[cgma-dev] r1440 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Thu Dec 6 13:00:43 CST 2007
Author: janehu
Date: 2007-12-06 13:00:43 -0600 (Thu, 06 Dec 2007)
New Revision: 1440
Modified:
cgm/trunk/geom/OCC/OCCBody.hpp
cgm/trunk/geom/OCC/OCCCurve.hpp
cgm/trunk/geom/OCC/OCCLoop.hpp
cgm/trunk/geom/OCC/OCCLump.cpp
cgm/trunk/geom/OCC/OCCLump.hpp
cgm/trunk/geom/OCC/OCCPoint.hpp
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
cgm/trunk/geom/OCC/OCCQueryEngine.hpp
cgm/trunk/geom/OCC/OCCShell.cpp
cgm/trunk/geom/OCC/OCCShell.hpp
cgm/trunk/geom/OCC/OCCSurface.cpp
cgm/trunk/geom/OCC/OCCSurface.hpp
Log:
Added mass_property for lump; Added geometry_type for Surface; Removed reverse_sence for surface; Added set_TopoDS_** for all types, this is because the translate call for OCC is sometimes 'applied to a duplicate of S' which can be accessed using Shape(). Testing on this part is not successful yet.
Modified: cgm/trunk/geom/OCC/OCCBody.hpp
--- cgm/trunk/geom/OCC/OCCBody.hpp 2007-12-05 19:09:43 UTC (rev 1439)
+++ cgm/trunk/geom/OCC/OCCBody.hpp 2007-12-06 19:00:43 UTC (rev 1440)
@@ -61,6 +61,7 @@
//- associated with the object.
TopoDS_CompSolid *get_TopoDS_Shape() {return myTopoDSShape; }
+ void set_TopoDS_Shape( TopoDS_CompSolid shape){*myTopoDSShape = shape;}
virtual CubitStatus get_transforms( CubitTransformMatrix &tfm );
//R CubitStatus
Modified: cgm/trunk/geom/OCC/OCCCurve.hpp
--- cgm/trunk/geom/OCC/OCCCurve.hpp 2007-12-05 19:09:43 UTC (rev 1439)
+++ cgm/trunk/geom/OCC/OCCCurve.hpp 2007-12-06 19:00:43 UTC (rev 1440)
@@ -318,6 +318,7 @@
TopoDS_Edge *get_TopoDS_Edge( )
{ return myTopoDSEdge; }
+ void set_TopoDS_Edge(TopoDS_Edge edge){*myTopoDSEdge = edge;}
protected:
Modified: cgm/trunk/geom/OCC/OCCLoop.hpp
--- cgm/trunk/geom/OCC/OCCLoop.hpp 2007-12-05 19:09:43 UTC (rev 1439)
+++ cgm/trunk/geom/OCC/OCCLoop.hpp 2007-12-06 19:00:43 UTC (rev 1440)
@@ -45,6 +45,7 @@
void disconnect_all_curves();
inline TopoDS_Wire* get_TopoDS_Wire() {return myTopoDSWire;}
+ void set_TopoDS_Wire(TopoDS_Wire loop){ *myTopoDSWire = loop;}
virtual ~OCCLoop() ;
//- The destructor
Modified: cgm/trunk/geom/OCC/OCCLump.cpp
--- cgm/trunk/geom/OCC/OCCLump.cpp 2007-12-05 19:09:43 UTC (rev 1439)
+++ cgm/trunk/geom/OCC/OCCLump.cpp 2007-12-06 19:00:43 UTC (rev 1440)
@@ -71,6 +71,27 @@
+// Purpose : Find centroid
+// Special Notes :
+// Author : Jane Hu
+// Creation Date : 12/06/07
+CubitStatus OCCLump::mass_properties( CubitVector& centroid,
+ double& volume )
+ GProp_GProps myProps;
+ BRepGProp::VolumeProperties(*myTopoDSSolid, myProps);
+ volume = myProps.Mass();
+ gp_Pnt pt = myProps.CentreOfMass();
+ centroid.set(pt.X(), pt.Y(), pt.Z());
+ return CUBIT_SUCCESS;
// Purpose : The purpose of this function is to append a
// attribute to the GE. The name is attached to the
// underlying solid model entity this one points to.
Modified: cgm/trunk/geom/OCC/OCCLump.hpp
--- cgm/trunk/geom/OCC/OCCLump.hpp 2007-12-05 19:09:43 UTC (rev 1439)
+++ cgm/trunk/geom/OCC/OCCLump.hpp 2007-12-06 19:00:43 UTC (rev 1440)
@@ -54,6 +54,7 @@
{myBodyPtr = new_body;}
TopoDS_Solid *get_TopoDS_Solid(){ return myTopoDSSolid; }
+ void set_TopoDS_Solid(TopoDS_Solid solid) {*myTopoDSSolid = solid;}
virtual void append_simple_attribute_virt(CubitSimpleAttrib*);
//R void
Modified: cgm/trunk/geom/OCC/OCCPoint.hpp
--- cgm/trunk/geom/OCC/OCCPoint.hpp 2007-12-05 19:09:43 UTC (rev 1439)
+++ cgm/trunk/geom/OCC/OCCPoint.hpp 2007-12-06 19:00:43 UTC (rev 1440)
@@ -63,6 +63,7 @@
//- The destructor
TopoDS_Vertex *get_TopoDS_Vertex(){return myTopoDSVertex; }
+ void set_TopoDS_Vertex(TopoDS_Vertex vertex){*myTopoDSVertex = vertex;}
//R void
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2007-12-05 19:09:43 UTC (rev 1439)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2007-12-06 19:00:43 UTC (rev 1440)
@@ -109,17 +109,9 @@
const int OCCQueryEngine::OCCQE_MINOR_VERSION = 2;
const int OCCQueryEngine::OCCQE_SUBMINOR_VERSION = 0;
-TopTools_DataMapOfShapeInteger *OCCMap = new TopTools_DataMapOfShapeInteger;
-std::map<int, TopologyBridge*>* OccToCGM = new std::map<int, TopologyBridge*>;
-DLIList<OCCBody*> *BodyList = new DLIList<OCCBody*>;
-DLIList<OCCSurface*> *SurfaceList = new DLIList<OCCSurface*>;
-DLIList<OCCCurve*> *CurveList = new DLIList<OCCCurve*>;
typedef std::map<int, TopologyBridge*>::value_type valType;
-int iTotalTBCreated = 0;
-CubitBoolean *PRINT_RESULT = CUBIT_FALSE;
+int OCCQueryEngine::iTotalTBCreated = 0;
+CubitBoolean OCCQueryEngine::PRINT_RESULT = CUBIT_FALSE;
// Description:
// Author :
@@ -141,6 +133,12 @@
OCCQueryEngine::OCCQueryEngine()
GeometryQueryTool::instance()->add_gqe( this );
+ OCCMap = new TopTools_DataMapOfShapeInteger;
+ OccToCGM = new std::map<int, TopologyBridge*>;
+ BodyList = new DLIList<OCCBody*>;
+ SurfaceList = new DLIList<OCCSurface*>;
+ CurveList = new DLIList<OCCCurve*>;
@@ -998,7 +996,7 @@
BRep_Builder aBuilder;
Standard_Boolean result = BRepTools::Read(*aShape, (char*) file_name, aBuilder);
if (result==0) return CUBIT_FAILURE;
- *PRINT_RESULT = print_results;
+ PRINT_RESULT = print_results;
imported_entities = populate_topology_bridge(*aShape);
@@ -1039,7 +1037,7 @@
OCCBody *body;
if (!OCCMap->IsBound(*posolid))
- if(*PRINT_RESULT)
+ if(PRINT_RESULT)
PRINT_INFO("Adding Bodies.\n");
(iTotalTBCreated)++;
body = new OCCBody(posolid);
@@ -1075,7 +1073,7 @@
OCCBody *body;
- if(*PRINT_RESULT)
+ if(PRINT_RESULT)
PRINT_INFO("Adding solids.\n");
iTotalTBCreated++;
lump = new OCCLump(posolid);
@@ -1109,7 +1107,7 @@
OCCShell *shell ;
if (!OCCMap->IsBound(*poshell))
- if(*PRINT_RESULT)
+ if(PRINT_RESULT)
PRINT_INFO("Adding shells.\n");
iTotalTBCreated++;
shell = new OCCShell(poshell);
@@ -1136,7 +1134,7 @@
OCCSurface *surface;
if (!OCCMap->IsBound(*poface))
- if(*PRINT_RESULT)
+ if(PRINT_RESULT)
PRINT_INFO("Adding faces.\n");
iTotalTBCreated++;
surface = new OCCSurface(poface);
@@ -1165,7 +1163,7 @@
OCCLoop *loop ;
if (!OCCMap->IsBound(*powire))
- if(*PRINT_RESULT)
+ if(PRINT_RESULT)
PRINT_INFO("Adding loops.\n");
iTotalTBCreated++;
loop = new OCCLoop(powire);
@@ -1202,7 +1200,7 @@
*poedge = aShape;
if (!OCCMap->IsBound(*poedge))
- if(*PRINT_RESULT)
+ if(PRINT_RESULT)
PRINT_INFO("Adding edges.\n");
iTotalTBCreated++;
curve = new OCCCurve(poedge);
@@ -1228,9 +1226,9 @@
OCCPoint *point;
TopoDS_Vertex *povertex = new TopoDS_Vertex;
*povertex = aShape;
- if (!OCCMap->IsBound(*povertex))
+ if (iTotalTBCreated == 0 || !OCCMap->IsBound(*povertex))
- if(*PRINT_RESULT)
+ if(PRINT_RESULT)
PRINT_INFO("Adding vertices.\n");
iTotalTBCreated++;
point = new OCCPoint(povertex);
@@ -1746,10 +1744,85 @@
gp_Trsf aTrsf;
aTrsf.SetTranslation(aVec);
- BRepBuilderAPI_Transform aBRepTrsf(*shape, aTrsf);
+ BRepBuilderAPI_Transform aBRepTrsf( aTrsf);
+ aBRepTrsf.Perform(*shape);
+ TopoDS_Shape translated_shape = aBRepTrsf.Shape();
+ update_entity_shape(entity, &translated_shape);
+CubitStatus OCCQueryEngine::update_entity_shape(GeometryEntity* entity_ptr,
+ TopoDS_Shape *shape)
+ if (OCCBody *body_ptr = CAST_TO( entity_ptr, OCCBody))
+ TopoDS_CompSolid* theShape = (TopoDS_CompSolid*) shape;
+ if (!theShape)
+ PRINT_ERROR("Entity and TopoDS_Shape don't match.\n" );
+ return CUBIT_FAILURE;
+ body_ptr->set_TopoDS_Shape(*theShape);
+ else if (OCCLump * lump_ptr = CAST_TO( entity_ptr,OCCLump))
+ TopoDS_Solid * theSolid = (TopoDS_Solid *) shape;
+ if(theSolid)
+ lump_ptr->set_TopoDS_Solid(*theSolid);
+ else
+ else if( OCCSurface *surface_ptr = CAST_TO( entity_ptr, OCCSurface))
+ TopoDS_Face *theFace = (TopoDS_Face *)shape;
+ if(!theFace)
+ surface_ptr->set_TopoDS_Face(*theFace);
+ else if( OCCCurve *curve_ptr = CAST_TO( entity_ptr, OCCCurve))
+ TopoDS_Edge *theEdge = (TopoDS_Edge *) shape;
+ if (!theEdge)
+ curve_ptr->set_TopoDS_Edge(*theEdge);
+ else if( OCCPoint *point_ptr = CAST_TO( entity_ptr, OCCPoint))
+ TopoDS_Vertex *thePoint = (TopoDS_Vertex*) shape;
+ if (!thePoint)
+ point_ptr->set_TopoDS_Vertex(*thePoint);
+ PRINT_ERROR("Non-OCC TopologyBridge at %s:%d.\n", __FILE__, __LINE__ );
//a is angular value of rotation in radians
CubitStatus OCCQueryEngine::rotate( GeometryEntity* entity,
const CubitVector& v, double a )
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.hpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.hpp 2007-12-05 19:09:43 UTC (rev 1439)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.hpp 2007-12-06 19:00:43 UTC (rev 1440)
@@ -290,6 +290,9 @@
DLIList<BodySM*>& body_list,
CubitBox& super_box );
+ CubitStatus update_entity_shape(GeometryEntity* entity_ptr,
+ TopoDS_Shape *shape);
CubitStatus translate( BodySM* body, const CubitVector& offset );
CubitStatus rotate ( BodySM* body, const CubitVector& axis, double angle );
CubitStatus scale ( BodySM* body, double factor );
@@ -349,8 +352,8 @@
DLIList<OCCCurve*> &facet_curves,
DLIList<OCCPoint*> &facet_points );
- int iTotalTBCreated ;
- CubitBoolean *PRINT_RESULT;
+ static int iTotalTBCreated ;
+ static CubitBoolean PRINT_RESULT;
static OCCQueryEngine* instance_;
//- static pointer to unique instance of this class
Modified: cgm/trunk/geom/OCC/OCCShell.cpp
--- cgm/trunk/geom/OCC/OCCShell.cpp 2007-12-05 19:09:43 UTC (rev 1439)
+++ cgm/trunk/geom/OCC/OCCShell.cpp 2007-12-06 19:00:43 UTC (rev 1440)
@@ -65,27 +65,7 @@
-// Purpose : Get the bounding box of the object.
-// Special Notes :
-CubitBox OCCShell::bounding_box() const
- CubitBox cBox;
- DLIList<TopologyBridge*> surfs;
- get_children_virt(surfs);
- for(int i = 0; i < surfs.size(); i ++)
- OCCSurface* occ_surf = CAST_TO(surfs.get_and_step(), OCCSurface);
- cBox |= occ_surf->bounding_box();
- return cBox;
// Purpose : Get geometry modeling engine: OCCQueryEngine
// Special Notes :
Modified: cgm/trunk/geom/OCC/OCCShell.hpp
--- cgm/trunk/geom/OCC/OCCShell.hpp 2007-12-05 19:09:43 UTC (rev 1439)
+++ cgm/trunk/geom/OCC/OCCShell.hpp 2007-12-06 19:00:43 UTC (rev 1440)
@@ -47,8 +47,8 @@
//- Destructor.
TopoDS_Shell* get_TopoDS_Shell() {return myTopoDSShell;}
- virtual CubitBox bounding_box() const;
+ void set_TopoDS_Shell(TopoDS_Shell shell){*myTopoDSShell = shell;}
virtual GeometryQueryEngine*
get_geometry_query_engine() const;
//R GeometryQueryEngine*
Modified: cgm/trunk/geom/OCC/OCCSurface.cpp
--- cgm/trunk/geom/OCC/OCCSurface.cpp 2007-12-05 19:09:43 UTC (rev 1439)
+++ cgm/trunk/geom/OCC/OCCSurface.cpp 2007-12-06 19:00:43 UTC (rev 1440)
@@ -166,6 +166,46 @@
+// Purpose : Returns a surface type ID -- the values of these are
+// determined by OCC.
+// Special Notes :
+// This code is very ACIS-specific and could change with
+// new versions of ACIS. There are #defines for the
+// various surface type ID's. These are defined in the
+// header files of each of the specific surface classes
+// in ACIS.
+// Creator : Jane HU
+GeometryType OCCSurface::geometry_type()
+ BRepAdaptor_Surface asurface(*myTopoDSFace);
+ if (asurface.GetType() == GeomAbs_BezierSurface)
+ return BEZIER_SURFACE_TYPE;
+ if (asurface.GetType() == GeomAbs_BSplineSurface)
+ return SPLINE_SURFACE_TYPE;
+ if (asurface.GetType() == GeomAbs_Plane)
+ return PLANE_SURFACE_TYPE;
+ if (asurface.GetType() == GeomAbs_Cylinder ||
+ asurface.GetType() == GeomAbs_Cone)
+ return CONE_SURFACE_TYPE;
+ if (asurface.GetType() == GeomAbs_Sphere)
+ return SPHERE_SURFACE_TYPE;
+ if (asurface.GetType() == GeomAbs_Torus)
+ return TORUS_SURFACE_TYPE;
+ if (asurface.GetType() == GeomAbs_SurfaceOfRevolution)
+ return REVOLUTION_SURFACE_TYPE;
+ if (asurface.GetType() == GeomAbs_SurfaceOfExtrusion)
+ return EXTRUSION_SURFACE_TYPE;
+ if (asurface.GetType() == GeomAbs_OffsetSurface)
+ return OFFSET_SURFACE_TYPE;
+ return UNDEFINED_SURFACE_TYPE;
// Special Notes :
Modified: cgm/trunk/geom/OCC/OCCSurface.hpp
--- cgm/trunk/geom/OCC/OCCSurface.hpp 2007-12-05 19:09:43 UTC (rev 1439)
+++ cgm/trunk/geom/OCC/OCCSurface.hpp 2007-12-06 19:00:43 UTC (rev 1440)
@@ -290,6 +290,7 @@
//- values.
TopoDS_Face *get_TopoDS_Face(){return myTopoDSFace;}
+ void set_TopoDS_Face(TopoDS_Face face) {*myTopoDSFace = face;}
void get_loops(DLIList<OCCLoop*>&);
@@ -364,12 +365,6 @@
virtual CubitSense get_geometry_sense();
//- Return the relative surface sense. (see below)
- virtual void reverse_sense();
- //- Switch the sense of this Surface wrt the RefFace that owns it:
- //- For Facet, this means switch the sense of the RefFace that
- //- owns this Surface with respect to the positive sense of the
- //- first FACE in FACEPtrList_.
CubitStatus save_attribs( FILE* file_ptr );
// Write FactAttribs out to file
More information about the cgma-dev
