[cgma-dev] r1429 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov janehu at mcs.anl.gov
Wed Nov 28 13:21:34 CST 2007
Author: janehu
Date: 2007-11-28 13:21:34 -0600 (Wed, 28 Nov 2007)
New Revision: 1429
Modified:
   cgm/trunk/geom/OCC/OCCLump.cpp
   cgm/trunk/geom/OCC/OCCQueryEngine.cpp
   cgm/trunk/geom/OCC/OCCQueryEngine.hpp
   cgm/trunk/geom/OCC/OCCShell.cpp
   cgm/trunk/geom/OCC/OCCShell.hpp
Log:
Added Body, Surface and Curve lists for to store OCC entities used to retrieve parent info for lower topology entities.
Modified: cgm/trunk/geom/OCC/OCCLump.cpp
--- cgm/trunk/geom/OCC/OCCLump.cpp	2007-11-28 18:40:47 UTC (rev 1428)
+++ cgm/trunk/geom/OCC/OCCLump.cpp	2007-11-28 19:21:34 UTC (rev 1429)
@@ -63,14 +63,6 @@
   myTopoDSSolid = theSolid;
-OCCLump::OCCLump(DLIList<ShellSM*> &shells,
-                     BodySM *body_ptr )
-  myBodyPtr = body_ptr;
-  myShells += shells;
 OCCLump::~OCCLump()
@@ -194,8 +186,7 @@
 void OCCLump::get_parents_virt(DLIList<TopologyBridge*> &bodies)
-  if (myBodyPtr != NULL )
-    bodies.append_unique(myBodyPtr);
+  bodies.append(myBodyPtr);
 void OCCLump::get_children_virt(DLIList<TopologyBridge*> &shellsms)
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2007-11-28 18:40:47 UTC (rev 1428)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2007-11-28 19:21:34 UTC (rev 1429)
@@ -111,13 +111,14 @@
 const int OCCQueryEngine::OCCQE_SUBMINOR_VERSION = 0;
 TopTools_DataMapOfShapeInteger *OCCQueryEngine::OCCMap = new TopTools_DataMapOfShapeInteger;
-TopTools_DataMapOfShapeInteger *OCCQueryEngine::OCCMapr = new TopTools_DataMapOfShapeInteger;
-DLIList<TopologyBridge*> *OCCQueryEngine::CGMList = new DLIList<TopologyBridge*>;
+DLIList<OCCBody*> *OCCQueryEngine::BodyList = new DLIList<OCCBody*>;
+DLIList<OCCSurface*> *OCCQueryEngine::SurfaceList = new DLIList<OCCSurface*>;
+DLIList<OCCCurve*> *OCCQueryEngine::CurveList = new DLIList<OCCCurve*>;
 std::map<int, TopologyBridge*>* OCCQueryEngine::OccToCGM = new std::map<int, TopologyBridge*>;
 typedef std::map<int, TopologyBridge*>::value_type valType;
 int OCCQueryEngine::iTotalTBCreated = 0;
-CubitBoolean PRINT_RESULT = CUBIT_FALSE;
+CubitBoolean OCCQueryEngine::PRINT_RESULT = CUBIT_FALSE;
 // Description:
 // Author     :
@@ -1044,6 +1045,7 @@
                 OCCMap->Bind(*posolid, iTotalTBCreated);
                 OccToCGM->insert(valType(iTotalTBCreated,
                                 (TopologyBridge*)body));
+                BodyList->append(body);
         else
@@ -1080,6 +1082,7 @@
                    DLIList<Lump*> lumps;
 		   lumps.append(lump);
 		   body = new OCCBody(lumps);
@@ -1143,6 +1146,7 @@
 		OCCMap->Bind(*poface, iTotalTBCreated);
 				(TopologyBridge*)surface));
+		SurfaceList->append(surface);
 	else
@@ -1205,6 +1209,7 @@
 		OCCMap->Bind(*poedge, iTotalTBCreated);
 				(TopologyBridge*)curve));
+		CurveList->append((OCCCurve*)curve);
         else
@@ -1250,86 +1255,6 @@
        return (OccToCGM->find(k))->second;
-CubitStatus OCCQueryEngine::import_solid_model(FILE *file_ptr,
-                                                 const char* /*file_type*/,
-                                                 DLIList<TopologyBridge*> &imported_entities,
-                                                 CubitBoolean ,
-                                                 const char* ,
-                                                 CubitBoolean,
-                                                 CubitBoolean,
-                                                 CubitBoolean,
-                                                 CubitBoolean,
-                                                 CubitBoolean,
-                                                 CubitBoolean )
-  CubitPoint **points_array = NULL;
-  CurveFacetEvalTool **cfet_array = NULL;
-  FacetEvalTool **fet_array = NULL;
-  //int num_points, num_edges, num_facets;
-  //int num_cfet, num_fet;
-  // read in the file type "MESHED_BASED_GEOMETRY"
-  char fileType[19] = {0};
-  if( fread( fileType, 1, 19, file_ptr) != 19 )
-    PRINT_ERROR("Trouble reading in file type for MBG\n");
-    return CUBIT_FAILURE;
-  if( strncmp( fileType, "MESH_BASED_GEOMETRY", 19 ) )
-    PRINT_ERROR("Not MESH_BASED_GEOMETRY file type\n");
-  // read in the endian value
-  NCubitFile::CIOWrapper file_reader(file_ptr, 19, 0);
-  // read in version #
-  UnsignedInt32 version;
-  file_reader.Read( &version, 1 );
-  //Read in points/edges/facets
-  CubitStatus status;
-  status = restore_facets( file_ptr, file_reader.get_endian(),
-                           num_points, num_edges,
-                           num_facets, points_array, num_cfet,
-                           num_fet, cfet_array, fet_array );
-  if( status == CUBIT_FAILURE)
-    PRINT_ERROR("Problems restore facets\n");
-  //Restore Topology
-  status = restore_topology( file_ptr, file_reader.get_endian(),
-                             num_points, points_array,
-                             num_cfet, cfet_array, num_fet,
-                             fet_array, imported_entities);
-    PRINT_ERROR("Problems restore MDB topology\n");
-  if(cfet_array != NULL)
-    delete [] cfet_array;
-  if(fet_array != NULL)
-    delete [] fet_array;
-  if(points_array != NULL)
-    delete [] points_array;
-  return CUBIT_SUCCESS;
 // Purpose       : Deletes all solid model entities associated with the
 //                 Bodies in the input list.
@@ -1340,13 +1265,14 @@
 // Creation Date : 4/23/01
-void OCCQueryEngine::delete_solid_model_entities(DLIList<BodySM*>&BodyList) const
+void OCCQueryEngine::delete_solid_model_entities(DLIList<BodySM*>&bodyList) const
   BodySM* BodyPtr = NULL;
-  for (int i = 0; i < BodyList.size(); i++ )
+  for (int i = 0; i < bodyList.size(); i++ )
-    BodyPtr = BodyList.get_and_step();
+    BodyPtr = bodyList.get_and_step();
     this->delete_solid_model_entities(BodyPtr);
+    BodyList->remove((OCCBody*)BodyPtr);
   return;
@@ -1431,6 +1357,7 @@
   // Remove the links between OCC and Cubit
   //  unhook_ENTITY_from_VGI(face);
+  SurfaceList->remove((OCCSurface*)surface);
   delete face;
   delete surface;
@@ -1472,6 +1399,7 @@
   //unhook_ENTITY_from_VGI(edge);
+  CurveList->remove((OCCCurve*) curve);
   delete edge;
   delete curve;
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.hpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.hpp	2007-11-28 18:40:47 UTC (rev 1428)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.hpp	2007-11-28 19:21:34 UTC (rev 1429)
@@ -326,6 +326,12 @@
   Curve* populate_topology_bridge(TopoDS_Edge aShape);
   Point* populate_topology_bridge(TopoDS_Vertex aShape);
+  static DLIList<OCCBody*> *BodyList ;
+  static DLIList<OCCSurface*> *SurfaceList ;
+  static DLIList<OCCCurve*> *CurveList ;
+  static TopTools_DataMapOfShapeInteger* OCCMap;
+  static std::map<int, TopologyBridge*>* OccToCGM;
 protected:
   OCCQueryEngine();
@@ -342,13 +348,9 @@
                               DLIList<OCCPoint*> &facet_points );
-  static TopTools_DataMapOfShapeInteger* OCCMap;
-  static std::map<int, TopologyBridge*>* OccToCGM;
-  static TopTools_DataMapOfShapeInteger* OCCMapr;
-  static DLIList<TopologyBridge*>* CGMList;
   static int iTotalTBCreated ;
   static OCCQueryEngine* instance_;
-  static CubitBoolean PRINT_RESULTS;
+  static CubitBoolean PRINT_RESULT;
     //- static pointer to unique instance of this class
   static const int OCCQE_MAJOR_VERSION;
Modified: cgm/trunk/geom/OCC/OCCShell.cpp
--- cgm/trunk/geom/OCC/OCCShell.cpp	2007-11-28 18:40:47 UTC (rev 1428)
+++ cgm/trunk/geom/OCC/OCCShell.cpp	2007-11-28 19:21:34 UTC (rev 1429)
@@ -39,6 +39,11 @@
 #include <TopExp.hxx>
 #include <TopTools_IndexedMapOfShape.hxx>
+#include "TopTools_IndexedDataMapOfShapeListOfShape.hxx"
+#include "TopoDS.hxx"
+#include "TopTools_ListIteratorOfListOfShape.hxx"
+#include "TopTools_DataMapOfShapeInteger.hxx"
 // ********** END CUBIT INCLUDES           **********
 // ********** BEGIN STATIC DECLARATIONS    **********
@@ -56,10 +61,6 @@
   myTopoDSShell = theShell;
-OCCShell::OCCShell( DLIList<Surface*> my_surfs )
-  mySurfs += my_surfs;
 // Purpose       : The destructor.
@@ -100,35 +101,41 @@
                                               DLIList<CubitSimpleAttrib*>&)
   { return CUBIT_FAILURE; }
-void OCCShell::add_surfaces(DLIList<Surface*> surfaces)
-    mySurfs = surfaces;
-void OCCShell::add_surface(Surface* surface)
-  mySurfs.append(surface);
-DLIList<Surface*> OCCShell::surfaces()
-  return mySurfs;
 // Purpose       : Query solid modeler topology
 // Special Notes :
-// Creator       : Jason Kraftcheck
+// Author        : Jane Hu
-// Creation Date :
+// Creation Date : 11/28/07
 void OCCShell::get_parents_virt( DLIList<TopologyBridge*>& parents )
-  { /*parents.append(myLump);*/ }
+  OCCBody * body = NULL;
+  DLIList <OCCBody* > *bodies = OCCQueryEngine::BodyList;
+  TopTools_IndexedDataMapOfShapeListOfShape M;
+  for(int i = 0; i <  bodies->size(); i++)
+     body = bodies->get_and_step();
+     TopExp::MapShapesAndAncestors(*(body->get_TopoDS_Shape()),
+				   TopAbs_SHELL, TopAbs_SOLID, M);
+     const TopTools_ListOfShape& ListOfShapes =
+				M.FindFromKey(*(get_TopoDS_Shell()));
+     if (!ListOfShapes.IsEmpty())
+         TopTools_ListIteratorOfListOfShape it(ListOfShapes) ;
+         for (;it.More(); it.Next())
+	   TopoDS_Solid Solid = TopoDS::Solid(it.Value());
+           int k = OCCQueryEngine::OCCMap->Find(Solid);
+	   parents.append((OCCLump*)(OCCQueryEngine::OccToCGM->find(k))->second);
 void OCCShell::get_children_virt( DLIList<TopologyBridge*>& children )
   TopTools_IndexedMapOfShape M;
@@ -140,39 +147,7 @@
-void OCCShell::get_surfaces( DLIList<OCCSurface*>& result_list )
-  TopTools_IndexedMapOfShape M;
-  TopExp::MapShapes(*myTopoDSShell, TopAbs_FACE, M);
-  int ii;
-  for (ii=1; ii<=M.Extent(); ii++) {
-	  TopologyBridge *surface = OCCQueryEngine::occ_to_cgm(M(ii));
-	  result_list.append_unique(dynamic_cast<OCCSurface*>(surface));
-// Purpose       : Disconnect input surfaces from "this" shell
-// Special Notes :
-// Creator       : Corey Ernst
-// Creation Date : 08/31/04
-void OCCShell::disconnect_surfaces( DLIList<OCCSurface*> &surfs_to_disconnect )
-  for (int i = surfs_to_disconnect.size(); i--; )
-    OCCSurface* surface = surfs_to_disconnect.get_and_step();
-    if( mySurfs.move_to( dynamic_cast<Surface*>(surface) ) )
-      mySurfs.change_to(NULL);
-  mySurfs.remove_all_with_value( NULL );
 // Purpose       : Tear down topology
 // Special Notes :
@@ -183,7 +158,6 @@
 void OCCShell::disconnect_all_surfaces()
-  mySurfs.clean_out();
Modified: cgm/trunk/geom/OCC/OCCShell.hpp
--- cgm/trunk/geom/OCC/OCCShell.hpp	2007-11-28 18:40:47 UTC (rev 1428)
+++ cgm/trunk/geom/OCC/OCCShell.hpp	2007-11-28 19:21:34 UTC (rev 1429)
@@ -47,6 +47,7 @@
   virtual ~OCCShell() ;
     //- Destructor.
+  TopoDS_Shell* get_TopoDS_Shell() {return myTopoDSShell;}
   virtual CubitBox bounding_box() const;
   virtual GeometryQueryEngine*
More information about the cgma-dev mailing list
