[cgma-dev] r1357 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov janehu at mcs.anl.gov
Tue Nov 6 12:41:14 CST 2007
Author: janehu
Date: 2007-11-06 12:41:14 -0600 (Tue, 06 Nov 2007)
New Revision: 1357
Modified:
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
   cgm/trunk/geom/OCC/OCCQueryEngine.cpp
   cgm/trunk/geom/OCC/OCCQueryEngine.hpp
Log:
Added line-body intersection query and entity deletion. Also introduce a OccToCGM map which holds int returned from OCC internal TopTools_DataMapOfShapeInteger as the key. This provides a back pointor of TopoDS_Shape to TopologyBridge.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2007-11-05 23:17:01 UTC (rev 1356)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2007-11-06 18:41:14 UTC (rev 1357)
@@ -15,6 +15,8 @@
 #include "config.h"
 #include "gp_Pnt.hxx"
+#include "TopoDS_Shape.hxx"
+#include "TopologyBridge.hpp"
 #include "OCCModifyEngine.hpp"
 #include "OCCQueryEngine.hpp"
 #include "CubitMessage.hpp"
@@ -94,13 +96,16 @@
 // Function   : make_Point
 // Member Type: PUBLIC
 // Description: make a geometric entity point
-// Author     : John Fowler
-// Date       : 10/02
+// Author     : Jane Hu
+// Date       : 10/07
 Point* OCCModifyEngine::make_Point( CubitVector const& point) const
-  OCCPoint *occ_pt = new OCCPoint(point);
-  return  CAST_TO(occ_pt, Point);
+  gp_Pnt pt = gp_Pnt( point.x(), point.y(), point.z());
+  TopoDS_Vertex theVertex = BRepBuilderAPI_MakeVertex(pt);
+  // Create a new PointACIS object
+  return OCCQueryEngine::instance()->populate_topology_bridge_vertex( theVertex );
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2007-11-05 23:17:01 UTC (rev 1356)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2007-11-06 18:41:14 UTC (rev 1357)
@@ -97,6 +97,8 @@
 //#include "TopOpeBRep_Point2d.hxx"
 #include "BRepExtrema_DistShapeShape.hxx"
 #include "BRepAlgoAPI_Section.hxx"
+#include "BRepBuilderAPI_MakeEdge.hxx"
+#include "gp_Lin.hxx"
 using namespace NCubitFile;
 OCCQueryEngine* OCCQueryEngine::instance_ = NULL;
@@ -109,6 +111,9 @@
 TopTools_DataMapOfShapeInteger *OCCQueryEngine::OCCMapr = new TopTools_DataMapOfShapeInteger;
 DLIList<TopologyBridge*> *OCCQueryEngine::CGMList = new DLIList<TopologyBridge*>;
+std::map<int, TopologyBridge*>* OccToCGM = new std::map<int, TopologyBridge*>;
+typedef std::map<int, TopologyBridge*>::value_type valType;
+int iTotalTBCreated = 0;
 // Description:
 // Author     :
@@ -525,7 +530,7 @@
                                             *(occ_curve1->get_TopoDS_Edge()),
                                             *(occ_curve2->get_TopoDS_Edge()));
-  distShapeShape.Perform();
+  //distShapeShape.Perform();
   if (!distShapeShape.IsDone())
      PRINT_ERROR("Cannot calculate the intersection points for the input curves.\n");
@@ -570,7 +575,7 @@
   BRepExtrema_DistShapeShape distShapeShape(*(occ_curve->get_TopoDS_Edge()),
                                             *(occ_surface->get_TopoDS_Face()));
      PRINT_ERROR("Cannot calculate the intersection points for the input curve and surface.\n");
@@ -639,7 +644,7 @@
   BRepExtrema_DistShapeShape distShapeShape(*shape1, *shape2);
@@ -1426,7 +1431,7 @@
 			CGMList->append(coedge);
 //			CGMList->append(curve);
 			Map->Bind(*poedge, CGMList->where_is_item(coedge));
-			populate_topology_bridge_vertex(*poedge, imported_entities, curve);
+			//populate_topology_bridge_vertex(*poedge, imported_entities, curve);
 		} else {
 			coedge = (OCCCoEdge*)(*CGMList)[Map->Find(*poedge)];
@@ -1435,36 +1440,41 @@
 	return CUBIT_SUCCESS;
-CubitStatus OCCQueryEngine::populate_topology_bridge_vertex(TopoDS_Shape aShape, DLIList<TopologyBridge*> &imported_entities, Curve *curve)
+Point* OCCQueryEngine::populate_topology_bridge_vertex(TopoDS_Shape aShape)
+	OCCPoint *point;
 	TopExp_Explorer Ex;
 	for (Ex.Init(aShape, TopAbs_VERTEX); Ex.More(); Ex.Next()) {
 		TopoDS_Vertex *povertex = new TopoDS_Vertex;
 		*povertex = TopoDS::Vertex(Ex.Current());
-		OCCPoint *point;
-		if (!OCCMap->IsBound(*povertex)) {
-			printf("Adding vertex\n");
-                        gp_Pnt pt = BRep_Tool::Pnt(*povertex);
-			point = new OCCPoint(pt);
-			CGMList->append(point);
-//			imported_entities.append(point);
-			OCCMap->Bind(*povertex, CGMList->where_is_item(point));
-		} else {
-			point = (OCCPoint*)(*CGMList)[OCCMap->Find(*povertex)];
+		if (!OCCMap->IsBound(*povertex))
+	 	  printf("Adding vertex\n");
+                  iTotalTBCreated++;
+	 	  point = new OCCPoint(povertex);
+		  CGMList->append(point);
+//		  imported_entities.append(point);
+		  OCCMap->Bind(*povertex, iTotalTBCreated);
+                  OccToCGM->insert(valType(iTotalTBCreated,
+                                          (TopologyBridge*)point));
+                else {
+                  int i = OCCMap->Find(*povertex);
+	 	  point = (OCCPoint*)(OccToCGM->find(i))->second;
-	return CUBIT_SUCCESS;
+	return point;
 TopologyBridge* OCCQueryEngine::occ_to_cgm(TopoDS_Shape shape)
-	if ((shape.ShapeType() != TopAbs_EDGE) || (shape.Orientation() == TopAbs_FORWARD)) return (*CGMList)[OCCMap->Find(shape)];
-	else return (*CGMList)[OCCMapr->Find(shape)];
-/*	if (OCCMap->IsBound(shape))*/ return (*CGMList)[OCCMap->Find(shape)];
-//	else return (*CGMList)[(*OCCMapt)[shape]];
+       if(!OCCMap->IsBound(shape))
+	 return (TopologyBridge*) NULL;
+       int k = OCCMap->Find(shape);
+       return (OccToCGM->find(k))->second;
 CubitStatus OCCQueryEngine::import_solid_model(FILE *file_ptr,
                                                  const char* /*file_type*/,
@@ -1585,13 +1595,27 @@
   TopoDS_Shape* shape = fbody->get_TopoDS_Shape();
+  if (!shape)
+    return CUBIT_FAILURE;
+  //remove the entry from the map
+  int k;
+  if(OCCMap->IsBound(*shape))
+    k = OCCMap->Find(*shape);
+    if(!OCCMap->UnBind(*shape))
+      PRINT_ERROR("The OccBody and TopoDS_Shape pair is not in the map!");
+    if(!OccToCGM->erase(k))
   // Remove the links between OCC and Cubit
   //  unhook_ENTITY_from_VGI(shape);
-  if (!shape)
-    return CUBIT_FAILURE;
+  delete shape;
+  delete bodysm;
-  delete shape;
@@ -1608,18 +1632,32 @@
 OCCQueryEngine::delete_solid_model_entities( Surface* surface ) const
   OCCSurface* fsurf = dynamic_cast<OCCSurface*>(surface);
-  if (!fsurf || fsurf->has_parent_shell())
+  if (!fsurf)
   TopoDS_Face* face = fsurf->get_TopoDS_Face();
+  if(!face)
+  int k;
+  if(OCCMap->IsBound(*face))
+    k = OCCMap->Find(*face);
+    if(!OCCMap->UnBind(*face))
+      PRINT_ERROR("The OccSurface and TopoDS_Face pair is not in the map!");
   //  unhook_ENTITY_from_VGI(face);
-  if(!face)
   delete face;
+  delete surface;
@@ -1636,29 +1674,30 @@
 OCCQueryEngine::delete_solid_model_entities( Curve* curve ) const
   OCCCurve* fcurve = dynamic_cast<OCCCurve*>(curve);
-  //if (!fcurve || fcurve->has_parent_coedge())
-  //  return CUBIT_FAILURE;
+  if (!fcurve )
-  OCCPoint* start = dynamic_cast<OCCPoint*>(fcurve->start_point());
-  OCCPoint*   end = dynamic_cast<OCCPoint*>(fcurve->end_point()  );
+  TopoDS_Edge * edge = fcurve->get_TopoDS_Edge();
+  if (!edge)
+  int k;
+  if(OCCMap->IsBound(*edge))
+    k = OCCMap->Find(*edge);
-  if (start == end )
-      end = NULL;
+    if(!OCCMap->UnBind(*edge))
+      PRINT_ERROR("The OccCurve and TopoDS_Edge pair is not in the map!");
-  if (start)
-    //start->disconnect_curve(fcurve);
-    //if (!start->has_parent_curve())
-    //  delete_solid_model_entities(start);
-  if (end)
-    //end->disconnect_curve(fcurve);
-    //if (!end->has_parent_curve())
-    //  delete_solid_model_entities(end);
+  // Remove the links between OCC and Cubit
+  //unhook_ENTITY_from_VGI(edge);
+  delete edge;
   delete curve;
@@ -1675,35 +1714,96 @@
 CubitStatus
 OCCQueryEngine::delete_solid_model_entities( Point* point ) const
-  //OCCPoint* fpoint = dynamic_cast<OCCPoint*>(point);
+  OCCPoint* fpoint = dynamic_cast<OCCPoint*>(point);
+  if (!fpoint)
+  TopoDS_Vertex *vertex = fpoint->get_TopoDS_Vertex();
+  if (!vertex)
+  int k;
+  if(OCCMap->IsBound(*vertex))
+    k = OCCMap->Find(*vertex);
+    if(!OCCMap->UnBind(*vertex))
+      PRINT_ERROR("The OccPoint and TopoDS_Vertex pair is not in the map!");
+  //unhook_ENTITY_from_VGI(vertex);
+  delete vertex;
   delete point;
-CubitStatus OCCQueryEngine::fire_ray(BodySM *,
-                                          const CubitVector &,
-                                          DLIList<double>&,
-                                          DLIList<GeometryEntity*> *) const
+CubitStatus OCCQueryEngine::fire_ray(BodySM * body,
+                                     const CubitVector &start,
+                                     const CubitVector &unit,
+                                     DLIList<double>& ray_parms,
+                                    DLIList<GeometryEntity*> *entity_list) const
-  PRINT_ERROR("OCCQueryEngine::fire_ray not yet implemented.\n");
+  CubitStatus status = CUBIT_SUCCESS;
   //- fire a ray at the specified body, returning the entities hit and
   //- the parameters along the ray; return CUBIT_FAILURE if error
+  // - line body intersection.
+  gp_Pnt p(start.x(), start.y(), start.z());
+  gp_Dir dir(unit.x(), unit.y(), unit.z());
+  gp_Lin L(p, dir);
+  TopoDS_Edge edge = BRepBuilderAPI_MakeEdge(L);
+  OCCBody *occBody = CAST_TO(body, OCCBody);
+  if (occBody == NULL)
+     PRINT_ERROR("Option not supported for non-occ based geometry.\n");
+  BRepExtrema_DistShapeShape distShapeShape(edge,
+					*(occBody->get_TopoDS_Shape()));
+  if (!distShapeShape.IsDone())
+     PRINT_ERROR("Cannot calculate the intersection points for the input body.\n");
+   if (distShapeShape.Value() < get_sme_resabs_tolerance())
+     int numPnt = distShapeShape.NbSolution();
+     for (int i = 1; i <= numPnt; i++)
+       double para;
+       distShapeShape.ParOnEdgeS1(i , para);
+       ray_parms.append(para);
+       TopoDS_Shape shape = distShapeShape.SupportOnShape2(i);
+       std::map<int,TopologyBridge*>::iterator it = OccToCGM->find(k);
+       TopologyBridge* tb = (*it).second;
+       entity_list->append((GeometryEntity*)tb);
+  return status;
 double OCCQueryEngine::get_sme_resabs_tolerance() const
-  PRINT_ERROR("OCCQueryEngine::get_sme_resabs_tolerance not yet implemented.\n");
+  PRINT_WARNING("OCC doesn't have its standard linear tolerance.\n");
+  return 1e-6;
 // Gets solid modeler's resolution absolute tolerance
 double OCCQueryEngine::set_sme_resabs_tolerance( double )
   PRINT_ERROR("OCCQueryEngine::set_sme_resabs_tolerance not yet implemented.\n");
+  return 0.0;
 CubitStatus OCCQueryEngine::set_int_option( const char* , int )
@@ -1817,7 +1917,7 @@
 //Author: jdfowle
 //Date: 12/15/03
-CubitStatus OCCQueryEngine::create_super_facet_bounding_box(
+CubitStatus OCCQueryEngine::create_super_bounding_box(
                                 DLIList<BodySM*>& body_list,
                                 CubitBox& super_box )
@@ -1828,47 +1928,13 @@
   body_list.reset();
   for ( i = 0; i < body_list.size(); i++ ) {
     bodySM = body_list.get_and_step();
-    create_facet_bounding_box(bodySM,super_box);
+    OCCBody* occBody = CAST_TO(bodySM, OCCBody);
+    super_box |= occBody->get_bounding_box();
   return status;
-//Function:   create_facet_bounding_box(PUBLIC)
-//Description: Find the bounding box of a BodySM
-//Author: jdfowle
-//Date: 12/15/03
-CubitStatus OCCQueryEngine::create_facet_bounding_box(
-                                BodySM* bodySM,
-                                CubitBox& bbox )
-  OCCBody *fbody_ptr;
-  int j;
-  DLIList<OCCSurface*> facet_surf_list;
-  DLIList<CubitFacet*> facet_list;
-  DLIList<CubitPoint*> point_list;
-  OCCSurface *facet_surface;
-  CubitBox surf_bbox, total_box;
-  CubitStatus status = CUBIT_FAILURE;
-    fbody_ptr = dynamic_cast<OCCBody *>(bodySM);
-    //fbody_ptr->get_surfaces(facet_surf_list);
-    for ( j = 0; j < facet_surf_list.size(); j++ ) {
-      facet_surface = facet_surf_list.get_and_step();
-      facet_list.clean_out();
-      point_list.clean_out();
-      //facet_surface->get_my_facets(facet_list,point_list);
-      //status = FacetDataUtil::get_bbox_of_points(point_list,surf_bbox);
-      if ( j == 0 ) total_box = surf_bbox;
-      else
-        total_box |= surf_bbox;
-  bbox |= total_box;
-  return status;
 const char* fqe_xform_err = "Transform not implemented for OCC geometry.\n";
 CubitStatus OCCQueryEngine::restore_transform( BodySM* body )
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.hpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.hpp	2007-11-05 23:17:01 UTC (rev 1356)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.hpp	2007-11-06 18:41:14 UTC (rev 1357)
@@ -277,12 +277,9 @@
   CubitStatus ensure_is_ascii_stl_file(FILE * fp, CubitBoolean &is_ascii);
   //- returns true in is_ascii if fp points to an ascii stl file
-CubitStatus create_super_facet_bounding_box(
+  CubitStatus create_super_bounding_box(
                                 CubitBox& super_box );
-CubitStatus create_facet_bounding_box(
-                                BodySM* bodySM,
-                                CubitBox& bbox );
   CubitStatus restore_transform( BodySM* body );
@@ -315,6 +312,14 @@
   static TopologyBridge* occ_to_cgm(TopoDS_Shape shape);
   virtual CubitBoolean volumes_overlap (Lump *lump1, Lump *lump2 ) const ;
+  CubitStatus populate_topology_bridge_solid(TopoDS_Shape aShape, DLIList<TopologyBridge*> &imported_entities);
+  CubitStatus populate_topology_bridge_shell(TopoDS_Shape aShape, DLIList<TopologyBridge*> &imported_entities);
+  CubitStatus populate_topology_bridge_face(TopoDS_Shape aShape, DLIList<TopologyBridge*> &imported_entities);
+  CubitStatus populate_topology_bridge_wire(TopoDS_Shape aShape, DLIList<TopologyBridge*> &imported_entities);
+  CubitStatus populate_topology_bridge_edge(TopoDS_Shape aShape, DLIList<TopologyBridge*> &imported_entities);
+  Point* populate_topology_bridge_vertex(TopoDS_Shape aShape);
 protected:
   OCCQueryEngine();
@@ -332,17 +337,11 @@
                               DLIList<OCCPoint*> &facet_points );
-  CubitStatus populate_topology_bridge_solid(TopoDS_Shape aShape, DLIList<TopologyBridge*> &imported_entities);
-  CubitStatus populate_topology_bridge_shell(TopoDS_Shape aShape, DLIList<TopologyBridge*> &imported_entities);
-  CubitStatus populate_topology_bridge_face(TopoDS_Shape aShape, DLIList<TopologyBridge*> &imported_entities);
-  CubitStatus populate_topology_bridge_wire(TopoDS_Shape aShape, DLIList<TopologyBridge*> &imported_entities);
-  CubitStatus populate_topology_bridge_edge(TopoDS_Shape aShape, DLIList<TopologyBridge*> &imported_entities);
-  CubitStatus populate_topology_bridge_vertex(TopoDS_Shape aShape, DLIList<TopologyBridge*> &imported_entities, Curve *curve);
   static TopTools_DataMapOfShapeInteger* OCCMap;
+  static std::map<int, TopologyBridge*>* OccToCGM;
   static TopTools_DataMapOfShapeInteger* OCCMapr;
   static DLIList<TopologyBridge*>* CGMList;
+  static int iTotalTBCreated ;
   static OCCQueryEngine* instance_;
     //- static pointer to unique instance of this class
More information about the cgma-dev mailing list
