[cgma-dev] r1427 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Wed Nov 28 08:45:44 CST 2007
Author: janehu
Date: 2007-11-28 08:45:44 -0600 (Wed, 28 Nov 2007)
New Revision: 1427
Modified:
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
Log:
Check to make sure when we export, we export in the original format of the Topo entities, which is if we just read in a Solid, we won't try to export a CompSolid which contains this Solid.
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2007-11-27 21:09:59 UTC (rev 1426)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2007-11-28 14:45:44 UTC (rev 1427)
@@ -918,8 +918,24 @@
//Add every shape to the compound
for (i = 0; i < OCC_bodies.size(); i++)
- TopoDS_Shape *shape = OCC_bodies.get_and_step()->get_TopoDS_Shape();
- B.Add(Co, *shape);
+ OCCBody* body = OCC_bodies.get_and_step();
+ TopoDS_CompSolid *shape = body->get_TopoDS_Shape();
+ //check if this body is build backwards from lump. if so,
+ //the body and its CompSolid doesn't have bounded relationship
+ //established. In this case, each individual lump of the body
+ // will be exported as TopoDS_Solid without a CompSolid
+ if(OCCMap->IsBound(*shape))
+ B.Add(Co, *shape);
+ else
+ DLIList<Lump*> lumps = body->lumps();
+ for(int i = 0; i < lumps.size(); i++)
+ OCCLump *occ_lump = (OCCLump *) lumps.get_and_step();
+ B.Add(Co, *(occ_lump->get_TopoDS_Solid()));
for (i = 0; i < OCC_surfaces.size(); i++)
@@ -992,7 +1008,7 @@
// suitable to popolate for a TopoDS_CompSolid or TopoDS_Compound shape.
TopExp_Explorer Ex;
for (Ex.Init(aShape, TopAbs_COMPSOLID); Ex.More(); Ex.Next())
- tblist.append(populate_topology_bridge(TopoDS::Solid(Ex.Current())));
+ tblist.append(populate_topology_bridge(TopoDS::CompSolid(Ex.Current())));
for (Ex.Init(aShape, TopAbs_SOLID, TopAbs_COMPSOLID); Ex.More(); Ex.Next())
tblist.append(populate_topology_bridge(TopoDS::Solid(Ex.Current()), CUBIT_TRUE));
More information about the cgma-dev
