[cgma-dev] r1358 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Wed Nov 7 12:04:01 CST 2007
Author: janehu
Date: 2007-11-07 12:04:01 -0600 (Wed, 07 Nov 2007)
New Revision: 1358
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
cgm/trunk/geom/OCC/OCCQueryEngine.hpp
Log:
Added populate_topoplogy_bridge for TopoDS_Shape, TopoDS_Solid, TopoDS_Shell, TopoDS_Face, TopoDS_Wire, TopoDS_Edge, TopoDS_Vertex in Query function.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2007-11-06 18:41:14 UTC (rev 1357)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2007-11-07 18:04:01 UTC (rev 1358)
@@ -105,7 +105,7 @@
TopoDS_Vertex theVertex = BRepBuilderAPI_MakeVertex(pt);
// Create a new PointACIS object
- return OCCQueryEngine::instance()->populate_topology_bridge_vertex( theVertex );
+ return OCCQueryEngine::instance()->populate_topology_bridge( theVertex );
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2007-11-06 18:41:14 UTC (rev 1357)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2007-11-07 18:04:01 UTC (rev 1358)
@@ -95,6 +95,7 @@
//#include "TopOpeBRepTool_ShapeTool.hxx"
//#include "BRepPrimAPI_MakePrism.hxx"
//#include "TopOpeBRep_Point2d.hxx"
+#include "TopTools_DataMapOfShapeInteger.hxx"
#include "BRepExtrema_DistShapeShape.hxx"
#include "BRepAlgoAPI_Section.hxx"
#include "BRepBuilderAPI_MakeEdge.hxx"
@@ -1302,166 +1303,168 @@
// CGMList->append(body);
imported_entities.append(body);
// OCCMap->Bind(*aShape, CGMList->where_is_item(body));
- populate_topology_bridge_solid(*aShape, imported_entities);
+ populate_topology_bridge(*aShape);
return CUBIT_SUCCESS;
-CubitStatus OCCQueryEngine::populate_topology_bridge_solid(TopoDS_Shape aShape, DLIList<TopologyBridge*> &imported_entities)
+BodySM* OCCQueryEngine::populate_topology_bridge(TopoDS_Shape aShape)
- TopExp_Explorer Ex;
- for (Ex.Init(aShape, TopAbs_SOLID); Ex.More(); Ex.Next()) {
- TopoDS_Solid *posolid = new TopoDS_Solid;
- *posolid = TopoDS::Solid(Ex.Current());
- OCCLump *lump;
- if (!OCCMap->IsBound(*posolid)) {
- printf("Adding solid\n");
- lump = new OCCLump(posolid);
- CGMList->append(lump);
-// imported_entities.append(lump);
- OCCMap->Bind(*posolid, CGMList->where_is_item(lump));
- populate_topology_bridge_shell(*posolid, imported_entities);
- } else {
- lump = (OCCLump*)((*CGMList)[OCCMap->Find(*posolid)]);
- return CUBIT_SUCCESS;
+ TopoDS_Shape *poshape = new TopoDS_Shape;
+ *poshape = aShape;
+ BodySM *body;
+ if (!OCCMap->IsBound(*poshape))
+ printf("Adding Shape\n");
+ iTotalTBCreated++;
+ body = new OCCBody(poshape);
+// CGMList->append(lump);
+// imported_entities.append(lump);
+ OCCMap->Bind(*poshape, iTotalTBCreated);
+ OccToCGM->insert(valType(iTotalTBCreated,
+ (TopologyBridge*)body));
+ else
+ int k = OCCMap->Find(*poshape);
+ body = (OCCBody*)(OccToCGM->find(k))->second;
+ TopExp_Explorer Ex;
+ for (Ex.Init(aShape, TopAbs_SOLID); Ex.More(); Ex.Next())
+ populate_topology_bridge(TopoDS::Solid(Ex.Current()));
+ return body;
-CubitStatus OCCQueryEngine::populate_topology_bridge_shell(TopoDS_Shape aShape, DLIList<TopologyBridge*> &imported_entities)
+Lump* OCCQueryEngine::populate_topology_bridge(TopoDS_Solid aShape)
+ TopoDS_Solid *posolid = new TopoDS_Solid;
+ *posolid = aShape;
+ OCCLump *lump;
+ if (!OCCMap->IsBound(*posolid))
+ printf("Adding solid\n");
+ lump = new OCCLump(posolid);
+ OCCMap->Bind(*posolid, iTotalTBCreated);
+ (TopologyBridge*)lump));
+ else
+ int k = OCCMap->Find(*posolid);
+ lump = (OCCLump*)(OccToCGM->find(k))->second;
TopExp_Explorer Ex;
- for (Ex.Init(aShape, TopAbs_SHELL); Ex.More(); Ex.Next()) {
- TopoDS_Shell *poshell = new TopoDS_Shell;
- *poshell = TopoDS::Shell(Ex.Current());
- OCCShell *shell;
- if (!OCCMap->IsBound(*poshell)) {
- printf("Adding shell\n");
- shell = new OCCShell(poshell);
- CGMList->append(shell);
-// imported_entities.append(shell);
- OCCMap->Bind(*poshell, CGMList->where_is_item(shell));
- populate_topology_bridge_face(*poshell, imported_entities);
- } else {
- shell = (OCCShell*)(*CGMList)[OCCMap->Find(*poshell)];
- shell->add_lump((OCCLump*)(*CGMList)[OCCMap->Find(aShape)]);
+ for (Ex.Init(aShape, TopAbs_SHELL); Ex.More(); Ex.Next())
+ populate_topology_bridge(TopoDS::Shell(Ex.Current()));
+ return lump;
-CubitStatus OCCQueryEngine::populate_topology_bridge_face(TopoDS_Shape aShape, DLIList<TopologyBridge*> &imported_entities)
+OCCShell* OCCQueryEngine::populate_topology_bridge(TopoDS_Shell aShape)
+ TopoDS_Shell *poshell = new TopoDS_Shell;
+ *poshell = aShape;
+ OCCShell *shell = new OCCShell(poshell);
+// CGMList->append(shell);
+// imported_entities.append(shell);
TopExp_Explorer Ex;
- for (Ex.Init(aShape, TopAbs_FACE); Ex.More(); Ex.Next()) {
- TopoDS_Face *poface = new TopoDS_Face;
- *poface = TopoDS::Face(Ex.Current());
- OCCSurface *surface;
- if (!OCCMap->IsBound(*poface)) {
- printf("Adding face\n");
-/* BRepAdaptor_Surface asurface(*poface);
- Bnd_Box aBox;
- double min[3], max[3];
- BndLib_AddSurface::Add(asurface, Precision::Approximation(), aBox);
- aBox.Get( min[0], min[1], min[2], max[0], max[1], max[2]);
- printf(". . . box: %lf %lf %lf, %lf %lf %lf\n", min[0], min[1], min[2], max[0], max[1], max[2]);*/
+ for (Ex.Init(aShape, TopAbs_FACE); Ex.More(); Ex.Next())
+ populate_topology_bridge(TopoDS::Face(Ex.Current()));
+ return shell;
- surface = new OCCSurface(poface);
- CGMList->append(surface);
+Surface* OCCQueryEngine::populate_topology_bridge(TopoDS_Face aShape)
+ TopoDS_Face *poface = new TopoDS_Face;
+ *poface = aShape;
+ OCCSurface *surface;
+ if (!OCCMap->IsBound(*poface))
+ printf("Adding face\n");
+ surface = new OCCSurface(poface);
+// CGMList->append(surface);
// imported_entities.append(surface);
- OCCMap->Bind(*poface, CGMList->where_is_item(surface));
- populate_topology_bridge_wire(*poface, imported_entities);
- } else {
- surface = (OCCSurface*)(*CGMList)[OCCMap->Find(*poface)];
- //surface->add_shell((OCCShell*)(*CGMList)[OCCMap->Find(aShape)]);
+ OCCMap->Bind(*poface, iTotalTBCreated);
+ (TopologyBridge*)surface));
+ else
+ int k = OCCMap->Find(*poface);
+ surface = (OCCSurface*)(OccToCGM->find(k))->second;
+ for (Ex.Init(aShape, TopAbs_WIRE); Ex.More(); Ex.Next())
+ populate_topology_bridge(TopoDS::Wire(Ex.Current()));
+ return surface;
-CubitStatus OCCQueryEngine::populate_topology_bridge_wire(TopoDS_Shape aShape, DLIList<TopologyBridge*> &imported_entities)
+OCCLoop* OCCQueryEngine::populate_topology_bridge(TopoDS_Wire aShape)
+ TopoDS_Wire *powire = new TopoDS_Wire;
+ *powire = aShape;
+ OCCLoop *loop = new OCCLoop(powire);
TopExp_Explorer Ex;
- for (Ex.Init(aShape, TopAbs_WIRE); Ex.More(); Ex.Next()) {
- TopoDS_Wire *powire = new TopoDS_Wire;
- *powire = TopoDS::Wire(Ex.Current());
- OCCLoop *loop;
- if (!OCCMap->IsBound(*powire)) {
- printf("Adding wire\n");
- loop = new OCCLoop(powire);
- CGMList->append(loop);
-// imported_entities.append(loop);
- OCCMap->Bind(*powire, CGMList->where_is_item(loop));
- populate_topology_bridge_edge(*powire, imported_entities);
- } else {
- loop = (OCCLoop*)(*CGMList)[OCCMap->Find(*powire)];
- loop->add_surface((OCCSurface*)(*CGMList)[OCCMap->Find(aShape)]);
+ for (Ex.Init(aShape, TopAbs_EDGE); Ex.More(); Ex.Next())
+ populate_topology_bridge(TopoDS::Edge(Ex.Current()));
+ return loop;
-CubitStatus OCCQueryEngine::populate_topology_bridge_edge(TopoDS_Shape aShape, DLIList<TopologyBridge*> &imported_entities)
+Curve* OCCQueryEngine::populate_topology_bridge(TopoDS_Edge aShape)
- TopTools_DataMapOfShapeInteger *Map, *Mapr;
- for (Ex.Init(aShape, TopAbs_EDGE); Ex.More(); Ex.Next()) {
- TopoDS_Edge *poedge = new TopoDS_Edge;
- *poedge = TopoDS::Edge(Ex.Current());
- Curve *curve;
- OCCCoEdge *coedge;
- TopoDS_Shape test = *poedge;
- if (poedge->Orientation() == TopAbs_FORWARD) {
- Map = OCCMap;
- Mapr = OCCMapr;
- } else if (poedge->Orientation() == TopAbs_REVERSED) {
- Map = OCCMapr;
- Mapr = OCCMap;
- } else {
- printf("Oooooop!\n");
- if (!Mapr->IsBound(*poedge)) {
- printf("Adding edge\n");
- curve = new OCCCurve(poedge);
- } else {
- curve = ((OCCCoEdge*)(*CGMList)[Mapr->Find(*poedge)])->curve();
- if (!Map->IsBound(*poedge)) {
- printf("Adding coedge\n");
- coedge = new OCCCoEdge(poedge, curve);
- CGMList->append(coedge);
-// CGMList->append(curve);
- Map->Bind(*poedge, CGMList->where_is_item(coedge));
- //populate_topology_bridge_vertex(*poedge, imported_entities, curve);
- } else {
- coedge = (OCCCoEdge*)(*CGMList)[Map->Find(*poedge)];
- coedge->add_loop((OCCLoop*)occ_to_cgm(aShape));
+ Curve *curve;
+ OCCCoEdge *coedge;
+ TopoDS_Edge *poedge = new TopoDS_Edge;
+ *poedge = aShape;
+ if (!OCCMap->IsBound(*poedge))
+ printf("Adding coedge\n");
+ curve = new OCCCurve(poedge);
+ coedge = new OCCCoEdge(poedge, curve);
+// CGMList->append(coedge);
+// CGMList->append(curve);
+ OCCMap->Bind(*poedge, iTotalTBCreated);
+ (TopologyBridge*)coedge));
+ else
+ int i = OCCMap->Find(*poedge);
+ coedge = (OCCCoEdge*)(OccToCGM->find(i))->second;
+ curve = coedge->curve();
+ for (Ex.Init(aShape, TopAbs_VERTEX); Ex.More(); Ex.Next())
+ populate_topology_bridge(TopoDS::Vertex(Ex.Current()));
+ return curve;
-Point* OCCQueryEngine::populate_topology_bridge_vertex(TopoDS_Shape aShape)
+Point* OCCQueryEngine::populate_topology_bridge(TopoDS_Vertex aShape)
OCCPoint *point;
- for (Ex.Init(aShape, TopAbs_VERTEX); Ex.More(); Ex.Next()) {
- TopoDS_Vertex *povertex = new TopoDS_Vertex;
- *povertex = TopoDS::Vertex(Ex.Current());
- if (!OCCMap->IsBound(*povertex))
- printf("Adding vertex\n");
- iTotalTBCreated++;
- point = new OCCPoint(povertex);
- CGMList->append(point);
-// imported_entities.append(point);
- OCCMap->Bind(*povertex, iTotalTBCreated);
- OccToCGM->insert(valType(iTotalTBCreated,
- (TopologyBridge*)point));
- else {
- int i = OCCMap->Find(*povertex);
- point = (OCCPoint*)(OccToCGM->find(i))->second;
+ TopoDS_Vertex *povertex = new TopoDS_Vertex;
+ *povertex = aShape;
+ if (!OCCMap->IsBound(*povertex))
+ printf("Adding vertex\n");
+ point = new OCCPoint(povertex);
+// CGMList->append(point);
+// imported_entities.append(point);
+ OCCMap->Bind(*povertex, iTotalTBCreated);
+ (TopologyBridge*)point));
+ else
+ int i = OCCMap->Find(*povertex);
+ point = (OCCPoint*)(OccToCGM->find(i))->second;
return point;
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.hpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.hpp 2007-11-06 18:41:14 UTC (rev 1357)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.hpp 2007-11-07 18:04:01 UTC (rev 1358)
@@ -32,7 +32,6 @@
#include "CubitFileIOWrapper.hpp"
#include "GeometryQueryEngine.hpp"
-#include <TopTools_DataMapOfShapeInteger.hxx>
#include <map>
// ********** END CUBIT INCLUDES **********
@@ -79,7 +78,15 @@
class OCCCoEdge;
class OCCCurve;
class OCCPoint;
+class TopTools_DataMapOfShapeInteger;
+class TopoDS_Vertex;
+class TopoDS_Edge;
+class TopoDS_Shape;
+class TopoDS_Wire;
+class TopoDS_Face;
+class TopoDS_Solid;
+class TopoDS_Shell;
// ********** END FORWARD DECLARATIONS **********
// ********** BEGIN MACRO DEFINITIONS **********
@@ -313,12 +320,11 @@
virtual CubitBoolean volumes_overlap (Lump *lump1, Lump *lump2 ) const ;
- CubitStatus populate_topology_bridge_solid(TopoDS_Shape aShape, DLIList<TopologyBridge*> &imported_entities);
- CubitStatus populate_topology_bridge_shell(TopoDS_Shape aShape, DLIList<TopologyBridge*> &imported_entities);
- CubitStatus populate_topology_bridge_face(TopoDS_Shape aShape, DLIList<TopologyBridge*> &imported_entities);
- CubitStatus populate_topology_bridge_wire(TopoDS_Shape aShape, DLIList<TopologyBridge*> &imported_entities);
- CubitStatus populate_topology_bridge_edge(TopoDS_Shape aShape, DLIList<TopologyBridge*> &imported_entities);
- Point* populate_topology_bridge_vertex(TopoDS_Shape aShape);
+ BodySM* populate_topology_bridge(TopoDS_Shape aShape);
+ Lump* populate_topology_bridge(TopoDS_Solid aShape);
+ Surface* populate_topology_bridge(TopoDS_Face aShape);
+ Curve* populate_topology_bridge(TopoDS_Edge aShape);
+ Point* populate_topology_bridge(TopoDS_Vertex aShape);
protected:
@@ -326,6 +332,9 @@
private:
+ OCCLoop* populate_topology_bridge(TopoDS_Wire aShape);
+ OCCShell* populate_topology_bridge(TopoDS_Shell aShape);
CubitStatus write_topology( FILE *file_ptr,
DLIList<OCCBody*> &facet_bodies,
DLIList<OCCLump*> &facet_lumps,
More information about the cgma-dev
