTreeNode(i+ofi,j+ofj,k+ofk);
- // attempt to find it in the tree
- pos = nodemap.find(curnode);
- if (pos!=nodemap.end())
- // if cell is in the tree search its list for close points
- DLIList<CubitPoint*> curlist = (*pos).first->get_list();
- for (ii= curlist.size(); ii>0; ii--)
- curpoint = curlist.get_and_step();
- curdist = dist(data, curpoint);
- if (curdist<mindist)
- closest = curpoint;
- mindist=curdist;
- delete curnode;
- curnode = new GridSearchTreeNode(i+ofi,j+ofj,k);
- mindist=curdist;
- delete curnode;
- curnode = new GridSearchTreeNode(i+ofi,j,k+ofk);
- mindist=curdist;
- delete curnode;
- curnode = new GridSearchTreeNode(i+ofi,j,k);
- mindist=curdist;
- delete curnode;
- curnode = new GridSearchTreeNode(i,j+ofj,k+ofk);
- mindist=curdist;
- delete curnode;
- curnode = new GridSearchTreeNode(i,j+ofj,k);
- mindist=curdist;
- delete curnode;
- curnode = new GridSearchTreeNode(i,j,k+ofk);
- mindist=curdist;
- delete curnode;
- curnode = new GridSearchTreeNode(i,j,k);
- mindist=curdist;
- // if closest point is within epsilon distance return the closest point
- if (mindist<=epsilon)
- delete curnode;
- return closest;
- else
- // add current point and cell to tree
- if (pos==nodemap.end())
- curnode->add(data);
- nodemap.insert(gmap::value_type(curnode, 1));
- else
- (*pos).first->add(data);
- delete curnode;
- return data;
Deleted: cgm/trunk/geom/OCC/GridSearchTree.hpp
--- cgm/trunk/geom/OCC/GridSearchTree.hpp 2007-10-10 16:30:25 UTC (rev 1306)
+++ cgm/trunk/geom/OCC/GridSearchTree.hpp 2007-10-10 16:32:10 UTC (rev 1307)
@@ -1,37 +0,0 @@
-#ifndef GSTREE_HPP
-#define GSTREE_HPP
-#include "GridSearchTreeNode.hpp"
-#include <typeinfo>
-#if !defined(NT) && !defined(CANT_USE_STD)
-using std::type_info;
-#endif
-#include <map>
-typedef STD(map)< GridSearchTreeNode* , int, GridSearchTreeNode::GSTNodeComparator > gmap;
-class GridSearchTree {
-private:
- double epsilon;
- gmap nodemap;
- gmap::iterator pos;
-public:
- GridSearchTree(double tolerance) {
- epsilon = tolerance;
- ~GridSearchTree() {}
- CubitPoint * fix (CubitPoint * data);
-#endif
Deleted: cgm/trunk/geom/OCC/GridSearchTreeNode.hpp
--- cgm/trunk/geom/OCC/GridSearchTreeNode.hpp 2007-10-10 16:30:25 UTC (rev 1306)
+++ cgm/trunk/geom/OCC/GridSearchTreeNode.hpp 2007-10-10 16:32:10 UTC (rev 1307)
@@ -1,45 +0,0 @@
-#ifndef GSTREENODE_HPP
-#define GSTREENODE_HPP
-class GridSearchTreeNode {
-private:
- DLIList <CubitPoint *> plist;
-public:
- long icoord;
- long jcoord;
- long kcoord;
- GridSearchTreeNode (long i, long j, long k) {
- icoord=i;
- jcoord=j;
- kcoord=k;
- ~GridSearchTreeNode() {}
- DLIList <CubitPoint *> get_list(){
- return plist;
- void add(CubitPoint * data) {
- plist.append(data);
-class GSTNodeComparator {
-public:
- bool operator () (GridSearchTreeNode * a, GridSearchTreeNode * b) const
- return ( a->icoord < b->icoord ) || (a->icoord==b->icoord && a->jcoord<b->jcoord) || (a->icoord == b->icoord && a->jcoord==b->jcoord && a->kcoord < b->kcoord );
-#endif
More information about the cgma-dev
